查看: 1647|回復: 0
51單片機RC522開發包
ID:864715 發表于 2021-6-6 22:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <intrins.h>
#include "reg52.h"
#include "main.h"
#include "mfrc522.h"
#include <string.h>
#define MAXRLEN 18
//功    能:尋卡
//參數說明: req_code[IN]:尋卡方式
//                0x52 = 尋感應區內所有符合14443A標準的卡
//                0x26 = 尋未進入休眠狀態的卡
//          pTagType[OUT]:卡片類型代碼
//                0x4400 = Mifare_UltraLight
//                0x0400 = Mifare_One(S50)
//                0x0200 = Mifare_One(S70)
//                0x0800 = Mifare_Pro(X)
//                0x4403 = Mifare_DESFire
//返    回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
   char status;
   unsigned int  unLen;
   unsigned char ucComMF522Buf[MAXRLEN];
//  unsigned char xTest ;
   ClearBitMask(Status2Reg,0x08);
   WriteRawRC(BitFramingReg,0x07);
//  xTest = ReadRawRC(BitFramingReg);
//  if(xTest == 0x07 )
//   { LED_GREEN  =0 ;}
// else {LED_GREEN =1 ;while(1){}}
   SetBitMask(TxControlReg,0x03);
   ucComMF522Buf[0] = req_code;
   status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
//     if(status  == MI_OK )
//   else {LED_GREEN =1 ;}
   if ((status == MI_OK) && (unLen == 0x10))
       *pTagType     = ucComMF522Buf[0];
       *(pTagType+1) = ucComMF522Buf[1];
   {   status = MI_ERR;   }
   return status;
//功    能:防沖撞
//參數說明: pSnr[OUT]:卡片序列號,4字節
//返    回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
    char status;
    unsigned char i,snr_check=0;
    unsigned int  unLen;
    WriteRawRC(BitFramingReg,0x00);
    ClearBitMask(CollReg,0x80);
    ucComMF522Buf[0] = PICC_ANTICOLL1;
    ucComMF522Buf[1] = 0x20;
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
    if (status == MI_OK)
             for (i=0; i<4; i++)
             *(pSnr+i)  = ucComMF522Buf[ i];
             snr_check ^= ucComMF522Buf[ i];
         if (snr_check != ucComMF522Buf[ i])
    SetBitMask(CollReg,0x80);
    return status;
//功    能:選定卡片
//參數說明: pSnr[IN]:卡片序列號,4字節
//返    回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
    char status;
    unsigned char i;
    unsigned int  unLen;
    ucComMF522Buf[1] = 0x70;
    ucComMF522Buf[6] = 0;
    for (i=0; i<4; i++)
            ucComMF522Buf[i+2] = *(pSnr+i);
            ucComMF522Buf[6]  ^= *(pSnr+i);
    CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x18))
    {   status = MI_OK;  }
    return status;
//功    能:驗證卡片密碼
//參數說明: auth_mode[IN]: 密碼驗證模式
//                 0x60 = 驗證A密鑰
//                 0x61 = 驗證B密鑰
//          addr[IN]:塊地址
//          pKey[IN]:密碼
//          pSnr[IN]:卡片序列號,4字節
//返    回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
    char status;
    unsigned int  unLen;
    unsigned char i,ucComMF522Buf[MAXRLEN];
    ucComMF522Buf[0] = auth_mode;
    ucComMF522Buf[1] = addr;
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+2] = *(pKey+i);   }
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+8] = *(pSnr+i);   }
//   memcpy(&ucComMF522Buf[2], pKey, 6);
//   memcpy(&ucComMF522Buf[8], pSnr, 4);
    status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
    if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
    return status;
//功    能:讀取M1卡一塊數據
//參數說明: addr[IN]:塊地址
//          pData[OUT]:讀出的數據,16字節
//返    回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_READ;
    CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x90))
//   {   memcpy(pData, ucComMF522Buf, 16);   }
        for (i=0; i<16; i++)
        {    *(pData+i) = ucComMF522Buf[ i];   }
    return status;
//功    能:寫數據到M1卡一塊
//          pData[IN]:寫入的數據,16字節
//返    回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_WRITE;
    if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
        //memcpy(ucComMF522Buf, pData, 16);
        {    ucComMF522Buf[ i] = *(pData+i);   }
        CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
    return status;
//功    能:命令卡片進入休眠狀態
//返    回: 成功返回MI_OK
char PcdHalt(void)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_HALT;
    ucComMF522Buf[1] = 0;
    return MI_OK;
//用MF522計算CRC16函數
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
    unsigned char i,n;
    ClearBitMask(DivIrqReg,0x04);
    WriteRawRC(CommandReg,PCD_IDLE);
    SetBitMask(FIFOLevelReg,0x80);
    for (i=0; i<len; i++)
    {   WriteRawRC(FIFODataReg, *(pIndata+i));   }
    WriteRawRC(CommandReg, PCD_CALCCRC);
    i = 0xFF;
    do
        n = ReadRawRC(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04));
    pOutData[0] = ReadRawRC(CRCResultRegL);
    pOutData[1] = ReadRawRC(CRCResultRegM);
//功    能:復位RC522
//返    回: 成功返回MI_OK
char PcdReset(void)
    MF522_RST=1;
    _nop_();
    MF522_RST=0;
    _nop_();
    MF522_RST=1;
     _nop_();
    WriteRawRC(CommandReg,PCD_RESETPHASE);
    _nop_();
    WriteRawRC(ModeReg,0x3D);            //和Mifare卡通訊,CRC初始值0x6363
    WriteRawRC(TReloadRegL,30);
    WriteRawRC(TReloadRegH,0);
    WriteRawRC(TModeReg,0x8D);
    WriteRawRC(TPrescalerReg,0x3E);
    WriteRawRC(TxAutoReg,0x40);
    return MI_OK;
//設置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
   if (type == 'A')                     //ISO14443_A
/*     WriteRawRC(CommandReg,0x20);    //as default
       WriteRawRC(ComIEnReg,0x80);     //as default
       WriteRawRC(DivlEnReg,0x0);      //as default
           WriteRawRC(ComIrqReg,0x04);     //as default
           WriteRawRC(DivIrqReg,0x0);      //as default
           WriteRawRC(Status2Reg,0x0);//80    //trun off temperature sensor
           WriteRawRC(WaterLevelReg,0x08); //as default
       WriteRawRC(ControlReg,0x20);    //as default
           WriteRawRC(CollReg,0x80);    //as default
       WriteRawRC(ModeReg,0x3D);//3F
/*           WriteRawRC(TxModeReg,0x0);      //as default???
           WriteRawRC(RxModeReg,0x0);      //as default???
           WriteRawRC(TxControlReg,0x80);  //as default???
           WriteRawRC(TxSelReg,0x10);      //as default???
       WriteRawRC(RxSelReg,0x86);//84
//      WriteRawRC(RxThresholdReg,0x84);//as default
//      WriteRawRC(DemodReg,0x4D);      //as default
//      WriteRawRC(ModWidthReg,0x13);//26
       WriteRawRC(RFCfgReg,0x7F);   //4F
        /*   WriteRawRC(GsNReg,0x88);        //as default???
           WriteRawRC(CWGsCfgReg,0x20);    //as default???
       WriteRawRC(ModGsCfgReg,0x20);   //as default???
              WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
  //     PcdSetTmo(106);
                            delay_10ms(1);
       PcdAntennaOn();
   else{ return -1; }
   return MI_OK;
//功    能:讀RC632寄存器
//參數說明:Address[IN]:寄存器地址
//返    回:讀出的值
unsigned char ReadRawRC(unsigned char Address)
     unsigned char i, ucAddr;
     unsigned char ucResult=0;
     MF522_SCK = 0;
     MF522_NSS = 0;
     ucAddr = ((Address<<1)&0x7E)|0x80;
     for(i=8;i>0;i--)
         MF522_SI = ((ucAddr&0x80)==0x80);
         MF522_SCK = 1;
         ucAddr <<= 1;
         MF522_SCK = 0;
     for(i=8;i>0;i--)
         MF522_SCK = 1;
         ucResult <<= 1;
         ucResult|=(bit)MF522_SO;
         MF522_SCK = 0;
     MF522_NSS = 1;
     MF522_SCK = 1;
     return ucResult;
//功    能:寫RC632寄存器
//          value[IN]:寫入的值
void WriteRawRC(unsigned char Address, unsigned char value)
    MF522_SCK = 0;
    MF522_NSS = 0;
    ucAddr = ((Address<<1)&0x7E);
    for(i=8;i>0;i--)
        MF522_SCK = 1;
        ucAddr <<= 1;
        MF522_SCK = 0;
    for(i=8;i>0;i--)
        MF522_SI = ((value&0x80)==0x80);
        MF522_SCK = 1;
        value <<= 1;
        MF522_SCK = 0;
    MF522_NSS = 1;
    MF522_SCK = 1;
//功    能:置RC522寄存器位
//參數說明:reg[IN]:寄存器地址
//          mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    tmp = ReadRawRC(reg);
    WriteRawRC(reg,tmp | mask);  // set bit mask
//功    能:清RC522寄存器位
//          mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    WriteRawRC(reg, tmp & ~mask);  // clear bit mask
//功    能:通過RC522和ISO14443卡通訊
//參數說明:Command[IN]:RC522命令字
//          pInData[IN]:通過RC522發送到卡片的數據
//          InLenByte[IN]:發送數據的字節長度
//          pOutData[OUT]:接收到的卡片返回數據
//          *pOutLenBit[OUT]:返回數據的位長度
char PcdComMF522(unsigned char Command,
                 unsigned char *pInData,
                 unsigned char InLenByte,
                 unsigned char *pOutData,
                 unsigned int  *pOutLenBit)
    char status = MI_ERR;
    unsigned char irqEn   = 0x00;
    unsigned char waitFor = 0x00;
    unsigned char lastBits;
    unsigned char n;
    unsigned int i;
    switch (Command)
       case PCD_AUTHENT:
          irqEn   = 0x12;
          waitFor = 0x10;
          break;
       case PCD_TRANSCEIVE:
          irqEn   = 0x77;
          waitFor = 0x30;
          break;
       default:
         break;
    WriteRawRC(ComIEnReg,irqEn|0x80);
    ClearBitMask(ComIrqReg,0x80);
    for (i=0; i<InLenByte; i++)
    {   WriteRawRC(FIFODataReg, pInData[ i]);    }
    WriteRawRC(CommandReg, Command);
    if (Command == PCD_TRANSCEIVE)
    {    SetBitMask(BitFramingReg,0x80);  }
//    i = 600;//根據時鐘頻率調整,操作M1卡最大等待時間25ms
i = 2000;
    do
         n = ReadRawRC(ComIrqReg);
         i--;
    while ((i!=0) && !(n&0x01) && !(n&waitFor));
    ClearBitMask(BitFramingReg,0x80);
    if (i!=0)
         if(!(ReadRawRC(ErrorReg)&0x1B))
             status = MI_OK;
             if (n & irqEn & 0x01)
             {   status = MI_NOTAGERR;   }
                       n = ReadRawRC(FIFOLevelReg);
                      lastBits = ReadRawRC(ControlReg) & 0x07;
                if (lastBits)
                {   *pOutLenBit = (n-1)*8 + lastBits;   }
                {   *pOutLenBit = n*8;   }
                if (n == 0)
                {   n = 1;    }
                if (n > MAXRLEN)
                {   n = MAXRLEN;   }
                for (i=0; i<n; i++)
                {   pOutData[ i] = ReadRawRC(FIFODataReg);    }
   SetBitMask(ControlReg,0x80);           // stop timer now
   return status;
//開啟天線
//每次啟動或關閉天險發射之間應至少有1ms的間隔
void PcdAntennaOn()
    unsigned char i;
    i = ReadRawRC(TxControlReg);
    if (!(i & 0x03))
        SetBitMask(TxControlReg, 0x03);
//關閉天線
void PcdAntennaOff()
    ClearBitMask(TxControlReg, 0x03);
//功    能:扣款和充值
//參數說明: dd_mode[IN]:命令字
//               0xC0 = 扣款
//               0xC1 = 充值
//          addr[IN]:錢包地址
//          pValue[IN]:4字節增(減)值,低位在前
//返    回: 成功返回MI_OK
char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = dd_mode;
        memcpy(ucComMF522Buf, pValue, 4);
//       for (i=0; i<16; i++)
//       {    ucComMF522Buf[ i] = *(pValue+i);   }
        CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
        unLen = 0;
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
        if (status != MI_ERR)
        {    status = MI_OK;    }
        ucComMF522Buf[0] = PICC_TRANSFER;
    return status;
//功    能:備份錢包
//參數說明: sourceaddr[IN]:源地址
//          goaladdr[IN]:目標地址
//返    回: 成功返回MI_OK
char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_RESTORE;
    ucComMF522Buf[1] = sourceaddr;
        ucComMF522Buf[0] = 0;
        ucComMF522Buf[2] = 0;
        ucComMF522Buf[3] = 0;
        {    status = MI_OK;    }
    if (status != MI_OK)
    {    return MI_ERR;   }
    ucComMF522Buf[1] = goaladdr;
    return status;
// Delay 10ms
void delay_10ms(unsigned int _10ms)
#ifndef NO_TIMER2
    RCAP2LH = RCAP2_10ms;
    T2LH    = RCAP2_10ms;
    TR2 = TRUE;
    while (_10ms--)
            while (!TF2);
            TF2 = FALSE;
    TR2 = FALSE;
#else
    while (_10ms--)
            delay_50us(19);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid )
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(19);
            if (CmdValid)
                return;
#endif
51讀寫卡程序.zip
48.69 KB, 下載次數: 25, 下載積分: 黑幣 -5
主站蜘蛛池模板: 国产一级片在线播放 | 精品国产欧美一区二区三区成人 | 久久私人影院 | 99热最新 | 九九热在线观看 | 天堂资源网 | 日韩大片在线观看 | 国产无遮挡又黄又爽又色 | 涩涩视频免费观看 | 麻豆视频一区二区 | 日韩成人精品视频 | 日韩久久精品 | a级片免费观看 | av手机天堂网 | 黄色在线免费观看视频 | 久久九 | 欧美日韩免费在线观看 | 日韩在线精品视频 | 草草在线观看 | 亚洲视频一区在线观看 | 免费看大片a | av免费在线观看网站 | 午夜av在线 | 久久午夜影院 | 欧美日韩免费一区二区三区 | 午夜精品影院 | 亚洲第一第二区 | 天堂国产| 亚洲午夜久久 | 欧美成人精品一区二区三区在线看 | 老女人毛片 | 国产精品av一区二区 | 亚洲精品成人网 | 成人午夜又粗又硬又大 | 亚洲视频区 | 亚洲精品一区二区三区精华液 | 成人在线一区二区 | xxxx性欧美| 日韩在线免费视频 | 亚洲精选一区 | 国产区一区 |
