查看: 2836|回復: 0
bascom avr利用can通信控制伺服電機上使能
ID:941018 發表于 2021-6-20 18:36 | 顯示全部樓層 |閱讀模式
本帖最后由 紅日888 于 2021-6-20 21:34 編輯
'此列子為串口轉can通信控制伺服電機上使能的列子
$regfile = "m128def.dat"                                    '單片機型號頭文件
$crystal = 8000000                                          '晶振頻率
$baud = 19200
$hwstack = 256
$swstack = 256
$framesize = 256
Declare Sub Send(byval Str_code As String)
Declare Function Can_data(byval Std_mode As Integer , Byval Data_length As Integer , _
                           Byval Func_code As String , Byval Node_id As String , _
                           Byval Str_data As String) As String
Declare Sub Set_enable(byval Node_id As String , Byval Ctrl_mode As Integer , Byval Value As Integer)
Config Portd = Output
Const Std_frame = 1                                         '標準幀
Const Ext_frame = 0                                         '擴展幀
Const Position_mode = 0                                     '位置模式
Const Speed_mode = 1                                        '速度模式
Dim Can_code As String * 26
Portd = &HFF
Wait 1
'1號伺服位置模式上使能
Set_enable "01" , Position_mode , 1
Portd.3 = 0
Wait 1
'2號伺服速度模式上使能
Set_enable "02" , Speed_mode , 1
Portd.4 = 0
Wait 10
'1號伺服掉使能
Set_enable "01" , Position_mode , 0
Portd.3 = 1
Wait 1
'2號伺服掉使能
Set_enable "02" , Speed_mode , 0
Portd.4 = 1
Wait 1
End
'按值發送
Sub Send(byval Str_code As String )
    Local I1 As Integer , Mystr As String * 4 , Mybyte As Byte , Length As Integer
    Length = Len(str_code)
    For I1 = 1 To Length Step 2
        Mystr = Mid(str_code , I1 , 2)
        Mybyte = Hexval(mystr)
        Printbin Mybyte
    Next
End Sub
'Can幀數據Std_mode=1為標準幀=0為擴展幀,
'Data_length為數據區長度最大8字節,
'Func_code為功能碼一個字節,
'Node_id為節點ID一個字節,
'Str_data數據區十六進制字符串,最大8個字節
   Local Count As Integer , Str_code As String * 26 , I As Integer
   Select Case Std_mode
   Case Is = Std_frame
      Str_code = "0" + Str(data_length)                     '標準幀的第一個字符為0第二個字符為數據區的字節數(最大8字節)
   Case Is = Ext_frame
      Str_code = "8" + Str(data_length)                     '擴展幀的第一個字符為8第二個字符為數據區的字節數(最大8字節)
   End Select
   Str_code = Str_code + "0000"
   If Len(func_code) = 1 Then
      Str_code = Str_code + "0"
   End If
   Str_code = Str_code + Func_code
   If Len(node_id) = 1 Then Str_code = Str_code + "0"
   Str_code = Str_code + Node_id
   Count = Len(str_data)
   Count = 16 - Count
   Str_code = Str_code + Str_data
   For I = 1 To Count
   Next I
   Can_data = Str_code
End Function
'伺服驅動器使能Node_id為驅動器節點ID,
'Ctrl_mode有兩種模式,位置模式Position_mode = 0和速度模式 Speed_mode = 1
'Value值設置非0為上使能,設置為0為掉使能
   If Value <> 0 Then
      '上使能
      '02 00 00 02 0A 00 00 00 00 00 00 00 00   '控制字清0
      Can_code = Can_data(std_frame , 2 , "02" , Node_id , "0000" )       '獲得完整can報文
      Send Can_code                                         '發數據
      Waitms 5
      Select Case Ctrl_mode
      Case Is = Position_mode
        '01 00 00 03 0A 01 00 00 00 00 00 00 00    '速度模式
        Can_code = Can_data(std_frame , 1 , "03" , Node_id , "01" )       '獲得完整can報文
        Send Can_code                                       '發數據
        Waitms 5
      Case Is = Speed_mode
        '01 00 00 03 0A 03 00 00 00 00 00 00 00    '位置模式
        Can_code = Can_data(std_frame , 1 , "03" , Node_id , "03" )       '獲得完整can報文
        Send Can_code                                       '發數據
        Waitms 5
      End Select
      '02 00 00 02 0A 06 00 00 00 00 00 00 00   '始能第一步
      Can_code = Can_data(std_frame , 2 , "02" , Node_id , "0600" )       '獲得完整can報文
      Send Can_code                                         '發數據
      Waitms 5
      '02 00 00 02 0A 07 00 00 00 00 00 00 00   '始能第二步
      Can_code = Can_data(std_frame , 2 , "02" , Node_id , "0700" )       '獲得完整can報文
      Send Can_code                                         '發數據
      Waitms 5
      '02 00 00 02 0A 0F 00 00 00 00 00 00 00   '始能第三步
      Can_code = Can_data(std_frame , 2 , "02" , Node_id , "0F00" )       '獲得完整can報文
      Send Can_code                                         '發數據
      Waitms 5
   Else
      '掉使能02 00 00 02 0A 05 00 00 00 00 00 00 00
      Can_code = Can_data(std_frame , 2 , "02" , Node_id , "0500" )       '獲得完整can報文
      Send Can_code                                         '發數據
   End If
End Sub
主站蜘蛛池模板: 黄色片免费在线观看 | 嫩草久久| 日韩一区二区在线播放 | 国产免费成人 | 国产人人干 | 中文字幕在线观看一区 | 欧美一级色 | 理论片中文字幕 | 亚洲高清中文字幕 | 亚洲影视一区 | 中文久久久 | 一区二区三区不卡视频 | 一级片久久久 | 欧美色图一区 | 狠狠干综合 | 亚洲成人免费 | 美女91网站| 久久精彩 | 亚洲高清中文字幕 | av免费网站 | 中国av在线播放 | 性久久久久久久 | 色天堂影院 | 亚洲成a人 | 亚洲黄色在线视频 | 欧美黄色一级大片 | 中文字幕自拍 | av在线视| 欧美日韩中文字幕 | 亚洲欧美一区二区三区四区 | www.日本黄色 | 日韩精品大片 | 国产成人福利 | 国产福利网站 | 色中色综合 | 国产黄色免费 | 国产视频一区二区在线观看 | 极品尤物一区二区三区 | 手机av片 | 国产剧情一区 | 国产高清一区二区三区 |
