查看: 2095|回復(fù): 0
stm32f103超聲波驅(qū)動(dòng)程序
ID:831137 發(fā)表于 2021-6-27 20:37 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "key.h"
  6. //超聲波硬件接口定義
  7. #define HCSR04_PORT     GPIOB
  8. #define HCSR04_CLK      RCC_APB2Periph_GPIOB
  9. #define HCSR04_TRIG     GPIO_Pin_11
  10. #define HCSR04_ECHO     GPIO_Pin_10
  11. //超聲波計(jì)數(shù)
  12. u16 msHcCount = 0;
  13. //定時(shí)器4設(shè)置
  14. void hcsr04_NVIC()
  15. {
  16.         NVIC_InitTypeDef NVIC_InitStructure;
  17.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  18.
  19.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  20.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  21.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  22.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  23.         NVIC_Init(&NVIC_InitStructure);
  24. }
  25. //IO口初始化 及其他初始化
  26. void Hcsr04Init()
  27. {
  28.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  29.     GPIO_InitTypeDef GPIO_InitStructure;
  30.     RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
  31.
  32.     GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
  33.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  34.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  35.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  36.     GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
  37.
  38.     GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
  39.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  40.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  41.     GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
  42.
  43.
  44.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  45.
  46.     TIM_DeInit(TIM4);
  47.     TIM_TimeBaseStructure.TIM_Period = (999);
  48.     TIM_TimeBaseStructure.TIM_Prescaler =(71);
  49.     TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  50.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  51.     TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  52.
  53.     TIM_ClearFlag(TIM4, TIM_FLAG_Update);
  54.     TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
  55.     TIM_Cmd(TIM4,DISABLE);
  56. }
  57. //打開定時(shí)器4
  58. static void OpenTimerForHc()
  59. {
  60.    TIM_SetCounter(TIM4,0);
  61.    msHcCount = 0;
  62.    TIM_Cmd(TIM4, ENABLE);
  63. }
  64. //關(guān)閉定時(shí)器4
  65. static void CloseTimerForHc()
  66. {
  67.    TIM_Cmd(TIM4, DISABLE);
  68. }
  69. //定時(shí)器4終中斷
  70. void TIM4_IRQHandler(void)
  71. {
  72.    if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  73.    {
  74.                    msHcCount++;
  75.        TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
  76.
  77.    }
  78. }
  79. //獲取定時(shí)器4計(jì)數(shù)器值
  80. u32 GetEchoTimer(void)
  81. {
  82.    u32 t = 0;
  83.    t = msHcCount*1000;
  84.    t += TIM_GetCounter(TIM4);
  85.    TIM4->CNT = 0;
  86.    delay_ms(50);
  87.    return t;
  88. }
  89. //通過定時(shí)器4計(jì)數(shù)器值推算距離
  90. float Hcsr04GetLength(void )
  91. {
  92.    u32 t = 0;
  93.    int i = 0;
  94.    float lengthTemp = 0;
  95.    float sum = 0;
  96.    while(i!=5)
  97.    {
  98.       TRIG_Send = 1;
  99.       delay_us(20);
  100.       TRIG_Send = 0;
  101.       while(ECHO_Reci == 0);
  102.       OpenTimerForHc();
  103.       i = i + 1;
  104.       while(ECHO_Reci == 1);
  105.       CloseTimerForHc();
  106.       t = GetEchoTimer();
  107.                         lengthTemp = ((float)t*0.034/2);//cm
  108.       sum = lengthTemp + sum ;
  109.
  110.     }
  111.     lengthTemp = sum/5.0;
  112.     return lengthTemp;
  113. }
  114.
  115. //測(cè)試主函數(shù)
  116. int main(void)
  117. {
  118.          float length;
  119.          delay_init();                     //延時(shí)函數(shù)初始化
  120.          //NVIC_Configuration();          //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  121.          hcsr04_NVIC();
  122.          uart_init(9600);                 //串口初始化為9600
  123.          Hcsr04Init();
  124.          LED_Init();
  125.
  126.   // Hcsr04Init();
  127.
  128.    while(1)
  129.          {
  130.      length = Hcsr04GetLength();
  131.      printf("距離為:%.3fcm\n",length);
  132.                  if(length>100)
  133.                  {
  134.                                  GPIO_ResetBits(GPIOB,GPIO_Pin_0);
  135.                  }
  136.                  else
  137.                  {
  138.                          GPIO_SetBits(GPIOB,GPIO_Pin_0);
  139.                  }
  140.                  delay_ms(50);
  141.         }
  142. }
代碼: 超聲波(用).7z (219.91 KB, 下載次數(shù): 36)
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 国产做爰视频免费播放 | 亚洲天堂一区二区三区 | 夜夜嗨av一区二区三区网页 | 精品久久一区二区 | 一区二区三区免费看 | 黄色免费大片 | 成人黄色在线视频 | 久久免费看视频 | 欧美一二 | 国产午夜三级 | 婷婷六月天 | 色网站在线 | 吃奶动态图 | 精品国产一二三 | 久久久久久久久久久久久久 | 亚洲区在线 | 日韩欧美大片 | 免费一级片 | 在线视频一区二区三区 | 国产精品视频在线观看 | 日日夜夜综合网 | 精品欧美黑人一区二区三区 | 日韩欧美黄色片 | 97在线免费| 亚洲成人福利 | 日韩一区二区三区在线 | 亚洲黄色天堂 | 欧美九九九 | 99看片| 久久精品一区二区三区四区五区 | 日韩一区二区三区在线 | 日韩精品综合 | 免费观看a级片 | 九九影视理伦片 | 一区二区福利视频 | 欧美亚洲三级 | 亚洲一区二区三区在线 | 国产成人97精品免费看片 | 美女免费网站 | 国产这里只有精品 | 亚洲免费在线观看视频 |
