查看: 6990|回復: 14
這個WS2812驅動程序,指定點亮具體的那一顆LED燈、什么顏色,應該怎么操作呢?
ID:856401 發表于 2021-7-5 19:50 來自觸屏版 | 顯示全部樓層 |閱讀模式
5黑幣
#include <STC15F2K60S2.H>
#include "intrins.h"
sbit WS2812 = P1^7;
#define numLEDs 8   //燈的個數
unsigned char buf_R[numLEDs] = {0};//顏色緩存
unsigned char buf_G[numLEDs] = {0};
unsigned char buf_B[numLEDs] = {0};
void RGB_Set_Up();  //送0碼
void RGB_Set_Down(); //送1碼
void HAL_Delay(unsigned int t)
                unsigned int x,y;
          for(x=114;x>0;x--)
          for(y=t;y>0;y--);
//復位延時
void Delay50us()                //@22.1184MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 2;
        j = 15;
        do
                while (--j);
        } while (--i);
//1碼,高電平850ns 低電平400ns 誤差正負150ns
void RGB_Set_Up()
                WS2812 = 1;
          //經過邏輯分析儀調試的的延時
                _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();
          _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_();_nop_();
                WS2812 = 0;
//1碼,高電平400ns 低電平850ns 誤差正負150ns
void RGB_Set_Down()
                WS2812 = 1;
          //經過邏輯分析儀調試的的延時
                WS2812 = 0;
//發送24位數據
void Send_2811_24bits(unsigned char G8,unsigned char R8,unsigned char B8)
          unsigned int n = 0;
          //發送G8位
                for(n=0;n<8;n++)
                        G8<<=n;
                        if(G8&0x80 == 0x80)
                                RGB_Set_Up();
                          RGB_Set_Down();
                //發送R8位
                for(n=0;n<8;n++)
                        R8<<=n;
                        if(R8&0x80 == 0x80)
                                RGB_Set_Up();
                                RGB_Set_Down();
                //發送B8位
          for(n=0;n<8;n++)
                        B8<<=n;
                        if(B8&0x80 == 0x80)
                                RGB_Set_Up();
                          RGB_Set_Down();
//復位碼
void RGB_Rst()
                WS2812 = 0;
                Delay50us();
//把24位數據GRB碼轉RGB
void Set_Colour(unsigned char r,unsigned char g,unsigned char b)
          unsigned char i;
                for(i=0;i<numLEDs;i++)
                                buf_R[i] = r; //緩沖
                          buf_G[i] = g;
                          buf_B[i] = b;
                        Send_2811_24bits(buf_G[i],buf_R[i],buf_B[i]);//發送顯示
//某一個點顯示的顏色
void SetPointColour(unsigned int num,unsigned char r,unsigned char g,unsigned char b)
          unsigned char i;
                                buf_R[num] = r;//緩沖
                          buf_G[num] = g;
                          buf_B[num] = b;
//顏色交換24位不拆分發
void SetPixelColor(unsigned char num,unsigned long c)
          unsigned char i;
                                buf_R[num] = (unsigned char)(c>>16);
                          buf_G[num] = (unsigned char)(c>>8);
                          buf_B[num] = (unsigned char)(c);
//復位
void PixelUpdate()
        RGB_Rst();
//顏色
unsigned long Color(unsigned char r, unsigned char g, unsigned char b)
  return ((unsigned long)r << 16) | ((unsigned long)g <<  8) | b;
//顏色算法
unsigned long Wheel(unsigned char WheelPos)
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85)
    return Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
//彩虹
void rainbow(unsigned int wait)
  unsigned int i, j;
  for(j=0; j<256; j++)
    for(i=0; i<numLEDs; i++)
      SetPixelColor(i, Wheel((i+j) & 255));
                PixelUpdate();
    HAL_Delay(wait);
//稍微不同的是,這使得彩虹均勻分布
void rainbowCycle(unsigned int wait)
  unsigned int i, j;
  for(j=0;j<256*5;j++)
        { // 5 cycles of all colors on wheel  車輪上所有顏色的5個循環
     SetPixelColor(i, Wheel(((i * 256 / numLEDs) + j) & 255));
          PixelUpdate();
    HAL_Delay (wait);
//Theatre-style crawling lights.呼吸燈
void theaterChase(unsigned long c, unsigned int wait)
        int j,q;
        unsigned int i;
  for (j=0; j<10; j++)
        {  //do 10 cycles of chasing  做10個循環
    for (q=0; q < 3; q++)
      for (i=0; i<numLEDs; i=i+3)
        SetPixelColor(i+q, c);    //turn every third pixel on  把每一個第三個像素
                        PixelUpdate();
      HAL_Delay(wait);
       SetPixelColor(i+q, 0);        //turn every third pixel off   把每一個第三個像素關掉
                        PixelUpdate();
//Theatre-style crawling lights with rainbow effect
//帶有彩虹效果的戲劇式爬行燈
void theaterChaseRainbow(unsigned int wait)
        int j,q;
        unsigned int i;
  for (j=0; j < 256; j++)
        {     // cycle all 256 colors in the wheel 在輪子上循環所有256色
      for (i=0; i < numLEDs; i=i+3)
        SetPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel off 把每一個第三個像素
      PixelUpdate();
      HAL_Delay(wait);
// Fill the dots one after the other with a color
//用一種顏色填充這些圓點
void colorWipe(unsigned long c, unsigned int wait)
        unsigned int i=0;
  for( i=0; i<numLEDs; i++)
    SetPixelColor(i, c);
    PixelUpdate();
    HAL_Delay(wait);
                          rainbow(45);
        rainbowCycle(40);
        theaterChase(Color(0,0,255),80); // Blue
                          theaterChase(Color(0,255,0),80); // Blue
                          theaterChase(Color(255,0,0),80); // Blue
                    theaterChaseRainbow(40);
                                colorWipe(255,255);
ID:390416 發表于 2021-7-6 20:26 | 顯示全部樓層
ID:885138 發表于 2021-7-7 18:52 來自觸屏版 | 顯示全部樓層
三個字節一組,第一個led顯示最先發的第一組,并將之后的教據向后轉發,第二個led留下第2組……直至無數據
ID:885138 發表于 2021-7-7 18:54 來自觸屏版 | 顯示全部樓層
調用這個函數//發送24位數據 void Send_2811_24bits(unsigned char G8,unsigned char R8,unsigned char B8)
ID:811711 發表于 2021-7-8 08:39 | 顯示全部樓層
二樓基本正確
ID:811711 發表于 2021-7-8 17:22 | 顯示全部樓層
這代碼也太長了把。。。
ID:411116 發表于 2021-9-23 22:10 | 顯示全部樓層
這句代碼就可以控制SetPixelColor(5, 255);括號里第一個數字代表第幾個LED,第二個數字代表顏色
ID:399179 發表于 2021-12-11 21:34 來自觸屏版 | 顯示全部樓層
rong433 發表于 2021-9-23 22:10
能具體帖個程序來嗎?謝謝!
ID:89515 發表于 2021-12-12 15:45 | 顯示全部樓層
你需要顯示第幾個燈就將它前面的幾個燈的占空比寫0就行了,自己很容易封裝一個函數出來
ID:399179 發表于 2021-12-21 19:39 來自觸屏版 | 顯示全部樓層
mengzhixinheng 發表于 2021-12-12 15:45
我等小白能力不夠啊!
ID:962286 發表于 2021-12-22 11:12 | 顯示全部樓層
做一個顯存來存所有燈的狀態,然后需要改變哪個燈或者哪幾個燈的顏色或者亮度,就更改對應的顯存,最后把顯存的數據發送到WS2812的總線上。
ID:860003 發表于 2022-1-14 12:27 | 顯示全部樓層
三個字節一組,第一個led顯示最先發的第一組,并將之后的教據向后轉發,第二個led留下第2組……直至無數據。能做時鐘!
ID:1015077 發表于 2022-4-19 15:05 | 顯示全部樓層
請問以下如何只改變燈的亮度而不改變顏色?我試著改變RGB值顏色也會改變。比如RGB(255,255,255),調成RGB(128,128,128)就會從白色變成灰色
ID:844772 發表于 2022-4-19 15:39 | 顯示全部樓層
Berri 發表于 2022-4-19 15:05
請問以下如何只改變燈的亮度而不改變顏色?我試著改變RGB值顏色也會改變。比如RGB(255,255,255),調成R ...
那是因為人眼睛對不同色光的敏感不同,對黃色相對更敏感,改變亮度時各個分色的數字不是同步減少,你可以用電腦調好數值。
ID:726356 發表于 2024-5-17 10:02 | 顯示全部樓層
3個數值都是一樣的話只是降低亮度了,RGB顏色的閾值不一樣才能改變顏色啊,
主站蜘蛛池模板: 黄色精品视频 | 特黄一级视频 | 五月婷婷激情 | 黄色大片在线 | 中文字幕高清 | 久久久久国产精品夜夜夜夜夜 | 久久午夜影院 | 成人做爰9片免费视频 | 日韩免费在线视频 | 国产精品羞羞答答 | 成人午夜在线观看 | 日本精品在线视频 | 日韩精品久久久 | 久草综合在线 | 特级淫片裸体免费看 | 亚洲精品911 | 亚洲免费黄色 | 成人三级在线观看 | 日韩欧美国产一区二区三区 | www.伊人网| 香蕉视频一区二区 | 伊人成人在线视频 | 欧美日韩精品久久 | 日韩亚洲欧美在线观看 | 亚洲欧美综合另类 | 三上悠亚一区 | 激情婷婷丁香 | 国产亚洲一区二区三区 | 91青青| 秘密爱大尺度做爰呻吟 | 欧美二区视频 | 99热这里都是精品 | 最新国产在线 | 激情五月综合色婷婷一区二区 | 三级黄色片网站 | 国产视频一区二区三区四区 | 四虎四虎 | 国产乱码精品一区二区三区忘忧草 | av资源站| 亚洲天堂一区 | 国产调教视频 |
