查看: 1407|回復: 0
基于AD電位器采集的電子密碼鎖
ID:957231 發表于 2021-7-28 20:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define uint unsigned int
#define uchar unsigned char
sbit SCL = P2^1;
sbit SDA = P2^0;
sbit RS = P2^6;
sbit RW = P2^5;
sbit EN = P2^7;
sbit DCLK = P3^6;
sbit DIN = P3^4;
sbit CS = P3^5;
sbit DOUT = P3^7;
sbit key1 = P3^1;
sbit key2 = P3^0;
sbit key3 = P3^2;
sbit key4 = P3^3;
uchar sec1,sec2,sec3,sec4,t,i;
int s = 0, k=0, wei = 0,NEW1,NEW2,NEW3,NEW4,old1,old2,old3,old4,wei1,k1;
uchar table1[] = "WELCOME";
uchar table2[] = "LOCK";
uchar table3[] = "Input Password:";
uchar table4[] = "CONGRATULATIONS";
uchar table5[] = "ERROR";
uchar table6[] = "Change Password";
uchar table7[] = "Seting Over";
uchar table8[] = "0000";
void delay5us()
void delayms(uint xms)
     int i,j;
        for(i=xms;i>0;i--)
            for(j=114;j>0;j--);
void init()
    SDA = 1;
    delay5us();
        SCL = 1;
        delay5us();
void start()
    SDA = 1;
        delay5us();
        SCL = 1;
        delay5us();
        SDA = 0;
        delay5us();
void respons()
    uchar i = 0;
        SCL = 1;
        delay5us();
        while((SDA==1)&&(i<250))
                i++;
        SCL = 0;
        delay5us();
void stop()
    SDA = 0;
        delay5us();
        SCL = 1;
    delay5us();
    SDA = 1;
    delay5us();
void writebyte(uchar DAT)   //發送
        uchar i,temp;
        temp = DAT;
    for(i=0;i<8;i++)
                temp = temp<<1;
            SCL = 0;
                delay5us();
        SDA = CY;
        delay5us();
        SCL = 1;
                delay5us();
     SCL = 0;
     delay5us();
     SDA = 1;
     delay5us();
uchar readbyte()            //接受
    uchar i,k;
        SCL = 0;
        delay5us();
        SDA = 1;
        delay5us();
        for(i=0;i<8;i++)
                SCL = 1;
                delay5us();
                k = (k<<1)|SDA;
                SCL = 0;
                delay5us();
        return (k);
void write_add(uchar address,uchar DAT)
    start();
        writebyte(0xA0);
        respons();
        writebyte(address);
        respons();
        writebyte(DAT);
        respons();
        stop();
uchar read_add(uchar address)
    uchar DAT;
    start();
    writebyte(0xA0);
    respons();
    writebyte(address);
    respons();
    start();
    writebyte(0xA1);
    respons();
    DAT = readbyte();
    stop();
    return(DAT);
void write_com(int com)
        EN = 0;
    RS = 0;
    RW = 0;
        P0 = com;
        delayms(1);
    EN = 1;
    delayms(5);
        EN = 0;
void write_date(int date)
        EN = 0;
    RS = 1;
    RW = 0;
        P0 = date;
        delayms(1);
        EN = 1;
        delayms(5);
        EN = 0;
void lcdset()
    write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void SPI_Write(uchar dat)
        uchar i;
        DCLK = 0;
        for(i=0; i<8; i++)
                DIN = dat >> 7;
                dat <<= 1;
                DCLK = 0;
                DCLK = 1;
uint SPI_Read(void)
        uint i, dat = 0;
        DCLK = 0;
        for(i=0; i<12; i++)
                dat <<= 1;
                DCLK = 1;
                DCLK = 0;
                dat |= DOUT;
        return dat;
uint Read_AD_Data(uchar cmd)
        uchar i;
        uint AD_Value;
        DCLK = 0;
        CS  = 0;
        SPI_Write(cmd);
        for(i=6; i>0; i--);
        DCLK = 1;
        _nop_();
        _nop_();
        DCLK = 0;
        _nop_();
        _nop_();
        AD_Value=SPI_Read();
        CS = 1;
        return AD_Value;
void datapros()
        uint temp;
        static uint j;
        if(j==50)
                j=0;
                temp = Read_AD_Data(0x94);
        j++;
    if(temp>0&&temp<400)
                t =0;
            sec1 = 0;
                sec2 = 0;
                sec3 = 0;
                sec4 = 0;
        if(temp>400&&temp<800)
                t =1;
                sec1 = 1;
                sec2 = 1;
                sec3 = 1;
                sec4 = 1;
        if(temp>800&&temp<1200)
                t =2;
                sec1 = 2;
                sec2 = 2;
                sec3 = 2;
                sec4 = 2;
        if(temp>1200&&temp<1600)
                t =3;
                sec1 = 3;
                sec2 = 3;
                sec3 = 3;
                sec4 = 3;
        if(temp>1600&&temp<2000)
                t =4;
                sec1 = 4;
                sec2 = 4;
                sec3 = 4;
                sec4 = 4;
        if(temp>2000&&temp<2400)
                t =5;
                sec1 = 5;
                sec2 = 5;
                sec3 = 5;
                sec4 = 5;
        if(temp>2400&&temp<2800)
                t =6;
                sec1 = 6;
                sec2 = 6;
                sec3 = 6;
                sec4 = 6;
        if(temp>2800&&temp<3600)
                t =7;
                sec1 = 7;
                sec2 = 7;
                sec3 = 7;
                sec4 = 7;
        if(temp>3600&&temp<4000)
                t =8;
                sec1 = 8;
                sec2 = 8;
                sec3 = 8;
                sec4 = 8;
        if(temp>4000&&temp<4400)
                t =9;
                sec1 = 9;
                sec2 = 9;
                sec3 = 9;
                sec4 = 9;
void display()
    if(s==0)
           write_com(0x80);
           for(i=0;i<7;i++)
          write_date(table1[i]);
        if(s==1)
           write_com(0x80);
           for(i=0;i<14;i++)
                   write_date(table3[i]);
           write_com(0x80+0x40+k);
           write_date(0x30+t);
        if(s==2)
           write_com(0x80);
           for(i=0;i<15;i++)
                   write_date(table4[i]);
    if(s==3)
           write_com(0x80);
           for(i=0;i<5;i++)
                   write_date(table5[i]);
     if(s==4)
           write_com(0x80);
           for(i=0;i<15;i++)
                   write_date(table6[i]);
           write_com(0x80+0x46+k1);
           write_date(0x30+sec1);
           write_date(0x30+sec2);
           write_date(0x30+sec3);
           write_date(0x30+sec4);
    if(s==5)
           write_com(0x80);
           for(i=0;i<11;i++)
                  write_date(table7[i]);
void keyscan();
void check_password();
    init();
        lcdset();
        old1 = read_add(1);
        old2 = read_add(2);
        old3 = read_add(3);
        old4 = read_add(4);
//        if(sec > 100)              //防止首次讀數據出錯
//                sec = 0;
                datapros();
                keyscan();
            display();
void keyscan()
    if(key1==0)
            delayms(1);
                if(key1==0)
                        lcdset();
                    s = 1;
                        display();
                while(!key1);
         if(key2==0)
             delayms(1);
                 if(key2==0)
                        switch(wei)
                                case 0: NEW1 = t; break;
                                case 1: NEW2 = t; break;
                            case 2: NEW3 = t; break;
                            case 3: NEW4 = t; break;
                        wei++;
                        s = 1;
                    k++;
                    if(k>=4)
                           k=0;
                        display();
                        if(wei >=4)
                       check_password();
                while(!key2);
          if(key3==0)
             delayms(1);
                 if(key3==0)
                        s = 4;
                while(!key3);
         if(key4==0)
             delayms(1);
                 if(key4==0)
                        switch(wei1)
                                case 0: old1 = sec1;  write_add(1,old1);break;
                                case 1: old2 = sec2;  write_add(2,old2);break;
                            case 2: old3 = sec3;  write_add(3,old3);break;
                            case 3: old4 = sec4;  write_add(4,old4);break;
                        wei1++;
                    k1++;
                    if(k1>=4)
                           k1=0;
                        display();
                        if(wei1 >=4)
                                lcdset();
                            s = 5;
                                display();
                while(!key4);
     if((NEW1==old1)&&(NEW2==old2)&&(NEW3==old3)&&(NEW4==old4))
                 lcdset();
             s = 2;
                 display();
             lcdset();
             s = 3;
                 display();
主站蜘蛛池模板: 亚洲天堂偷拍 | 黄色片观看 | 少妇一级毛片 | 91在线免费视频观看 | 在线视频成人 | 北岛玲在线 | 国产精品视频网站 | 福利在线看 | www.国产.com| 激情视频网址 | 天天操一操| 日韩精品三级 | 久久久久国产一区二区三区 | 爱爱免费网站 | 中文字幕在线观看一区 | 黄色在线免费看 | 欧美a视频 | 性久久久久久 | 国产精品美女久久久久av爽 | 国产精品二区一区二区aⅴ污介绍 | 性大毛片视频 | 国产精品久久久一区二区三区 | 日韩精品毛片 | 国产视频www| 久久精品国产亚洲 | 中文字幕在线免费视频 | 日本美女一级片 | 激情六月 | 国产精品无遮挡 | 能看的av网站 | 欧美精品二区三区四区免费看视频 | 天天色小说 | 五月天黄色网址 | 中文字幕久久精品 | 亚洲国产网站 | 青青国产 | 日韩黄色一级 | aaa亚洲 | 久久午夜视频 | 国产伦精品 | www.日韩在线 |
