查看: 2912|回復: 0
學習SPI之我為AT45DB041D寫驅動程序
認真閱讀了AT45DB041D的編程手冊,尤其是關于SPI讀寫時序、命令的傳送,直接在文檔中做了筆記。
感興趣的伙伴可以下載查看。這里推薦TI公司制作的關于SPI mode講解視頻:SPI modes tutorial
程序:
  1. #ifndef __AT45DB014D_H
  2. #define __AT45DB014D_H
  3. #include "stm32f10x.h"
  4. #include "SPI.h"
  5. #define AT45DB_CS_asserted()                   GPIO_ResetBits(GPIOA,GPIO_Pin_4);
  6. #define AT45DB_CS_disasserted()         GPIO_SetBits(GPIOA,GPIO_Pin_4);
  7. enum ReadCommands{
  8.         MainMoryPageRead                         = 0xD2,
  9. //        ContinuousArrayReadLegacy          = 0xE8,
  10.         ContinuousArrayReadLowFreqcy       = 0x03,
  11.         ContinuousArrayReadHighFreqcy       = 0x0B,
  12.         Buf1ReadLowFreqcy                        = 0xD1,
  13.         Buf2ReadLowFreqcy                        = 0xD3,
  14.         Buf1Read                                       = 0xD4,
  15.         Buf2Read                                        = 0xD6
  16. };
  17. enum ProgramEraseCommands{
  18.         Buf1Write                                                = 0x84,
  19.         Buf2Write                                                = 0x87,
  20.         Buf1toMaiMoryPageProgramWithBuiltin        = 0x83,
  21.         Buf2toMaiMoryPageProgramWithBuiltin        = 0x86,
  22.         Buf1toMaiMoryPageProgramNullBuiltin         = 0x88,
  23.         Buf2toMaiMoryPageProgramNullBuiltin       = 0x89,
  24.         MainMoryPageProgramByBuf1                   = 0x82,
  25.         MainMoryPageProgramByBuf2                  = 0x85,
  26.         PageEraseCommand                               = 0x81,
  27.         BlockEraseCommand                             = 0x50,
  28.         SectorEraseCommand                             = 0x7C,
  29.         ChipEraseCommand                                = 0xC7 //C7H + 94H + 80H + 9AH
  30. };
  31. enum AdditionalCommands{
  32.         MainMoryPagetoBuf1Transfer                          = 0x53,
  33.         MainMoryPagetoBuf2Transfer                         = 0x55,
  34.         MainMoryPagetoBuf1Compare                          = 0x60,
  35.         MainMoryPagetoBuf2Compare                          = 0x61,
  36.         AutoPageRewriteByBuf1                                    = 0x58,
  37.         AutoPageRewriteByBuf2                                   = 0x59,
  38.         DeepPowerdownCommand                             = 0xB9,
  39.         ResumefromDeepPowerdownCommand          = 0xAB,
  40.         ReadStatusRegisterCommand                       = 0xD7,
  41.         ManufacturerDeviceIDReadCommand         = 0x9F
  42. };
  43. enum ProtectionSecurityCommands{
  44.         EnableSectorProtection                  = 0xA9,//3DH + 2AH + 7FH + A9H
  45.         DisableSectorProtection                 = 0x9A,//3DH + 2AH + 7FH + 9AH
  46.         EraseSectorProtectionReg            = 0xCF,//3DH + 2AH + 7FH + CFH
  47.         ProgramSectorProtectionReg         = 0xFC,//3DH + 2AH + 7FH + FCH
  48.         ReadSectorProtectionReg              = 0x32,
  49.         SectorLockdownCommand            = 0x30,//3DH + 2AH + 7FH + 30H
  50.         ReadSectorLockdownReg               = 0x35,
  51.         ProgramSecurityReg                       = 0x9B,//9BH + 00H + 00H + 00H
  52.         ReadSecurityReg                            = 0x77
  53. };
  54. typedef struct
  55. {
  56.         u8 READY_BUSY :1 ;
  57.         u8 COMP           :1 ;
  58.         u8 PROTECT       :1 ;
  59.         u8 PAGE_SIZE    :1 ;
  60. }StatusRegType;
  61. typedef struct{
  62.         u8 FirstByte;
  63.         u8 SecondByte;
  64.         u8 ThirdByte;
  65. }ThreeAddressBytesType;
  66. void Config_AT45DB_CS_1_Pin(void);
  67. u8 ReadStatusRegister( StatusRegType *StatusRegTypeStruct);
  68. void ReadSecurityRegister( u8 *Output64Bytes );
  69. void ReadManufacturerDeviceID( u8 *StoreIC4BytesInfor);
  70. void ReadSectorProtectionRegister(u8 *Output8Bytes);
  71. void ReadSectorLockdownRegister(u8 *Output8Bytes);
  72. void MainMemoryPageRead(u16 PageSize,u16 WhichPage,u16 WhereStart,u16 HowManyBytes,u8 *WhereStore);
  73. void MainMemoryPageProgramThroughBuffer(u16 PageSize,u8 WhichBuffer,u16 WhichPage,u16 WhereStart,u16 HowManyBytes,u8 *FromWhere );
  74. void ContinuousArrayRead(u16 PageSize,u16 WhichPage,u16 WhereStart,u8 Speed_66_33MHZ,u32 HowManyBytes,u8 *WhereStore);
  75. void ChipErase(void);
  76. void PageErase(u16 PageSize,u16 WhichPage);
  77. void Block_SectorErase(u16 PageSize,u8 IsBlock0OrSector1,u8 WhichBlock_Sector);
  78. void BufferRead(u16 PageSize,u8 WhichBuffer,u8 Speed_66_33MHZ,u16 WhereStart,u16 HowManyBytes,u8 *WhereStore);
  79. void BufferWrite(u16 PageSize,u8 WhichBuffer,u16 WhereStart,u16 HowManyBytes,u8 *FromWhere);
  80. void AutoPageRewrite(u16 PageSize,u16 WhichPage,u8 WhichBuffer);
  81. void BuffertoMainMemoryPageWith_NullBuiltInErase(u16 PageSize,u8 WhichBuffer,u16 WhichPage,u8 With_Null_BuiltIn);
  82. void DeepPowerdown_ON1_OFF0(u8 On1_Off0);
  83. void EraseSectorProtectionRegister(void);
  84. void ProgramSectorProtectionRegister(u8 *ProtectedOrNot8Bytes);
  85. void SectorLockdown(u8 WhichSector0a0b_7);
  86. void ProgramSecurityRegister(u8 *Input64Bytes);
  87. void MainMemoryPagetoBufferTransfer(u16 PageSize,u16 FromWhichPage,u8 ToWhichBuffer);
  88. signed char MainMemoryPagetoBufferCompare(u16 PageSize,u16 WhichPage,u8 WhichBuffer);
  89. void SectorProtection_ON1_OFF0(u8 On1_Off0);
  90. void static SendDummyBytes(u8 HowManyDummy);
  91. void static Send4BytesCommands(u8 OperationCommand, ThreeAddressBytesType *ThreeAddrCommand);
  92. signed char static Get3AddressBytes_PageBuffer(u16 PageSize,u16 WhichPage,u16 PageStartOrBuffStart);
  93. signed char static Get3AddressBytes_BlockSector(u16 PageSize, u8 IsBlock0OrSector1,u8 WhichBlock_Sector);
  94. #endif
last but not least, 也請提出寶貴建議。
頭文件
頭文件
AT45DB041D代碼Projet.7z
201.36 KB, 下載次數: 32, 下載積分: 黑幣 -5
AT45DB041D-SU 編程手冊閱讀筆記.pdf
1.79 MB, 下載次數: 23, 下載積分: 黑幣 -5
參與人數 1黑幣 +80 收起 理由
admin + 80 共享資料的黑幣獎勵!
主站蜘蛛池模板: 秋霞一区二区 | 国产一级免费 | 一区二区免费视频 | 日皮视频免费看 | 激情综合婷婷 | 日韩欧美精品 | 欧美日韩成人在线观看 | www.欧美在线 | 在线理论片 | 麻豆av免费观看 | 91在线小视频 | 国产精品成人一区二区网站软件 | 黑人操亚洲女人 | 黄色录像一级片 | 四虎影院在线播放 | 欧美黄色网 | 日韩精品在线观看视频 | 精品久久影院 | 久久久久久精 | 成人精品福利 | www.天天操 | 中文字幕视频 | 国产精品天堂 | 国产伦精品一区二区三区四区 | 欧美日韩在线看 | 亚洲欧美精品在线 | 欧美美女性生活 | 黄色录像大片 | 黄色三级大片 | 亚洲精品在线视频观看 | 亚洲成人免费网站 | 一区二区三区四区国产 | 精品欧美一区二区精品久久 | 伊人av在线| 91久| 亚洲视频在线视频 | 一级特黄视频 | 一级片免费 | 久久精品久久久久 | 在线观看欧美日韩视频 | 久久久中文字幕 |
