#include //包含52單片機(jī)頭文件
#include "Delay.h"
sbit I2C_SCL = P2^1; //定義模擬IIC總線的時(shí)鐘線
sbit I2C_SDA = P2^0; //定義模擬IIC總線的數(shù)據(jù)線
#define TM1637_BRIGHTNESS 7 // 0 - 7
void I2C_delay()
nop_();
void I2C_start()
I2C_SCL = 1;
I2C_SDA = 1;
I2C_delay();
I2C_SDA = 0; // 時(shí)鐘線設(shè)置為常態(tài),低電平。
I2C 總線寫1個(gè)字節(jié)
不包含應(yīng)答位的檢測(cè)
void I2C_write_byte(char byte_to_write)
unsigned char i;
for(i=0; i>= 1;
return;
void I2C_check_ack()
// I2C 檢查應(yīng)答位,實(shí)際未檢查,只發(fā)送了應(yīng)答位時(shí)鐘,認(rèn)為TM1637工作正常
I2C_SCL = 0;
I2C_delay();//在第八個(gè)時(shí)鐘下降沿之后延時(shí)5us,開(kāi)始判斷ACK 信號(hào)
while(I2C_SDA)
I2C_SCL = 1;
I2C_delay();
I2C_SCL=0;
void I2C_send_ack()
I2C_SDA = 0;
I2C_delay();
I2C_SCL = 1;
I2C_delay();
I2C_SCL = 0;
I2C_delay();
I2C_SDA = 1;
I2C_delay();
void I2C_stop()
I2C_SCL = 0;
I2C_delay();
I2C_SDA = 0;
I2C_delay();
I2C_SCL = 1;
I2C_delay();
I2C_SDA = 1;
// TM1637模塊操作函數(shù)
void TM1637_write_command_byte(unsigned char command)
I2C_start();
I2C_write_byte(command);
I2C_check_ack();
I2C_stop();
// bright : 0 - 7
void TM1637_display_switch_and_bright(bit enable_display, unsigned char bright)
TM1637_write_command_byte(0x80 + (enable_display ? 0x08 : 0x00) + bright);
void TM1637_write_display_bytes(unsigned char first_addr,
unsigned char bytes_to_write[],
unsigned char num_of_bytes)
unsigned char i;
I2C_start();
I2C_write_byte(0x40);
I2C_check_ack();
I2C_stop();
I2C_start();
I2C_write_byte(0xC0 + first_addr);
I2C_check_ack();
for(i=0; i<num_of_bytes; i++)
I2C_write_byte(bytes_to_write[i]);
I2C_check_ack();
I2C_stop();
// addr: 0 - 5
void TM1637_write_display_byte(unsigned char addr, unsigned char segments)
I2C_start();
I2C_write_byte(0x40 + addr);
I2C_check_ack();
I2C_stop();
I2C_start();
I2C_write_byte(0xC0 + addr);
I2C_check_ack();
I2C_write_byte(segments);
I2C_check_ack();
I2C_stop();
code unsigned char TM1637_SEG_TAB[] =
0x3F // 00111111 0
,0x06 // 00000110 1
,0x5B // 01011011 2
,0x4F // 01001111 3
,0x66 // 01100110 4
,0x6d // 01101101 5
,0x7d // 01111101 6
,0x07 // 00000111 7
,0x7F // 01111111 8
,0x6F // 01101111 9
,0x77 // 01110111 A
,0x7C // 01111100 b
,0x39 // 00111001 C
,0x5E // 01011110 d
,0x79 // 01111001 E
,0x71 // 01110001 F
void TM1637_show_digit(unsigned char pos, unsigned char digit, bit with_dot)
TM1637_write_display_byte(pos, TM1637_SEG_TAB[digit] | (with_dot ? 0x20 : 0x00));
void TM1637_init()
unsigned char i;
TM1637_display_switch_and_bright(1, TM1637_BRIGHTNESS);
for(i=0; i<6; i++)
TM1637_write_display_byte(i, 0xFF);
Delay200ms();
for(i=0; i<6; i++)
TM1637_write_display_byte(i, 0x00);
Delay200ms();
for(i=0; i<6; i++)
Delay200ms();
for(i=0; i<6; i++)
Delay200ms();
void TM1637()
unsigned char seg;
unsigned char i, j;
TM1637_init();
for(i=0; i<16; i++)
for(j=0; j<6; j++)
TM1637_show_digit(j, i, 0);
Delay1s();
