查看: 3955|回復: 3
請教大家這個Arduino報錯是什么意思呢?has no member named
ID:5212 發表于 2021-9-5 12:53 | 顯示全部樓層 |閱讀模式
學習點亮0.96寸的OLED,直接用的別人的程序,編譯時都有這樣的報錯,請教各位這是什么意思呢?如何解決,謝謝了!
報錯代碼:
Arduino:1.8.12 (Windows 7), 開發板:"Arduino Nano, ATmega328P (Old Bootloader)"
F:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware F:\Program Files (x86)\Arduino\hardware -tools F:\Program Files (x86)\Arduino\tools-builder -tools F:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries F:\Program Files (x86)\Arduino\libraries -libraries F:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10812 -build-path C:\Users\liu\AppData\Local\Temp\arduino_build_793056 -warnings=all -build-cache C:\Users\liu\AppData\Local\Temp\arduino_cache_806397 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\Arduino\顯示單片機菜鳥\00\00.ino
F:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware F:\Program Files (x86)\Arduino\hardware -tools F:\Program Files (x86)\Arduino\tools-builder -tools F:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries F:\Program Files (x86)\Arduino\libraries -libraries F:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10812 -build-path C:\Users\liu\AppData\Local\Temp\arduino_build_793056 -warnings=all -build-cache C:\Users\liu\AppData\Local\Temp\arduino_cache_806397 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=F:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\Arduino\顯示單片機菜鳥\00\00.ino
Using board 'nano' from platform in folder: F:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: F:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.10]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.10.10]
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.4.6]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit_SSD1306@2.4.6]
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "F:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "F:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "F:\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "F:\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.8.3]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.8.3]
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "F:\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
Generating function prototypes...
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"F:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\preproc\\ctags_target_for_gcc_minus_e.cpp"
正在編譯項目...
"F:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IF:\\Arduino\\libraries\\Adafruit_GFX_Library" "-IF:\\Arduino\\libraries\\Adafruit_SSD1306" "-IF:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IF:\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp" -o "C:\\Users\\liu\\AppData\\Local\\Temp\\arduino_build_793056\\sketch\\00.ino.cpp.o"
F:\Arduino\顯示單片機菜鳥\00\00.ino: In function 'void test_SSD1306()':
00:175:11: error: 'class Adafruit_SSD1306' has no member named 'ShowCN_16'
00:176:11: error: 'class Adafruit_SSD1306' has no member named 'ShowCN_16'
使用 1.0  版本的庫 Wire 在文件夾: F:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
使用 1.10.10  版本的庫 Adafruit_GFX_Library 在文件夾: F:\Arduino\libraries\Adafruit_GFX_Library
使用 2.4.6  版本的庫 Adafruit_SSD1306 在文件夾: F:\Arduino\libraries\Adafruit_SSD1306
使用 1.0  版本的庫 SPI 在文件夾: F:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
使用 1.8.3  版本的庫 Adafruit_BusIO 在文件夾: F:\Arduino\libraries\Adafruit_BusIO
exit status 1
ID:161164 發表于 2021-9-5 17:08 | 顯示全部樓層
ShowCN_16是你抄代碼的源主自己寫的函數
坊間下載的Adafruit_SSD1306庫文件內是沒有這個函數的
要不找源主要庫文件
要不自己寫一個
ID:5212 發表于 2021-9-6 09:53 | 顯示全部樓層
lkc8210 發表于 2021-9-5 17:08
首先表示感謝!
源程序是在論壇里復制別人的
這個庫文件我也不會寫
ID:844772 發表于 2021-9-6 10:01 | 顯示全部樓層
a4681748 發表于 2021-9-6 09:53
首先表示感謝!
源程序是在論壇里復制別人的
這個庫文件我也不會寫
寫這個不需要太多技術,你把庫文件打開,基本照抄就行。否則就不用ShowCN_16方法,一個字一個字的寫唄。
主站蜘蛛池模板: 国产精品乱码一区二区视频 | 久久av网站 | 激情综合婷婷 | 国产又色又爽又黄又免费 | 青青草免费在线视频 | 国产精品免费在线 | 黄色片免费观看 | 懂色av一区二区夜夜嗨 | 国产天堂网 | 日韩黄色在线视频 | 久久大 | 国产三级一区 | 成人黄色免费视频 | 中文字幕在线观看一区 | 国内自拍偷拍 | 色综合天天综合网国产成人网 | 刘玥大战28公分黑人 | 欧美一级视频在线观看 | 午夜91 | 三级在线观看视频 | 三级网站在线播放 | 国产黄色在线观看 | 国产精品自在线 | 操操操操操操 | 97久久久久| 一区二区国产精品 | 久久精品99久久久久久 | 日本黄a三级三级三级 | 青青草一区二区 | 久久国产综合 | 久久夜色精品 | 久久亚洲国产精品 | 中文字幕在线免费播放 | 91狠狠操| 日韩精品网 | 午夜精品久久久久 | 欧美女同视频 | 国产黄色一级片 | 日韩成人免费视频 | 国产视频三区 | 黄色福利视频 |
