查看: 1704|回復: 0
stm32 anh led RGB WS2812b部分程序
stm32 anh led WS2812b
  1. #include "ws2812.h"
  2. /* Variables -----------------------------------------------*/
  3. static uint8_t LEDbuffer[LED_BUFFER_SIZE];
  4. TIM_HandleTypeDef TimHandle;
  5. TIM_OC_InitTypeDef sConfig;
  6. GPIO_InitTypeDef GPIO_InitStruct;
  7. DMA_HandleTypeDef hdma_tim;
  8. /* Functions -----------------------------------------------*/
  9. /**
  10. * @brief TIM MSP Initialization
  11. *        This function configures the hardware resources used in this example:
  12. *           - Peripheral's clock enable
  13. *           - Peripheral's GPIO Configuration
  14. *           - DMA configuration for transmission request by peripheral
  15. * @param htim: TIM handle pointer
  16. * @retval None
  17. */
  18. void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef *htim) {
  19.         /*##-1- Enable peripherals and GPIO Clocks #################################*/
  20.         /* TIMx clock enable */
  21.         TIMx_CLK_ENABLE();
  22.         /* Enable GPIO Channel Clock */
  23.         TIMx_CHANNEL1_GPIO_CLK_ENABLE();
  24.         /* Enable DMA clock */
  25.         DMAx_CLK_ENABLE();
  26.         /* Configure TIM1_Channel1 in output, push-pull & alternate function mode */
  27.         GPIO_InitStruct.Pin = GPIO_PIN_CHANNEL1;
  28.         GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  29.         GPIO_InitStruct.Pull = GPIO_PULLUP;
  30.         GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  31.         GPIO_InitStruct.Alternate = GPIO_AF_TIMx;
  32.         HAL_GPIO_Init(TIMx_GPIO_CHANNEL1_PORT, &GPIO_InitStruct);
  33.         /* Set the parameters to be configured */
  34.         hdma_tim.Init.Request = TIMx_CC1_DMA_REQUEST;
  35.         hdma_tim.Init.Direction = DMA_MEMORY_TO_PERIPH;
  36.         hdma_tim.Init.PeriphInc = DMA_PINC_DISABLE;
  37.         hdma_tim.Init.MemInc = DMA_MINC_ENABLE;
  38.         hdma_tim.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
  39.         hdma_tim.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
  40.         hdma_tim.Init.Mode = DMA_CIRCULAR;
  41.         hdma_tim.Init.Priority = DMA_PRIORITY_HIGH;
  42.         /* Set hdma_tim instance */
  43.         hdma_tim.Instance = TIMx_CC1_DMA_INST;
  44.         /* Link hdma_tim to hdma[TIM_DMA_ID_CC1] (channel1) */
  45.         __HAL_LINKDMA(htim, hdma[TIM_DMA_ID_CC1], hdma_tim);
  46.         /* Initialize TIMx DMA handle */
  47.         HAL_DMA_Init(htim->hdma[TIM_DMA_ID_CC1]);
  48.         /*##-2- Configure the NVIC for DMA #########################################*/
  49.         /* NVIC configuration for DMA transfer complete interrupt */
  50.         HAL_NVIC_SetPriority(TIMx_DMA_IRQn, 0, 0);
  51.         HAL_NVIC_EnableIRQ(TIMx_DMA_IRQn);
  52. }
  53. void ws2812_init(void) {
  54.         fillBufferBlack();
  55.         TimHandle.Instance = TIMx;
  56.         TimHandle.Init.Period = TIMER_PERIOD - 1;
  57.         TimHandle.Init.RepetitionCounter = LED_BUFFER_SIZE + 1; //LED_BUFFER_SIZE + 1;//0xFFFF;
  58.         TimHandle.Init.Prescaler = (uint32_t)(
  59.                         (SystemCoreClock / TIMER_CLOCK_FREQ) - 1);
  60.         TimHandle.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  61.         TimHandle.Init.CounterMode = TIM_COUNTERMODE_UP;
  62.         HAL_TIM_PWM_Init(&TimHandle);
  63.         /*##-2- Configure the PWM channel 3 ########################################*/
  64.         sConfig.OCMode = TIM_OCMODE_PWM1;
  65.         sConfig.OCPolarity = TIM_OCPOLARITY_HIGH;
  66.         sConfig.OCFastMode = TIM_OCFAST_DISABLE;
  67.         sConfig.OCIdleState = TIM_OCIDLESTATE_RESET;
  68.         //sConfig.Pulse        = 0;
  69.         HAL_TIM_PWM_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1);
  70.         /*##-3- Start PWM signal generation in DMA mode ############################*/
  71.         HAL_TIM_PWM_Start_DMA(&TimHandle, TIM_CHANNEL_1, (uint32_t *) LEDbuffer,
  72.                         LED_BUFFER_SIZE);
  73. }
  74. void ws2812_update(void) {
  75.         HAL_TIM_PWM_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1);
  76.         HAL_TIM_PWM_Start_DMA(&TimHandle, TIM_CHANNEL_1, (uint32_t *) LEDbuffer,
  77.                         LED_BUFFER_SIZE);
  78. }
  79. void setLEDcolor(uint32_t LEDnumber, uint8_t RED, uint8_t GREEN, uint8_t BLUE) {
  80.         uint8_t tempBuffer[24];
  81.         uint32_t i;
  82.         uint32_t LEDindex;
  83.         LEDindex = LEDnumber % LED_NUMBER;
  84.         for (i = 0; i < 8; i++) // GREEN data
  85.                 tempBuffer[i] = ((GREEN << i) & 0x80) ? WS2812_1 : WS2812_0;
  86.         for (i = 0; i < 8; i++) // RED
  87.                 tempBuffer[8 + i] = ((RED << i) & 0x80) ? WS2812_1 : WS2812_0;
  88.         for (i = 0; i < 8; i++) // BLUE
  89.                 tempBuffer[16 + i] = ((BLUE << i) & 0x80) ? WS2812_1 : WS2812_0;
  90.         for (i = 0; i < 24; i++)
  91.                 LEDbuffer[RESET_SLOTS_BEGIN + LEDindex * 24 + i] = tempBuffer[i];
  92. }
  93. void setWHOLEcolor(uint8_t RED, uint8_t GREEN, uint8_t BLUE) {
  94.         uint32_t index;
  95.         for (index = 0; index < LED_NUMBER; index++)
  96.                 setLEDcolor(index, RED, GREEN, BLUE);
  97. }
  98. void fillBufferBlack(void) {
  99.         /*Fill LED buffer - ALL OFF*/
  100.         uint32_t index, buffIndex;
  101.         buffIndex = 0;
  102.         for (index = 0; index < RESET_SLOTS_BEGIN; index++) {
  103.                 LEDbuffer[buffIndex] = WS2812_RESET;
  104.                 buffIndex++;
  105.         }
  106.         for (index = 0; index < LED_DATA_SIZE; index++) {
  107.                 LEDbuffer[buffIndex] = WS2812_0;
  108.                 buffIndex++;
  109.         }
  110.         LEDbuffer[buffIndex] = WS2812_0;
  111.         buffIndex++;
  112.         for (index = 0; index < RESET_SLOTS_END; index++) {
  113.                 LEDbuffer[buffIndex] = 0;
  114.                 buffIndex++;
  115.         }
  116. }
  117. void fillBufferWhite(void) {
  118.         /*Fill LED buffer - ALL OFF*/
  119.         uint32_t index, buffIndex;
  120.         buffIndex = 0;
  121.         for (index = 0; index < RESET_SLOTS_BEGIN; index++) {
  122.                 LEDbuffer[buffIndex] = WS2812_RESET;
  123.                 buffIndex++;
  124.         }
  125.         for (index = 0; index < LED_DATA_SIZE; index++) {
  126.                 LEDbuffer[buffIndex] = WS2812_1;
  127.                 buffIndex++;
  128.         }
  129.         LEDbuffer[buffIndex] = WS2812_0;
  130.         buffIndex++;
  131.         for (index = 0; index < RESET_SLOTS_END; index++) {
  132.                 LEDbuffer[buffIndex] = 0;
  133.                 buffIndex++;
  134.         }
  135. }
  136. void TIMx_DMA_IRQHandler(void) {
  137.         HAL_DMA_IRQHandler(TimHandle.hdma[TIM_DMA_ID_CC1]);
  138. }
WS2812.zip (25.38 KB, 下載次數: 23)
主站蜘蛛池模板: 国产黄色免费 | 黄色网址入口 | 男人天堂av网 | 欧美顶级黄色大片免费 | 色哥网 | 五月色丁香 | 久久一级视频 | 手机av免费 | 福利小视频在线观看 | 欧美一区二区三区在线视频 | 理论片中文字幕 | 欧美日韩在线观看一区二区 | 色综合久久久久 | www.久久久久久 | 快播少女爱欢乐 | 性做久久久久久久免费看 | 欧美日韩91 | 国产精品美女在线观看 | 在线看片你懂的 | 香蕉看片 | 久久精品视频免费 | 免费毛片观看 | 欧美日韩一区二区在线 | 中文在线免费观看 | 国产精品三级在线 | 亚洲 欧美 日韩 在线 | 亚洲成人毛片 | 日韩毛片在线观看 | 欧美日韩在线观看一区二区 | av中文在线 | 在线观看小视频 | 欧美一区二区视频在线观看 | 国产精品成人一区二区三区 | 午夜久久久 | 免费av播放 | 中国a一片一级一片 | 日韩中文字幕在线 | 欧美毛片基地 | 国产麻豆视频 | 黄色片视频 | 四虎黄色影院 |
