查看: 2845|回復: 1
經濟型紅外遙控開關制作
所用材料:  JFZM8P150TSL  8腳單片機 1個
                    AC/DC   220V TO  5V 電源模塊1個
                    SRD-05VDC-SL-C 繼電器1個
                    38K 紅外線接收頭1個
                    J3Y /SOT23  1個
                    101  /0805 1個
                    10K /0805 1個
                    3.9K  /0805 1個
                    100NF /0805  2個
制作出來的實物圖如下:
  1. // 編碼格式:NEC6121
  2. // 碼值: 45 46 47
  3. //        44 40 43
  4. //           15
  5. //        16    0D
  6. //           18
  7. //        08    5A
  8. //        42    4A
  9. //  1e 1c 02 0a
  10. #include "interrupt_vector.h"
  11. #include "JFZM8P150TSL.h"
  12. #define DISI()_asm{disi}
  13. #define WDTC()_asm{wdtc}
  14. #define NOP()_asm{nop}
  15. #define ENI()_asm{eni}
  16. #define SLEP()_asm{slep}
  17. #define IR_RE   P62
  18. #define OUT2  P64
  19. #define OUT1  P60
  20. #define OUT3  P61
  21. #define OUT4  P65
  22. #define uchar  unsigned char
  23. #define uint   unsigned int
  24. uchar  TEMPDATA;
  25. bit IR_OK;
  26. bit ON_OFF;
  27. uchar date[]={0x00,0x00,0x00,0x00};
  28. void delay026ms(void);
  29. void delay009ms(void);
  30. void delay(unsigned int i);
  31. void delay(unsigned int i)
  32. {
  33. while(--i)
  34. {
  35. if(!IR_RE)break;
  36. }
  37. }
  38. void intial(void)
  39. {
  40.   PORT6=0x00;
  41.   P6CR&=0x04;
  42. ON_OFF=1;
  43. _asm
  44. {
  45. mov a,@0x0F
  46. contw
  47. }
  48. }
  49. void IR_decode(void);
  50. void IR_decode(void)
  51. {
  52. static uchar i,j,k;
  53. if(!IR_RE)
  54. {
  55. WDTC();
  56. for(k=0;k<9;k++)
  57. {
  58. delay009ms();
  59. if(IR_RE)
  60. {
  61. k=10;
  62. break;
  63. }
  64. else if(k==8)
  65. {
  66. while(!IR_RE);
  67. delay026ms();
  68. if(IR_RE)
  69. {
  70. while(IR_RE);
  71. for(i=0;i<4;i++)
  72. {
  73. for(j=0;j<8;j++)
  74. {
  75. while(!IR_RE);
  76. delay009ms();
  77. if(!IR_RE)
  78. {
  79. date[i]>>=1;
  80. date[i]=date[i]&0x7f;
  81. }
  82. else if(IR_RE)
  83. {
  84. date[i]>>=1;
  85. date[i]=date[i]|0x80;
  86. while(IR_RE);
  87. }
  88. }
  89. k=9;IR_OK=1;
  90. }
  91. }
  92. }
  93. }
  94. }
  95. if(date[2]+date[3]==0xff)
  96. TEMPDATA=date[2];
  97. if(date[2]==0x45) //ALL CLOSE
  98. {
  99. OUT1=OUT2=OUT3=OUT4=0;
  100. }
  101. if(date[2]==0x46)
  102. {
  103. OUT2=!OUT2;
  104. }
  105. if(date[2]==0x44)
  106. {
  107. OUT1=!OUT1;
  108. }
  109. if(date[2]==0x0a)
  110. {
  111. OUT3=!OUT3;
  112. }
  113. if(date[2]==0x0d)
  114. {
  115. OUT4=!OUT4;
  116. }
  117. date[2]=0X00; //必須清除,不然容易頻繁啟動if內循環
  118. }
  119. void delay026ms(void)
  120. {
  121. uchar k,s;
  122. for(k=0;k<2;k++)
  123. for(s=0;s<220;s++);
  124. }
  125. void delay009ms(void) //900us
  126. {
  127. uchar m;
  128. for(m=0;m<145;m++);
  129. }
  130. void main (void)
  131. {
  132. intial();
  133. IR_OK=0;
  134. PORT5=0X00;
  135. PORT6=0X00;
  136. while(1)
  137. {
  138. IR_decode();
  139. }
  140. }
ID:424598 發表于 2021-9-15 11:10 | 只看該作者
某一個寶都搜不出來這個單片機,成本也沒標,如何個經濟法?
主站蜘蛛池模板: 日韩中文字幕第一页 | 黄色网页免费 | 成人午夜毛片 | 久草小视频 | 天天综合久久 | 五月天婷婷在线观看 | 成人黄色在线观看 | 日本在线不卡视频 | 日韩黄色录像 | 亚洲www啪成人一区二区麻豆 | 日韩一区二区三 | 久久精品在线视频 | 色综合久久天天综合网 | 在线观看国产小视频 | 一区二区三区视频 | 国产高清视频一区 | 国产日韩欧美日韩大片 | 成人免费毛片片v | 久久久精品在线观看 | www.欧美| 久久av网站 | 日韩精品成人免费观看视频 | 久久久久九九九 | 欧美日韩国产激情 | 亚洲一区二区在线免费观看 | 免费在线观看av网站 | 天天干夜夜爱 | 免费成人深夜夜国外 | 日韩午夜在线观看 | 日韩小视频在线观看 | 毛片一级片 | www.亚洲视频| 久久黄色大片 | 三级黄色 | 国产精品成人一区 | 午夜视频在线看 | 国产三区在线观看 | 亚洲欧美日韩一区 | 一区在线观看 | 一区二区三区视频在线 | 欧美视频二区 |
