查看: 2228|回復(fù): 2
分享一個單片機(jī)4IO帶6燈3按鍵電路
ID:887371 發(fā)表于 2021-9-24 12:00 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
分享一個4IO帶6燈3按鍵電路。
這電路把10k電阻換成1N4148,可帶6按鍵,也支持復(fù)合鍵。
ID:887371 發(fā)表于 2021-9-24 13:49 | 只看該作者
如不考慮驅(qū)動led和復(fù)合鍵,3個IO可驅(qū)動22個按鍵。
參考文章:小玩意,3個普通IO識別22個按鍵試驗
ID:1064915 發(fā)表于 2024-1-8 14:39 | 只看該作者
*                   3個IO接識別22鍵測試程序                         *
*       MCU:     AT89C2051                                          *
*       OSC:     12M cysytel                                        *
*       程序設(shè)計:Cowboy                                             *
*       程序版本:V1.0                                               *
#include <reg52.h>
//================== IO口線連接 ==================
sbit Bus          = P1^0;
sbit IO_a         = P1^4;
sbit IO_b         = P1^3;
sbit IO_c         = P1^2;
//================== 變量聲明 ====================
unsigned char Disp_buf[3];
unsigned char Dig;
unsigned char Key_count;
unsigned char bdata Key_state;
sbit KB0 = Key_state^0;
sbit KB1 = Key_state^1;
sbit KB2 = Key_state^2;
sbit KB3 = Key_state^3;
sbit KB4 = Key_state^4;
sbit KB5 = Key_state^5;
//================== 表格數(shù)據(jù) ====================
code unsigned char LED_font[24]=
        0x84,0x9f,0xa2,0x8a,0x99,0xc8,0xc0,0x9e,0x80, //012345678
        0x88,0x90,0xc1,0xe4,0x83,0xe0,0xf0,0xff,0xfb, //9abcdef -
code unsigned char Key_tab[64]=     //鍵碼映射表
{//  0  1  2  3  4  5  6  7  8  9
        22, 0, 2, 0, 0, 0, 0, 0, 4, 0, //0
         0, 0, 0, 0, 0,18, 0, 0, 0, 0, //1X
         0, 0, 0, 0, 0, 0, 3,14, 0, 0, //2X
        20,10, 6, 0, 0, 0, 0, 0, 1,19, //3X
         0, 5, 0, 0, 0,15, 0,11, 0, 0, //4X
         0,17, 0, 0,13, 8, 0,21, 0, 9, //5X
        16,12, 7, 0                    //6X
//=============== 檢測按鍵 =================
void Key_scan()
    unsigned char i;
    Key_count --;                        //掃描次序
    Key_count &= 3;
    switch (Key_count)                //按次序處理
        case 2:                                //第一輪掃描
        KB0 = IO_b;
        KB1 = IO_c;
        IO_a = 1;
        IO_b = 0;
        break;
        case 1:                                //每二輪掃描
        KB2 = IO_c;
        KB3 = IO_a;
        IO_b = 1;
        IO_c = 0;
        break;
        case 0:                                //每三輪掃描
        KB4 = IO_a;
        KB5 = IO_b;
        IO_c = 1;
        break;
        default:                        //每四輪掃描
        if (!IO_a) KB0 = 0;
        if (!IO_b) KB2 = 0;
        if (!IO_c) KB4 = 0;
        IO_a = 0;
        //======更新顯示緩沖區(qū)=======
        i = Key_tab[Key_state];
        if (i == 0)
            Disp_buf[2] = 0x11;                //顯示三橫
            Disp_buf[1] = 0x11;
            Disp_buf[0] = 0x11;
            Disp_buf[2] = 0x0c;     //字符"C"
            Disp_buf[1] = i / 10;   //鍵碼十位
            Disp_buf[0] = B;于      //鍵碼個位
        Key_state = 0;
                    ONE WIRE 顯示總線驅(qū)動程序
//=============== 發(fā)送一位 =================
void Send_bit(bit Dat)
    unsigned char i = 3;
    if (!Dat) Bus = 0;
        Bus = 0;
        Bus = 1;
    while(--i);                 //延時8us
    Bus = 1;
//=============== 總線驅(qū)動 =================
void Bus_drive()
    unsigned char i = 0;
    unsigned char Sdat;
    Send_bit(1);                        //Bit6消隱
    do Bus = 1; while(--i);             //延時768us
    do Bus = 0; while(--i);             //延時768us
    Bus = 1;
    Sdat = LED_font[Disp_buf[Dig++]];   //獲取顯示數(shù)據(jù)
    Send_bit(Sdat & 0x01);              //發(fā)送位0
    Send_bit(Sdat & 0x02);              //發(fā)送位1
    Send_bit(Sdat & 0x04);              //發(fā)送位2
    Send_bit(Sdat & 0x08);              //發(fā)送位3
    Send_bit(Sdat & 0x10);              //發(fā)送位4
    Send_bit(Sdat & 0x20);              //發(fā)送位5
    Send_bit(Dig  & 0x01);              //發(fā)送位選1
    Send_bit(Dig  & 0x02);              //發(fā)送位選2
    while(--i);                         //延時512us
    Send_bit(Sdat & 0x40);              //發(fā)送位6
    for (i = 7;i> 0;i--) Send_bit(1);  //位6移至Dout
    if (Dig == 3) Dig = 0;
                    延時 5ms 程序
void Delay_5ms()
    while(!TF1);
    TF1 = 0;
    TH1 = (- 5000) / 256;
    TL1 = (- 5000) % 256;
                        主程序
    TMOD = 0x10;            //定時器1,16位模式
    TCON = 0xc0;            //TR1=1;TF1=1;
    while(1)                //主循環(huán)
        Bus_drive();        //顯示總線驅(qū)動
        Key_scan();         //檢測按鍵
        Delay_5ms();        //延時5MS
主站蜘蛛池模板: 亚洲一区二区久久 | 久久综合久色欧美综合狠狠 | 又色又爽又黄gif动态图 | 成年网站在线观看 | 久久精品视 | 97视频免费 | 99这里有精品 | 人人插人人爽 | 精品一区二区三区免费 | 国产剧情在线 | 91片黄在线观看动漫 | 精品国产区一区二 | 欧美日韩三区 | www.久久久久久 | 欧美精品一区在线观看 | 亚洲一区在线视频 | 日本黄色中文字幕 | 午夜xxx| 中文字幕在线观看网址 | a一级黄色片 | 国产日韩久久 | 日韩在线视频免费观看 | 日本毛片视频 | 五月婷色 | 国产精品入口 | 国产精品123| 国产亚洲视频在线观看 | 97青青草| 免费国产黄色 | 天天精品视频 | 亚洲激情视频在线 | 1级黄色片| 欧美一区二区三区免费 | av少妇| 吃奶动态图 | 欧美一级黄色片 | 欧美视频一区 | 欧美激情专区 | 黄色网免费 | 免费看黄色小视频 | 欧美在线观看一区二区 |
