查看: 3847|回復: 1
stm32滴答定時器+LCD1602顯示真實系統時鐘Proteus仿真
ID:548850 發表于 2021-10-7 14:20 | 顯示全部樓層 |閱讀模式
LCD1602顯示系統真實時鐘
LCD1602顯示系統真實時鐘
#include "stm32f10x.h"
void LCD1602_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(LCD1602_CLK, ENABLE);
        GPIO_InitTypeDef LCD1602_GPIOStruct;
        LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_PP;
        LCD1602_GPIOStruct.GPIO_Speed = GPIO_Speed_10MHz;
        LCD1602_GPIOStruct.GPIO_Pin =  LCD1602_E | LCD1602_RS | LCD1602_RW ;
        GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
        //LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_OD;
        LCD1602_GPIOStruct.GPIO_Pin =   DB0 |  DB1 | DB2 |DB3 |  DB4 | DB5|
        DB6 |  DB7 ;     //若設置為開漏輸出 需要上拉電阻
void LCD1602_WaitReady(void) //檢測忙狀態
        uint8_t sta;
        LCD1602_GPIO_PORT->ODR =0x00FF;
        RSO(0);
        RWO(1);
        EO(1);
        SysTick_Delay_Us(1);
        do{
                sta=GPIO_ReadInputDataBit(LCD1602_GPIO_PORT,GPIO_Pin_7);
                EO(0);
        }while(sta);
void LCD1602_WriteCmd(uint8_t cmd) //寫指令
        LCD1602_WaitReady();
        RSO(0);
        RWO(0);
        EO(0);
        EO(1);
        LCD1602_GPIO_PORT->ODR &= (cmd|0xFF00);
        EO(0);
        SysTick_Delay_Us(400);
void LCD1602_WriteDat(uint8_t dat) //寫數據
        RSO(1);
        RWO(0);
        SysTick_Delay_Us(30);
        EO(1);
        LCD1602_GPIO_PORT->ODR &=(dat|0xFF00);
        EO(0);
void LCD1602_SetCursor(uint8_t x, uint8_t y)
    uint8_t addr;
    if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LCD1602_WriteCmd(addr|0x80);  //設置RAM地址
void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str, uint8_t len)
    LCD1602_SetCursor(x, y);        //設置起始地址
    while (len--)         //連續寫入len個字符數據
        LCD1602_WriteDat(*str++);
void LCD1602_Init(void)
          LCD1602_GPIO_Config();   //開啟GPIO口
    LCD1602_WriteCmd(0X38);  //16*2顯示,5*7點陣,8位數據接口
    LCD1602_WriteCmd(0x0C);  //顯示器開,光標關閉
    LCD1602_WriteCmd(0x06);  //文字不動,地址自動+1
    LCD1602_WriteCmd(0x01);  //清屏
int main(void)
{ uint8_t str[8];
        RCC_ClocksTypeDef RCC_Clocks;                        //時鐘結構體
        SysTick_Init(); //滴答定時器初始化
  LCD1602_Init();
        RCC_GetClocksFreq(&RCC_Clocks);                //獲取片上時鐘
        str[0]=RCC_Clocks.SYSCLK_Frequency/10000000+0x30;
        str[1]=RCC_Clocks.SYSCLK_Frequency/1000000%10+0x30;
        LCD1602_ShowStr(0,0,"sysclk:",7);
        LCD1602_ShowStr(7,0,str,2);
        LCD1602_ShowStr(9,0,"MHz",3);
        while(1);
void SysTick_Delay_Us( __IO uint32_t us)  //us延時函數
        uint32_t i;
        RCC_GetClocksFreq(&RCC_Clocks);                //獲取片上真實系統時鐘
        SysTick_Config(RCC_Clocks.SYSCLK_Frequency/1000000);
        for(i=0;i<us;i++)
                // 當計數器的值減小到0的時候,CRTL寄存器的位16會置1
                while( !((SysTick->CTRL)&(1<<16)) );
        // 關閉SysTick定時器
        SysTick->CTRL &=~SysTick_CTRL_ENABLE_Msk;
void SysTick_Delay_Ms( __IO uint32_t ms)  // ms延時函數
        uint32_t i;
        SysTick_Config(RCC_Clocks.SYSCLK_Frequency/1000);
        for(i=0;i<ms;i++)
                // 當置1時,讀取該位會清0
        // 關閉SysTick定時器
        SysTick->CTRL &=~ SysTick_CTRL_ENABLE_Msk;
全部資料51hei附件下載:
滴答定時器LCD1602仿真代碼.7z (189.71 KB, 下載次數: 102)
ID:984343 發表于 2021-12-20 21:31 來自觸屏版 | 顯示全部樓層
仿真圖是Proteus8.8版本的
主站蜘蛛池模板: 免费看黄色片 | 亚洲最大的网站 | 97精品在线 | a毛片视频| 欧美不卡在线观看 | 欧美日韩四区 | 精品久久久久久久久久久久久久久久 | 日韩一级免费视频 | 天天cao | 欧美成人精品欧美一级私黄 | 国产一区在线看 | japanese极品丰满少妇 | 日韩精品视频在线免费观看 | 久久99精品久久久久久 | 欧美精品一区二 | 91在线看片 | 欧美性猛交xxxx黑人猛交 | 日韩午夜片 | 欧美精品第一页 | 婷婷五月在线视频 | 真实人妻互换毛片视频 | 天天操夜夜操狠狠操 | 午夜在线视频 | 一级片在线观看视频 | 欧美日韩亚洲一区 | 欧美不卡在线 | 中文字幕永久免费 | 天天操夜夜操狠狠操 | 成人a毛片| 成年人视频免费看 | 18在线观看免费入口 | 欧美精品久久久久久久多人混战 | 精品一二三 | 国产精品一区二 | 欧洲一区二区三区 | 国产精品免费在线播放 | 精品一区三区 | 91精品久久久久久久久 | 久久精品一区二区三区四区五区 | 一级真人毛片 | 操少妇视频 |
