查看: 2068|回復: 0
VS-RK3399內核的kernel的dts簡寫
ID:959225 發表于 2021-10-26 10:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
VS-RK3399 內核的kernel的dts簡寫:
/dts-v1/;
#include <dt-bindings/input/input.h>
#include "rk3399-videostrong-board.dtsi"
#include "rk3399-android.dtsi"
#include "rk3399-vop-clk-set.dtsi"
#include <dt-bindings/sensor-dev.h>
        model = "Rockchip RK3399 VideoStrong Board MID (Android)";
        compatible = "rockchip,android", "rockchip,rk3399-VideoStrong-boad", "rockchip,rk3399";
          backlight: backlight {      //背光控制
                status = "disabled";
                compatible = "pwm-backlight";
                pwms = <&pwm0 0 25000 0>;
                brightness-levels = <
                          0   1   2   3   4   5   6   7
                          8   9  10  11  12  13  14  15
                         16  17  18  19  20  21  22  23
                         24  25  26  27  28  29  30  31
                         32  33  34  35  36  37  38  39
                         40  41  42  43  44  45  46  47
                         48  49  50  51  52  53  54  55
                         56  57  58  59  60  61  62  63
                         64  65  66  67  68  69  70  71
                         72  73  74  75  76  77  78  79
                         80  81  82  83  84  85  86  87
                         88  89  90  91  92  93  94  95
                         96  97  98  99 100 101 102 103
                        104 105 106 107 108 109 110 111
                        112 113 114 115 116 117 118 119
                        120 121 122 123 124 125 126 127
                        128 129 130 131 132 133 134 135
                        136 137 138 139 140 141 142 143
                        144 145 146 147 148 149 150 151
                        152 153 154 155 156 157 158 159
                        160 161 162 163 164 165 166 167
                        168 169 170 171 172 173 174 175
                        176 177 178 179 180 181 182 183
                        184 185 186 187 188 189 190 191
                        192 193 194 195 196 197 198 199
                        200 201 202 203 204 205 206 207
                        208 209 210 211 212 213 214 215
                        216 217 218 219 220 221 222 223
                        224 225 226 227 228 229 230 231
                        232 233 234 235 236 237 238 239
                        240 241 242 243 244 245 246 247
                        248 249 250 251 252 253 254 255>;
                default-brightness-level = <200>;
        test-power {
                status = "okay";
vsgpio_set {   //自定義
                compatible = "videostrong,gpio";
                pinctrl-names = "default";
                pinctrl-0 = <&b3G_gpio>;
                3G_power = <&gpio0 2 GPIO_ACTIVE_LOW>;
                3G_Spk_GP = <&gpio0 11 GPIO_ACTIVE_HIGH>;
                POWR_LED = <&gpio1 1 GPIO_ACTIVE_HIGH>;
                status = "okay";
vsproc_set {
                compatible = "videostrong,proc";
&backlight {
        status = "okay";
        #enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
&i2s1 {
        status = "okay";
        rockchip,i2s-broken-burst-len;
        rockchip,playback-channels = <2>;
        rockchip,capture-channels = <2>;
        #sound-dai-cells = <0>;
&i2s2 {   //打開音頻通道
        status = "okay";
&hdmi {//打開音頻通道
        status = "okay";
&hdmi_sound {
        status = "okay";
&i2c1 {
        status = "okay";
&i2c4 {
        status = "okay";
        gslx680@40 { //配置觸摸屏
        compatible = "videostrong,gslx680";
        reg = <0x40>;
        touch-gpio = <&gpio1 20 IRQ_TYPE_EDGE_RISING>;
        reset-gpio = <&gpio1 22 GPIO_ACTIVE_LOW>;
        max_x = <1024>;
        max_y = <600>;
        gt9xx@5d { //觸摸屏配置
        compatible = "videostrong,gt9xx";
        reg = <0x5d>;
        tp-size=<911>;
        max-x = <1024>;
        max-y = <600>;
mipitolvds@5a { //mipi 轉LVDS配置
              status = "okay";
        compatible = "videostrong,mipitolvds";
        reset-gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>;
        reg = <0x2d>;
        lsm330_accel@1e {  //重力定義
                status = "okay";
                compatible = "lsm330_acc";
                pinctrl-0 = <&lsm330a_irq_gpio>;
                reg = <0x1e>;
                irq-gpio = <&gpio4 26 IRQ_TYPE_EDGE_RISING>;
                type = <SENSOR_TYPE_ACCEL>;
                irq_enable = <0>;
                poll_delay_ms = <30>;
                layout = <4>;
        lsm330_gyro@6a {
                status = "okay";
                compatible = "lsm330_gyro";
                pinctrl-0 = <&lsm330g_irq_gpio>;
                reg = <0x6a>;
                irq-gpio = <&gpio1 24 IRQ_TYPE_EDGE_RISING>;
                type = <SENSOR_TYPE_GYROSCOPE>;
                irq_enable = <0>;
        sensor@0f {
                status = "okay";
                compatible = "ak8963";
                pinctrl-0 = <&ak8963_irq_gpio>;
                reg = <0x0f>;
                type = <SENSOR_TYPE_COMPASS>;
                irq_enable = <0>;
                layout = <3>;
        mma7600@4c {
                status = "okay";
                compatible = "gs_mma7660";
                pinctrl-0 = <&mma7660_irq_gpio>;
                reg = <0x4c>;
                irq_enable = <1>;
&pwm3 { //遙控器配置
        status = "okay";
        interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH 0>;
        compatible = "rockchip,remotectl-pwm";
        remote_pwm_id = <3>;
        handle_cpu_id = <0>;
        ir_key0 {
                rockchip,usercode = <0xff00>;
                rockchip,key_table =
                        <0xa6        KEY_POWER>,
                        <0xf2        KEY_HOME>,
                        <0xfa        KEY_BACK>,
                        <0xba        KEY_MENU>,
                        <0xf9        KEY_UP>,
                        <0xe9        KEY_DOWN>,
                        <0xa5        KEY_LEFT>,
                        <0xe4        KEY_RIGHT>,
                        <0xe5        KEY_ENTER>,
                        <0xec        KEY_VOLUMEUP>,
                        <0xe8        KEY_VOLUMEDOWN>,
                        <0xe6        KEY_MUTE>,
                  <0xed        388>,
                        <0xad        KEY_1>,
                        <0xaf        KEY_2>,
                        <0xef        KEY_3>,
                        <0xa9        KEY_4>,
                        <0xab        KEY_5>,
                        <0xeb        KEY_6>,
                        <0xb1        KEY_7>,
                        <0xb3        KEY_8>,
                        <0xf3        KEY_9>,
                        <0xf0        KEY_0>,
                        <0xae        KEY_BACKSPACE>,
      <0xde        KEY_SEARCH>;
         ir_key1 {
                rockchip,usercode = <0xfe01>;
                        <0xb0 KEY_BACK>,
                        <0xb4 KEY_F12>,
                        <0xb2 KEY_F11>,
                    <0xed 388>,
            <0xde KEY_SEARCH>;
&isp0 {
        status = "okay";
&isp1 {
        status = "okay";
&isp0_mmu {
        status = "okay";
&isp1_mmu {
        status = "okay";
&pcie_phy {
        status = "okay";
&pcie0 {
        ep-gpios = <&gpio2 4 GPIO_ACTIVE_HIGH>;
        num-lanes = <4>;
        pinctrl-0 = <&pcie_clkreqn>;
        status = "okay";
&mipi_dsi { //MIPI接口的LCD配置
        status = "okay";
        panel {
                compatible ="simple-panel-dsi";
                reg = <0>;
                backlight = <&backlight>;
                dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST |
                                MIPI_DSI_MODE_VIDEO_SYNC_PULSE)>;
                dsi,format = <MIPI_DSI_FMT_RGB888>;
                dsi,lanes = <4>;
                status = "okay";
                display-timings {
                        native-mode = <&timing0>;
                        timing0: timing0 {
                                clock-frequency = <65000000>;
                                hactive = <1024>;
                                vactive = <600>;
                                hback-porch = <80>;
                                hfront-porch = <80>;
                                vback-porch = <20>;
                                vfront-porch = <12>;
                                hsync-len = <2>;
                                vsync-len = <3>;
                                hsync-active = <0>;
                                vsync-active = <0>;
                                de-active = <0>;
                                pixelclk-active = <0>;
&route_hdmi {
        status = "okay";
        connect = <&vopb_out_hdmi>;
&route_mipi {  //MIPI開啟開機圖片功能
        connect = <&vopl_out_mipi>;
        status = "okay";
&mipi_in_vopb {
&hdmi_in_vopl{
&vopb {
        assigned-clocks = <&cru DCLK_VOP0_DIV>;
        assigned-clock-parents = <&cru PLL_VPLL>;
&vopl {
        assigned-clocks = <&cru DCLK_VOP1_DIV>;
        assigned-clock-parents = <&cru PLL_CPLL>;
&pinctrl {
        lcd-panel {
                lcd_panel_reset: lcd-panel-reset {
                        rockchip,pins = <4 30 RK_FUNC_GPIO &pcfg_pull_up>;
        hdmiin {
                hdmiin_gpios: hdmiin_gpios {
                rockchip,pins =
                                <2 5 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 6 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 7 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 8 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 9 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 12 RK_FUNC_GPIO &pcfg_pull_none>;
        ak8963{
            ak8963_irq_gpio:ak8963_irq_gpio{
                rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_pull_none>;
        mma7660 {
                mma7660_irq_gpio: mma7660_irq_gpio {
   lsm330_a {
                lsm330a_irq_gpio: lsm330a-irq-gpio {
        lsm330_g {
                lsm330g_irq_gpio: lsm330g-irq-gpio {
                        rockchip,pins = <1 24 RK_FUNC_GPIO &pcfg_pull_none>;
vsgpio_back {//配置GPIO輸出功能
                b3G_gpio: b3G_gpio {
                        rockchip,pins = <0 2 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 12 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 27 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 28 RK_FUNC_GPIO &pcfg_pull_up>;
主站蜘蛛池模板: 欧美日韩在线精品 | 国产成人免费在线视频 | av每日更新 | 男女啪啪免费网站 | 中文字幕av久久爽av | 天天操网站 | 日韩一区二区不卡 | 曰韩av| 国产欧美精品一区二区色综合 | 久久不卡视频 | 中文在线视频 | 激情网站在线观看 | 亚洲一区二区三区在线视频 | 中文字幕在线观看日韩 | 日韩成人在线播放 | 国产免费一区二区三区 | 欧美日韩精品 | 欧美在线观看视频 | 茄子视频色 | 美女天天干 | 中文字幕二区 | 久久精品视频一区二区 | 久久久一区二区 | 手机看片福利永久 | 日日夜夜艹| 日韩av免费播放 | 色婷婷18 | 日韩成人免费视频 | 久久久天堂国产精品女人 | 一级大片免费看 | 国产黄色精品视频 | 日韩怡红院 | 欧美a级成人淫片免费看 | 天堂在线中文资源 | 国产高清在线观看 | 欧美日韩精品一区二区在线播放 | 一区二区三区四区在线视频 | 国产一级片免费 | 久久免费视频观看 | 国产女人水真多18毛片18精品 | 黄色网在线 |
