查看: 1739|回復: 0
STM32單片機lcd16c02+adc程序
ID:967993 發表于 2021-11-1 14:53 | 顯示全部樓層 |閱讀模式
  1. // LCD1602.h
  2. #ifndef _BSP_LCD1602_H
  3. #define _BSP_LCD1602_H
  4. #include "stm32f10x.h"
  5. #include "stm32f10x_gpio.h"
  6. #include "bsp_SysTick.h"
  7. #define LCD1602_CLK  RCC_APB2Periph_GPIOB
  8. #define LCD1602_GPIO_PORT   GPIOB
  9. #define LCD1602_E    GPIO_Pin_10              //定義使能引腳
  10. #define LCD1602_RW   GPIO_Pin_11             //定義讀寫引腳
  11. #define LCD1602_RS   GPIO_Pin_12             //定義數據、命名引腳
  12. #define EO(X)         X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_E)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_E))
  13. #define RWO(X)        X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_RW)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_RW))
  14. #define RSO(X)        X? (GPIO_SetBits(LCD1602_GPIO_PORT,LCD1602_RS)):(GPIO_ResetBits(LCD1602_GPIO_PORT,LCD1602_RS))
  15. //只能是某個GPIO口的低八位
  16. #define DB0                                        GPIO_Pin_0
  17. #define DB1                                        GPIO_Pin_1
  18. #define DB2                                        GPIO_Pin_2
  19. #define DB3                                        GPIO_Pin_3
  20. #define DB4                                        GPIO_Pin_4
  21. #define DB5                                        GPIO_Pin_5
  22. #define DB6                                        GPIO_Pin_6
  23. #define DB7                                        GPIO_Pin_7
  24. void LCD1602_Init(void);  //初始化LCD602;
  25. void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str,uint8_t len);
  26. void LCD_ShowNum(uint8_t x, uint8_t y,uint8_t num);
  27. void LCD_ShowChar(uint8_t x, uint8_t y,uint8_t dat);
  28. #endif //_BSP_LCD1602_H
#include "adc.h"
void ADC1_GPIO_Config(void){
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1, ENABLE);        //使能ADC1,GPIOC時鐘
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //
    //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//為什么沒有配置這個????
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;        //模擬輸入
    GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PC4
void ADC_Config(void)
  ADC_InitTypeDef ADC_InitStructure;//ADC結構體變量//注意在一個語句快內變量的聲明要放在可執行語句的前面,否則出錯,因此要放在ADC1_GPIO_Config();前面
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在獨立模式
  ADC_InitStructure.ADC_ScanConvMode =        DISABLE; //使能掃描
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC轉換工作在連續模式
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//由軟件控制轉換,不使用外部觸發
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//轉換數據右對齊
  ADC_InitStructure.ADC_NbrOfChannel = 1;//轉換通道為1
  ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
  //ADC1選擇信道14,音序等級1,采樣時間55.5個周期
//  ADC_DMACmd(ADC1, ENABLE);//使能ADC1模塊DMA
  ADC_Cmd(ADC1, ENABLE);//使能ADC1
        ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
//  ADC_ResetCalibration(ADC1); //重置.(復位).ADC1校準寄存器
//  while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校準重置完成
//  ADC_StartCalibration(ADC1);//開始ADC1校準
//  while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校準完成
//  ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能ADC1軟件開始轉換
  1. //adc.h
  2. #ifndef  __ADC_H
  3. #define  __ADC_H
  4. #include "sys.h"
  5. void Adc_Init(void);
  6. void ADC1_GPIO_Config(void);
  7. void ADC_Config(void);
  8. #endif
  1. #include "bsp-lcd1602.h"
  2. void LCD1602_GPIO_Config(void)
  3. {
  4.         RCC_APB2PeriphClockCmd(LCD1602_CLK, ENABLE);
  5.         GPIO_InitTypeDef LCD1602_GPIOStruct;
  6.         LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_PP;
  7.         LCD1602_GPIOStruct.GPIO_Speed = GPIO_Speed_10MHz;
  8.         LCD1602_GPIOStruct.GPIO_Pin =  LCD1602_E | LCD1602_RS | LCD1602_RW ;
  9.         GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
  10.         LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_OD;
  11.         LCD1602_GPIOStruct.GPIO_Pin =   DB0 |  DB1 | DB2 |DB3 |  DB4 | DB5|
  12.        DB6 |  DB7 ;     //設置為開漏輸出
  13.         GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
  14. }
  15. void LCD1602_WaitReady(void) //檢測忙狀態
  16. {
  17.         uint8_t sta;
  18.         GPIOB->ODR =0x00FF;
  19.         RSO(0);
  20.         RWO(1);
  21.         EO(1);
  22.         SysTick_Delay_Us(1);
  23.         do{
  24.                 sta=GPIO_ReadInputDataBit(LCD1602_GPIO_PORT,GPIO_Pin_7);
  25.                 EO(0);
  26.         }while(sta);
  27. }
  28. void LCD1602_WriteCmd(uint8_t cmd) //寫指令
  29. {
  30.         LCD1602_WaitReady();
  31.         RSO(0);
  32.         RWO(0);
  33.         EO(0);
  34.         SysTick_Delay_Us(1);
  35.         EO(1);
  36.         LCD1602_GPIO_PORT->ODR &= (cmd|0xFF00);
  37.         EO(0);
  38.         SysTick_Delay_Us(400);
  39. }
  40. void LCD1602_WriteDat(uint8_t dat) //寫數據
  41. {
  42.         LCD1602_WaitReady();
  43.         RSO(1);
  44.         RWO(0);
  45.         SysTick_Delay_Us(30);
  46.         EO(1);
  47.         LCD1602_GPIO_PORT->ODR &=(dat|0xFF00);
  48.         EO(0);
  49.         SysTick_Delay_Us(400);
  50. }
  51. void LCD1602_SetCursor(uint8_t x, uint8_t y)
  52. {
  53.     uint8_t addr;
  54.
  55.     if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
  56.         addr = 0x00 + x;  //第一行字符地址從0x00起始
  57.     else
  58.         addr = 0x40 + x;  //第二行字符地址從0x40起始
  59.     LCD1602_WriteCmd(addr|0x80);  //設置RAM地址
  60. }
  61. void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str, uint8_t len)
  62. {
  63.     LCD1602_SetCursor(x, y);        //設置起始地址
  64.     while (len--)         //連續寫入len個字符數據
  65.     {
  66.         LCD1602_WriteDat(*str++);
  67.     }
  68. }
  69. //??1???
  70. //x,y :????
  71. //num:??(0~99)
  72. //-----------------------------*/
  73. void LCD_ShowNum(uint8_t x, uint8_t y,uint8_t num)
  74. {
  75.             LCD1602_SetCursor(x, y);        //設置起始地址
  76.     LCD_ShowChar(x,y,num+'0');
  77.
  78. }
  79. void LCD_ShowChar(uint8_t x, uint8_t y,uint8_t dat)
  80. {
  81.             LCD1602_SetCursor(x, y);        //設置起始地址
  82.         LCD1602_WriteDat(dat);
  83. }
  84. void LCD1602_Init(void)
  85. {
  86.           LCD1602_GPIO_Config();   //開啟GPIO口
  87.     LCD1602_WriteCmd(0X38);  //16*2顯示,5*7點陣,8位數據接口
  88.     LCD1602_WriteCmd(0x0C);  //顯示器開,光標關閉
  89.     LCD1602_WriteCmd(0x06);  //文字不動,地址自動+1
  90.     LCD1602_WriteCmd(0x01);  //清屏
  91. }
  92.
  93.
  1. int main()
  2. #include "stm32f10x.h"
  3. #include "bsp-lcd1602.h"
  4. #include "delay.h"
  5. #include "sys.h"
  6. #include "adc.h"
  7. int main(void)
  8. {
  9. int a,b,c,d;
  10.         float temp;
  11.
  12.         delay_init();                     //延時函數初始化
  13.         LCD1602_Init();
  14.   ADC1_GPIO_Config();
  15.   ADC_Config();
  16.         LCD1602_ShowStr(1,0,"adcvalue=0.0V",13);
  17.         LCD1602_ShowStr(1,1,"LIUTONGBO 32",13);
  18.
  19.         while(1)
  20.         {
  21.                 b=ADC_GetConversionValue(ADC1);
  22.         temp=(float)b*(3.4/4096);
  23.         a=temp/0.675;
  24.         c=temp*10;
  25.         d=c%10;
  26.         LCD_ShowNum(10,0,a);
  27.         LCD_ShowNum(12,0,d);
  28.         }
  29. }
參與人數 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
主站蜘蛛池模板: 欧美一级特黄视频 | 女教师合集乱500篇小说 | 亚洲精品欧美 | 色综合av | 视频一区在线观看 | 黄色大片在线 | 蜜桃精品一区二区 | 成人一区在线观看 | 天天爽天天爽 | 日韩二区三区 | 欧美日韩亚洲一区二区 | 日韩成人精品 | 在线播放av网站 | 97青青草| 日日夜夜草 | 一级免费毛片 | 国产成人精品亚洲 | 日韩在线视频播放 | 欧美色综合天天久久综合精品 | 国模一区二区三区 | 在线观看黄色av | 日韩第一区 | 红桃视频成人 | 免费毛片在线 | 欧美激情一区二区三区 | 精品无人国产偷自产在线 | 亚洲国产欧美在线 | 国产主播一区二区 | 波多野结衣乳巨码无在线观看 | 永久免费精品视频 | 免费看黄色大片 | 日韩精品福利 | 精品国产91| 国产一级视频在线观看 | 三级在线免费观看 | 久久在线 | 亚洲国产成人在线 | 中文字幕高清在线 | 国产视频一二三 | 亚洲激情中文字幕 | 97在线超碰 |
