查看: 4198|回復: 2
ESP8266開發板NODEMCU點燈科技WIFI插座小度智能屏遠控測試成功
ID:83626 發表于 2021-11-23 08:06 | 顯示全部樓層 |閱讀模式
制作出來的實物圖如下:
直接上代碼
  1. // 低電平繼電器動作,高電平繼電器釋放 小度語音 操作 成功,20211121
  2. /////////////////////////////////////////////////////////////////////////////////
  3. #define BLINKER_WIFI
  4. #define BLINKER_MIOT_OUTLET
  5. #define BLINKER_DUEROS_OUTLET
  6. #define BLINKER_ALIGENIE_OUTLET
  7. #define BLINKER_PRINT Serial
  8. #include <WiFiManager.h>
  9. #include <Blinker.h>
  10. char auth[] = "--------";
  11. int relay = 2;
  12. int key   = 0;
  13. int counter = 0;
  14. BlinkerButton Button1("btn-abc");
  15. WiFiManager wifiManager;
  16. char devname[] = "ESP8266_chazuo";
  17. void WebConfig() {
  18.   Serial.println("Entered config mode...");
  19.   wifiManager.setConfigPortalTimeout(60);
  20.   wifiManager.autoConnect(devname);
  21.   WiFi.hostname(devname);
  22.   Serial.println("");
  23.     Serial.print("ESP8266 Connected to ");
  24.     Serial.println(WiFi.SSID());
  25.     Serial.print("IP address:\t");
  26.     Serial.println(WiFi.localIP());
  27. }
  28. //=================================================================
  29. void button1_callback(const String & state)
  30. {
  31.   BLINKER_LOG("app操作了!: ", state);
  32.   if (digitalRead(relay)==LOW) {
  33.     BLINKER_LOG("滅燈!");
  34.     digitalWrite(relay, HIGH);
  35.     Button1.color("gray");
  36.     Button1.text("插座已關閉");
  37.     Button1.print("off");
  38.   }
  39.   else if (digitalRead(relay)==HIGH) {
  40.     BLINKER_LOG("亮燈!");
  41.     digitalWrite(relay,LOW);
  42.     Button1.color("red");
  43.     Button1.text("插座已打開");
  44.     Button1.print("on");
  45.   }
  46. }
  47. //=================================================================
  48. void miotPowerState(const String & state)
  49. {
  50.     BLINKER_LOG("小愛語音操作!");
  51.     if (state == BLINKER_CMD_ON){
  52.         digitalWrite(relay,LOW);
  53.         BlinkerMIOT.powerState("on");
  54.         BLINKER_LOG("亮燈!");
  55.         BlinkerMIOT.print();
  56.     }
  57.     else if (state == BLINKER_CMD_OFF){
  58.         digitalWrite(relay,HIGH);
  59.         BlinkerMIOT.powerState("off");
  60.         BLINKER_LOG("滅燈!");
  61.         BlinkerMIOT.print();
  62.     }
  63. }
  64. //=================================================================
  65. void miotQuery(int32_t queryCode)
  66. {
  67.     BLINKER_LOG("MIOT Query codes: ", queryCode);
  68.     switch (queryCode)
  69.     {
  70.         case BLINKER_CMD_QUERY_ALL_NUMBER :
  71.             BLINKER_LOG("MIOT Query All");
  72.             BlinkerMIOT.powerState(relay ? "on" : "off");
  73.             BlinkerMIOT.print();
  74.             break;
  75.         case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
  76.             BLINKER_LOG("MIOT Query Power State");
  77.             BlinkerMIOT.powerState(relay ? "on" : "off");
  78.             BlinkerMIOT.print();
  79.             break;
  80.         default :
  81.             BlinkerMIOT.powerState(relay ? "on" : "off");
  82.             BlinkerMIOT.print();
  83.             break;
  84.     }
  85. }
  86. //=================================================================
  87. void duerPowerState(const String & state)
  88. {
  89.     BLINKER_LOG("小度語音操作!");              //串口打印
  90.     if (state == BLINKER_CMD_ON){
  91.         digitalWrite(relay,LOW);
  92.         BlinkerDuerOS.powerState("on");     //????
  93.         BLINKER_LOG("亮燈!");
  94.         BlinkerDuerOS.print();
  95.     }
  96.     else if (state == BLINKER_CMD_OFF){
  97.         digitalWrite(relay,HIGH);
  98.         BlinkerDuerOS.powerState("off");
  99.         BLINKER_LOG("滅燈!");
  100.         BlinkerDuerOS.print();
  101.     }
  102. }
  103. //=================================================================
  104. void duerQuery(int32_t queryCode)
  105. {
  106.     BLINKER_LOG("DuerOS Query codes: ", queryCode);
  107.     switch (queryCode)
  108.     {
  109.         case BLINKER_CMD_QUERY_ALL_NUMBER :
  110.             BLINKER_LOG("DuerOS Query All");
  111.             BlinkerDuerOS.powerState(relay ? "on" : "off");
  112.             BlinkerDuerOS.print();
  113.             break;
  114.         case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
  115.             BLINKER_LOG("DuerOS Query Power State");
  116.             BlinkerDuerOS.powerState(relay ? "on" : "off");
  117.             BlinkerDuerOS.print();
  118.             break;
  119.         default :
  120.             BlinkerDuerOS.powerState(relay ? "on" : "off");
  121.             BlinkerDuerOS.print();
  122.             break;
  123.     }
  124. }
  125. //=================================================================
  126. void aligeniePowerState(const String & state)
  127. {
  128.     BLINKER_LOG("天貓精靈語音操作!");
  129.     if (state == BLINKER_CMD_ON){
  130.         digitalWrite(relay,LOW);
  131.         BlinkerAliGenie.powerState("on");
  132.         BLINKER_LOG("亮燈!");
  133.         BlinkerAliGenie.print();
  134.     }
  135.     else if (state == BLINKER_CMD_OFF){
  136.         digitalWrite(relay,HIGH);
  137.         BlinkerAliGenie.powerState("off");
  138.         BLINKER_LOG("滅燈!");
  139.         BlinkerAliGenie.print();
  140.     }
  141. }
  142. //=================================================================
  143. void aligenieQuery(int32_t queryCode)
  144. {
  145.     BLINKER_LOG("AliGenie Query codes: ", queryCode);
  146.     switch (queryCode)
  147.     {
  148.         case BLINKER_CMD_QUERY_ALL_NUMBER :
  149.             BLINKER_LOG("AliGenie Query All");
  150.             BlinkerAliGenie.powerState(relay ? "on" : "off");
  151.             BlinkerAliGenie.print();
  152.             break;
  153.         case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
  154.             BLINKER_LOG("AliGenie Query Power State");
  155.             BlinkerAliGenie.powerState(relay ? "on" : "off");
  156.             BlinkerAliGenie.print();
  157.         default :
  158.             BlinkerAliGenie.powerState(relay ? "on" : "off");
  159.             BlinkerAliGenie.print();
  160.             break;
  161.     }
  162. }
  163. //=================================================================
  164. void dataRead(const String & data)
  165. {
  166.     BLINKER_LOG("Blinker readString: ", data);
  167.     Blinker.vibrate();
  168.     uint32_t BlinkerTime = millis();
  169.     Blinker.print("millis", BlinkerTime);
  170. }
  171. //=========================================================================
  172. void heartbeat()
  173. {
  174.   BLINKER_LOG("狀態同步!");
  175.    if (digitalRead(relay)==LOW)
  176.     {
  177.         Button1.print("on");
  178.         Button1.color("red");
  179.         Button1.text("繼電器打開");
  180.     }
  181.     else
  182.     {
  183.         Button1.print("off");
  184.         Button1.color("gray");
  185.         Button1.text("繼電器關閉");
  186.     }
  187. }
  188. //=================================================================
  189. void sdms()
  190. {
  191. if (digitalRead(relay)==HIGH&&digitalRead(key)==LOW)
  192.   {
  193.      Blinker.delay(400);
  194.      if (digitalRead(key)==HIGH)
  195.      {
  196.       BLINKER_LOG("本地開關動作!");
  197.       BLINKER_LOG("亮燈!");
  198.       digitalWrite(relay,LOW);
  199.       Button1.color("red");
  200.       Button1.text("繼電器打開");
  201.       Button1.print("on");
  202.       }
  203.    }
  204. if (digitalRead(relay)==LOW&&digitalRead(key)==LOW)
  205.     {
  206.       Blinker.delay(400);
  207.       if (digitalRead(key)==HIGH)
  208.         {
  209.         BLINKER_LOG("本地開關動作!");
  210.         BLINKER_LOG("滅燈!");
  211.         digitalWrite(relay, HIGH);
  212.         Button1.color("gray");
  213.         Button1.text("繼電器關閉");
  214.         Button1.print("off");
  215.         }
  216.       }
  217.   }
  218. //=================================================================
  219. void setup()
  220. {  Serial.begin(115200);
  221.   delay(10);
  222.   BLINKER_DEBUG.stream(Serial);
  223.   BLINKER_DEBUG.debugAll();
  224.   pinMode(relay, OUTPUT);
  225.   digitalWrite(relay, LOW);
  226.   pinMode(key,INPUT_PULLUP);
  227.   WebConfig();
  228.   Blinker.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
  229.   Button1.attach(button1_callback);
  230.   Blinker.attachData(dataRead);
  231.   Blinker.attachHeartbeat(heartbeat);
  232.   BlinkerMIOT.attachPowerState(miotPowerState);
  233.   BlinkerDuerOS.attachPowerState(duerPowerState);
  234.   BlinkerAliGenie.attachPowerState(aligeniePowerState);
  235.   BlinkerMIOT.attachQuery(miotQuery);
  236.   BlinkerDuerOS.attachQuery(duerQuery);
  237.   BlinkerAliGenie.attachQuery(aligenieQuery);
  238. }
  239. //=================================================================
  240. void loop() {
  241.   Blinker.run();
  242.   sdms();
  243.   }
ID:964308 發表于 2021-12-14 00:49 | 顯示全部樓層
arduino的WiFi庫能用在esp8266上嗎,需不需要自己下載庫
ID:156580 發表于 2021-12-21 12:51 | 顯示全部樓層
沒注釋?
主站蜘蛛池模板: 欧美亚洲 | 亚洲视频在线播放 | av片在线观看 | 在线观看视频一区 | 欧美三级精品 | 久久成人av | 黄色片中文字幕 | 欧美日韩免费一区二区三区 | 欧美久久一区二区 | 热久久中文字幕 | 日韩在线网址 | 性欧美69 | 国产黄色免费观看 | 欧美精品久久99 | 韩日视频 | 亚洲第十页| 国产一区二区三区在线看 | 一级黄视频 | 国产视频www | 国产午夜免费视频 | 美女福利网站 | 日韩欧美国产一区二区三区 | 色综合视频在线观看 | 欧美精品在线看 | 亚洲精品www久久久久久广东 | 日本黄色一级视频 | 午夜一区| 日韩免费在线观看视频 | 国产成人亚洲精品自产在线 | 91色网站| 亚洲天堂偷拍 | 永久免费av | 亚洲免费久久 | 国产天堂网 | 国产精品福利一区 | www.成人网| 福利片在线 | 天天干天天弄 | 成人永久免费 | www.色综合| 国产高清毛片 |
