查看: 2842|回復: 0
單片機+DAC0832產生波形程序 通過按鍵選擇 Proteus仿真
ID:978036 發表于 2021-11-28 22:44 | 顯示全部樓層 |閱讀模式
上篇的升級版!proteus仿真圖和代碼:
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #include<ABSACC.H>
  5. #define  data_OUT  XBYTE[0x7FFF]
  6. char code dat[]={
  7.      0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
  8.      0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
  9.      0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
  10.      0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  11.      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
  12.      0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
  13.      0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
  14.      0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
  15.      0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
  16.      0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
  17.      0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
  18.      0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  19.      0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
  20.      0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
  21.      0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
  22.      0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x7E
  23. };
  24. bit flag=0;
  25.   void delay(unsigned  int N)
  26.   {
  27.   int i;
  28.   for(i=0;i<N;i++);
  29.   }
  30. void conversion_once_0832(unsigned char out_data)
  31.            {
  32.            data_OUT=out_data; //輸出數據
  33.            delay(10);         //延時等待轉換
  34.             }
  35. uchar  keyscan()
  36. {
  37. uchar key;
  38. if(P1!=0xff)
  39.   {
  40.    delay(61);
  41.    key=P1;
  42.    if(key!=0xff)
  43.     flag=~flag;
  44.     return(key);
  45.   }
  46. }
  47. void triangle()
  48. {
  49.   uchar k;
  50.   for(k=0;k<255;k++)
  51.     conversion_once_0832(k);
  52.   for(;k>0;k--)
  53.      conversion_once_0832(k);
  54. }
  55. void square()
  56. {
  57. conversion_once_0832(0xff);
  58. delay(1000);
  59. conversion_once_0832(0x00);
  60. delay(1000);
  61. }
  62. void juchibo()
  63. {
  64.   uchar j;
  65.   for(j=0;j<255;j++)
  66.    conversion_once_0832(j);
  67. }
  68. void sin()
  69. {
  70. uchar i;
  71. for(i=0;i<255;i++)
  72.    {
  73.     conversion_once_0832(dat[i]);
  74.    }
  75. }
  76. void main()
  77. {
  78. uchar temp;
  79. while(1)
  80.   {
  81.    temp=keyscan();
  82.    switch(temp)
  83.      {
  84.            case 0xfe: do{
  85.                                     triangle();
  86.                                         }while(keyscan()&&(flag==1));break;
  87.            case 0xfd: do{
  88.                                     square();
  89.                                         }while(keyscan()&&(flag==1));break;
  90.            case 0xfb: do{
  91.                                     juchibo();
  92.                                         }while(keyscan()&&(flag==1));break;
  93.        case 0xf7: do{
  94.                                     sin();
  95.                                         }while(keyscan()&&(flag==1));break;
  96.            default: break;
  97.          }
  98.   }
  99. }
  100.
仿真代碼51hei附件下載:
DAC0832(總).7z (70.4 KB, 下載次數: 44)
參與人數 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
主站蜘蛛池模板: 这里都是精品 | 精品一区视频 | 国产午夜麻豆影院在线观看 | 亚洲精品91 | 五月激情综合网 | www.中文字幕 | 日韩成人精品 | 色伊伊 | 国产资源在线观看 | 精品久久精品 | 99婷婷| 精品视频在线播放 | 欧美成人黄色 | 黄网在线免费观看 | 日本a级大片 | 日韩高清国产一区在线 | 欧美在线一级 | 亚洲精品久久久久久久久久久 | 日本黄色免费网站 | 日韩精品视频在线 | 国产又粗又黄又爽又硬的视频 | 国产逼逼 | 欧美日韩亚洲视频 | 97国产超碰 | 日韩欧美不卡 | 天堂网中文 | 黄片毛片在线观看 | 日韩一区二区三区在线 | 免费av网址在线观看 | 亚洲福利一区 | 午夜精品999| www.五月婷婷 | 日韩毛片免费看 | 日韩精品视频一区二区三区 | 国产美女自拍视频 | 欧美一级黄色大片 | 国产99对白在线播放 | 综合久久久久 | 国产高清一区 | 日韩一区精品 | 日韩欧美一区在线 |
