經過幾天的努力終于可以在Proteus 8 示波器顯示小功率晶體管輸出特性曲線圖形了
采用數字電位器生成階梯電壓。在生成每個階梯的同時產生同步信號(占空比%90~95),反向后供鋸齒波產生電路。
程序很簡單:
rem Main.bas file generated by New Project wizard
rem
rem Created: 周五 5月 2022/1/28 TAOTIE
rem Processor: ATmega8
rem Compiler: BASCOM-AVR簡易晶體管圖示儀仿真
rem Write your code here
$regfile = "m8def.dat"
$crystal = 8000000
Dim c As Byte '通道變量
Dim X As Byte '電阻變量
ddrd.7=1
Config Pind.7 = Output
Config Pinb.2 = Output '寫入控制
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1
Spiinit
'調整各通道滑臂在下方輸出電壓為0v
'頻道0--5循環,上臂A--W電阻值由小變大
Do
'For C = 0 To 5
'c=0
For x= 0 To 250 Step 25
Pind.7 =0
Waitus 15
Pind.7 =1
Spiout X , 1
Portb.2 = 0 '寫入
'Spiout c, 1 '寫入通道
Spiout X , 1 '寫入電阻值
Portb.2 = 1 '寫入停止
Pind.7 =1
Next x
'Waitms 100
Loop
End
