查看: 2257|回復: 3
官網AN1299對應的工程,dsPIC33CK芯片,編譯不成功,怎么辦?
ID:959891 發表于 2022-3-3 23:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
在Microchip官網下載了AN1299對應工程,芯片是dsPIC33CK芯片的,編譯不通過。詳細情況請看截圖。
1.截圖的左側工程的文件是灰色。但是雙擊能夠打得開。
2.編譯報錯,都是生成.o格式的文件報錯。
nbproject/Makefile-MCLV2.mk:166: recipe for target 'build/MCLV2/production/_ext/1360926148/adc.o' failed
ID:959891 發表于 2022-3-5 14:44 | 只看該作者
有沒有大神幫忙看看?
ID:285526 發表于 2023-10-18 00:50 | 只看該作者
I am using DSPIC33CK32MC102 , I have code and its hex file ready. I made the connections for the controller those are as follows:
    Pullup resistor of 5.5 kΩ for MCLR pin and 100 Ω between pullup and MCLR pin
    0.1 uF ceramic capacitor between VDD and VSS as told in datasheet
I am using PICKIT 4 for programming where the pin are connected as follows:
    MCLR = pin 27
    VDD = pin 20
    VSS = pin 19
    PGD = pin17
    PGC = pin 18
The connections are perfect and no wire is bas solder
When I plug USB to laptop and click "connect" it says following error and connects anyhow:
    Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device. UDID1 = 000000 UDID2 = 000000 UDID3 = 000000 UDID4 = 000000 UDID5 = 000000
After this, when I click "program" it gives following error:
    Programming did not complete. You are trying to change protected boot memory. In order to do this you must select the "Boot, Secure and General Segments" option on the debug tool Secure Segment properties page.
Then in settings > secure segment > segments to be programmed > Boot, General and Config segment is selected.
    [ Pgm ] at 0x0, expected 0x00040200, got 0x00000000. You have set the program speed to Normal. The circuit on your board may require you to slow the speed down. Please change the setting in the tool properties to low and try the operation again. Programming did not complete.
Then in settings > PICKIT4 tool options > programming speed > low selected.
    [ Pgm ] at 0x0, expected 0x00040200, got 0x00000000. Programming did not complete.
Also this approach:
After this I click "erase" followed by "read" it says:
    Read complete Warning: Debug bit is set on target image. This may not run correctly in production.
Now if I hit "program" it says following warning:
    Memory Image changed do you wish to continue programming device
Selecting yes it programs successfully, but I don't know what has he program its more like a blank file is been programmed.
The following memory area(s) will be programmed:
    program memory: start address = 0x0, end address = 0x5eff configuration memory Programming/Verify complete 2023-08-02 15:58:58 +0530 - Programming complete *** Hold In Reset mode is enabled ***
help me,
is it
hardware error
How i can rid of it.
ID:285526 發表于 2023-10-18 15:15 | 只看該作者
我有與上面鏈接相同的問題,
有什么可以幫助我的嗎
主站蜘蛛池模板: 国产精品二 | 国产乱码久久久久久 | 欧美性猛交xxxx乱大交退制版 | 欧美理伦 | 国产黄色免费看 | 久久精品在线观看 | 青青草视频污 | 欧美日韩成人在线 | 国产黄色精品视频 | 成人欧美激情 | 超碰在线免费 | 中文字字幕在线 | 最新国产精品视频 | 在线亚洲精品 | 日本免费黄色网址 | 亚洲va国产va天堂va久久 | www.色日本| 欧美日韩亚洲综合 | 日本精品在线视频 | 91porn在线 | 色婷av| 伊人网在线| 亚洲视频一区二区三区四区 | 在线天堂av| 国产精品欧美在线 | 久久国产成人 | 亚洲一区二区三区在线播放 | 色99999| 特一级黄色片 | 欧美久久网 | 一区二区视频在线播放 | 欧美日韩福利 | 久久精品导航 | 男男成人高潮片免费网站 | 91视频精品| 自拍偷拍中文字幕 | 两性午夜视频 | 色婷婷国产 | 精品亚洲一区二区三区四区五区 | 欧美日韩一区二区三区四区 | 91视频在线 |
