設(shè)計(jì)一個(gè)單片機(jī)鍵盤接口電路,實(shí)現(xiàn)4*4矩陣鍵盤,用數(shù)碼管顯示相應(yīng)按鍵內(nèi)容,當(dāng)指定某一個(gè)按鍵連續(xù)被按三次時(shí),顯示“口”字符號(hào),按鍵有去抖動(dòng)功能,數(shù)碼管可以通過清零鍵清零。
單片機(jī)源程序如下:
- //0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71 共陰
- //0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E 共楊
- #include <reg52.h>
- #define GPIO_DIG P0 //段選數(shù)碼管
- #define GPIO_KEY P2 //矩陣按鍵
- sbit led = P1^0;
- typedef unsigned char uchar;
- typedef unsigned int uint;
- uint keynum = 0;
- uint count=0;
- uchar code table[]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
- uchar code table0[]={0x5c};
- void delay( uchar i ){
- while( i-- );
- void key44scan(void)//鍵盤掃描函數(shù)
- // uint count=0;
- uint t;
- P2=0xfe;
- t=P2;
- t=t&0xf0;
- if(t!=0xf0){
- delay(100);
- if(t!=0xf0)
- t=P2;
- count++;
- switch(t)
- case 0xee:keynum=1; break;
- case 0xde:keynum=5; break;
- case 0xbe:keynum=9; break;
- case 0x7e:keynum=13; break;
- P0=table[keynum];
- while(t!=0xf0)
- t=P2;
- t=t&0xf0;
- P2=0xfd;
- t=P2;
- t=t&0xf0;
- if(t!=0xf0){
- delay(100);
- if(t!=0xf0)
- t=P2;
- count++;
- switch(t)
- case 0xed:keynum=2; break;
- case 0xdd:keynum=6; break;
- case 0xbd:keynum=10; break;
- case 0x7d:keynum=14; break;
- P0=table[keynum];
- while(t!=0xf0)
- t=P2;
- t=t&0xf0;
- P2=0xfb;
- t=P2;
- t=t&0xf0;
- if(t!=0xf0){
- delay(100);
- if(t!=0xf0)
- t=P2;
- count++;
- switch(t)
- case 0xeb:keynum=3; break;
- case 0xdb:keynum=7; break;
- case 0xbb:keynum=11; break;
- case 0x7b:keynum=15; break;
- P0=table[keynum];
- while(t!=0xf0)
- t=P2;
- t=t&0xf0;
- P2=0xf7;
- t=P2;
- t=t&0xf0;
- if(t!=0xf0){
- delay(100);
- if(t!=0xf0)
- t=P2;
- count++;
- switch(t)
- case 0xe7:keynum=4; break;
- case 0xd7:keynum=8; break;
- case 0xb7:keynum=12; break;
- case 0x77:keynum=0; break;
- P0=table[keynum];
- while(t!=0xf0)
- t=P2;
- t=t&0xf0;
- // if(count==3){
- // count = 0;
- // led =~ led;
- // P0=table0[0];
- // delay(1000);
- void main (){
- led = 0;
- while(1) {
- key44scan();
- if(count==3){
- //count = 0;
- led =~ led;
- P0=table0[0];
- // delay(1000);
- if(count==4){
- count = 0;
- led =~ led;
- P0=table[0];
- // delay(1000);
Keil代碼與Proteus仿真下載:
實(shí)驗(yàn)2.7z
(65.26 KB, 下載次數(shù): 48)
2022-4-8 16:14 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
