查看: 3602|回復: 1
基于STM32103C8的DHT22溫濕度LCD12864顯示代碼
ID:235055 發表于 2022-5-15 11:30 | 顯示全部樓層 |閱讀模式
使用STM32F103C8T6最小系統,搭載DHT22溫濕度傳感器,顯示屏用12864,測量數據和溫度計的顯示數值基本一致!
溫濕度顯示
對比溫度計顯示
  1. #include "humiture.h"
  2. #include "systick.h"
  3. char RHData_H_Temp,RHData_L_Temp,TData_H_Temp,TData_L_Temp,CheckData_Temp;      //溫濕度數據校驗前存放位置
  4. char RHData_H,RHData_L,TData_H,TData_L,CheckData;       //最終溫濕度數據存放處
  5. char check_temp;
  6. void Humitureport_outputinit(void)
  7. {
  8.         GPIO_InitTypeDef GPIO_InitStructure_A;                 //聲明一個結構體變量,用來初始化GPIO_A ; A PORT AS OUTPUT
  9.
  10.         //SystemInit();                                        //system CLK initial
  11.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //enable APB2 external clock
  12.                 /*  配置GPIO_A的模式和IO口 */
  13.         GPIO_InitStructure_A.GPIO_Pin =   Humiture_Port;                  //選擇你要設置的IO口
  14.         GPIO_InitStructure_A.GPIO_Mode =  GPIO_Mode_Out_PP;                 //設置推挽輸出模式
  15.         GPIO_InitStructure_A.GPIO_Speed = GPIO_Speed_50MHz;                 //設置傳輸速率
  16.         GPIO_Init(GPIOA,&GPIO_InitStructure_A);                            //init GPIOA port by GPIO_InitStructure structure
  17.
  18. }
  19. void Humitureport_inputinit(void)
  20. {
  21.         GPIO_InitTypeDef GPIO_InitStructure_A;                        //聲明一個結構體變量,用來初始化GPIO_A ; A PORT AS OUTPUT
  22.         //SystemInit();                                        //system CLK initial
  23.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //enable APB2 external clock
  24.                 /*  配置GPIO_A的模式和IO口 */
  25.         GPIO_InitStructure_A.GPIO_Pin =   Humiture_Port;             //選擇你要設置的IO口
  26.         GPIO_InitStructure_A.GPIO_Mode =  GPIO_Mode_IPU;                   //設置為上拉輸入模式
  27.         GPIO_InitStructure_A.GPIO_Speed = GPIO_Speed_50MHz;                 //設置傳輸速率
  28.         GPIO_Init(GPIOA,&GPIO_InitStructure_A);                            //init GPIOA port by GPIO_InitStructure structure
  29.
  30. }
  31. char  Bit_Select(void)
  32.       {
  33.
  34.                 uchar i,temp;
  35.                                   uchar Byte_Data = 0;          //存放每字節溫濕度的數據
  36. //                                  Byte_Data = 0;
  37. //          Humitureport_inputinit();
  38.           for(i=0;i<8;i++)
  39.                  {
  40.                            //FLAG=2;
  41.                            //while((!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12))&&FLAG++);    //判斷數據位是0還是1
  42.                                                   while(!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12));    //判斷數據位是0還是1
  43.                                 delay_us(30);                                                   //如果30微秒過后引腳還為高電平則為1
  44.                     if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12))
  45.        temp = 1;
  46.               else
  47.                 temp = 0;
  48.                           //FLAG=2;
  49.                           while(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12));
  50.
  51.                           // if(FLAG == 1)break;           //超時則跳出for循環
  52.
  53.                           Byte_Data<<=1;
  54.                            Byte_Data|= temp;
  55.                  }
  56.                  return Byte_Data;
  57.               }
  58.
  59. /*******************************************************************************
  60. * 函 數 名         : HumitureRead
  61. * 函數功能                     : 溫濕度數據讀取
  62. * 輸    入         : 無
  63. * 輸    出         : 無
  64. *******************************************************************************/
  65.
  66. void HumitureRead(void)
  67.         {
  68.             Humitureport_outputinit();                  //端口配置為輸出模式
  69.       GPIO_ResetBits(GPIOA,GPIO_Pin_12);          //主機拉低18ms
  70.             delay_ms(1);
  71.             GPIO_SetBits(GPIOA,GPIO_Pin_12);            //主機由上拉電阻拉高延時30us
  72.       delay_us(30);
  73.                   Humitureport_inputinit();                   //主機設為輸入模式
  74.
  75.             if(!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12))                //判斷DHT22是否有響應信號輸出
  76.                {
  77. //                 FLAG=2;
  78. //                 while((!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12))&&FLAG++);      //判斷DHT22的80us響應信號是否結束
  79. //                 FLAG=2;
  80. //                 while((GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12))&&FLAG++);       //判斷DHT22是否發出80us高電平,如果是進入數據接受狀態
  81.            //FLAG=2;
  82.                  while(!GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12));      //判斷DHT22的80us響應信號是否結束
  83.                  //FLAG=2;
  84.                  while(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_12));       //判斷DHT22是否發出80us高電平,如果是進入數據接受狀態
  85.                                          RHData_H_Temp = Bit_Select();
  86.                  RHData_L_Temp = Bit_Select();
  87.                                          TData_H_Temp  =        Bit_Select();
  88.                                          TData_L_Temp  =        Bit_Select();
  89.                                    CheckData_Temp =        Bit_Select();
  90.
  91. //                                         GPIO_ResetBits(GPIOA,GPIO_Pin_12);               //DHT22拉低總線50us
  92.                                          delay_us(50);
  93.                  Humitureport_outputinit();                  //端口配置為輸出模式
  94.                                          GPIO_SetBits(GPIOA,GPIO_Pin_12);             //主機拉高總線
  95.
  96.                  check_temp = (RHData_H_Temp + RHData_L_Temp + TData_H_Temp + TData_L_Temp);
  97.                                          if(check_temp == CheckData_Temp)
  98.                                          {
  99.        RHData_H = RHData_H_Temp;
  100.        RHData_L = RHData_L_Temp;
  101.        TData_H  = TData_H_Temp;
  102.        TData_L  = TData_L_Temp;
  103.        CheckData= CheckData_Temp;
  104.                                          }
  105.                }
  106.
  107.         }
  108. /*******************************************************************************
  109. * 函 數 名         : Humitureoutput
  110. * 函數功能                     : 溫濕度數據輸出
  111. * 輸    入         : 無
  112. * 輸    出         : 無
  113. *******************************************************************************/
  114. void Humitureoutput(void)
  115. {
  116.            HumitureRead();
  117.                   HumitureData[0] = RHData_H;
  118.            HumitureData[1] = RHData_L;
  119.            HumitureData[2] = TData_H;
  120.            HumitureData[3] = TData_L;
  121.            HumitureData[4] = CheckData;
  122. }
  1. #include "public.h"          //公共函數頭文件
  2. /****************************************************************************
  3. * Function Name  : main
  4. * Description    : Main program.
  5. * Input          : None
  6. * Output         : None
  7. * Return         : None
  8. ****************************************************************************/
  9. char HumitureData[5] = {0};                     //存放溫濕度數據
  10. int main()
  11. {
  12.            SystemInit();
  13.            RCC_HSE_Configuration();                     //自定義系統時間(可以修改時鐘)
  14.
  15.                  lcd_init();         //lcd初始化
  16.                  display_word();     //顯示”卡號“漢字
  17.         while(1)
  18.         {
  19.                  Humitureoutput();
  20.                  Humiture_display();
  21.                  delay_ms(1000);        //Systick 計數最大值為0xFFFFFF
  22.            delay_ms(1000);
  23.         }
  24.
  25. }
Keil代碼下載:
代碼.7z (202.92 KB, 下載次數: 96)
ID:944118 發表于 2022-6-10 17:06 | 顯示全部樓層
這個代碼咋不好使
主站蜘蛛池模板: 久久久国产精品人人片 | 欧美顶级黄色大片免费 | 日本三级中文字幕 | 在线视频一区二区 | 国产又猛又黄又爽 | 久久中文视频 | 国产91一区 | 久久av资源 | www.国产精品 | 国产成人亚洲精品自产在线 | 国产精品原创 | 亚洲小视频在线观看 | 一区二区不卡 | 亚洲精品免费视频 | 精品视频国产 | 久久这里有精品 | 久久久夜 | 国产原创精品 | 中文字幕免费在线看线人动作大片 | 一级做a视频 | 欧美福利影院 | 欧美视频在线观看 | 免费看a级片 | 中文字幕在线观看一区 | 91麻豆精品一区二区三区 | 在线日韩欧美 | 国产精品免费在线 | 在线性视频 | 日韩中文字幕精品 | 日韩欧美色 | www.久久精品 | 欧美黑人一区二区三区 | 中文字幕在线观看一区 | 日日夜夜天天干 | 精品在线一区 | 日韩精品一级 | 欧美日韩一区二区三区视频 | 精品99视频| 日韩大片在线观看 | 日韩中文字幕视频 | 中文文字幕文字幕高清 |
