查看: 1950|回復: 0
萬能遙控解碼器Delphi 源代碼
ID:1038393 發表于 2022-7-5 11:43 | 顯示全部樓層 |閱讀模式
指令集為:
實習期附件不能傳大,主要代碼
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, SPComm, StdCtrls;
  const
    sStatyArry :array [0..3] of string=('01 06 00 00 00 01 48 0A',
    '01 06 00 00 00 02 08 0B',
    '01 06 00 00 00 03 C9 CB',
    '01 06 00 00 00 04 88 09') ;
    sButtonArry :array [0..3] of string=('01 06 00 01 00 01 19 CA',
    '01 06 00 01 00 02 59 CB',
    '01 06 00 01 00 03 98 0B',
    '01 06 00 01 00 04 D9 C9') ;
procedure TForm1.Comm1ReceiveData(Sender: TObject; Buffer: Pointer;
  BufferLength: Word);
var
  iTmp, I, StrLenght : Integer;
  ViewString,ViewChar, sTmp, sTmp1 : string;
  rbuf : array[1..1000] of byte;
  rbufChar : array[1..1000] of Char;
  MS : TMemoryStream;
begin
// BufferLength := Sizeof(rbuf);
  ViewString := '';
  Move(Buffer^, PChar(@rbuf)^, BufferLength);
  for I := 1 to BufferLength do begin
    ViewString := ViewString + IntToHex(rbuf[I-1],2)+'';
  end;
  ViewString:=Trim(ViewString);
  if ViewString ='000101' then
  begin
     Memo1.Lines.Add('connect sucuss');
  end
  begin
      Memo1.Lines.Add('receive data:'+#13#10+'----------------------'+#13#10+ViewString+#13#10+'----------------------'+#13#10+FormatDateTime('YYYY-MM-DD hh:mm:ss',Now));
  end;
end;
procedure TForm1.Button2Click(Sender: TObject);
begin
  SendHex(sStatyArry[0]);
end;
procedure TForm1.SendHex(S: String);
var
  s2:string;
  buf1:array[0..50000] of char;
  i:integer;
begin
  if not bOpen then
  begin
    Memo1.Lines.Add('send data failed!,pls connect;');
    Exit;
  end;
  s2:='';
  for i:=1 to  length(s) do
  begin
    if ((copy(s,i,1)>='0') and (copy(s,i,1)<='9'))or((copy(s,i,1)>='a') and (copy(s,i,1)<='f'))
        or((copy(s,i,1)>='A') and (copy(s,i,1)<='F')) then
    begin
        s2:=s2+copy(s,i,1);
    end;
  end;
  for i:=0 to (length(s2) div 2-1) do
    buf1[ i]:=char(strtoint('$'+copy(s2,i*2+1,2)));
  Comm1.WriteCommData(buf1,(length(s2) div 2));
  Memo1.Lines.Add('send data:'+#13#10+'----------------------'+#13#10+s+#13#10+'----------------------'+#13#10+FormatDateTime('YYYY-MM-DD hh:mm:ss',Now));
end;
procedure TForm1.Button3Click(Sender: TObject);
begin
  Comm1.StopComm;
  Button1.Enabled:=True;
  Button3.Enabled:=False;
  bOpen:=False;
end;
參與人數 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎勵!
主站蜘蛛池模板: 波多野结衣视频在线 | 在线免费看a| 男人爱看的网站 | 亚洲黄色成人 | 亚洲精品福利 | 亚洲欧美日韩国产 | 亚洲一区二区三区在线视频 | 亚洲播放 | 国产午夜免费 | 日韩在线中文字幕 | 快播少女爱欢乐 | 中文字幕av一区 | 日韩精品免费视频 | 亚洲欧美日韩在线 | 黑人一级黄色片 | 狠狠操狠狠操 | 在线播放中文字幕 | 成人在线小视频 | a视频在线观看 | 午夜久久久 | 99精品欧美一区二区蜜桃免费 | 色在线播放 | 亚洲一区二区三区视频 | 国产精品一区二区三区不卡 | 免费三级网站 | 国产91精品在线观看 | 日韩成人片 | 草草视频在线 | 中文字幕在线观看免费 | 超碰在线99 | 免费中文字幕日韩欧美 | 一区二区视频在线 | 黄色免费小视频 | 色综合国产 | 亚洲欧美精品一区二区 | 一区二区高清 | 亚洲一区二区三区在线视频 | 日韩精品不卡 | 日本不卡在线视频 | 国产伦理一区二区 | 亚洲免费视频一区 |
