制作出來的實物圖如下:
MAX7219點陣屏
* 8x8led.h
* Created on: Sep 14, 2022
* Author: 大野豬_YEPIG
#ifndef LED7219_8X8LED_H_
#define LED7219_8X8LED_H_
#include "stm32f1xx_hal.h" //HAL庫文件聲明.
#define PIN_CLK GPIO_PIN_13 //ISP 13針腳
#define PIN_CS GPIO_PIN_2 //PA2 針腳
#define PIN_DIN GPIO_PIN_15 //ISP 15針腳
extern SPI_HandleTypeDef hspi2;
//PB13 ------> SPI2_SCK CLK
//PB15 ------> SPI2_MOSI DIN
//PA2 ------> CS
void Write_Byte(uint8_t DATA);
//void Write_Max7219(uint8_t addr,uint8_t dat);
void Write_Max7219_1(uint8_t addr,uint8_t dat);
void Write_Max7219_2(uint8_t addr,uint8_t dat);
void Write_Max7219_3(uint8_t addr,uint8_t dat);
void Write_Max7219_4(uint8_t addr,uint8_t dat);
void Init_Max7219(void);
#endif /* LED7219_8X8LED_H_ */
* 8x8led.c
* Author: 大野豬_YEPIG
#include "8x8led.h"
#include "main.h"
#include "ASCII_8x8.h"
HAL_GPIO_WritePin(GPIOA,PIN_CS,GPIO_PIN_RESET);//低
HAL_SPI_Transmit(&hspi2,&DATA,1,0xfff);
Write_Max7219_1(0x09, 0x00);//譯碼方式:BCD碼
Write_Max7219_1(0x0a, 0x01);//亮度
Write_Max7219_1(0x0b, 0x07);//掃描界限;8個數碼管顯示
Write_Max7219_1(0x0c, 0x01);//掉電模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00);//顯示測試:1;測試結束,正常顯示:0
Write_Max7219_2(0x09, 0x00);//譯碼方式:BCD碼
Write_Max7219_2(0x0a, 0x01);//亮度
Write_Max7219_2(0x0b, 0x07);//掃描界限;8個數碼管顯示
Write_Max7219_2(0x0c, 0x01);//掉電模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00);//顯示測試:1;測試結束,正常顯示:0
Write_Max7219_3(0x09, 0x00);//譯碼方式:BCD碼
Write_Max7219_3(0x0a, 0x01);//亮度
Write_Max7219_3(0x0b, 0x07);//掃描界限;8個數碼管顯示
Write_Max7219_3(0x0c, 0x01);//掉電模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00);//顯示測試:1;測試結束,正常顯示:0
Write_Max7219_4(0x09, 0x00);//譯碼方式:BCD碼
Write_Max7219_4(0x0a, 0x01);//亮度
Write_Max7219_4(0x0b, 0x07);//掃描界限;8個數碼管顯示
Write_Max7219_4(0x0c, 0x01);//掉電模式:0,普通模式:1
Write_Max7219_4(0x0f, 0x00);//顯示測試:1;測試結束,正常顯示:0
/*向M第一片MAX7219寫入數據*/
void Write_Max7219_1(uint8_t add1,uint8_t dat1)
HAL_GPIO_WritePin(GPIOA,PIN_CS,GPIO_PIN_RESET);//0
Write_Byte(add1); //寫入地址,即數碼管編號
Write_Byte(dat1); //寫入數據,即數碼管顯示數字
HAL_GPIO_WritePin(GPIOA,PIN_CS,GPIO_PIN_SET);//1
/*第二片MAX7219的寫入數據*/
void Write_Max7219_2(uint8_t add2,uint8_t dat2)
Write_Byte(add2);
Write_Byte(dat2);
HAL_GPIO_WritePin(GPIOA,PIN_CLK,GPIO_PIN_SET);//1
Write_Byte(0x00); //片1寫入空
Write_Byte(0x00);
/*第三片MAX7219的寫入數據*/
void Write_Max7219_3(uint8_t add3,uint8_t dat3)
Write_Byte(add3);
Write_Byte(dat3);
Write_Byte(0x00);
Write_Byte(0x00); //片2寫入空
Write_Byte(0x00);
/*第四片MAX7219的寫入數據*/
void Write_Max7219_4(uint8_t add4,uint8_t dat4)
Write_Byte(add4);
Write_Byte(dat4);
Write_Byte(0x00);
Write_Byte(0x00);
Write_Byte(0x00); //片3寫入空
Write_Byte(0x00);
RTC
* rtc.h
* Created on: 2021年10月20日
* Author: 大野豬_YEPIG
#ifndef INC_RTC_H_
#define INC_RTC_H_
#include "main.h" //IO定義與初始化函數在main.c文件中,必須引用
//時間讀寫與設置說明//
1,在mani.c文件中主循環之前放入RTC_Init();可使能RTC時鐘。
RTC_Init函數自帶判斷首次上電功能
2,使用RTC_Get();讀出時間。讀出的數據存放在:
年 ryear (16位)
月 rmon (以下都是8位)
日 rday
時 rhour
分 rmin
秒 rsec
周 rweek
3,使用RTC_Set(4位年,2位月,2位日,2位時,2位分,2位秒); 寫入時間。
例如:RTC_Set(2022,8,6,21,34,0);
其他函數都是幫助如上3個函數的,不需要調用。
注意要使用RTC_Get和RTC_Set的返回值,為0時表示讀寫正確。
extern RTC_HandleTypeDef hrtc;
//聲明rtc.c文件中定義的全局變量(注意:這里不能給變量賦值)
extern uint16_t ryear;
extern uint8_t rmon,rday,rhour,rmin,rsec,rweek;
void RTC_Init(void); //用戶自建的帶有上電BPK判斷的RTC初始化【在主循環前調用】
uint8_t Is_Leap_Year(uint16_t year);//判斷是否是閏年函數
uint8_t RTC_Get(void);//讀出當前時間值【主函數中需要讀RTC時調用】
uint8_t RTC_Set(uint16_t syear,uint8_t smon,uint8_t sday,uint8_t hour,uint8_t min,uint8_t sec);//寫入當前時間【主函數中需要寫入RTC時調用】
uint8_t RTC_Get_Week(uint16_t year,uint8_t month,uint8_t day);//按年月日計算星期
#endif
* rtc.c
* Author: 大野豬_YEPIG
#include "rtc.h"
//以下2行全局變量,用于RTC時間的讀取與讀入
uint16_t ryear; //4位年
uint8_t rmon,rday,rhour,rmin,rsec,rweek;//2位月日時分秒周
void RTC_Init(void) //用戶自建的帶有上電BPK判斷的RTC初始化
hrtc.Instance = RTC;
hrtc.Init.AsynchPrediv = RTC_AUTO_1_SECOND;
hrtc.Init.OutPut = RTC_OUTPUTSOURCE_NONE;
if (HAL_RTC_Init(&hrtc) != HAL_OK)
Error_Handler();
if(HAL_RTCEx_BKUPRead(&hrtc,RTC_BKP_DR1)!=0X5050){ //判斷是否首次上電
HAL_RTCEx_BKUPWrite(&hrtc,RTC_BKP_DR1,0X5050); //標記數值 下次不執行“首次上電”的部分
RTC_Set(2022,1,1,0,0,0);//寫入RTC時間的操作RTC_Set(4位年,2位月,2位日,2位時,2位分,2位秒)
//判斷是否是閏年函數
//月份 1 2 3 4 5 6 7 8 9 10 11 12
//閏年 31 29 31 30 31 30 31 31 30 31 30 31
//非閏年 31 28 31 30 31 30 31 31 30 31 30 31
//輸入:年份
//輸出:該年份是不是閏年.1,是.0,不是
uint8_t Is_Leap_Year(uint16_t year){
if(year%4==0){ //必須能被4整除
if(year%100==0){
if(year%400==0)return 1;//如果以00結尾,還要能被400整除
else return 0;
}else return 1;
}else return 0;
//設置時鐘
//把輸入的時鐘轉換為秒鐘
//以1970年1月1日為基準
//1970~2099年為合法年份
//月份數據表
uint8_t const table_week[12]={0,3,3,6,1,4,6,2,5,0,3,5}; //月修正數據表
const uint8_t mon_table[12]={31,28,31,30,31,30,31,31,30,31,30,31};//平年的月份日期表
//寫入時間
uint8_t RTC_Set(uint16_t syear,uint8_t smon,uint8_t sday,uint8_t hour,uint8_t min,uint8_t sec){ //寫入當前時間(1970~2099年有效),
uint16_t t;
uint32_t seccount=0;
if(syear<2000||syear>2099)return 1;//syear范圍1970-2099,此處設置范圍為2000-2099
for(t=1970;t<syear;t++){ //把所有年份的秒鐘相加
if(Is_Leap_Year(t))seccount+=31622400;//閏年的秒鐘數
else seccount+=31536000; //平年的秒鐘數
smon-=1;
for(t=0;t<smon;t++){ //把前面月份的秒鐘數相加
seccount+=(uint32_t)mon_table[t]*86400;//月份秒鐘數相加
if(Is_Leap_Year(syear)&&t==1)seccount+=86400;//閏年2月份增加一天的秒鐘數
seccount+=(uint32_t)(sday-1)*86400;//把前面日期的秒鐘數相加
seccount+=(uint32_t)hour*3600;//小時秒鐘數
seccount+=(uint32_t)min*60; //分鐘秒鐘數
seccount+=sec;//最后的秒鐘加上去
//【寄存器操作】因為HAL庫的不完善,無法直接調用RTC_ReadTimeCounter函數。此處改用寄存器直接操作。
RTC->CRL|=1<<4; //允許配置
RTC->CNTL=seccount&0xffff;
RTC->CNTH=seccount>>16;
RTC->CRL&=~(1<<4);//配置更新
while(!(RTC->CRL&(1<<5)));//等待RTC寄存器操作完成
//【寄存器操作】結束
return 0; //返回值:0,成功;其他:錯誤代碼.
//讀出時間
uint8_t RTC_Get(void){//讀出當前時間值 //返回值:0,成功;其他:錯誤代碼.
static uint16_t daycnt=0;
uint32_t timecount=0;
uint32_t temp=0;
uint16_t temp1=0;
//【寄存器操作】因為HAL庫的不完善,無法直接調用RTC_WriteTimeCounter函數。此處改用寄存器直接操作。
timecount=RTC->CNTH;//得到計數器中的值(秒鐘數)
timecount<<=16;
timecount+=RTC->CNTL;
//【寄存器操作】結束
temp=timecount/86400; //得到天數(秒鐘數對應的)
if(daycnt!=temp){//超過一天了
daycnt=temp;
temp1=1970; //從1970年開始
while(temp>=365){
if(Is_Leap_Year(temp1)){//是閏年
if(temp>=366)temp-=366;//閏年的秒鐘數
else {temp1++;break;}
else temp-=365; //平年
temp1++;
ryear=temp1;//得到年份
temp1=0;
while(temp>=28){//超過了一個月
if(Is_Leap_Year(ryear)&&temp1==1){//當年是不是閏年/2月份
if(temp>=29)temp-=29;//閏年的秒鐘數
else break;
}else{
if(temp>=mon_table[temp1])temp-=mon_table[temp1];//平年
else break;
temp1++;
rmon=temp1+1;//得到月份
rday=temp+1; //得到日期
temp=timecount%86400; //得到秒鐘數
rhour=temp/3600; //小時
rmin=(temp%3600)/60; //分鐘
rsec=(temp%3600)%60; //秒鐘
rweek=RTC_Get_Week(ryear,rmon,rday);//獲取星期
return 0;
uint8_t RTC_Get_Week(uint16_t year,uint8_t month,uint8_t day){ //按年月日計算星期(只允許1901-2099年)//已由RTC_Get調用
uint16_t temp2;
uint8_t yearH,yearL;
yearH=year/100;
yearL=year%100;
// 如果為21世紀,年份數加100
if (yearH>19)yearL+=100;
// 所過閏年數只算1900年之后的
temp2=yearL+yearL/4;
temp2=temp2%7;
temp2=temp2+day+table_week[month-1];
if (yearL%4==0&&month<3)temp2--;
return(temp2%7); //返回星期值
OLED
* oled.h
* Created on: Jun 26, 2022
* Author: 大野豬_YEPIG
#ifndef OLED_OLED_H_
#define OLED_OLED_H_
#include <string.h>//用于字符串處理的庫
#include <stdarg.h>
#include <stdlib.h>
#include "stdio.h"
extern I2C_HandleTypeDef hi2c1;//聲明USART1的HAL庫結構體
#define OLED0561_ADD 0x78 // OLED的I2C地址(禁止修改)
#define COM 0x00 // OLED 指令(禁止修改)
#define DAT 0x40 // OLED 數據(禁止修改)
void OLED0561_Init(void);//初始化
void OLED_DISPLAY_ON (void);//OLED屏開顯示
void OLED_DISPLAY_OFF (void);//OLED屏關顯示
void OLED_DISPLAY_LIT (uint8_t x);//OLED屏亮度設置(0~255)
void OLED_DISPLAY_CLEAR(void);//清屏操作
void OLED_DISPLAY_8x16(uint8_t x,uint8_t y,uint16_t w);//顯示8x16的單個字符
void OLED_DISPLAY_8x16_BUFFER(uint8_t row,uint8_t *str);//顯示8x16的字符串
void OLED_DISPLAY_16x16(uint8_t x,uint8_t y,uint16_t w); //漢字顯示
void OLED_DISPLAY_PIC1(void);//圖片顯示
void OLED_printf_US(uint8_t row,uint8_t *str,uint8_t i);//用于OLED_printf函數專用的顯示程序
void OLED_printf (uint8_t row,char *fmt, ...);//OLED專用的printf函數
#endif /* OLED_OLED_H_ */
* oled.c
* Author: 大野豬_YEPIG
#include "oled.h"
#include "ASCII_8x16.h" //引入字體 ASCII
#include "CHS_16x16.h" //引入漢字字體
#include "PIC1.h" //引入圖片
void OLED0561_Init (void){//OLED屏開顯示初始化
OLED_DISPLAY_OFF(); //OLED關顯示
OLED_DISPLAY_CLEAR(); //清空屏幕內容
OLED_DISPLAY_ON(); //OLED屏初始值設置并開顯示
void OLED_DISPLAY_ON (void){//OLED屏初始值設置并開顯示
uint8_t buf[28]={
0xae,//0xae:關顯示,0xaf:開顯示
0x00,0x10,//開始地址(雙字節)
0xd5,0x80,//顯示時鐘頻率?
0xa8,0x3f,//復用率?
0xd3,0x00,//顯示偏移?
0XB0,//寫入頁位置(0xB0~7)
0x40,//顯示開始線
0x8d,0x14,//VCC電源
0xa1,//設置段重新映射?
0xc8,//COM輸出方式?
0xda,0x12,//COM輸出方式?
0x81,0xff,//對比度,指令:0x81,數據:0~255(255最高)
0xd9,0xf1,//充電周期?
0xdb,0x30,//VCC電壓輸出
0x20,0x00,//水平尋址設置
0xa4,//0xa4:正常顯示,0xa5:整體點亮
0xa6,//0xa6:正常顯示,0xa7:反色顯示
0xaf//0xae:關顯示,0xaf:開顯示
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,buf,28,1000);
void OLED_DISPLAY_OFF (void){//OLED屏關顯示
uint8_t buf[3]={
0x8d,0x10,//VCC電源
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,buf,3,1000);
void OLED_DISPLAY_LIT (uint8_t x){//OLED屏亮度設置(0~255)
uint8_t buf=0x81;
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf,1,1000);
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&x,1,1000);
void OLED_DISPLAY_CLEAR(void){//清屏操作
uint8_t j,t;
uint8_t buf[2]={0x10,0x00};
for(t=0xB0;t<0xB8;t++){ //設置起始頁地址為0xB0
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&t,1,1000);
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[0],1,1000);
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[1],1,1000);
for(j=0;j<132;j++){ //整頁內容填充
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,DAT,I2C_MEMADD_SIZE_8BIT,&buf[1],1,1000);
//顯示英文與數字8*16的ASCII碼
//取模大小為8*16,取模方式為“從左到右從上到下”“縱向8點下高位”
void OLED_DISPLAY_8x16(uint8_t x, //顯示漢字的頁坐標(從0到7)(此處不可修改)
uint8_t y, //顯示漢字的列坐標(從0到63)
uint16_t w){ //要顯示漢字的編號
uint8_t j,t,c=0;
uint8_t buf[4];
y=y+1; //因OLED屏的內置驅動芯片是從0x02列作為屏上最左一列,所以要加上偏移量
for(t=0;t<2;t++){
buf[0]=0xb0+x; buf[1]=y/16+0x10; buf[2]=y%16;
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[0],1,1000); //頁地址(從0xB0到0xB7)
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[1],1,1000); //起始列地址的高4位
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[2],1,1000); //起始列地址的低4位
for(j=0;j<8;j++){ //整頁內容填充
buf[3]=ASCII_8x16[(w*16)+c-512];
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,DAT,I2C_MEMADD_SIZE_8BIT,&buf[3],1,1000);//為了和ASII表對應要減512
c++;}x++; //頁地址加1
//----- 用于漢字顯示的程序 ------//
//顯示漢字16*16
//取模大小為16*16,取模方式為“從左到右從上到下”“縱向8點下高位”
void OLED_DISPLAY_16x16(uint8_t x, //顯示漢字的頁坐標(從0xB0到0xB7)
uint8_t j,t,c=0;
uint8_t buf[5];
for(t=0;t<2;t++){
buf[0]=0xb0+x;buf[1]=y/16+0x10;buf[2]=y%16;
for(j=0;j<16;j++){ //整頁內容填充
buf[3]=GB_16[(w*32)+c];
c++;}x++; //頁地址加1
buf[4]=0xAF;
HAL_I2C_Mem_Write(&hi2c1,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&buf[4],1,1000);
void OLED_DISPLAY_PIC1(void){ //顯示全屏圖片
uint8_t m,i;
uint8_t buf[4];
for(m=0;m<8;m++){//
buf[0]=0xb0+m;buf[1]=0x10;buf[2]=0x02;
for(i=0;i<128;i++){//送入128次圖片顯示內容
buf[3]=PIC1[i+m*128];
//向LCM發送一個字符串,長度64字符之內。
//應用:OLED_DISPLAY_8_16_BUFFER(0," DoYoung Studio");
void OLED_DISPLAY_8x16_BUFFER(uint8_t row,uint8_t *str){
uint8_t r=0;
while(*str != '\0'){
OLED_DISPLAY_8x16(row,r*8,*str++);
r++;
void OLED_printf_US(uint8_t row,uint8_t *str,uint8_t i){
uint8_t r=0;
while(i != r){//i是長度值,當顯示到i之后退出
OLED_DISPLAY_8x16(row,r*8,*str++);//顯示英文與數字8*16的ASCII碼
r++;
//OLED專用的printf函數
//調用方法:OLED_printf(0,"123");
char buff[17]; //用于存放轉換后的數據 [長度]
uint16_t i=0;
va_list arg_ptr;
va_start(arg_ptr,fmt);
vsnprintf(buff, 20,fmt,arg_ptr);//數據轉換
i=strlen(buff);//得出數據長度
if(strlen(buff)>16)i=16;//如果長度大于最大值,則長度等于最大值(多出部分忽略)
OLED_printf_US(row,(uint8_t *)buff,i);//最終調用OLED專用的printf函數來顯示
va_end(arg_ptr);
修正時間方法,上位機通過 串口usart1 訪問 115200 ,編碼改成中文,按回車顯示當前時間,按C 回車 提示操作成功 輸入當前時間 比如:20220916144030 年月日小時分鐘秒 回車 就同步成功。
RTC實時時鐘測試
實時時間:2022-09-16 14:44:07
單按回車鍵更新時間,輸入字母C初始化時鐘
請輸入設置時間,格式20170806120000,按回車鍵確定!
C
初始化成功
20220916144530
寫入成功
代碼下載:
PIG_RTC HAL庫代碼.7z
(661.97 KB, 下載次數: 40)
2022-9-16 18:23 上傳
點擊文件名下載附件
項目源碼
