查看: 2858|回復(fù): 6
編譯錯誤error: At end of source: #18: expected a ")"
回帖獎勵 1 黑幣 回復(fù)本帖可獲得 1 黑幣獎勵! 每人限 1 次
ID:1060439 發(fā)表于 2023-1-7 14:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
void rt_fs00603a_init(void)
        rt_thread_t tid;
        fs00603a_mutex = rt_mutex_create("fs00603amt", RT_IPC_FLAG_PRIO);
        RT_ASSERT(fs00603a_mutex != RT_NULL);
#ifdef RT_USING_HEAP
        tid = rt_thread_create("fs00603a",
                                                        fs00603a_thread_entry,
                                                        RT_NULL,
                                                        RT_FS00603A_THREAD_STACK_SIZE,
                                                        RT_FS00603A_THREAD_PRIORITY,
                                                        20);
        RT_ASSERT(tid != RT_NULL);
        fs00603a_rx_sem = rt_sem_create("fsrxsem", 0, RT_IPC_FLAG_FIFO);
#else
        rt_err_t result;
        tid = &bt_thread;
        result = rt_thread_init(tid,
                                                        "fs00603",
                                                        RT_NULL,
                                                        bt_stack,
                                                        sizeof(bt_stack),
                                                        20);
        RT_ASSERT(result == RT_EOK);
#endif
        rt_thread_startup(tid);
編譯后報以下錯誤
此程序在另一臺電腦上是可以編譯通過的,設(shè)置也是一樣,版本也一樣。
ID:277550 發(fā)表于 2023-1-8 08:45 | 只看該作者
檢查文件編碼
ID:1060439 發(fā)表于 2023-1-10 09:11 | 只看該作者
謝謝你!
ID:1078332 發(fā)表于 2023-6-5 20:37 | 只看該作者
    rt_thread_t tid;
                           RT_NULL,
                           20);
#else
    rt_err_t result;
    static rt_uint8_t fs00603a_stack[RT_FS00603A_THREAD_STACK_SIZE];
    tid = rt_thread_create(&tid,
                           "fs00603",
                           RT_NULL,
                           fs00603a_stack,
                           sizeof(fs00603a_stack),
                           20);
#endif
void rt_fs00603a_init(void) {     rt_thread_t tid;      fs00603a_mutex = rt_mutex_create("fs00603amt", RT_IPC_FLAG_PRIO);     RT_ASSERT(fs00603a_mutex != RT_NULL);  #ifdef RT_USING_HEAP     tid = rt_thread_create("fs00603a",                            fs00603a_thread_entry,                            RT_NULL,                            RT_FS00603A_THREAD_STACK_SIZE,                            RT_FS00603A_THREAD_PRIORITY,                            20);     RT_ASSERT(tid != RT_NULL);     fs00603a_rx_sem = rt_sem_create("fsrxsem", 0, RT_IPC_FLAG_FIFO); #else     rt_err_t result;     static rt_uint8_t fs00603a_stack[RT_FS00603A_THREAD_STACK_SIZE];     tid = rt_thread_create(&tid,                            "fs00603",                            fs00603a_thread_entry,                            RT_NULL,                            fs00603a_stack,                            sizeof(fs00603a_stack),                            RT_FS00603A_THREAD_PRIORITY,                            20);     RT_ASSERT(tid != RT_NULL); #endif      rt_thread_startup(tid); }
ID:1078332 發(fā)表于 2023-6-5 20:39 | 只看該作者
在 #else 條件分支內(nèi)對 tid 進(jìn)行了非法賦值。bt_thread 的類型是 struct rt_thread,而不是 rt_thread_t。
在 #else 條件分支內(nèi)對 tid 進(jìn)行了非法初始化。tid 的類型是 rt_thread_t,&bt_thread 并不符合 rt_thread_t 的定義。
在 #else 條件分支內(nèi)對 bt_stack 和 sizeof(bt_stack) 進(jìn)行了非法使用。這兩個變量在這個條件分支里沒有定義,應(yīng)該使用正確的線程堆棧變量和大小。
ID:772183 發(fā)表于 2023-6-20 09:03 | 只看該作者
是語法錯誤嗎?
主站蜘蛛池模板: 国产传媒一区二区 | 免费视频a | 黄色av毛片 | 国产逼逼 | 欧美日韩国产在线播放 | 三级av片 | 免费看的毛片 | 中文字幕日韩一区 | 在线观看黄色小视频 | 久久久高清 | 黄视频网站在线观看 | 国产高潮在线 | 超碰人人网 | 日日操日日干 | 99久久婷婷国产综合精品草原 | 国产午夜精品一区二区三区视频 | www.伊人网| 黄色一级片网站 | 国产精品久久午夜夜伦鲁鲁 | 视频一区二区在线播放 | 日本a在线观看 | 毛片网站在线观看 | 国产a√| 91亚洲精选 | 亚洲丝袜av | 国产精品一区视频 | 国产三级在线观看视频 | 亚洲丝袜视频 | 国产三级黄色片 | 欧美一区免费 | 黄色片视频网站 | 天堂中文在线视频 | 中国一级毛片 | 91蜜桃在线观看 | 一区二区小视频 | 亚洲精品免费在线 | 嫩草在线观看 | 亚洲精品国产一区 | 羞羞的视频在线观看 | av高清不卡| 国产欧美综合一区二区三区 |
