IIC SPI接口都有,移植性適用
單片機(jī)源程序如下:
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "tim.h"
- #include "usart.h"
- #include "gpio.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "lcd_init.h" //OLED頭文件
- #include "pic.h" //圖片頭文件
- #include "lcd.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- // OLED屏幕接口描述
- // GND 電源地
- // VCC 3.3v電源
- // SCL PA0(SCLK)
- // SDA PA1(MOSI)
- // RES PA2
- // DC PA3
- // CS PA4
- // BLK PA5
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- void HAL_Delay_us(uint32_t Delay_us);
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- float t=0;
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_TIM2_Init();
- MX_USART1_UART_Init();
- /* USER CODE BEGIN 2 */
- LCD_Init(); //LCD初始化
- LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- LCD_ShowChinese(40,0,"中景園電子",RED,WHITE,16,0);
- LCD_ShowString(10,20,"LCD_W:",RED,WHITE,16,0);
- LCD_ShowIntNum(58,20,LCD_W,3,RED,WHITE,16);
- LCD_ShowString(10,40,"LCD_H:",RED,WHITE,16,0);
- LCD_ShowIntNum(58,40,LCD_H,3,RED,WHITE,16);
- LCD_ShowFloatNum1(10,60,t,4,RED,WHITE,16);
- t+=0.11;
- LCD_ShowPicture(100,20,40,40,gImage_1);
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Initializes the RCC Oscillators according to the specified parameters
- * in the RCC_OscInitTypeDef structure.
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB buses clocks
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN 4 */
- // Core\Src\delay.c
- __HAL_TIM_SetCounter(&htim2, 0);
- __HAL_TIM_ENABLE(&htim2);
- while(__HAL_TIM_GetCounter(&htim2) < Delay_us);
- /* Disable the Peripheral */
- __HAL_TIM_DISABLE(&htim2);
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- __disable_irq();
- while (1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
復(fù)制代碼 |
HAL_OLED_SPI.7z
2023-3-18 01:55 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
5.19 MB, 下載次數(shù): 28, 下載積分: 黑幣 -5
HAL_OLED_IIC.7z
2023-3-18 01:55 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
5.19 MB, 下載次數(shù): 40, 下載積分: 黑幣 -5
