查看: 2315|回復(fù): 7
使用STC15W408AS單片機(jī)的PCA模塊,占空比為0時(shí)CCP0 CCP1 CCP2三個(gè)腳為高電平
void PWM_Init()
    PWM0_L = 0;
    PWM1_L = 0;
    PWM2_L = 0;
    HDU = 0;
    HDV = 0;
    HDW = 0;
    //0x 01110000
    P3M1 &= ~0x70;
    P3M0 |= 0x70;
//  CMOD = 1 << 1; // 選擇系統(tǒng)時(shí)鐘/2為時(shí)鐘源 PWM頻率=24M/2/256=46.9K
    CMOD = 5 << 1; //CMOD寄存器配置 選擇系統(tǒng)時(shí)鐘/4為時(shí)鐘源 PWM頻率24M/4/256=23.4K
    CL = 0;  //PCA 計(jì)數(shù)器清零
    CH = 0;
    PCA_PWM0 = 0X00;  //PCA_PWM0工作于8位PWM功能
    CCAP0H = 0;
    CCAP0L = 0;
    CCAPM0 = 0x42; //0x 0100 0010 設(shè)置PWM模式
    PCA_PWM1 = 0X00;
    CCAP1H = 0;
    CCAP1L = 0;
    CCAPM1 = 0x42;
    PCA_PWM2 = 0X00;
    CCAP2H = 0;
    CCAP2L = 0;
    CCAPM2 = 0x42;
    CR = 1;  //PCA定時(shí)器開(kāi)始工作
    MCU_IOinit();
    USER_Delay_MS(50);
    OLED_Init();
    USER_Delay_MS(100);
    OLED_Clear();
    USER_Delay_MS(100);
    //OLED_ShowChar(0,6,'V',16);
    OLED_DrawBMP(0,0,77,32,BMP1);
    USER_Delay_MS(600);
    Motor_flag = 0;
    motor_MO = 0;
    //bitch1 = 0;
    //flag = 0;
    PWM_Init();
    ADC_Init();
    //CMP_Init();
    //EA = 1;
    while (1)
PWM初始化
PWM初始化
ID:1070246 發(fā)表于 2023-4-6 21:25 | 只看該作者
PCA_PWM0,PCA_PWM1,PCA_PWM2想用這三路控制上橋,有沒(méi)有辦法默認(rèn)輸出低電平
ID:213173 發(fā)表于 2023-4-7 07:30 | 只看該作者
Qibaobao 發(fā)表于 2023-4-6 21:25
void PWM_Init(void)
        CCON = 0;                                //初始化PCA控制寄存器
        CL = 0;                 //復(fù)位PCA寄存器
        CH = 0;                 //復(fù)位PCA寄存器
//        CMOD = 0x00;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/12/256=3.600KHZ 278us
//        CMOD = 0x02;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/2/256=21.600KHZ 46us
//        CMOD = 0x04;                         //設(shè)置PCA時(shí)鐘源,PWM頻率= 定時(shí)器溢出11.0592MHZ/1~65536/256=43.200KHZ~0.659HZ
//        CMOD = 0x06;                         //設(shè)置PCA時(shí)鐘源,PWM頻率= 外部時(shí)鐘/1/256
//        CMOD = 0x08;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/1/256=43.200KHZ 23us
//        CMOD = 0x0A;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/4/256=10.800KHZ 93us
//        CMOD = 0x0C;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/6/256=7.200KHZ 139us
        CMOD = 0x0E;                         //設(shè)置PCA時(shí)鐘源,PWM頻率=11.0592MHZ/8/256=5.400KHZ 185us
        PCA_PWM0 = 0x00;        //PCA模塊0工作于8位PWM
        PCA_PWM1 = 0x00;        //PCA模塊1工作于8位PWM
        CCAP0H = CCAP0L = 0xFF; //PWM0的占空比為0%,0x00占空比為100%
        CCAP1H = CCAP1L = 0xFF; //PWM1的占空比為0%,0x00占空比為100%
        CCAP2H = CCAP2L = 0xFF; //PWM1的占空比為0%,0x00占空比為100%
        CCAPM0 = 0x42;                        //允許CCP0腳用作脈寬調(diào)節(jié)輸出
        CCAPM1 = 0x42;          //允許CCP1腳用作脈寬調(diào)節(jié)輸出
        CCAPM2 = 0x42;          //允許CCP1腳用作脈寬調(diào)節(jié)輸出
ID:1070246 發(fā)表于 2023-4-8 21:32 | 只看該作者
wulin 發(fā)表于 2023-4-7 07:30
void PWM_Init(void)
感謝您的回答,修改參照修改后不是常高電平,但是存在小的尖峰,如圖片所示,這個(gè)看著是不是不能避免。
輸出波形
輸出波形
ID:213173 發(fā)表于 2023-4-9 07:05 | 只看該作者
Qibaobao 發(fā)表于 2023-4-8 21:32
這個(gè)問(wèn)題在PWM占空比大于0%時(shí)反映不出來(lái),當(dāng)需要占空比絕對(duì)等于0%時(shí),雖然這個(gè)脈沖很窄,處理起來(lái)很麻煩。宏晶的產(chǎn)品手冊(cè)沒(méi)有相關(guān)介紹,官方例程也沒(méi)有見(jiàn)到處理方法。以往做的一個(gè)工程就是遇到這種情況,摸索了好長(zhǎng)時(shí)間。最終選擇:STC15W408AS單片機(jī)的PWM默認(rèn)輸出口設(shè)置0或1不會(huì)影響PWM正常輸出,并可以在3個(gè)IO口之間切換。利用這個(gè)特點(diǎn),PWM默認(rèn)輸出口置0,正常工作。當(dāng)需要占空比絕對(duì)等于0%時(shí),將PWM默認(rèn)輸出口轉(zhuǎn)到其他空閑腳或根本沒(méi)有外部引腳的端口。當(dāng)事腳就能保持純低電平。當(dāng)時(shí)這個(gè)工程使用STC15W408AS-16,只用了一路PWM0,默認(rèn)輸出口P1.1,使用特殊功能寄存器AUXR1|=0x10;轉(zhuǎn)到CCP_2。需要恢復(fù)時(shí)AUXR1&=0xcf;再切換回來(lái)。雖然這個(gè)問(wèn)題成功解決,但有沒(méi)有更好的解決方法不得而知。
ID:1038987 發(fā)表于 2023-4-9 07:59 | 只看該作者
需要默認(rèn)低電平需要加下接電路。加10K電陰到GND
ID:1070246 發(fā)表于 2023-4-9 21:53 | 只看該作者
15031773670 發(fā)表于 2023-4-9 07:59
謝謝,嘗試過(guò)了,加下拉電阻沒(méi)有效果,還是會(huì)存在大概200ns的高電平。
ID:1034262 發(fā)表于 2023-4-10 13:33 | 只看該作者
STC的PCA工作于PWM時(shí),設(shè)置的占空比值是輸出低電平的時(shí)間值。要高電平的,取反一下。
PCA-PWM連續(xù)輸出0或1的方法,以PCA0(PWM0-CCP0)為例:
PCA_PWM0 &= ~0x02;        // PWM0正常輸出
PCA_PWM0 |= 0x3f, CCAP0H = 0xff, CCAP0L = 0xff;        // PWM0一直輸出0
PCA_PWM0 &= 0xc0, CCAP0H = 0,    CCAP0L = 0;        // PWM0一直輸出1
主站蜘蛛池模板: 欧美在线免费观看视频 | 国产精品香蕉 | 免费一级a毛片 | 国产又爽又黄免费视频 | 啪啪导航 | 五月婷婷亚洲 | 91久久国产综合久久91精品网站 | 免费av一区 | 国产麻豆视频 | 成人xxx| 国产一区二区视频在线观看 | 亚洲精品18在线观看 | 成人国产精品免费观看 | 成人一级毛片 | 中文字幕在线免费视频 | 欧美精品亚洲精品 | 国产精品一区二区不卡 | 日日干日日干 | 国产黄色在线播放 | 91av视频| 国产中文字幕在线播放 | 福利视频免费观看 | 又黄又爽的网站 | 亚洲视频一区在线观看 | 9l视频自拍九色9l视频成人 | www.狠狠操.com| 欧美日韩在线一区 | 日韩精品极品视频在线观看免费 | 成人高清免费 | 国产亚洲欧美在线 | 亚洲播放| 亚洲一区二区免费视频 | 欧美一级免费 | 黄色免费在线看 | 国产中文字幕在线 | 欧美日韩在线免费观看 | 天天做天天爽 | 麻豆精品一区 | 国产一区二区视频在线 | 成人在线观看网站 | 日韩视频免费观看 |
