查看: 3402|回復(fù): 0
基于51單片機(jī)LCD1602和數(shù)碼管顯示倒計(jì)時(shí)程序Proteus仿真圖
ID:1080717 發(fā)表于 2023-6-2 19:03 | 顯示全部樓層 |閱讀模式
使用8051單片機(jī)控制的倒計(jì)時(shí)器程序,通過連接LCD顯示屏和數(shù)碼管來實(shí)現(xiàn)倒計(jì)時(shí)功能
系統(tǒng)接1個(gè)按鍵用于啟動(dòng),1個(gè)蜂鳴器用于提示計(jì)時(shí)時(shí)間到,兩個(gè)數(shù)碼管用于顯示時(shí)間。
功能:系統(tǒng)上電數(shù)碼管顯示60;當(dāng)按鍵按下時(shí),系統(tǒng)開始倒計(jì)時(shí),同時(shí)數(shù)碼管顯示當(dāng)前時(shí)間;當(dāng)計(jì)時(shí)為0時(shí),蜂鳴器響。
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. sbit buzzer=P3^3;
  3. sbit key=P3^2;
  4. sbit m=P3^0;
  5. sbit n=P3^1;
  6. sbit RS=P3^4;
  7. sbit RW=P3^5;
  8. sbit E=P3^6;
  9. unsigned char a[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  10. unsigned char b[10]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
  11. unsigned char DJS=0;
  12. unsigned int count;
  13. unsigned char s = 60; // 倒計(jì)時(shí)初始值
  14. void delay(unsigned char t)
  15. {
  16.          unsigned char i,j;
  17.          for (i = 0; i < t; i++)
  18.     for (j = 0; j < 250; j++);
  19. }
  20. void writecommand(unsigned char command)
  21. {
  22.                                 RS=0;
  23.                                 RW=0;
  24.                                 P1=command;
  25.                                 delay(5);
  26.                                 E=1;
  27.                                 delay(5);
  28.                                 E=0;
  29. }
  30. void writecount(unsigned char count)
  31. {
  32.                                 RS=1;
  33.                                 RW=0;
  34.                                 P1=count;
  35.                                 delay(5);
  36.                                 E=1;
  37.                                 delay(5);
  38.                                 E=0;
  39. }
  40. void cursor(unsigned char H,m)
  41. {
  42.                         if(H==0)
  43.         {
  44.                                 writecommand(0x80+m);
  45.         }
  46.                         else if(H==1)
  47.         {
  48.                                 writecommand(0x80+0x40+m);
  49.         }
  50. }
  51. void LCDstring(unsigned char *string)
  52. {
  53.                                 while(*string!='\0')
  54.                                 writecount(*string++);
  55. }
  56. void LCDInit()
  57. {
  58.                                 E=0;
  59.                                 writecommand(0x38);
  60.                                 writecommand(0x0c);
  61.                                 writecommand(0x06);
  62.                                 writecommand(0x01);
  63. }
  64. //void on()
  65. //{
  66. //                                writecommand(0x0c);
  67. //}
  68. //void off()
  69. //{
  70. //                                writecommand(0x08);
  71. //}
  72. void ShowInit()
  73. {
  74.                                 cursor(0,0);
  75.                                 LCDstring("LCD");
  76.                                 cursor(0,5);
  77.                                 writecount(0x31);
  78.                                 cursor(0,6);
  79.                                 writecount(0x36);
  80.                                 cursor(0,7);
  81.                                 writecount(0x30);
  82.                                 cursor(0,8);
  83.                                 writecount(0x32);
  84.                                 cursor(0,10);
  85.                                 writecount(b[6]);
  86.                                 cursor(0,11);
  87.                                 writecount(b[0]);
  88.                                 cursor(1,0);
  89.                                 LCDstring("Test--Program--");
  90. }
  91. void display()
  92. {
  93.         if (DJS == 1)                                                //倒計(jì)時(shí)進(jìn)行中
  94. {
  95.                         if (s> 0)
  96.                 {
  97.                                 cursor(0,10);
  98.                                 writecount(b[s/10]);    //顯示定時(shí)器T0產(chǎn)生的 分(十位)
  99.                                 writecount(b[s%10]);    //顯示定時(shí)器T0產(chǎn)生的 分(個(gè)位)
  100.                                 n = 0;                                         //開數(shù)碼管1
  101.                                 m = 1;
  102.                                 P2 = a[s/10];                         //顯示十位數(shù)字
  103.                                 delay(10);                      //延時(shí)10毫秒
  104.                                 m = 0;                          //開數(shù)碼管2
  105.                                 n = 1;
  106.                                 P2 = a[s%10];                         //顯示個(gè)位數(shù)字
  107.                                 delay(10);                             //延時(shí)10毫秒
  108.
  109.                 }
  110.                         else
  111.                 {
  112.                                 buzzer = 0;
  113.                                 delay(250);
  114.                                 buzzer = 1;
  115.                                 DJS = 0;                                 //倒計(jì)時(shí)結(jié)束,清零
  116.                                 cursor(0,10);
  117.                                 writecount(b[6]);            //LCD顯示數(shù)字為6
  118.                                 writecount(b[0]);            //LCD顯示數(shù)字為0
  119.                 }
  120. }
  121.                 else                                                         //倒計(jì)時(shí)為0,顯示60秒
  122.         {
  123.                         n = 0;                                        //開數(shù)碼管1
  124.                         m = 1;
  125.                         P2 = a[6];                                     //顯示數(shù)字為6
  126.                         delay(20);                                    // 延時(shí)10毫秒
  127.                         m = 0;                                         //開數(shù)碼管2
  128.                         n = 1;
  129.                         P2 = a[0];                                     // 顯示數(shù)字為0
  130.                         delay(20);                                     // 延時(shí)10毫秒
  131.                         s= 60;                                       // 重置倒計(jì)時(shí)初始值
  132.
  133.         }
  134. }
  135. void main()
  136. {
  137.                 TMOD= 0x01;
  138.                 TL0 = (65536 - 1000)%256;
  139.                 TH0 = (65536 - 1000)/256;
  140.                 EA = 1;
  141.                 ET0 = 1;
  142.                 TR0 = 1;
  143.                 EX0=1;
  144.                 IT0=1;
  145.                 LCDInit();
  146.                 ShowInit();
  147.                 while(1)
  148. {
  149.                 display();
  150. }
  151. }
  152. void Int0() interrupt 0
  153. {
  154.                 delay(10);
  155.                 if(key==0)
  156. {
  157.                 DJS=1;
  158. }
  159. }
  160. void Int1() interrupt 1
  161. {
  162.                 TL0 = (65536-1000)%256;
  163.                 TH0 = (65536-1000)/256;
  164.                 count++;
  165.                 if(count == 500)
  166. {
  167.         count = 0;
  168.         s--;
  169. }
  170. }
Keil代碼與Proteus仿真下載:
LCD1602.zip (31.88 KB, 下載次數(shù): 29)
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: www.男人的天堂 | 亚洲成人av在线播放 | 成人国产精品免费观看 | 不卡av在线播放 | 久久在线视频 | 欧美一级特黄视频 | 亚洲欧美日韩另类 | 在线不欧美 | 久久精品视频网站 | 欧美夜夜操 | 久久精品www人人爽人人 | 婷婷一区二区三区 | 婷婷色在线 | 免费网站黄 | 天天搞天天干 | 免费在线观看黄 | 国产黄色片网站 | ass亚洲尤物裸体pics | 久久国产精 | 成年人黄色网址 | 黄色小视频免费 | 91精品国产色综合久久不卡98 | 放几个免费的毛片出来看 | 天堂成人网| 一区二区三区四区国产 | 亚洲福利一区二区 | www.av在线播放 | 国产精品日韩在线 | 国产传媒在线播放 | 色综合天天综合网国产成人网 | 午夜网址 | 日韩免费一区二区三区 | 精品久久一区二区三区 | 欧美日韩在线一区 | 国产51自产区| 男女h黄动漫啪啪无遮挡软件 | 五月天激情国产综合婷婷婷 | 成年人午夜视频 | 黄色资源在线观看 | 黄色大片免费在线观看 | 在线日韩一区 |
