查看: 2768|回復: 4
給大家分享一款 STC8H8K64U_LQFP64單片機精簡開發板小巧實用有原理圖+例程包
【聲明】此程序僅用于學習與參考!
/*************  功能說明    **************
4路串口全雙工中斷方式收發通訊程序。
通過PC向MCU發送數據, MCU收到后通過串口把收到的數據原樣返回.
用定時器做波特率發生器,建議使用1T模式(除非低波特率用12T),并選擇可被波特率整除的時鐘頻率,以提高精度。
下載時, 選擇時鐘 11.0592MHz (用戶可自行修改頻率).
#include    "STC8H8K64U.h"       //包含此頭文件后,里面聲明的寄存器不需要再手動輸入,避免重復定義
#include "stdio.h"
#include    "intrins.h"
#define uchar unsigned char//宏定義無符號字符型
#define uint unsigned int  //宏定義無符號整型
#define MAIN_Fosc       11059200L   //定義主時鐘(精確計算9600波特率)
typedef     unsigned char   u8;
typedef     unsigned int    u16;
typedef     unsigned long   u32;
////手動輸入聲明"reg51.h"頭文件里面沒有定義的寄存器
//sfr AUXR = 0x8E;
sfr INT_CLKO = 0x8F;
//sfr P_SW1 = 0xA2;
//sfr P_SW2 = 0xBA;
//sfr IE2  = 0xAF;
//sfr S4CON = 0x84;
//sfr S4BUF = 0x85;
//sfr S2CON = 0x9A;
//sfr S2BUF = 0x9B;
//sfr S3CON = 0xAC;
//sfr S3BUF = 0xAD;
//sfr T2H  = 0xD6;
//sfr T2L  = 0xD7;
//sfr T3H  = 0xD4;
//sfr T3L  = 0xD5;
//sfr T4H  = 0xD2;
//sfr T4L  = 0xD3;
//sfr T4T3M = 0xD1;
//sfr P4   = 0xC0;
//sfr P5   = 0xC8;
//sfr P6   = 0xE8;
//sfr P7   = 0xF8;
//sfr P1M1 = 0x91;    //PxM1.n,PxM0.n     =00--->Standard,    01--->push-pull
//sfr P1M0 = 0x92;    //                  =10--->pure input,  11--->open drain
//sfr P0M1 = 0x93;
//sfr P0M0 = 0x94;
//sfr P2M1 = 0x95;
//sfr P2M0 = 0x96;
//sfr P3M1 = 0xB1;
//sfr P3M0 = 0xB2;
//sfr P4M1 = 0xB3;
//sfr P4M0 = 0xB4;
//sfr P5M1 = 0xC9;
//sfr P5M0 = 0xCA;
//sfr P6M1 = 0xCB;
//sfr P6M0 = 0xCC;
//sfr P7M1 = 0xE1;
//sfr P7M0 = 0xE2;
//sbit P00 = P0^0;
//sbit P01 = P0^1;
//sbit P02 = P0^2;
//sbit P03 = P0^3;
//sbit P04 = P0^4;
//sbit P05 = P0^5;
//sbit P06 = P0^6;
//sbit P07 = P0^7;
//sbit P10 = P1^0;
//sbit P11 = P1^1;
//sbit P12 = P1^2;
//sbit P13 = P1^3;
//sbit P14 = P1^4;
//sbit P15 = P1^5;
//sbit P16 = P1^6;
//sbit P17 = P1^7;
//sbit P20 = P2^0;
//sbit P21 = P2^1;
//sbit P22 = P2^2;
//sbit P23 = P2^3;
//sbit P24 = P2^4;
//sbit P25 = P2^5;
//sbit P26 = P2^6;
//sbit P27 = P2^7;
//sbit P30 = P3^0;
//sbit P31 = P3^1;
//sbit P32 = P3^2;
//sbit P33 = P3^3;
//sbit P34 = P3^4;
//sbit P35 = P3^5;
//sbit P36 = P3^6;
//sbit P37 = P3^7;
//sbit P40 = P4^0;
//sbit P41 = P4^1;
//sbit P42 = P4^2;
//sbit P43 = P4^3;
//sbit P44 = P4^4;
//sbit P45 = P4^5;
//sbit P46 = P4^6;
//sbit P47 = P4^7;
//sbit P50 = P5^0;
//sbit P51 = P5^1;
//sbit P52 = P5^2;
//sbit P53 = P5^3;
//sbit P54 = P5^4;
//sbit P55 = P5^5;
//sbit P56 = P5^6;
//sbit P57 = P5^7;
#define Baudrate1   9600UL
#define Baudrate2   9600UL
#define Baudrate3   9600UL
#define Baudrate4   9600UL
#define UART1_BUF_LENGTH    64
#define UART2_BUF_LENGTH    64
#define UART3_BUF_LENGTH    64
#define UART4_BUF_LENGTH    64
u8  TX1_Cnt;    //發送計數
u8  RX1_Cnt;    //接收計數
u8  TX2_Cnt;    //發送計數
u8  RX2_Cnt;    //接收計數
u8  TX3_Cnt;    //發送計數
u8  RX3_Cnt;    //接收計數
u8  TX4_Cnt;    //發送計數
u8  RX4_Cnt;    //接收計數
bit B_TX1_Busy; //發送忙標志
bit B_TX2_Busy; //發送忙標志
bit B_TX3_Busy; //發送忙標志
bit B_TX4_Busy; //發送忙標志
u8  xdata RX1_Buffer[UART1_BUF_LENGTH]; //接收緩沖
u8  xdata RX2_Buffer[UART2_BUF_LENGTH]; //接收緩沖
u8  xdata RX3_Buffer[UART3_BUF_LENGTH]; //接收緩沖
u8  xdata RX4_Buffer[UART4_BUF_LENGTH]; //接收緩沖
uchar receBuf[10];//接收緩沖區
void    UART1_config(u8 brt);   // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
void    UART2_config(u8 brt);   // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
void    UART3_config(u8 brt);   // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer3做波特率.
void    UART4_config(u8 brt);   // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer4做波特率.
void    PrintString1(u8 *puts);
void    PrintString2(u8 *puts);
void    PrintString3(u8 *puts);
void    PrintString4(u8 *puts);
void    delay(uchar dat);//延時程序
void    senduart2();//發送函數
void    KEY(); //按鍵函數
void    LED(); //測試輸出
/****************  IO口定義及聲明 *****************/
/****************  按鍵輸入口 *****************/
sbit S1=P3^2;//外部中斷輸入0
sbit S2=P3^3;//外部中斷輸入1
sbit S3=P3^4;
sbit S4=P3^5;
sbit S5=P3^6;
sbit S6=P3^7;
/****************  485通訊換向口 *****************/
sbit RS485_DIR = P0^2; //RS485方向控制
/****************  外部函數聲明和外部變量聲明 *****************/
bit flag_zx3=0;//串口2標志
uchar UART3_JS=0;//串口2數據計數
bit S1bz=0;//按鍵1標志
bit S2bz=0;//按鍵2標志
bit S3bz=0;//按鍵3標志
bit S4bz=0;//按鍵4標志
bit S5bz=0;//按鍵5標志
bit S6bz=0;//按鍵6標志
bit UART3_FSBZ=0;//串口2發送標志
uchar uart_dat=0;//按鍵數據
uint yssj=1000;
// 函數: void main(void)
// 描述: 主函數。
// 參數: none.
// 返回: none.
void main(void)
    P0M1 = 0x00;   P0M0 = 0x00;   //設置為準雙向口
    P1M1 = 0x00;   P1M0 = 0x00;   //設置為準雙向口
    P2M1 = 0x00;   P2M0 = 0x00;   //設置為準雙向口
    P3M1 = 0x00;   P3M0 = 0x00;   //設置為準雙向口
    P4M1 = 0x00;   P4M0 = 0x00;   //設置為準雙向口
    P5M1 = 0x00;   P5M0 = 0x00;   //設置為準雙向口
    P6M1 = 0x00;   P6M0 = 0x00;   //設置為準雙向口
    P7M1 = 0x00;   P7M0 = 0x00;   //設置為準雙向口
    LED();
    UART1_config(2);    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
    UART2_config(2);    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
    UART3_config(0);    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer3做波特率.
    UART4_config(0);    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer4做波特率.
    EA = 1;             //允許全局中斷
          RS485_DIR=1;//發送狀態
    PrintString1("STC8H8K64U UART1 Test Programme!\r\n");  //UART1發送一個字符串
    PrintString2("STC8H8K64U UART2 Test Programme!\r\n");  //UART2發送一個字符串
    PrintString3("STC8H8K64U UART3 Test Programme!\r\n");  //UART3發送一個字符串
    PrintString4("STC8H8K64U UART4 Test Programme!\r\n");  //UART4發送一個字符串
    RS485_DIR=0;//讀取狀態
    while (1)
                                KEY();//按鍵函數
        if((TX1_Cnt != RX1_Cnt) && (!B_TX1_Busy))   //收到數據, 發送空閑
            SBUF = RX1_Buffer[TX1_Cnt];
            B_TX1_Busy = 1;
            if(++TX1_Cnt >= UART1_BUF_LENGTH)   TX1_Cnt = 0;
        if((TX2_Cnt != RX2_Cnt) && (!B_TX2_Busy))   //收到數據, 發送空閑
            S2BUF = RX2_Buffer[TX2_Cnt];
            B_TX2_Busy = 1;
            if(++TX2_Cnt >= UART2_BUF_LENGTH)   TX2_Cnt = 0;
//        if((TX3_Cnt != RX3_Cnt) && (!B_TX3_Busy))   //收到數據, 發送空閑
//            S3BUF = RX3_Buffer[TX3_Cnt];
//            B_TX3_Busy = 1;
//            if(++TX3_Cnt >= UART3_BUF_LENGTH)   TX3_Cnt = 0;
        if((TX4_Cnt != RX4_Cnt) && (!B_TX4_Busy))   //收到數據, 發送空閑
            S4BUF = RX4_Buffer[TX4_Cnt];
            B_TX4_Busy = 1;
            if(++TX4_Cnt >= UART4_BUF_LENGTH)   TX4_Cnt = 0;
//          主函數程序結束
                                        延時函數
void delay(uint dat)//延時程序
uint m,n,s;
for(m=dat;m>0;m--)
for(n=2;n>0;n--)
for(s=100;s>0;s--);
/****************發送函數*********************/
void senduart3()//發送函數
RS485_DIR=1;
S3BUF=0xAA;B_TX3_Busy = 1;while(B_TX3_Busy);
S3BUF=uart_dat;B_TX3_Busy = 1;while(B_TX3_Busy);
S3BUF=0xFF;B_TX3_Busy = 1;while(B_TX3_Busy);
S3BUF=0xBB;B_TX3_Busy = 1;while(B_TX3_Busy);
RS485_DIR=0;
/*****************清空發送緩沖區*************************/
void clear_receBuf() //清空發送緩沖區
uchar i;
for(i=0;i<5;i++)
RX3_Buffer=0;
        按鍵函數
void KEY() //按鍵函數
if(UART3_FSBZ==1){senduart3();UART3_FSBZ=0;}
if((S1==0)&&(S1bz==0)){delay(10);if((S1==0)&&(S1bz==0)){uart_dat=0X01;senduart3();S1bz=1;}}if((S1==1)&&(S1bz==1)){delay(10);if((S1==1)&&(S1bz==1)){S1bz=0;}}
if((S2==0)&&(S2bz==0)){delay(10);if((S2==0)&&(S2bz==0)){uart_dat=0X02;senduart3();S2bz=1;}}if((S2==1)&&(S2bz==1)){delay(10);if((S2==1)&&(S2bz==1)){S2bz=0;}}
if((S3==0)&&(S3bz==0)){delay(10);if((S3==0)&&(S3bz==0)){uart_dat=0X03;senduart3();S3bz=1;}}if((S3==1)&&(S3bz==1)){delay(10);if((S3==1)&&(S3bz==1)){S3bz=0;}}
if((S4==0)&&(S4bz==0)){delay(10);if((S4==0)&&(S4bz==0)){uart_dat=0X04;senduart3();S4bz=1;}}if((S4==1)&&(S4bz==1)){delay(10);if((S4==1)&&(S4bz==1)){S4bz=0;}}
if((S5==0)&&(S5bz==0)){delay(10);if((S5==0)&&(S5bz==0)){uart_dat=0X05;senduart3();S5bz=1;}}if((S5==1)&&(S5bz==1)){delay(10);if((S5==1)&&(S5bz==1)){S5bz=0;}}
if((S6==0)&&(S6bz==0)){delay(10);if((S6==0)&&(S6bz==0)){uart_dat=0X06;senduart3();S6bz=1;}}if((S6==1)&&(S6bz==1)){delay(10);if((S6==1)&&(S6bz==1)){S6bz=0;}}
void LED() //測試輸出
P0=0XFF;
P1=0XFF;
P2=0XFF;
P3=0XFF;
P4=0XFF;
P5=0XFF;
P6=0XFF;
P7=0XFF;
delay(yssj);P40=0;
delay(yssj);P64=0;
delay(yssj);P65=0;
delay(yssj);P66=0;
delay(yssj);P67=0;
delay(yssj);P30=0;
delay(yssj);P31=0;
delay(yssj);P32=0;
delay(yssj);P33=0;
delay(yssj);P34=0;
delay(yssj);P50=0;
delay(yssj);P51=0;
delay(yssj);P35=0;
delay(yssj);P36=0;
delay(yssj);P37=0;
delay(yssj);P70=0;
delay(yssj);P71=0;
delay(yssj);P72=0;
delay(yssj);P73=0;
delay(yssj);P41=0;
delay(yssj);P42=0;
delay(yssj);P43=0;
delay(yssj);P44=0;
delay(yssj);P20=0;
delay(yssj);P21=0;
delay(yssj);P22=0;
delay(yssj);P23=0;
delay(yssj);P24=0;
delay(yssj);P25=0;
delay(yssj);P26=0;
delay(yssj);P27=0;
delay(yssj);P74=0;
delay(yssj);P75=0;
delay(yssj);P76=0;
delay(yssj);P77=0;
delay(yssj);P45=0;
delay(yssj);P46=0;
delay(yssj);P00=0;
delay(yssj);P01=0;
delay(yssj);P02=0;
delay(yssj);P03=0;
delay(yssj);P04=0;
delay(yssj);P52=0;
delay(yssj);P53=0;
delay(yssj);P05=0;
delay(yssj);P06=0;
delay(yssj);P07=0;
delay(yssj);P60=0;
delay(yssj);P61=0;
delay(yssj);P62=0;
delay(yssj);P63=0;
delay(yssj);P10=0;
delay(yssj);P11=0;
delay(yssj);P47=0;
delay(yssj);P14=0;
delay(yssj);P15=0;
delay(yssj);P16=0;
delay(yssj);P17=0;
delay(yssj);P13=0;
delay(yssj);
P0=0XFF;
P1=0XFF;
P2=0XFF;
P3=0XFF;
P4=0XFF;
P5=0XFF;
P6=0XFF;
P7=0XFF;
delay(yssj);
P0=0X00;
P1=0X00;
P2=0X00;
P3=0X00;
P4=0X00;
P5=0X00;
P6=0X00;
P7=0X00;
delay(yssj);
P0=0XFF;
P1=0XFF;
P2=0XFF;
P3=0XFF;
P4=0XFF;
P5=0XFF;
P6=0XFF;
P7=0XFF;
delay(yssj);
P0=0X00;
P1=0X00;
P2=0X00;
P3=0X00;
P4=0X00;
P5=0X00;
P6=0X00;
P7=0X00;
delay(yssj);
P0=0XFF;
P1=0XFF;
P2=0XFF;
P3=0XFF;
P4=0XFF;
P5=0XFF;
P6=0XFF;
P7=0XFF;
delay(yssj);
P0=0X00;
P1=0X00;
P2=0X00;
P3=0X00;
P4=0X00;
P5=0X00;
P6=0X00;
P7=0X00;
delay(yssj);
P0=0XFF;
P1=0XFF;
P2=0XFF;
P3=0XFF;
P4=0XFF;
P5=0XFF;
P6=0XFF;
P7=0XFF;
// 函數: void PrintString1(u8 *puts)
// 描述: 串口1發送字符串函數。
// 參數: puts:  字符串指針.
// 返回: none.
    for (; *puts != 0;  puts++)     //遇到停止符0結束
        SBUF = *puts;
        B_TX1_Busy = 1;
        while(B_TX1_Busy);
// 函數: void PrintString2(u8 *puts)
// 描述: 串口2發送字符串函數。
// 參數: puts:  字符串指針.
// 返回: none.
        S2BUF = *puts;
        B_TX2_Busy = 1;
        while(B_TX2_Busy);
// 函數: void PrintString3(u8 *puts)
// 描述: 串口3發送字符串函數。
// 參數: puts:  字符串指針.
// 返回: none.
        S3BUF = *puts;
        B_TX3_Busy = 1;
        while(B_TX3_Busy);
// 函數: void PrintString4(u8 *puts)
// 描述: 串口4發送字符串函數。
// 參數: puts:  字符串指針.
// 返回: none.
        S4BUF = *puts;
        B_TX4_Busy = 1;
        while(B_TX4_Busy);
// 函數: SetTimer2Baudraye(u16 dat)
// 描述: 設置Timer2做波特率發生器。
// 參數: dat: Timer2的重裝值.
// 返回: none.
void    SetTimer2Baudraye(u16 dat)
    AUXR &= ~(1<<4);    //Timer stop
    AUXR &= ~(1<<3);    //Timer2 set As Timer
    AUXR |=  (1<<2);    //Timer2 set as 1T mode
    T2H = dat / 256;
    T2L = dat % 256;
    IE2  &= ~(1<<2);    //禁止中斷
    AUXR |=  (1<<4);    //Timer run enable
// 函數: void   UART1_config(u8 brt)
// 描述: UART1初始化函數。
// 參數: brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
// 返回: none.
    /*********** 波特率使用定時器2 *****************/
    if(brt == 2)
        AUXR |= 0x01;       //S1 BRT Use Timer2;
        SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate1);
    /*********** 波特率使用定時器1 *****************/
        TR1 = 0;
        AUXR &= ~0x01;      //S1 BRT Use Timer1;
        AUXR |=  (1<<6);    //Timer1 set as 1T mode
        TMOD &= ~(1<<6);    //Timer1 set As Timer
        TMOD &= ~0x30;      //Timer1_16bitAutoReload;
        TH1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) / 256);
        TL1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) % 256);
        ET1 = 0;    //禁止中斷
        INT_CLKO &= ~0x02;  //不輸出時鐘
        TR1  = 1;
    SCON = (SCON & 0x3f) | 0x40;    //UART1模式, 0x00: 同步移位輸出, 0x40: 8位數據,可變波特率, 0x80: 9位數據,固定波特率, 0xc0: 9位數據,可變波特率
//  PS  = 1;    //高優先級中斷
    ES  = 1;    //允許中斷
    REN = 1;    //允許接收
    P_SW1 &= 0x3f;      //UART1 switch to, 0x00: P3.0 P3.1
    P_SW1 |= 0x00;      //UART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7, 0xC0: P4.3 P4.4
//  PCON2 |=  (1<<4);   //內部短路RXD與TXD, 做中繼, ENABLE,DISABLE
    B_TX1_Busy = 0;
    TX1_Cnt = 0;
    RX1_Cnt = 0;
// 函數: void   UART2_config(u8 brt)
// 描述: UART2初始化函數。
// 參數: brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
// 返回: none.
void    UART2_config(u8 brt)    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
    if(brt == 2)
        SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate2);
        S2CON &= ~(1<<7);   // 8位數據, 1位起始位, 1位停止位, 無校驗
        IE2   |= 1;         //允許中斷
        S2CON |= (1<<4);    //允許接收
        P_SW2 &= ~0x01;     //UART2 switch to: 0: P1.0 P1.1
//        P_SW2 |= 1;         //UART2 switch to: 1: P4.0 P4.2
        B_TX2_Busy = 0;
        TX2_Cnt = 0;
        RX2_Cnt = 0;
// 函數: void UART3_config(u8 brt)
// 描述: UART3初始化函數。
// 參數: brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer3做波特率.
// 返回: none.
void UART3_config(u8 brt)    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer3做波特率.
    if(brt == 2)
        SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate3);
        S3CON = 0x10;       //8位數據, 使用Timer2做波特率發生器, 允許接收
        S3CON = 0x50;       //8位數據, 使用Timer3做波特率發生器, 允許接收
        T3H = (65536UL - (MAIN_Fosc / 4) / Baudrate3) / 256;
        T3L = (65536UL - (MAIN_Fosc / 4) / Baudrate3) % 256;
        T4T3M &= 0xf0;
        T4T3M |= 0x0a;
    IE2 |= 0x08;          //允許UART3中斷
    P_SW2 &= ~0x02;       //UART3 switch bit1 to: 0: P0.0 P0.1
    //P_SW2 |= 0x02;      //UART3 switch bit1 to: 1: P5.0 P5.1
    B_TX3_Busy = 0;
    TX3_Cnt = 0;
    RX3_Cnt = 0;
// 函數: void UART4_config(u8 brt)
// 描述: UART4初始化函數。
// 參數: brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer4做波特率.
// 返回: none.
void UART4_config(u8 brt)    // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer4做波特率.
    if(brt == 2)
        SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate4);
        S4CON = 0x10;       //8位數據, 使用Timer2做波特率發生器, 允許接收
        S4CON = 0x50;       //8位數據, 使用Timer4做波特率發生器, 允許接收
        T4H = (65536UL - (MAIN_Fosc / 4) / Baudrate4) / 256;
        T4L = (65536UL - (MAIN_Fosc / 4) / Baudrate4) % 256;
        T4T3M &= 0x0f;
        T4T3M |= 0xa0;
    IE2 |= 0x10;         //允許UART4中斷
//   P_SW2 &= ~0x04;      //UART4 switch bit2 to: 0: P0.2 P0.3
    P_SW2 |= 0x04;       //UART4 switch bit2 to: 1: P5.2 P5.3
    B_TX4_Busy = 0;
    TX4_Cnt = 0;
    RX4_Cnt = 0;
// 函數: void UART1_int (void) interrupt UART1_VECTOR
// 描述: UART1中斷函數。
// 參數: nine.
// 返回: none.
void UART1_int (void) interrupt 4
    if(RI)
        RI = 0;
        RX1_Buffer[RX1_Cnt] = SBUF;
        if(++RX1_Cnt >= UART1_BUF_LENGTH)   RX1_Cnt = 0;
    if(TI)
        TI = 0;
        B_TX1_Busy = 0;
// 函數: void UART2_int (void) interrupt UART2_VECTOR
// 描述: UART2中斷函數。
// 參數: nine.
// 返回: none.
void UART2_int (void) interrupt 8
    if((S2CON & 1) != 0)
        S2CON &= ~1;    //Clear Rx flag
        RX2_Buffer[RX2_Cnt] = S2BUF;
        if(++RX2_Cnt >= UART2_BUF_LENGTH)   RX2_Cnt = 0;
    if((S2CON & 2) != 0)
        S2CON &= ~2;    //Clear Tx flag
        B_TX2_Busy = 0;
//void UART2_int (void) interrupt 8
//if((S2CON & 1) != 0)
//S2CON &= ~1; //接收標志清零
//RX2_Buffer[UART2_JS++&0x0F] = S2BUF;    //把接受的數據存儲到BUT數組中
//if(RX2_Buffer[0]!=0xaa){UART2_JS=0;}
//if(UART2_JS>=5){UART2_JS=0;flag_zx2=1;}
//if(flag_zx2==1)
//flag_zx2=0;
//if((RX2_Buffer[0]==0xaa)&&(RX2_Buffer[1]==0x00)&&(RX2_Buffer[2]==0x00)&&(RX2_Buffer[3]==0x00)&&(RX2_Buffer[4]==0xBB))
////        P0=0X55;
////        senduart2();//發送數據
//        UART2_FSBZ=1;
//        clear_receBuf();
//    if((S2CON & 2) != 0)
//        S2CON &= ~2;    //Clear Tx flag
//        B_TX2_Busy = 0;
// 函數: void UART3_int (void) interrupt UART3_VECTOR
// 描述: UART3中斷函數。
// 參數: nine.
// 返回: none.
//void UART3_int (void) interrupt 17
//    if((S3CON & 0x01) != 0)
//        S3CON &= ~0x01;    //Clear Rx flag
//        RX3_Buffer[RX3_Cnt] = S3BUF;
//        if(++RX3_Cnt >= UART3_BUF_LENGTH)   RX3_Cnt = 0;
//    if((S3CON & 0x02) != 0)
//        S3CON &= ~0x02;    //Clear Tx flag
//        B_TX3_Busy = 0;
if((S3CON & 1) != 0)
S3CON &= ~1; //接收標志清零
RX3_Buffer[UART3_JS++&0x0F] = S3BUF;    //把接受的數據存儲到BUT數組中
if(RX3_Buffer[0]!=0xaa){UART3_JS=0;}
if(UART3_JS>=5){UART3_JS=0;flag_zx3=1;}
if(flag_zx3==1)
flag_zx3=0;
if((RX3_Buffer[0]==0xaa)&&(RX3_Buffer[1]==0x00)&&(RX3_Buffer[2]==0x00)&&(RX3_Buffer[3]==0x00)&&(RX3_Buffer[4]==0xBB))
//        P0=0X55;
//        senduart3();//發送數據
        UART3_FSBZ=1;
        clear_receBuf();
    if((S3CON & 2) != 0)
        S3CON &= ~2;    //Clear Tx flag
        B_TX3_Busy = 0;
// 函數: void UART4_int (void) interrupt UART4_VECTOR
// 描述: UART4中斷函數。
// 參數: nine.
// 返回: none.
void UART4_int (void) interrupt 18
    if((S4CON & 0x01) != 0)
        S4CON &= ~0x01;    //Clear Rx flag
        RX4_Buffer[RX4_Cnt] = S4BUF;
        if(++RX4_Cnt >= UART4_BUF_LENGTH)   RX4_Cnt = 0;
    if((S4CON & 0x02) != 0)
        S4CON &= ~0x02;    //Clear Tx flag
        B_TX4_Busy = 0;
                                                結束
GYJ-0321 某一個寶描述_14.jpg (584.06 KB, 下載次數: 134)
GYJ-0321 STC8H8K64U_LQFP64精簡開發板個人程序.zip
107.13 KB, 下載次數: 29, 下載積分: 黑幣 -5
GYJ-0321 STC8H8K64U_LQFP64精簡開發板使用手冊.pdf
3.16 MB, 下載次數: 20, 下載積分: 黑幣 -5
STC8H4K64Txx-觸摸按鍵校驗檢測.zip
3.49 MB, 下載次數: 14, 下載積分: 黑幣 -5
三相無刷電機驅動-STC8H1K28-20220512.rar
158.39 KB, 下載次數: 13, 下載積分: 黑幣 -5
收藏收藏3 分享淘帖 頂 踩
ID:92810 發表于 2024-1-17 16:40 | 只看該作者
謝謝樓主分享,下載學習了。
ID:574758 發表于 2024-10-12 11:51 | 只看該作者
謝謝樓主,下載保存中
ID:92810 發表于 2024-12-18 09:20 | 只看該作者
謝謝樓主分享,下載學習了。
ID:92810 發表于 2025-1-6 00:48 | 只看該作者
謝謝樓主分享,下載學習了。
主站蜘蛛池模板: 日本一区二区在线播放 | 日韩国产精品视频 | 欧美亚洲在线 | 免费一级大片 | 色黄大色黄女片免费中国 | 日韩精品网 | 亚洲久草| www.huangse| 免费视频毛片 | 日韩精品一区在线 | 成人三级晚上看 | 色综合五月天 | 狼人久久 | 国产一级一片免费播放放a 免费国产视频 | 亚洲免费黄色 | 欧美专区第一页 | 中文字幕亚洲欧美 | 亚洲精品成人网 | 亚洲综合精品 | 国产中文字幕一区二区 | 免费a在线 | 日本精品二区 | 91网站免费 | 国产一级在线 | 国产中文一区 | 国产一区二区三区视频 | 一区二区三区成人 | 亚洲午夜视频在线观看 | 欧美日韩亚洲另类 | 日韩精品第一页 | 91视频亚洲 | 中文字幕1区 | 国产一区精品在线观看 | 中文一区二区 | 一级免费黄色片 | 美女张开腿 | 91精品国产乱码久久久久久 | 欧美黄色一级视频 | 中国久久久 | 国产视频福利 | 黄色小视频在线播放 |
