原理圖及代碼在附件
下載附件
2023-7-22 15:11 上傳
- #include <reg51.h>
- #include <string.h>
- #include <math.h>
- #include <uart.h>
- #include <i2c.h>
- #define max_freq 108000
- #define min_freq 87500
- sbit KEY1=P3^2;
- sbit KEY2=P3^3;
- unsigned char radio_write_data[5]={0x29,0xc2,0x20,0x11,0x00}; //要寫入TEA5767的數據
- //unsigned char radio_write_data[5]={0x2a,0xb6,0x40,0x11,0x40}; //要寫入TEA5767的數據
- unsigned char radio_read_data[5]; //TEA5767讀出的狀態
- unsigned int default_pll=0x301d; //0x29f9; //默認存臺的pll,95.8MHz
- //unsigned int max_pll=0x339b; //108MHz時的pll,
- //unsigned int min_pll=9000; //70MHz時的pll
- unsigned long frequency;
- unsigned int pll;
- /*void delay(unsigned int time)
- while(time--);
- void delay1ms (unsigned int b)//1ms
- for(b;b>0;b--)
- {unsigned int i;
- for(i=0;i<300;i++)
- void radio_write(void)
- unsigned char i;
- iic_start();
- iic_write8bit(0xc0); //TEA5767寫地址
- if(!iic_testack())
- for(i=0;i<5;i++)
- iic_write8bit(radio_write_data[i]);
- iic_ack();
- iic_stop();
- //由頻率計算PLL
- void get_pll(void)
- unsigned char hlsi;
- // unsigned int twpll=0;
- hlsi=radio_write_data[2]&0x10; //HLSI位
- if (hlsi)
- pll=(unsigned int)((float)((frequency+225)*4)/(float)32.768); //頻率單位:k
- else
- pll=(unsigned int)((float)((frequency-225)*4)/(float)32.768); //頻率單位:k
- //由PLL計算頻率
- void get_frequency(void)
- unsigned int npll=0;
- npll=pll;
- if (hlsi)
- frequency=(unsigned long)((float)(npll)*(float)8.192-225); //頻率單位:KHz
- else
- frequency=(unsigned long)((float)(npll)*(float)8.192+225); //頻率單位:KHz
- //讀TEA5767狀態,并轉換成頻率
- void radio_read(void)
- unsigned char i;
- unsigned char temp_l,temp_h;
- pll=0;
- iic_start();
- iic_write8bit(0xc1); //TEA5767讀地址
- for(i=0;i<5;i++)
- radio_read_data[i]=iic_read8bit();
- iic_ack();
- iic_stop();
- temp_l=radio_read_data[1];
- temp_h=radio_read_data[0];
- temp_h&=0x3f;
- pll=temp_h*256+temp_l;
- get_frequency();
- //手動設置頻率,mode=1,+0.1MHz; mode=0:-0.1MHz ,不用考慮TEA5767用于搜臺的相關位:SM,SUD
- void search(bit mode)
- radio_read();
- if(mode)
- frequency+=10;
- if(frequency>max_freq)
- frequency=min_freq;
- else
- frequency-=10;
- if(frequency<min_freq)
- frequency=max_freq;
- get_pll();
- radio_write_data[0]=pll/256;
- radio_write_data[1]=pll%256;
- radio_write_data[2]=0x20;
- radio_write_data[3]=0x11;
- radio_write_data[4]=0x00;
- radio_write();
- //自動搜臺,mode=1,頻率增加搜臺; mode=0:頻率減小搜臺,不過這個好像不能循環搜臺
- /*void auto_search(bit mode)
- radio_read();
- get_pll();
- if(mode)
- radio_write_data[2]=0xa0;
- else
- radio_write_data[0]=pll/256+0x40;
- radio_write();
- radio_read();
- while(!(radio_read_data[0]&0x80)) //搜臺成功標志
- delay(1000);
- radio_read();
- //disp_freq(9,1);
- PutNum(frequency);
- void main()
- UART_Init();//串口初始化
- UART_Send_Str("調頻收音機\n");
- radio_write();
- while(1)
- if(KEY1==0)
- delay1ms(15); //延時15ms
- if(KEY1==0)
- while(KEY1==0);//等待按鍵釋放
- search(1);
- radio_read();
- UART_Send_Str("目前頻率\n");
- UART_Put_Num(frequency);
- UART_Send_Str("\n");
- if(KEY2==0)
- if(KEY2==0)
- while(KEY2==0);//等待按鍵釋放
- search(0);
- radio_read();
Keil代碼下載:
01.7z
(59.83 KB, 下載次數: 26)
2023-7-22 15:13 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
