查看: 2109|回復(fù): 0
python寫的跑表程序
用PyCharm 編輯,可以讓大家學(xué)習(xí)python的多線程
以下是源代碼
import time
import tkinter as tk
from tkinter import *  # Frame use
import threading
import time
import os
import sys
wcmsec = 0
wcsec = 0
wcminutes = 0
wcrun = 0
timegetbk = 0
global t
# ---------main-------------------
if __name__ == '__main__':
    def main():
        global wcrun
        win = tk.Tk()
        win.geometry('350x160')
        win.minsize(350, 160)  # 最小尺寸  python tkinter 設(shè)置窗口大小不可縮放
        win.maxsize(350, 160)  # 最大尺寸
        win.wm_attributes('-topmost', 1)  # python tkinter窗口彈出置頂?shù)姆椒?br />
        win.title("秒表REV2")
        def startwatch():
            global wcrun, timegetbk
            timegetbk = time.time()
            wcrun = 1
        def Resetwatch():
            global wcmsec, wcsec, wcminutes, wcrun
            wcmsec = 0
            wcsec = 0
            wcminutes = 0
            wcrun = 0
            text.delete(1.0, tk.END)
            str1 = "00" + ":" + "00" + ":" + "00"
            text.insert(tk.INSERT, str1)
        def stopwatch():
            if (wcrun == 1):
                wcrun = 0
            else:
                wcrun = 1
            # time.sleep(0.3)  # 休眠1
        def timecycle():
            global wcmsec, wcsec, wcminutes, wcrun, timegetbk
            # button3.configure(text="--- World!", command=stopwatch)
            if (wcrun == 1):
                win.title("已運(yùn)行")
                button3.configure(text="停止!", command=stopwatch)
            else:
                win.title("已停止")
                button3.configure(text="運(yùn)行!", command=stopwatch)
            win.focus_set()
            if (wcrun > 0):
                timeget = time.time()
                if (timeget > timegetbk):
                    wcmsec = wcmsec + ((timeget - timegetbk) * 1000)
            if (wcmsec > 999):
                wcmsec = wcmsec - 1000
                wcsec = wcsec + 1
                if (wcsec > 59):
                    wcsec = wcsec - 60
                    wcminutes = wcminutes + 1
                    if (wcminutes > 99):
                        wcminutes = 0
            wcnum = int(wcmsec / 10)
            if (wcnum < 10):
                dispmsec = "0" + str(wcnum)
            else:
                dispmsec = str(wcnum)
            if (wcsec < 10):
                dispsec = "0" + str(wcsec)
            else:
                dispsec = str(wcsec)
            if (wcminutes < 10):
                dispmin = "0" + str(wcminutes)
            else:
                dispmin = str(wcminutes)
            str1 = dispmin + ":" + dispsec + ":" + dispmsec
            #threading.Timer(0.1, timecycle).start()
        def display():
                for i in range(1, 500000):
                    time.sleep(0.1)
              #      print("hello world")
                    timecycle()
            #global t
           # t = threading.Timer(0.1, timecycle)
           # t.start()
        def xFunc1(event):
            if (event.char == "v") or (event.char == "V"):
                startwatch()
            if (event.char == "b") or (event.char == "B"):
                startwatch()
            if (event.char == "n") or (event.char == "N"):
                startwatch()
            if (event.char == " "):
                stopwatch()
        def kill(pid):
            try:
                # command = 'taskkill /F /IM %d' %pid
                # print type(command)
                # os.system(command) #1111
                import subprocess
                subprocess.Popen("cmd.exe /k taskkill /F /T /PID %i" % pid, shell=True)
            except:
                print('no process')
        def on_closing():
            time.sleep(0.1)  # 休眠1
            #t.cancel()  # 關(guān)閉線程
            win.destroy()  # 關(guān)閉窗口
            pid = os.getpid()
            # os.system('taskkill /f /pid %s' % '20500')
            kill(pid)
            sys.exit()
            try:
                sys.exit(0)
            except:
                sys.exit(1)
        text = Text(
            master=win,  # 父容器
            bg='pink',  # 背景顏色
            fg='red',  # 文本顏色
            relief='sunken',  # 邊框的3D樣式 flatsunkenraisedgrooveridgesolid
            bd=3,  # 邊框的大小
            width=8,  # 寬度
            height=1,  # 高度
            state='normal',  # 設(shè)置狀態(tài) normalreadonly disabled
            cursor='arrow',  # 鼠標(biāo)移動(dòng)時(shí)樣式 arrow, circle, cross, plus...
            font=('黑體', 55),  # 字體
            wrap='char',  # 字?jǐn)?shù)夠width后是否換行 char, none,  word
        text.pack()
        y_setposition = 100
        x_setposition = 20
        x_space_set = 115
        x_position = x_setposition
        # button2 = tk.Button(win, text="啟動(dòng)", command=startwatch)
        # button2 = tk.Button(win, text="發(fā)送版本", command=sw.stopwatch(), width=15, height=5)
        button2.place(x = x_position,y = y_setposition,width = 80,height = 50)
        button2 = Button(
            master=win,  # 父容器
            activebackground='red',  # 背景顏色
            activeforeground="white",
            bd="2",
            command=startwatch,
            text="啟動(dòng)",
            font=('黑體', 22),
        button2.place(x=x_position, y=y_setposition, width=80, height=50)
        button3 = tk.Button(win, text="停止", command=stopwatch)
        x_position = x_setposition + x_space_set
        button3.place(x=x_position, y=y_setposition, width=80, height=50)
        button1 = tk.Button(win, text="復(fù)位", command=Resetwatch)
        x_position = x_setposition + x_space_set + x_space_set
        button1.place(x=x_position, y=y_setposition, width=80, height=50)
        win.bind("<Key>", xFunc1)
        global t1
        t1 = threading.Timer(0.1, timecycle())
        t1.start()
        rx1 = threading.Thread(target=display)  # 多線程
        rx1.start()
        win.protocol("WM_DELETE_WINDOW", on_closing)
        win.mainloop()
    main()
#  pyinstaller -F -w main.py   build1
#  pyinstaller -w main.py
app界面
app界面
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 伊人一区| 免费黄色网址在线观看 | 国产激情久久 | 国产一区二区三区四区 | 精品日韩在线 | 亚洲精品乱码久久久久久蜜桃91 | 91美女片黄在线观看91美女 | 国产三级做爰高清在线 | 国产视频黄 | 欧美成人极品 | 亚洲a级片 | 亚洲一级特黄 | 福利在线观看 | 国产伦精品一区二区三区视频黑人 | 中文字幕在线看 | 天天射天天舔 | 成人小网站 | 欧美一级欧美三级在线观看 | 午夜在线看片 | 69av视频| 国产美女一区二区三区 | 激情久久综合 | 青青草福利视频 | 日韩在线免费视频 | 精品日韩一区 | 中文久久久 | 日韩中文字幕在线观看 | 中文字幕一区在线 | 97青青草 | 亚洲第一在线 | 中文字幕免费高清 | 一区二区三区久久久 | 日韩av在线不卡 | 黄色片观看 | 国内精品一区二区 | 国产激情综合 | 成人自拍视频在线观看 | 在线看黄的网站 | 色老板免费视频 | 国产黄色免费 | 亚洲视频网址 |
