查看: 1589|回復(fù): 1
原創(chuàng)-visual basic net串口樣板架構(gòu)
ID:328023 發(fā)表于 2023-9-5 11:41 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
visual basicnet其實比visual C#更好用,作為嵌入式開發(fā)人員,用basic入門更簡單,可以很快做出調(diào)試產(chǎn)品工具。附件是完整項目
這個是電腦串口尋找子函數(shù)
   Private Sub com_channel_get(ByVal getcom1 As Integer)
        Dim getcom As Integer
        Dim ports As String() = SerialPort.GetPortNames() '必須用命名空間,用SerialPort,獲取計算機(jī)的有效串口
        Dim port As String
        For Each port In ports
            Console.WriteLine(port)
        Next port
        ComboBox1.Items.Clear()
        ComboBox1.Text = ""
            ComboBox1.Items.Add(port) '向combobox中添加項
        Next port
        getcom = ComboBox1.Items.Count '讀ComboBox1的數(shù)值
        Dim comnum As Integer
        Dim textcom As String
        ComboBox1.Enabled = False
        '     Exit Sub
        Dim mBaudRate As Integer
        Dim mParity As IO.Ports.Parity
        Dim mDataBit As Integer
        Dim mStopbit As IO.Ports.StopBits
        Dim mPortName As String = "COM1"
        mBaudRate = 9600   '比特率
        mParity = Parity.None  '校驗位檢查設(shè)定
        mDataBit = 8    '數(shù)據(jù)位設(shè)定值
        mStopbit = StopBits.One  '停止位設(shè)定值
        For comnum = 0 To getcom - 1 Step 1
            ComboBox1.SelectedIndex() = comnum '第一個端口為默認(rèn)
            mPortName = ComboBox1.GetItemText(ComboBox1.SelectedItem) '欲開啟的通訊端口
            '     mPortName = "COM3"
        Next comnum
        RS232 = New IO.Ports.SerialPort(mPortName, mBaudRate, mParity, mDataBit, mStopbit)
        If RS232.IsOpen = True Then  '尚未開啟
            RS232.Close()  '開啟通訊端口
        End If
        Threading.Thread.Sleep(50)
        Try
            If RS232.IsOpen = False Then  '尚未開啟
                RS232.Open()  '開啟通訊端口
                RS232.ReceivedBytesThreshold = 1        '設(shè)置引發(fā)事件的門限值
            End If
        Catch
            Try
                End If
            Catch
            End Try
        End Try
        Exit Sub
        Dim hexBytes(3) As Byte
        hexBytes(0) = &H6A
        'RS232.Write(hexBytes, 0, 1)
        RS232.Write("AT+DISC" + Chr(&HD) + Chr(&HA))
        Threading.Thread.Sleep(500)
        '   Dim rxdata As String = RS232_Data(3)
        Label1.Text = "通信未連接"
        Label1.ForeColor = Color.Red
        Dim textcompare As String = ""
        If (Len(gl_string) > 4) Then
            textcompare = Mid(gl_string, 1, 5)
        End If
        'ERROR OR OK+DISC
        If ((textcompare = "ERROR") Or (textcompare = "OK+DI")) Then
            Label1.Text = "通信已連接"
            Label1.ForeColor = Color.Green
            setrxnum = 4
        End If
        '    If (RS232.BytesToRead >= 5) Then
        'setrxnum = 8 '打開串口自動讀取
        '   Exit For
        '    End If
        End If
    End Sub
prj_Vbnet.zip (509.89 KB, 下載次數(shù): 1)
ID:262 發(fā)表于 2024-1-22 02:43 | 只看該作者
好資料,51黑有你更精彩!!!
主站蜘蛛池模板: 亚洲一区二区三区免费视频 | 国产欧美日韩一区 | 青青草国产精品 | 亚洲国产中文字幕 | 又黄又爽网站 | www.色婷婷| 国产精品久久久一区二区 | 精品久久久久久久久久久 | 国产情侣在线播放 | 四虎四虎 | 可以免费看黄的网站 | 97国产在线观看 | 久久精品亚洲 | 日韩在线免费 | h片在线 | 日韩三级在线播放 | 人人干人人爽 | 免费三片在线观看网站v888 | 久久精品2 | 在线观看黄色小视频 | 天天看天天干 | 日日操日日干 | 日韩在线免费视频 | 国产欧美在线观看 | 国产香蕉在线 | 日韩激情网站 | 日本免费在线观看 | 亚洲欧美视频在线观看 | 三级网站在线 | 午夜伦理福利 | 久久人人爽人人爽人人片 | 99午夜| 黄色激情视频网站 | 日本久久精品 | 国产精品久久久久久久久久久久久 | 国产精品羞羞答答 | 人人看人人干 | 成人深夜福利视频 | 国产欧美日韩一区二区三区 | 亚洲视频一区在线观看 | 国产成人在线播放 |
