查看: 2158|回復(fù): 4
仿真軟件中使用鎖存器無(wú)法實(shí)現(xiàn)單片機(jī)數(shù)碼管動(dòng)態(tài)顯示的問(wèn)題
回帖獎(jiǎng)勵(lì) 1 黑幣 回復(fù)本帖可獲得 1 黑幣獎(jiǎng)勵(lì)! 每人限 1 次(中獎(jiǎng)概率 20%)
各位前輩,我最近重拾單片機(jī),在實(shí)現(xiàn)數(shù)碼管動(dòng)態(tài)顯示的時(shí)候遇到一個(gè)問(wèn)題。我按照教程編寫了使用兩個(gè)鎖存器實(shí)現(xiàn)數(shù)碼管顯示的代碼,并使用定時(shí)器中斷來(lái)進(jìn)行延時(shí)的作用。當(dāng)延時(shí)為1s時(shí),可以實(shí)現(xiàn)前六個(gè)數(shù)碼管分別從1-6流動(dòng)。但是,如果將時(shí)間降低,我在proteus上無(wú)法實(shí)現(xiàn)動(dòng)態(tài)顯示的效果。仿真中的電路圖是我自己畫的,代碼是按照教程編寫的,請(qǐng)各位大佬幫我看一下問(wèn)題在哪?(有一個(gè)蜂鳴器,測(cè)試的大佬要關(guān)一下,不然很吵
  1. //數(shù)碼管以1s間隔從0-6,在前六個(gè)數(shù)碼管流水顯示
  2. //問(wèn)題:在proteus仿真無(wú)法實(shí)現(xiàn)實(shí)驗(yàn)板上的動(dòng)態(tài)數(shù)碼管顯示效果,無(wú)法用視覺(jué)暫留形成效果。。。。!
  3. #include<reg52.h>
  4. #include<intrins.h>
  5. #define uint unsigned int
  6. #define uchar unsigned char
  7. uchar temp,aa,numdu,numwe;
  8. sbit dula = P2^6;
  9. sbit wela = P2^7;
  10. uchar code table[] =  {
  11. 0x3f,0x06,0x5b,0x4f,
  12. 0x66,0x6d,0x7d,0x07,
  13. 0x7f,0x6f,0x77,0x7c,
  14. 0x39,0x5e,0x79,0x71};
  15. uchar code tablewe[] = {
  16. 0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
  17. void main()
  18. {
  19.         numdu = 0;
  20.         numwe = 0;
  21.         aa = 0;
  22.         TMOD = 0x01;//六行代碼完成定時(shí)器0中斷的初始化。。。。!
  23.         TH0 = (65536-5000)/256;
  24.         TL0 = (65536-5000)%256;
  25.         EA = 1;
  26.         ET0 = 1;
  27.         TR0 = 1;//啟動(dòng)定時(shí)器0!
  28.         while(1)
  29.         {
  30.                 if(aa==1)
  31.                 {
  32.                         aa = 0;
  33.                         numdu++;
  34.                         if(numdu==7)
  35.                         {
  36.                                 numdu = 1;
  37.                         }
  38.                         dula = 1;
  39.                         P0 = table[numdu];
  40.                         dula = 0;
  41.                         wela = 1;
  42.                         P0 = tablewe[numwe];
  43.                         wela = 0;
  44.                         numwe++;
  45.                         if(numwe==6)
  46.                                 numwe = 0;
  47.
  48.                 }
  49.         }
  50. }
  51. void timer0() interrupt 1
  52. {
  53.         TH0 = (65536-5000)/256;
  54.         TL0 = (65536-5000)%256;
  55.         aa++;
  56. }
ID:161164 發(fā)表于 2023-9-14 14:08 | 只看該作者
要加消影
  1.                 if(aa==1)
  2.                 {
  3.                         aa = 0;
  4.                         numdu++;
  5.                         if(numdu==7)
  6.                         {
  7.                                 numdu = 1;
  8.                         }
  9.                         wela = 1;
  10.                         P0 = 0xFF;//消影
  11.                         wela = 0;
  12.
  13.                         dula = 1;
  14.                         P0 = table[numdu];
  15.                         dula = 0;
  16.                         wela = 1;
  17.                         P0 = tablewe[numwe];
  18.                         wela = 0;
  19.                         numwe++;
  20.                         if(numwe==6)
  21.                                 numwe = 0;
  22.                 }
ID:272176 發(fā)表于 2023-9-14 15:41 | 只看該作者
謝謝老哥,修改成功。請(qǐng)問(wèn)這是段選P0口賦值和位選P0口賦值相互之間的干擾嗎?
我也剛意識(shí)到,上傳的代碼沒(méi)有注釋。感謝老哥!
ID:535881 發(fā)表于 2023-9-14 21:05 | 只看該作者
前兩天我也遇到了,proteus上使用數(shù)碼管必須消影。
當(dāng)數(shù)碼管切換到下一位時(shí),這個(gè)數(shù)碼管就會(huì)顯示上一個(gè)數(shù)碼管的數(shù)字,由于切換時(shí)間很短,一閃而過(guò),給人一種影的感覺(jué),為了不顯示上一個(gè)數(shù),應(yīng)該在切換數(shù)碼管之前把所有的燈關(guān)掉,這就是所謂的消影。
ID:123289 發(fā)表于 2023-9-15 15:19 | 只看該作者
要點(diǎn):
1、切換時(shí)間要盡可能短,讓有效顯示時(shí)間長(zhǎng),這樣亮度才能達(dá)到最大。
2、切換前要準(zhǔn)備好切換的數(shù)據(jù),這樣才能減少切換執(zhí)行的指令。
3、切換動(dòng)作的第一步是關(guān)顯示,這樣切換時(shí)的數(shù)據(jù)變化才不被顯示,顯示才不會(huì)混亂。
4、做切換動(dòng)作。
5、最后一步,是打開新一顯示。
切換步驟如下(切換過(guò)程僅在條指令):
1、U3 = 全關(guān)
2、U1 = 新的顯示位數(shù)據(jù)(數(shù)據(jù)事先做好,如放在變量NEX_D中,在此取用)
3、U3 = 打開新顯示位(數(shù)據(jù)事先做好,如放在變量NEX_W中,在此取用)
P0 = 全關(guān) → U3.LE = 1使能 → U3.LE = 0鎖存 → 關(guān)顯示【消隱】
P0 = NEX_D → U1.LE = 1使能 → U1.LE = 0鎖存 → 【切換顯示數(shù)據(jù)】
P0 = NEX_W → U3.LE = 1使能 → U3.LE = 0鎖存 → 【切換顯示位】
你的錯(cuò)誤是:
dula = 1;
錯(cuò)誤:【這時(shí)Ux打開,但數(shù)據(jù)P0是混亂的,導(dǎo)致短暫顯示不受控】
改正:【放在正確的數(shù)據(jù)準(zhǔn)備好之后】
P0 = table[numdu]
不佳:【C語(yǔ)言取數(shù)組中的數(shù)據(jù),不止一條指令,也即占用時(shí)間長(zhǎng)了】
最佳:【事先做 NEX_x = table[numdu],在此:P0 = NEX_x】
dula = 0【OK】
改正后:
P0 = NEX_x;【切換前準(zhǔn)備好 NEX_x = table[numdu]】
dula = 1;
dula = 0;
主站蜘蛛池模板: 免费一级黄色片 | 五月天婷婷激情网 | 国产精品一区久久 | 激情综| 午夜伦理视频 | 黄色在线播放 | 成人福利在线观看 | 一级大片 | 九色av| 国产成人在线观看免费网站 | 草草视频在线观看 | 亚洲www. | 91视频亚洲 | 国产欧美一区二区三区在线看蜜臀 | 亚洲综合激情网 | 亚洲欧洲天堂 | 国产又粗又长又爽 | 国产精品99久久久久久www | 国产精品成人一区二区三区 | 特级丰满少妇一级aaaa爱毛片 | 成人小视频在线观看 | 一区二区三区视频 | 中文字幕av网| 天天天天天操 | 久久综合久 | 91国在线| 欧美成人综合 | 精品一区二区国产 | 日韩精品三级 | 日本中文字幕视频 | 亚洲国产中文字幕 | 日韩黄网| 亚洲a视频 | 欧美一区二区三区视频 | 人人爽爽人人 | 91爱看| 免费黄色片视频 | 亚洲精品成人在线 | 亚洲福利在线观看 | 死神来了4无删减版在线观看 | 欧美日韩综合网 |
