查看: 3064|回復: 14
關于使用東軟軟件單片機點亮使用74HC595級聯數碼管程序問題
50黑幣
數碼管顯示亂碼,幫忙分析下原因:
#include "Led_Display.h"
//#include"smg.h"
#include <hic.h>
#include "delay.h"
const char smgduan[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共陽
//u16 smgduan[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//共陽
//u16 smgduan[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰
u8 DisPlayData[8];
u16 count;
u16 sec,min,hour;
//sbit SCL = (PA1);//時鐘脈沖信號——上升沿有效ST
//sbit RCL = (PA3);//打入信號————上升沿有效SH
//sbit DIO = (PA5);//串行數據入DS...............
void Smg_Init( )
    ANSL = 0xFF;        //選擇對應端口為數字IO功能
        ANSH = 0xFF;        //選擇對應端口為數字IO功能
    PAT = 0x00;         //所有IO設為輸出低電平
    PBT = 0x00;
    PCT = 0x00;
    PA = 0x00;
    PB = 0x00;
    PC = 0x00;
        //PB6=0;
****函數名:                SMG_Write_Bite (u8 dat,u8 dat1)
****功能                        寫入數據
void SMG_Write_Byte (u8 dat,u8 dat1)
        u8 i;
        for(i=0;i<8;i++)
                //((dat<<i)&0x80)? DIO_HIGH:DIO_LOW;                                //        三目運算
                if((dat<<i)&0x80)
                        DIO=1;
                        DIO=0;
                //SCL_HIGH;
                //SCL_LOW;
                SCL=1;
                //delay_us(10);
                //delay_ms(1);
                //delay(1);
                SCL=0;
        for(i=0;i<8;i++)
                //((dat1<<i)&0x80)? DIO_HIGH:DIO_LOW;                                //        三目運算
                //SCL_HIGH;
                //SCL_LOW;
                if((dat<<i)&0x80)
                        DIO=1;
                        DIO=0;
                SCL=1;
                SCL=0;
        //RCL_HIGH;
        //RCL_LOW;
        RCL=1;
        RCL=0;
void SMG_Number (u16 sec,u16 count)
//                SMG_Write_Byte (smgduan[((sec%1000)%100)%10],0x01);
                SMG_Write_Byte (smgduan[sec%10],0x01);
                //delay_ms(1);
                delay(1);
//                SMG_Write_Byte (smgduan[((sec%1000)%100)/10],0x02);
                SMG_Write_Byte (smgduan[sec/10],0x02);
                //delay_ms(1);
                delay(1);
//                SMG_Write_Byte (smgduan[(sec%1000)/100],0x04);
                SMG_Write_Byte (smgduan[min%10],0x04);
                //delay_ms(1);
                delay(1);
//                SMG_Write_Byte (smgduan[sec/1000],0x08);
                SMG_Write_Byte (smgduan[min/10],0x08);
                //delay_ms(1);
                delay(1);
//        if(sec>4500)
//                count++;
//                if(count>9999)
//                        count=0;
//                SMG_Write_Byte (smgduan[((count%1000)%100)%10],0x10);
                SMG_Write_Byte (smgduan[(hour%100)%10],0x10);
                delay(1);
//                SMG_Write_Byte (smgduan[((count%1000)%100)/10],0x20);
                SMG_Write_Byte (smgduan[(hour%100)/10],0x20);
                delay(1);
//                SMG_Write_Byte (smgduan[(count%1000)/100],0x40);
                SMG_Write_Byte (smgduan[hour/100],0x40);
                delay(1);
                SMG_Write_Byte (smgduan[count],0x80);
                delay(1);
#ifndef _LED_DISPLAY_H
#define _LED_DISPLAY_H
#include <hic.h>
#include "typedef.h"
#define SCL  (PA0)//時鐘脈沖信號——上升沿有效ST
#define RCL  (PA6)//打入信號————上升沿有效SH
#define DIO  (PA7)//串行數據入DS...............
//typedef   unsigned  char   u8;
//typedef   unsigned  int    u16;
//typedef   unsigned  long   u32;
void        Smg_Init( void);
void        SMG_Number (u16 sec,u16 count);
void        SMG_Write_Byte (u8 dat,u8 dat1);
//typedef uint8_t  u8;
#endif
/*sample.c*/
#include <hic.h>
#include "delay.h"
函數名:void RAMclear(void)
描  述:RAM區數據清零,RAM區地址0x0000~0x03FF
輸入值:無
輸出值:無
返回值:無
void RAMclear(void)
    for (IAAH=0; IAAH<=0x03; IAAH++)
        for (IAAL=0; IAAL<0xFF; IAAL++)
            IAD = 0x00;
        IAD = 0x00;
        Smg_Init( );
        //SMG_Number(1000,1000);
        {SMG_Number(1000,1000);
                //delay_ms(500);
                PB6=0;
                //delay_ms(500);
                delay(100);
                PB6=1;
                delay(100);
74HC595級聯
74HC595級聯
最佳答案
查看完整內容
void SMG_Write_Byte (u8 dat,u8 dat1)有錯誤
ID:384109 發表于 2023-10-12 19:37 | 只看該作者
ID:143767 發表于 2023-10-13 10:06 | 只看該作者
東軟的軟件是什么軟件?
ID:372579 發表于 2023-10-13 12:26 | 只看該作者
這個軟件還真沒用過,不過數碼管顯示亂,可能是引腳和程序不對,數碼管真值不對等等,要先查查硬件電路
ID:332444 發表于 2023-10-13 14:04 | 只看該作者
代碼中用發送8個數據為一次,發送16個數據分為2次發送8個數據即可。
ID:69038 發表于 2023-10-13 14:20 | 只看該作者
595這么友善的器件,一般是不會有問題的,即使有問題,單步跟蹤一下,基本上就能排除問題了。
ID:61632 發表于 2023-10-13 16:42 | 只看該作者
dj3365191 發表于 2023-10-13 10:06
東軟的軟件是什么軟件?
iDesigner4.1這個軟件,國產的MCU,想學習學習
ID:61632 發表于 2023-10-13 16:45 | 只看該作者
xianfajushi 發表于 2023-10-13 14:04
我也感覺是void SMG_Write_Byte (u8 dat,u8 dat1)這段代碼里出現問題了,因為這個是我STM32里用過的,移植修改的,結果出現了亂碼。感謝你的建議,后面會按照你的想法測試一下。
ID:61632 發表于 2023-10-13 16:47 | 只看該作者
aide51 發表于 2023-10-13 12:26
74HC595級聯的數碼管是一個成品模塊;不存在問題;引腳的設置,也沒有問題。
ID:69038 發表于 2023-10-13 17:06 | 只看該作者
595的SDA數據是在SCK的上升沿才鎖存的,所以,你把SMG_Write_Byte 中的SCL=1;SCL=0調一下?
//595送出串行數據
void send_595(char dat)        //595發送1字節數據
    char count1;               //位計數器,單字節為8位
        for (count1=8;count1>0;count1--)
                hc595_sda=dat & 0x01;  //取最低位數據做為串行數據位,低位先發,若高位先發,則dat & 0x80
                hc595_sck=0;           //置SCK為低
                Delay10us();           //延時
                hc595_sck=1;               //置SCK為高
                Delay10us();               //延時,輸出一個位的數據
                dat>>=1;               //數據右移,下一個位的數據,若高位先發則dat<<=1
ID:332444 發表于 2023-10-13 17:12 | 只看該作者
我今天回復了個挺好玩的16燈逐一點亮,注意代碼中的10和18的值,讓大家娛樂鑒賞,電路圖就不提供了吖,其實提問16等和切換的不少,這里就都有了吖。
ID:1095802 發表于 2023-10-14 09:52 | 只看該作者
xianfajushi 發表于 2023-10-13 17:12
我今天回復了個挺好玩的16燈逐一點亮,注意代碼中的10和18的值,讓大家娛樂鑒賞,電路圖就不提供了吖,其實 ...
這個SY,MY好像都沒啥作用啊
ID:332444 發表于 2023-10-14 20:20 | 只看該作者
殿堂之上 發表于 2023-10-14 09:52
這個SY,MY好像都沒啥作用啊
有用無用不是紙上談兵,實際試看就知道了。而且,鑒賞也需要會,這個代碼其實未優化,也是很有意思的,能同步卻也能完成16燈。
ID:61632 發表于 2023-10-17 16:08 | 只看該作者
zhuls 發表于 2023-10-13 17:06
//595送出串 ...
很感謝你的建議
ID:61632 發表于 2023-10-17 16:17 | 只看該作者
非常感謝大家的積極幫助和建議,我在這邊把我的結果奉上:
數碼管顯示亂碼,幫忙分析下原因:
//#include"smg.h"
#include <hic.h>
#include "delay.h"
u8 DisPlayData[8];
u16 count;
u16 sec,min,hour;
void Smg_Init( )
    PBT = 0x00;
    PCT = 0x00;
    PA = 0x00;
    PB = 0x00;
    PC = 0x00;
        //PB6=0;
****功能                        寫入數據
        u8 i;
        for(i=0;i<8;i++)
                if((dat<<i)&0x80)
                        DIO=1;
                        DIO=0;
                //SCL_HIGH;
                //SCL_LOW;
                SCL=1;
                //delay_us(10);
                //delay_ms(1);
                //delay(1);
                SCL=0;
        for(i=0;i<8;i++)
                //SCL_HIGH;
                //SCL_LOW;
                if((dat1<<i)&0x80)//這個原寫成dat,修改成dat1;
                        DIO=1;
                        DIO=0;
                SCL=1;
                SCL=0;
        //RCL_HIGH;
        //RCL_LOW;
        RCL=1;
        RCL=0;
                SMG_Write_Byte (smgduan[((sec%1000)%100)%10],0x01);//數碼管顯示公式進行了更改
                delay(1);
                delay(1);
                delay(1);
                delay(1);
//        if(sec>4500)
//                count++;
//                if(count>9999)
//                        count=0;
//                 SMG_Write_Byte (smgduan[(hour%100)%10],0x10);
//                delay(1);
//                 SMG_Write_Byte (smgduan[(hour%100)/10],0x20);
//                delay(1);
//                 SMG_Write_Byte (smgduan[hour/100],0x40);
//                 delay(1);
//                 SMG_Write_Byte (smgduan[count],0x80);
//                 delay(1);
#include <hic.h>
#endif
/*sample.c*/
#include <hic.h>
#include "delay.h"
輸入值:無
輸出值:無
返回值:無
void RAMclear(void)
            IAD = 0x00;
        IAD = 0x00;
        Smg_Init( );
                //delay_ms(500);
                PB6=0;
                //delay_ms(500);
                delay(100);
                PB6=1;
                delay(100);
//結果更改成這樣之后,數碼管顯示正常,完全OK
主站蜘蛛池模板: 国产黄色在线 | 中文字幕1区 | 日本一本草久p | 亚洲性色av | 亚洲国产成人精品女人久久久 | 国产丝袜视频 | 国产区视频在线 | 亚洲综合在线视频 | 在线h片| 91蝌蚪少妇偷拍 | 亚洲一区精品视频 | 三级在线免费观看 | 久久精品6| 亚洲人天堂 | 国产一区二区在线播放 | 国产尤物视频 | 手机成人在线视频 | 日韩1级片 | 日韩精品在线一区 | 色影视| 伊人9999| 午夜专区 | 国产精品一区一区三区 | 日韩av一级 | 国产成人av网站 | 国产成人精品亚洲男人的天堂 | 日韩在线视频观看 | 中文在线免费看视频 | 午夜一区二区三区 | 精品国产91 | 午夜av在线播放 | 亚洲一区二区三区中文字幕 | 国产亚洲一区二区三区 | 夜夜肉她怀孕h周君彦 | 日韩亚洲天堂 | 久久综合久 | 国产一级免费视频 | 成人爽a毛片一区二区免费 www.欧美精品 | 婷婷狠狠| 91精品久久久久久粉嫩 | 日本一区二区三区在线视频 |
