查看: 1811|回復: 5
一個OLED12832大字符阿拉伯數字字庫
ID:22439 發(fā)表于 2023-10-17 21:29 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
打算D一個轉速測量儀,用oled12832顯示,網上沒找到大字體,寫了一個。
  1. const unsigned char code z17X32[]=
  2. {
  3.   0x00,0xe0,0xf8,0xfc,0x3e,0x1f,0x0f,0x0f,  0x0f,0x0f,0x1f,0x3e,0xfc,0xf8,0xe0,0x00,  0x00,//0 //17列32行           //17
  4.   0xfe,0xff,0xff,0x01,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0x00,0x01,0xff,0xff,0xfe,  0x00,                                           //34
  5.   0x7f,0xff,0xff,0x80,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0x00,0x80,0xff,0xff,0x7f,  0x00,                                           //51
  6.   0x00,0x07,0x1f,0x3f,0x7c,0xf8,0xf0,0xf0,  0xf0,0xf0,0xf8,0x7c,0x3f,0x1f,0x07,0x00,  0x00,                                           //68
  7.   0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0xf0,  0xf8,0xfe,0xff,0xff,0x00,0x00,0x00,0x00,  0x00,//1
  8.   0x00,0x00,0x00,0x0f,0x07,0x03,0x01,0x01,  0x00,0xff,0xff,0xff,0x00,0x00,0x00,0x00,  0x00,
  9.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  0x00,0xff,0xff,0xff,0x00,0x00,0x00,0x00,  0x00,
  10.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  0x00,0xff,0xff,0xff,0x00,0x00,0x00,0x00,  0x00,
  11.   0xc0,0xf0,0xfc,0x7c,0x3e,0x1f,0x0f,0x0f,  0x0f,0x0f,0x0f,0x1f,0x1e,0x7e,0xfc,0xf0,  0xc0,//2
  12.   0x01,0x03,0x03,0x00,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0x80,0xc0,0xf0,0xff,0x7f,  0x0f,
  13.   0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0xf0,  0x78,0x3e,0x1f,0x0f,0x07,0x03,0x00,0x00,  0x00,
  14.   0xe0,0xf8,0xfe,0xff,0xf7,0xf3,0xf1,0xf0,  0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,  0xf0,
  15.
  16.   0xc0,0xf0,0xfc,0x7e,0x1e,0x1f,0x0f,0x0f,  0x0f,0x0f,0x1e,0x3e,0xfc,0xf8,0xe0,0x00,  0x00,//3
  17.   0x00,0x01,0x01,0x00,0x00,0x00,0xe0,0xe0,  0xe0,0xf0,0xf0,0xf8,0xbf,0x9f,0x07,0x00,  0x00,
  18.   0x80,0xc0,0xc0,0x00,0x00,0x00,0x01,0x01,  0x01,0x01,0x01,0x03,0x0f,0xff,0xfe,0xf8,  0x00,
  19.   0x03,0x0f,0x3f,0x7f,0x78,0xf8,0xf0,0xf0,  0xf0,0xf0,0xf8,0x78,0x3e,0x1f,0x0f,0x03,  0x00,
  20.
  21.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc0,  0xe0,0xf8,0x7e,0xff,0xff,0xff,0x00,0x00,  0x00,//4
  22.   0x00,0x00,0x80,0xc0,0xf0,0xfc,0x7f,0x1f,  0x07,0x01,0x00,0xff,0xff,0xff,0x00,0x00,  0x00,
  23.   0xf0,0xfe,0xff,0xff,0xf3,0xf1,0xf0,0xf0,  0xf0,0xf0,0xf0,0xff,0xff,0xff,0xf0,0xf0,  0xf0,
  24.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0xff,0xff,0xff,0x00,0x00,  0x00,
  25.
  26.   0x00,0x00,0xf8,0xff,0xff,0x0f,0x0f,0x0f,  0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,  0x00,//5
  27.   0xe0,0xff,0xff,0xff,0x78,0x38,0x3c,0x3c,  0x3c,0x3c,0x7c,0x78,0xf0,0xe0,0xc0,0x00,  0x00,
  28.   0x80,0x81,0x81,0x00,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0x00,0x01,0xff,0xff,0xff,  0x00,
  29.   0x03,0x0f,0x3f,0x7e,0x78,0xf0,0xf0,0xf0,  0xf0,0xf0,0x78,0x78,0x3e,0x1f,0x07,0x01,  0x00,
  30.
  31.   0x00,0xc0,0xf0,0xf8,0x7c,0x1e,0x1e,0x0f,  0x0f,0x0f,0x0f,0x0f,0x1e,0x7e,0xfc,0xf8,  0xe0,//6
  32.   0xfc,0xff,0xff,0xc3,0xe0,0xf0,0x70,0x78,  0x78,0x78,0x78,0xf8,0xf0,0xe0,0xc0,0x80,  0x00,
  33.   0x7f,0xff,0xff,0x03,0x01,0x00,0x00,0x00,  0x00,0x00,0x00,0x00,0x00,0x03,0xff,0xff,  0xfe,
  34.   0x00,0x07,0x0f,0x3f,0x7c,0x78,0xf0,0xf0,  0xf0,0xf0,0xf0,0xf8,0x7c,0x3e,0x1f,0x0f,  0x01,
  35.
  36.   0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,0x0f,  0x0f,0x0f,0x0f,0x0f,0xcf,0xef,0x7f,0x1f,  0x0f,//7
  37.   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  0xe0,0xf8,0xfe,0x1f,0x07,0x01,0x00,0x00,  0x00,
  38.   0x00,0x00,0x00,0x00,0x00,0xc0,0xf8,0xff,  0x3f,0x07,0x00,0x00,0x00,0x00,0x00,0x00,  0x00,
  39.   0x00,0x00,0x00,0x00,0xf8,0xff,0xff,0x07,  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  0x00,
  40.
  41.   0x00,0xe0,0xf8,0xfc,0x3e,0x1f,0x0f,0x0f,  0x0f,0x0f,0x1f,0x3e,0xfc,0xf8,0xe0,0x00,  0x00,//8
  42.   0x00,0x07,0x8f,0xdf,0xfc,0xf8,0xf0,0xf0,  0xf0,0xf0,0xf8,0xfc,0xdf,0x8f,0x07,0x00,  0x00,
  43.   0xfc,0xff,0xff,0x07,0x01,0x01,0x00,0x00,  0x00,0x00,0x01,0x01,0x07,0xff,0xff,0xf8,  0x00,
  44.   0x03,0x0f,0x3f,0x3e,0x78,0xf8,0xf0,0xf0,  0xf0,0xf0,0xf8,0x78,0x3e,0x3f,0x0f,0x03,  0x00,
  45.   0xc0,0xf0,0xf8,0xfc,0x3e,0x1f,0x0f,0x0f,  0x0f,0x0f,0x1e,0x1e,0x7c,0xf8,0xe0,0x00,  0x00,//9
  46.   0x7f,0xff,0xff,0xc0,0x00,0x00,0x00,0x00,  0x00,0x00,0x00,0x80,0xc0,0xff,0xff,0xff,  0x00,
  47.   0x00,0x01,0x07,0x0f,0x0f,0x1f,0x1e,0x1e,  0x1e,0x0e,0x0f,0x07,0xc3,0xff,0xff,0x3f,  0x00,
  48.   0x07,0x1f,0x3f,0x7c,0xf8,0xf0,0xf0,0xf0,  0xf0,0xf8,0x78,0x3c,0x1f,0x0f,0x03,0x00,  0x00,
  49. };
  50. void dis_z17x32 (unsigned char x, y, k)
  51. {
  52.         unsigned char m=0;
  53.         unsigned int adder=68*k;
  54.         OLED_Set_Pos(x , y);
  55.         for(m = 0;m < 17;m++)                //字模17列32行
  56.         {
  57.                 OLED_WrDat(z17X32[adder]);
  58.                 adder += 1;
  59.         }
  60.         OLED_Set_Pos(x,y + 1);
  61.         for(m = 0;m < 17;m++)                //字模17列32行
  62.         {
  63.                 OLED_WrDat(z17X32[adder]);
  64.                 adder += 1;
  65.         }
  66.         OLED_Set_Pos(x,y + 2);
  67.         for(m = 0;m < 17;m++)                //字模17列32行
  68.         {
  69.                 OLED_WrDat(z17X32[adder]);
  70.                 adder += 1;
  71.         }
  72.         OLED_Set_Pos(x,y + 3);
  73.         for(m = 0;m < 17;m++)                //字模17列32行
  74.         {
  75.                 OLED_WrDat(z17X32[adder]);
  76.                 adder += 1;
  77.         }
  78. }
收藏收藏7 分享淘帖 頂2 踩
ID:1064915 發(fā)表于 2023-10-18 08:22 | 只看該作者
128X32每屏可顯示8列共8個16×32點陣的漢字,用17×32點陣,每屏少1字
ID:707333 發(fā)表于 2023-10-18 17:47 | 只看該作者
可以用軟件轉的,字體就自由選擇了
ID:22439 發(fā)表于 2023-10-18 23:17 | 只看該作者
在取模軟件上看到做滿32點高的字體,橫向17點是比較美觀好看的,再說用的時候每個數字間再留幾個點間隔才美觀,轉速測量如果用滿6位數字,最大可以測量到每分鐘九十九萬轉了,沒有這么快的電機
ID:1057978 發(fā)表于 2023-10-19 08:15 | 只看該作者
六六六,取字模這個軟件我咋老覺得不好用
ID:1096562 發(fā)表于 2023-10-19 13:04 | 只看該作者
666,學習了,之后試試
主站蜘蛛池模板: 久久精品综合 | 国产在线中文字幕 | 91成人在线视频 | 久久久一区二区 | 日韩黄色免费视频 | 国产一级特黄aaa大片 | 91精品国产乱码久久久久久 | 亚洲怡春院 | 亚洲午夜一区 | 亚洲欧美视频在线 | 97视频免费 | 久久久精品 | 超碰精品在线 | 日韩在线视频一区 | 欧美日韩综合网 | 日韩黄色免费视频 | 久久亚洲免费视频 | 欧美日韩一二三区 | 亚洲毛片av | 青青草国产在线视频 | 国产日韩欧美日韩大片 | 一级黄色大片 | 欧美三级 欧美一级 | 91亚洲国产成人久久精品麻豆 | 一级片免费在线观看 | 日韩免费观看 | 日本一级做a爱片 | 午夜在线影院 | 成人91看片| 成人一级视频 | 视频一区在线观看 | 亚洲午夜久久 | 亚洲第一区在线观看 | 日日夜夜精品 | 一级特黄视频 | 国产三级成人 | 日韩欧美综合 | 黄色av毛片 | 亚洲精品在线看 | 五月六月丁香 | 成人免费视频观看视频 |
