查看: 1875|回復(fù): 1
51單片機(jī)AD四路采集串口顯示雙IIC及OLED顯示
ID:866576 發(fā)表于 2023-11-6 14:51 | 顯示全部樓層 |閱讀模式
為了讓后來者少走彎路,分享一個(gè)51單片機(jī)AD四路采集PCF8591實(shí)時(shí)采集的例程。雙IIC接口,還附上Proteus防真。
地址:AD四路采集串口顯示雙IIC
單片機(jī)源程序如下:
  1. #include "main.h"
  2. // 變量定義
  3. u32 V0=0,V1=0,V2=0,V3=0;
  4. u8 num;
  5. //******************************************************************/
  6. main()
  7. {
  8.         OLED_Init();
  9.         OLED_ColorTurn(0);     //0正常顯示,1 反色顯示
  10.   OLED_DisplayTurn(0);   //0正常顯示 1 屏幕翻轉(zhuǎn)顯示
  11.         OLED_DrawBMP(0,0,128,64,BMP1);
  12.
  13.         Uart_Init();
  14.         Timer0_Init();
  15.
  16.         delayms(500);
  17.   OLED_Clear();
  18.
  19.         OLED_ShowChinese(24,1,0,16);//祝
  20.         OLED_ShowChinese(40,1,1,16);//你
  21.         OLED_ShowChinese(56,1,2,16);//好
  22.         OLED_ShowChinese(72,1,3,16);//運(yùn)
  23.         OLED_ShowChinese(88,1,4,16);//!
  24.         delayms(500);
  25.          OLED_Clear();
  26.
  27.         OLED_ShowString(0,0,"CHANNEL1:",16);
  28.         OLED_ShowString(0,2,"CHANNEL2:",16);
  29.         OLED_ShowString(0,4,"CHANNEL3:",16);
  30.         OLED_ShowString(0,6,"CHANNEL4:",16);
  31.
  32.         while(1)
  33.         {
  34.              if(num==10)
  35.                          {
  36.                          V0=ADC(0x40);
  37.                              delayms(10);
  38.                    V1=ADC(0x41);
  39.                        delayms(10);
  40.                          V2=ADC(0x42);
  41.                                    delayms(10);
  42.                          V3=ADC(0x43);
  43.                              delayms(10);
  44.                          DAC(V1);
  45.                              delayms(10);
  46.
  47.                                   UartPrintASCII(V0);
  48.                         delayms(2);
  49.           UartPrintASCII(V1);
  50.             delayms(2);
  51.                 UartPrintASCII(V2);
  52.                    delayms(2);
  53.                 UartPrintASCII(V3);
  54.                                   UartPrintf("OK !");
  55.
  56.                    V0=V0*50000/255;
  57.                          V1=V1*50000/255;
  58.                          V2=V2*50000/255;
  59.                          V3=V3*50000/255;
  60.
  61.                                 num=0;
  62.
  63.                                                   OLED_ShowNum(80,0,V1/10000,1,16);
  64.                                                         OLED_ShowString(88,0,".",16);
  65.                                                         OLED_ShowNum(96,0,V1%10000,4,16);
  66.
  67.                                                   OLED_ShowNum(80,2,V2/10000,1,16);
  68.                                                         OLED_ShowString(88,2,".",16);
  69.                                                         OLED_ShowNum(96,2,V2%10000,4,16);
  70.
  71.                                                   OLED_ShowNum(80,4,V3/10000,1,16);
  72.                                                         OLED_ShowString(88,4,".",16);
  73.                                                         OLED_ShowNum(96,4,V3%10000,4,16);
  74.
  75.                                                   OLED_ShowNum(80,6,V0/10000,1,16);
  76.                                                         OLED_ShowString(88,6,".",16);
  77.                                                         OLED_ShowNum(96,6,V0%10000,4,16);
  78.
  79.                          }
  80.
  81.    }
  82. }
  83. //*******************************************************************
  84. void Timer0_Isr() interrupt 1
  85. {
  86.         TF0 = 0;                      /*清除中斷標(biāo)志*/
  87.   TR0 = 0;                      /*關(guān)中斷*/
  88.
  89.         num++;
  90.
  91.   TL0 = 0x00;                                //設(shè)置定時(shí)初始值
  92.         TH0 = 0x4C;                                //設(shè)置定時(shí)初始值
  93.   TR0 = 1;                      /*開中斷*/
  94. }
  95. //*******************************************************************
  1. #include "ADC.h"
  2. //*****串口初始化函數(shù)***********
  4. void Uart_Init(void)
  5. {
  6.         REN  = 1;       //允許串行口接收數(shù)據(jù)
  7.         PCON &= 0x7F;                //波特率不倍速
  8.         SCON = 0x50;                //8位數(shù)據(jù),可變波特率
  9.         AUXR &= 0xBF;                //定時(shí)器時(shí)鐘12T模式
  10.         AUXR &= 0xFE;                //串口1選擇定時(shí)器1為波特率發(fā)生器
  11.         TMOD &= 0x0F;                //設(shè)置定時(shí)器模式
  12.         TMOD |= 0x20;                //設(shè)置定時(shí)器模式
  13.         TL1 = 0xFD;                        //設(shè)置定時(shí)初始值
  14.         TH1 = 0xFD;                        //設(shè)置定時(shí)重載值
  15.         EA   = 1;       //打開全局中斷控制
  16.         ES   = 0;       //打開串行口中斷
  17.         ET1 = 0;                          //禁止定時(shí)器中斷
  18.         TR1 = 1;                          //定時(shí)器1開始計(jì)時(shí)
  19. }
  20. void UartPrintASCII(u8 dat)                                //發(fā)送一個(gè)字符
  21. {
  22.           TI=0;
  23.     SBUF=dat;
  24.     while(TI==0);
  25.     TI=0;
  26. }
  27. void UartPrintf(u8 *p)                                //發(fā)送字符串
  28. {
  29.          while(*p)
  30.          {
  31.                  SBUF=*(p++);
  32.                 while(TI==0)
  33.                         {
  34.                   };
  35.                 TI=0;
  36.   }
  37. }
  38. void Timer0_Init(void)                //50毫秒@11.0592MHz
  39. {
  40.         EA=1;
  41.         ET0 = 1;        /*允許定時(shí)中斷*/
  42.         TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
  43.         TMOD |= 0x01;                //設(shè)置定時(shí)器模式
  44.         TL0 = 0x00;                                //設(shè)置定時(shí)初始值
  45.         TH0 = 0x4C;                                //設(shè)置定時(shí)初始值
  46.         TR0 = 1;        /*啟動(dòng)定時(shí)中斷*/
  47. }
  48. /*******************************************************************
  49.                      起動(dòng)總線函數(shù)
  50. 函數(shù)原型: void  IIcStart();
  51. 功能:     啟動(dòng)I2C總線,即發(fā)送I2C起始條件.
  52. ********************************************************************/
  53. void IIcStart()
  54. {
  55.   SCL=1;
  56.         SDA=1;         /*發(fā)送起始條件的數(shù)據(jù)信號(hào)*/
  57.       delay5us();
  58.   SDA=0;                     /*發(fā)送起始信號(hào)*/
  59.            delay5us();
  60. }
  61. /*******************************************************************
  62.                       結(jié)束總線函數(shù)
  63. 函數(shù)原型: void  IIcStop();
  64. 功能:     結(jié)束I2C總線,即發(fā)送I2C結(jié)束條件.
  65. ********************************************************************/
  66. void IIcStop()
  67. {
  68.         SCL=1 ;
  69.   SDA=0;      /*發(fā)送結(jié)束條件的數(shù)據(jù)信號(hào)*/
  70.            delay5us();
  71.   SDA=1;      /*發(fā)送I2C總線結(jié)束信號(hào)*/
  72.            delay5us();
  73. }
  74. /********************************************************************
  75.                    發(fā)送應(yīng)答
  76. 函數(shù)原型:  IIc_ACK(bit a);
  77. 功能:      主控器進(jìn)行應(yīng)答信號(hào)(注意:0表示發(fā)送應(yīng)答,1表示發(fā)送非應(yīng)答)
  78. ********************************************************************/
  79. void IIc_Ack(bit ack)
  80. {
  81.     SCL=1;
  82.         delay5us();
  83.     SDA=ack;                           /*清時(shí)鐘線,鉗住I2C總線以便繼續(xù)接收*/
  84.                             delay5us();
  85.           SCL=0;
  86. }
  87. /********************************************************************
  88.                    等待應(yīng)答
  89. 函數(shù)原型:  IIc_WaitACK(void);
  90. 功能:      主控器進(jìn)行應(yīng)答信號(hào)(0是就幫答)
  91. ********************************************************************/
  92. bit IIc_WaitAck(void)
  93. {
  94.           SCL=0;
  95.               delay5us();
  96.           SCL=1;
  97.               delay5us();
  98.     if(SDA==1)
  99.                 {
  100.                 SCL=0;
  101.                 return 0;
  102.           }
  103.           else
  104.                 {
  105.                  SCL=0;
  106.                  return 1;
  107.                 }
  108. }
  109. /*******************************************************************
  110.                  字節(jié)數(shù)據(jù)發(fā)送函數(shù)
  111. 函數(shù)原型: void  SendByte(UCHAR c);
  112. 功能:     將數(shù)據(jù)c發(fā)送出去,可以是地址,也可以是數(shù)據(jù),發(fā)完后等待應(yīng)答,并對(duì)
  113.           此狀態(tài)位進(jìn)行操作.(不應(yīng)答或非應(yīng)答都使ack=0)
  114.            發(fā)送數(shù)據(jù)正常,ack=1; ack=0表示被控器無應(yīng)答或損壞。
  115. ********************************************************************/
  116. void SendByte(unsigned char date)
  117. {
  118.     unsigned char temp,i;                   //用于探測(cè)字節(jié)內(nèi)某一位值的掩碼變量
  119.             temp=date;
  120.     for (i=0; i<8; i++)           //從高位到低位依次進(jìn)行
  121.     {
  122.                           temp=temp<<1;
  123.                           SCL=0 ;
  124.                              delay5us();
  125.                                 SDA = CY;
  126.            delay5us();
  127.         SCL = 1;              //拉高SCL
  128.           delay5us();
  129.     }
  130.                 SCL = 0;
  131.     SDA = 1;                 //8位數(shù)據(jù)發(fā)送完后,主機(jī)釋放SDA,以檢測(cè)從機(jī)應(yīng)答
  132. }
  133. /*******************************************************************
  134.                  字節(jié)數(shù)據(jù)接收函數(shù)
  135. 函數(shù)原型: UCHAR  RcvByte();
  136. 功能:        用來接收從器件傳來的數(shù)據(jù),并判斷總線錯(cuò)誤(不發(fā)應(yīng)答信號(hào)),
  137.           發(fā)完后請(qǐng)用應(yīng)答函數(shù)應(yīng)答從機(jī)。
  138. ********************************************************************/
  139. unsigned char RcvByte(void)
  140. {
  141.     unsigned char  i,j,k;
  142.            SCL=0;
  143.                   delay5us();
  144.   for(i=0;i<8;i++)
  145.       {
  146.         SCL=1;
  147.                                     delay5us();
  148.          j=SDA;
  149.                                  k=(k<<1)|j;
  150.                                  SCL=0;
  151.                                     delay5us();
  152.       }
  153.                         return k;
  154. }
  155. /*******************************************************************
  156. D/A 變換, 轉(zhuǎn)化函數(shù)
  157. *******************************************************************/
  158. void DAC(unsigned char dat)
  159. {
  160.    IIcStart();              //啟動(dòng)總線
  161.    SendByte(0x90);            //發(fā)送器件地址0x90是寫,0x91是讀
  162.     IIc_WaitAck();
  163.    SendByte(0x41);                //發(fā)送控制字節(jié)//允許DA輸出
  164.           IIc_WaitAck();
  165.    SendByte(dat);            //發(fā)送DAC的數(shù)值
  166.     IIc_WaitAck();
  167.    IIcStop();               //結(jié)束總線
  168. }
  169. /*******************************************************************
  170. ADC讀字節(jié)數(shù)據(jù)函數(shù)
  171. *******************************************************************/
  172. unsigned char ADC(unsigned char addr)
  173. {
  174.          unsigned char temp;
  175.    IIcStart();          //啟動(dòng)總線
  176.    SendByte(0x90);      //發(fā)送器件地址0x90是寫,0x91是讀
  177.     IIc_WaitAck();
  178.          SendByte(addr);                //控制字節(jié):選擇光敏電阻(0x41)還是滑動(dòng)變阻器(0x43
  179.     IIc_WaitAck();
  180.    IIcStart();
  181.    SendByte(0x91);
  182.           IIc_WaitAck();
  183.          temp=RcvByte();
  184.           IIc_Ack(1);            //0表示發(fā)送應(yīng)答,1表示發(fā)送非應(yīng)答
  185.          IIcStop();
  186.          return temp;
  187. }
Proteus8.15版本的仿真: Proteus8.15版本的仿真.7z (133.22 KB, 下載次數(shù): 50)
評(píng)分
查看全部評(píng)分
ID:1098747 發(fā)表于 2023-11-8 17:05 | 顯示全部樓層
你好,請(qǐng)問是采了四路的電壓值嗎
主站蜘蛛池模板: 美女福利视频 | 久久精品久久久 | 麻豆精品一区 | 精品免费国产 | 日韩欧美精品一区 | 久操视频在线观看 | 91在线播放视频 | 午夜在线视频观看 | 黄色大片免费在线观看 | 91久久久久久久 | 欧美一级艳片视频免费观看 | 亚洲一区二区三区在线 | 亚洲精品美女 | 久久国产亚洲 | 神马午夜我不卡 | 97视频在线免费观看 | 国产精品五区 | 看一级黄色片 | www.久久久久 | 亚洲影音 | 久草综合在线 | 久视频在线 | 日韩视频在线播放 | 亚洲三级小说 | av福利网站| 97自拍视频| 国产日韩欧美在线观看 | 亚洲国产91 | 欧美激情视频一区二区三区 | 精品久久一区二区 | 国产三级在线 | 午夜精品视频在线 | 国产精品一区在线 | av一级在线 | 高清乱码男女免费观看 | 久久久久国产 | 视频一二区 | 天天狠狠| 天天做夜夜爽 | 丨国产丨调教丨91丨 | 久久精品国产视频 |
