查看: 1904|回復: 2
基于單片機自動售貨機仿真及源程序
ID:190577 發表于 2023-11-15 20:32 | 顯示全部樓層 |閱讀模式
一、系統方案
1、本設計采用51單片機作為主控器。
2、商品選擇,購買數量選擇,投幣,液晶1602顯示。
3、電機模擬出貨。
二、硬件設計
原理圖如下:
三、單片機軟件設計
1、首先是系統初始化
void lcd_1602_init()               //LCD1602初始化函數
lcd_en=0;
lcd_1602_write_com(0x38);
lcd_1602_write_com(0x0e);
lcd_1602_write_com(0x06);
lcd_1602_write_com(0x01);
2、液晶顯示程序
void lcd_1602_write_com(uchar com)   //寫命令
rs=0;
rw=0;
P2=com;
lcd_1602_delay(5);
lcd_en=1;
lcd_1602_delay(5);
lcd_en=0;
void lcd_1602_write_data(uchar date) //寫數據
rs=1;
rw=0;
P2=date;
lcd_1602_delay(5);
lcd_en=1;
lcd_1602_delay(5);
lcd_en=0;
3、按鍵程序
unsigned char key(void)       //按鍵響應函數
unsigned char key,key1,key2;
P1=0XF0;
if((P1&0XF0)!=0XF0)           //ked down
       delay1(10);                         //延時去抖動
       if((P1&0XF0)!=0XF0)                  //仍然有鍵按下
        key1=P1&0XF0;                          //讀入列線值
        P1=0X0F;
        key2=P1&0X0F;
        key=key1|key2;
switch(key)                  //按鍵映射
case 0xee: e=0x00;break;
case 0xde: e=0x01;break;
case 0xbe: e=0x02;break;
case 0x7e: e=0x03; break;
case 0xed: e=0x04;break;
case 0xdd: e=0x05;break;
case 0xbd: e=0x06;break;
case 0x7d: e=0x07; break;
case 0xeb: e=0x08;break;
case 0xdb: e=0x09;break;
case 0xbb: e=0x0a;break;
case 0x7b: e=0x0b; break;
case 0xe7: e=0x0c;break;
case 0xd7: e=0x0d;break;
case 0xb7: e=0x0e;break;
case 0x77: e=0x0f; break;
while((P1&0X0F)!=0X0F);
delay1(10);
return 1;
return 0;
4、核心算法程序
/*****************main********************************/
unsigned char ok = 0, water_type = -1,  water_is_choose = 0;
char water_count = 0;
unsigned int flag = 0, money = 0, need_money;
lcd_1602_init();
again:
ok = 0; water_type = -1; water_count = 0; water_is_choose = 0;
flag = 0; money = 0; need_money = 0;
lcd1602_info_display(WAIT_SALE, 0, 0);
while(!ok)        //choose the water and count
  flag=key();
  if(flag)
    switch(e)         //不同的按鍵進行不同的操作
        case(0x00):
        water_type++;
        water_is_choose = 1;
        if(water_type == 8)
             water_type = 0;
P0 = water_change(0xff, water_type);
break;
case(0x01):
water_type--;
if(water_type == -1 || water_type == -2)
  water_type = 7;
break;
case(0x02):
if(water_is_choose == 1)
     water_count++;
     if(water_count > water_total[water_type])
       water_count = water_total[water_type];
break;
case(0x03):
  water_count--;
  if(water_count < 0)
      water_count = 0;
break;
case(0x0e):        //  返回
goto again;
break;
case(0x0f):         //   確認
      ok=1;
        break;
   default:
   break;
lcd_1602_saling(water_type, water_count);
//choose ok: calculate the money        //計算錢的總數
need_money = water_count * water_price[water_type];
lcd_1602_inputing(need_money, money);
ok = 0;
while(!ok)                //get money
                flag=key();
                if(flag)
                        switch(e)
                                case(0x04):
                                        money=money+1;
                                        break;
                                case(0x05):
                                        money=money+5;
                                        break;
                                case(0x06):
                                        money=money+10;
                                        break;
                                case(0x07):
                                        money=money+20;
                                        break;
                                case(0x08):
                                        money=money+50;
                                        break;
                                case(0x09):
                                        money=money+100;
                                        break;
                                case(0x0e):        //back
        lcd1602_info_display(CHANGE, money, CANCLE);
        P0 = 0xff;
        delay1(10000);
   goto again;
   break;
   default:
   break;
//show money
lcd_1602_inputing(need_money, money);    //投幣系統
if(money>0)
{if(money >= need_money)
                                P3=0x7f;
                                ok=0;                        //break and show back money
                                //show back money
                                lcd1602_info_display(CHANGE, money-need_money, NO_DATA);
                        //        out_water();
                                delay1(10000);
                                P0 = 0xff;
                                P3=0xff;
                                goto again;
四、 proteus仿真設計
Proteus軟件是一款應用比較廣泛的工具,它可以在沒有硬件平臺的基礎上通過自身的軟件仿真出硬件平臺的運行情況,這樣就可以通過軟件仿真來驗證我們設計的方案有沒有問題,如果有問題,可以重新選擇器件,連接器件,直到達到我們設定的目的,避免我們搭建實物的時候,如果當初選擇的方案有問題,我們器件都已經焊接好了,再去卸載下去,再去焊接新的方案的器件,測試,這樣會浪費人力和物力,也給開發者帶來一定困惑,Proteus仿真軟件就很好的解決這個問題,我們在設計之初,就使用該軟件進行模擬仿真,測試,選擇滿足我們設計的最優方案。最后根據測試沒問題的仿真圖紙,焊接實物,調試,最終完成本設計的作品。
ID:884711 發表于 2024-5-6 21:38 | 顯示全部樓層
路過學習,謝謝分享!
ID:961114 發表于 2024-5-7 15:52 | 顯示全部樓層
入門51,還的是 自帶硬件USB直接仿真,自帶硬件USB直接下載的 RMB1.4的 STC8H8K64U
主站蜘蛛池模板: 国产一区一区 | 国产精品久久久一区二区三区 | 成人午夜网 | 欧美在线一级 | 日本黄a三级三级三级 | 99中文字幕| 久久r| 天天综合av | 午夜精品视频在线观看 | 国产乱码精品一品二品 | 国产九九精品 | 午夜视频一区二区 | 美女福利网站 | 91久久国产综合久久91精品网站 | 波多野结衣乳巨码无在线观看 | 国产做爰视频免费播放 | 免费的毛片| 中文字幕国产精品 | 青青草福利视频 | a级片免费在线观看 | 国产精品一区三区 | 日韩三级一区 | 黄色小视频免费看 | 丁香六月综合 | 国产一区二区视频在线 | 天天碰天天操 | 色综合天天综合网天天狠天天 | 欧美在线播放视频 | 国产一区二区在线观看视频 | 可以免费看的av | 日韩精品一区在线观看 | 一区二区国产视频 | av资源站 | 欧美一级黄色录像 | 婷婷久久久 | 日韩精品视频一区二区三区 | 免费国产网站 | 黄色影院在线观看 | www4hutv| 日日夜夜精品免费 | 手机看片福利永久 |
