查看: 1933|回復: 7
LCD1602顯示,在實驗室使用單片機板成功 在仿真上無法顯示
這個需要到LCD顯示,但是我在單片機板上顯示成功,但是在仿真上無法顯示,電路連接應該沒有錯
#include <reg52.h>
#define uchar  unsigned   char
#define uint  unsigned         int
#define out P2
sbit LED =P1^4;
sbit key1=P3^2;
sbit key2=P3^3;
sbit key3=P3^4;
sbit key4=P3^5;
sbit lcdrs=P0^5;
sbit lcdrw=P0^6;
sbit lcden=P0^7;
void check_busy();
void write_cmd(uchar cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void T0_init();//T0初始化
void display(uchar date);
void keyscan();
void delay(uint z);
uchar sec=0,count=0,flag=0,keyflag=0;
{  T0_init();
  lcd_init();
   write_cmd(0x82);
   write_str("sec:");
  {         keyscan();
  switch(keyflag)
  {  case 1:TR0=1;LED=0;break;
     case 2:TR0=0;LED=1;break;
    display(sec);
void T0_init()
{          TMOD=0X01;
          TH0=(65536-50000)/256;
          TL0=(65536-50000)%256;
          ET0=1;
          EA=1;
void lcd_init()
{ write_cmd(0x38);
   write_cmd(0x0c);
   write_cmd(0x06);
   write_cmd(0x01);
   delay(1);
{          check_busy();
          lcdrs=0;
          lcdrw=0;
          lcden=0;
          out=cmd;
          lcden=1;
          delay(1);
          lcden=0;
          delay(1);
void check_busy()
{  uchar dt;
   do
   {dt=0xff;
    lcdrs=0;
        lcdrw=1;
        lcden=0;
        lcden=1;
        dt=out;
   }while(dt&0x80);
   lcden=0;
{         lcdrs=1;
         lcdrw=0;
         lcden=0;
         out=dat;
         lcden=1;
         delay(1);
         lcden=0;
         delay(1);
void delay(uint z)
{ uint i,j;
  for(j=z;j>0;j--)
   for(i=110;i>0;i--);
{  while(*str!='\0')
           write_data(*str++);
           delay(5);
void T0_it()interrupt 1
         count++;
         if(count>=20)
         {   count=0;
             sec++;
         if(sec>=60)
         {sec=0;flag=1;  }
{        write_cmd(0x88);
    write_data(date/10+0x30);
        write_cmd(0x89);
        write_data(date%10+0x30);
void keyscan()
{         key1=1;
    if(key1==0)
        {        delay(10);
           if(key1==0)
           {   while(!key1);
               keyflag=1;
        key2=1;
    if(key2==0)
        {        delay(10);
           if(key2==0)
           {   while(!key2);
               keyflag=2;
        if(key3==0)
        {sec++;
         if(sec==60)sec=60;}
        if(key4==0)
        {sec--;
         if(sec<=0)sec=0;}
屏幕截圖 2023-11-17 075529.png (46.4 KB, 下載次數: 73)
ID:94031 發表于 2023-11-17 10:58 | 只看該作者
LCD有多種驅動,實體顯示成功仿真不成功很正常。
ID:180919 發表于 2023-11-17 12:04 | 只看該作者
仿真正在的,檢查下1602的連線
ID:180919 發表于 2023-11-17 13:39 | 只看該作者
仿真電路MCU的P2口與P1口的網絡重復了
ID:213173 發表于 2023-11-17 15:06 | 只看該作者
除了地板指出的P2口與P1口的網絡重復了,另外P0.5、P0.6、P0.7還要外接上拉電阻。
ID:1096616 發表于 2023-11-17 22:30 | 只看該作者
wulin 發表于 2023-11-17 15:06
哦,原來問題出現在這里,我明白了,不過為什么一定要外接電阻lcd才可以正常顯示呢?
ID:213173 發表于 2023-11-18 06:55 | 只看該作者
深層次 發表于 2023-11-17 22:30
仿真用的AT89C52的P0與其它端口不同,是開漏模式,內部沒有上拉電阻。外部器件如不能提供高電平條件就得外加上拉電阻。
ID:1099277 發表于 2023-11-18 19:11 | 只看該作者
需要加上拉電阻才能驅動lcd顯示
主站蜘蛛池模板: 欧美理论片在线观看 | 奇米影视888 | 成年人免费看片 | 欧美亚洲| 欧美激情视频一区二区 | 国产福利91| 久久久久久网 | 爱搞逼综合网 | 一级大片免费看 | 日韩a在线 | 亚洲在线中文字幕 | 人人草人人爱 | 欧美精品网站 | 亚洲成a人片 | 91性高潮久久久久久久久 | 久久久一区二区三区 | 亚洲精品黄色 | 欧美人与性动交α欧美精品 | 东北少妇bbbb搡bbb搡 | 亚洲成人免费视频 | 这里只有精品视频在线观看 | 精品国产999久久久免费 | 黄色一级免费看 | 怡红院在线播放 | 国产精品久久久久久久久久久久午夜片 | 日韩av在线免费观看 | 中文字幕高清在线 | 91亚洲精品在线 | 国产成人免费在线视频 | 开心激情站| 国产精品尤物 | 91av在线播放 | 日韩欧美一区二区在线 | 欧美一区二区在线观看 | 国产一级片免费观看 | 成人黄色av| 午夜在线免费观看 | 国产精品视频免费看 | 国产一区高清 | 国产日韩视频 | 在线播放黄色 |
