//99分倒計時
#include"stc8H.h"
#include "intrins.h"
#include "daojishi.h"
#include "GPIO_init.h"
#define uint unsigned int
#define uchar unsigned char
#define ET3 0x20
#define ET4 0x40
#define T3IF 0x02
#define T4IF 0x04
sbit jiare_ge = P0^2;
sbit jiare_shi = P0^3;
sbit lenque_ge = P1^0;
sbit lenque_shi = P1^1;
sbit sajun_ge = P1^2;
sbit sajun_shi = P1^3;
//sbit LIGHT_JDQ = P3^7;
uchar count;
char sec,min;
bit flag,flag1,flag2,flag3;
uchar code table[]={
0x03,/*0*/
0x9F,/*1*/
0x25,/*2*/
0x0D,/*3*/
0x99,/*4*/
0x49,/*5*/
0x41,/*6*/
0x1F,/*7*/
0x01,/*8*/
0x09,/*9*/};
//sbit a = P2^7;
//sbit b = P2^6;
//sbit c = P2^5;
//sbit d = P2^4;
//sbit e = P2^3;
//sbit f = P2^2;
//sbit g = P2^1;
//sbit h = P2^0;
//sbit LED_com = P3^1;
void T0_init() //5毫秒@11.0592MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0x00; //設(shè)置定時初始值
TH0 = 0xEE; //設(shè)置定時初始值
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時器0開始計時
ET0 = 1; //使能定時器0中斷
void T1_init() //5毫秒@11.0592MHz
AUXR &= 0xBF; //定時器時鐘12T模式
TMOD &= 0x0F; //設(shè)置定時器模式
TL1 = 0x00; //設(shè)置定時初始值
TH1 = 0xEE; //設(shè)置定時初始值
TF1 = 0; //清除TF0標(biāo)志
TR1 = 1; //定時器0開始計時
ET1 = 1; //使能定時器0中斷
void T3_init() //5毫秒@11.0592MHz
T4T3M &= 0xFD; //定時器時鐘12T模式
T3L = 0x00; //65536-11.0592M/12/1000
T3H = 0xEE;
IE2 = ET3; //使能定時器中斷
T4T3M |= 0x08; //定時器3開始計時
void T4_init() //5毫秒@11.0592MHz
T4T3M &= 0xDF; //定時器時鐘12T模式
T4L = 0x00; //65536-11.0592M/12/1000
T4H = 0xEE;
T4T3M = 0x80; //啟動定時器
IE2 = ET4; //使能定時器中斷
void jiare_display()
static bit i=0;
static uchar temp=0;
P2=0xff;
i=~i;
if(++temp>=200)temp=0;
if(i==1)
jiare_ge = 0;
jiare_shi = 1;
P2=table[min/10];
jiare_ge = 1;
jiare_shi = 0;
if(temp<100)
P2=table[min%10]&0xfe;//閃秒
else P2=table[min%10];
void lenque_display()
static bit i=0;
P2=0xff;
i=~i;
if(i==1)
lenque_ge = 0;
lenque_shi = 1;
P2=table[min/10];
lenque_ge = 1;
lenque_shi = 0;
if(temp<100)
void sajun_display()
static bit i=0;
P2=0xff;
i=~i;
if(i==1)
sajun_ge = 0;
sajun_shi = 1;
P2=table[min/10];
sajun_ge = 1;
sajun_shi = 0;
if(temp<100)
void jiare_daojishi()
T0_init();
if(flag)
flag=0;
if(++count >= 200)
count = 0;
sec--;
if(sec < 0)
sec = 59;
min--;
if(min < 0)
min=99;
jiare_display();
void lenque_daojishi()
T1_init() ;
if(flag1)
flag1=0;
if(++count >= 200)
count = 0;
sec--;
if(sec < 0)
sec = 59;
min--;
if(min < 0)
min=99;
lenque_display();
void sajun_daojishi()
T3_init();
if(flag2)
flag2=0;
if(++count >= 200)
count = 0;
sec--;
if(sec < 0)
sec = 59;
min--;
if(min < 0)
min=99;
sajun_display();
void daojishi()
GPIO_init();
EA = 1;
T4_init();
while (1)
jiare_daojishi();
lenque_daojishi();
sajun_daojishi();
void TM0_Isr() interrupt 1 //5毫秒定時器0
flag=1;
void TM1_Isr() interrupt 3 //5毫秒定時器1
flag1=1;
void TM3_Isr() interrupt 19 //5毫秒定時器3
flag2=1;
void TM4_Isr() interrupt 20 //定時器4
TL1 = 0x00; //設(shè)置定時初始值5ms
flag3=1; //測試端口
