查看: 1123|回復: 1
單片機循跡小車程序
ID:1100946 發表于 2023-11-23 20:21 | 顯示全部樓層 |閱讀模式
#include
#define uchar unsigned char
#define uint unsigned int
uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
void delay_1ms(uint d)
        uint i;
        while(d--)
                for(i=0;i<75;i++);
void motor_run()                   //電機起動
          P1=0x35;
        delay_1ms(200);
        P1=0x53;
        delay_1ms(10);
/*        ENA=1;
        OUT1=0;
        OUT2=1;
        delay_1ms(800);
        OUT2=0;
        delay_1ms(200);
        ENB=1;
        OUT4=0;
        OUT3=1;
        delay_1ms(800);
        OUT3=0;
        delay_1ms(200);
void motor_left()                         //左進
        P1=0x30;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_right()                   //右進
        P1=0x05;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_right()                         //粗右進
        P1=0x55;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_big_left()
        P1=0x33;
        delay_1ms(200);
        P1=0x00;
        delay_1ms(20);
void motor_stop()                                        //電機停止
         P1=0x00;
void motor_back()
        P1=0x53;
        t0=0;
        t1=0;
        t2=0;
        t3=0;
        t4=0;
        t5=0;
        t6=0;
        tt1=0;
        EA=1;
        ET1=1;
        TR1=1;
        TMOD=0x01;
        TH1=-(1000/256);
        TL1=-(1000%256);
                 temp=P2;
                signal=temp&0xff;                   //得到紅外反向信號
                switch(signal)
                        case 0xff:           //無偏差
                                motor_run();
                                t0++;
                                if(t0==10)
                                        t0=0;
                                        motor_left();
                                        motor_right();
                                t1=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xfd:           //1輪右偏
                                motor_big_left();
                                t1++;
                                if(t1==4)
                                        t1=0;
                                        motor_left();
                                t0=t2=t3=t4=t5=t6=0;
                                break;
                        case 0xef:            //4輪左偏
                                motor_big_right();
                                t2++;
                                if(t2==4)
                                        t2=0;
                                        motor_right();
                                t0=t1=t3=t4=t5=t6=0;
                                break;
                        case 0xfb:     //2輪右偏出軌
                        case 0xf9:           //1、2輪右偏
                                motor_big_left();
                                t3++;
                                if(t3==4)
                                        t3=0;
                                        motor_left();
                                t0=t1=t2=t4=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xdf:           //5左偏出軌
                        case 0xcf:      //4、5輪左偏
                                motor_big_right();
                                t4++;
                                if(t4==4)
                                       t4=0;
                                        motor_right();
                                t0=t1=t2=t3=t5=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xfe:           //0最右偏出軌
                        case 0xfa:
                                motor_big_left();
                                t5++;
                                if(t5==1)
                                        t5=0;
                                        motor_left();
                                        motor_left();
                                t0=t1=t2=t3=t4=t6=0;
//                                delay_1ms(10);
                                break;
                        case 0xbf:     //6最左偏出軌
                        case 0x9f:
                                motor_big_right();
                                t6++;
                                if(t6==1)
                                        t6=0;
                                        motor_right();
                                        motor_right();
                                t0=t1=t2=t3=t4=t5=0;
//                                delay_1ms(10);
                                break;
                        case 0xeb:         //前兩傳感器壓在黑線上
                        case 0xdb:         //后兩傳感器壓在黑線上
                        case 0xbe:         //中間兩傳感器壓在黑線上
                        case 0xac:                 //前四傳感器壓在黑線上
                        case 0x9a:                //后四傳感器壓在黑線上
                                motor_back();
                                delay_1ms(200);
                                motor_stop();
//                                delay_1ms(1000);
                        default:
//                                motor_back();
//                                delay_1ms(50);
//                                motor_left();
//                                motor_right();
                                break;
/*void time1() interrupt 3
        TH1=-(1000/256);
        TL1=-(1000%256);
        tt1++;
        if(tt1==300)
                motor_back();
        //        delay_1ms(1);
                tt1=0;
ID:1104107 發表于 2023-12-13 14:41 | 顯示全部樓層
有沒有實物連線圖
主站蜘蛛池模板: 四虎海外| 一级真人毛片 | 免费成人小视频 | 亚洲国产免费 | 亚洲在线中文字幕 | 毛片在线观看视频 | 国产黄视频在线观看 | 九九热在线观看 | 亚洲一区免费 | 久久一区二区三区四区 | 午夜精品福利视频 | 中文字幕亚洲欧美 | 亚洲精品一区二区在线观看 | 一级黄色片免费 | 欧美日韩在线看 | 亚洲国产精品久久久久久 | 99久久精品一区二区成人 | 久草青青草 | 一级特黄色片 | 丁香婷婷激情 | 欧美激情视频网站 | 超碰97在线播放 | 香蕉网在线 | 日日夜夜精品免费 | 黄色日批视频 | 9.1成人免费看片 | 麻豆av在线 | 日b免费视频 | 99久久精品国产毛片 | 国产午夜视频 | 久热99 | 欧美日在线| 三级中文字幕 | 成年人网站在线免费观看 | 日韩精品在线免费观看 | 人人看av | 五月婷婷色综合 | 成人午夜av| 青青草精品视频 | 久久99精品久久久久久琪琪 | 国产三级午夜理伦三级 |
