這是時(shí)間和溫度輪流顯示的程序- /*
- 項(xiàng)目名稱:0.8寸4位共陽數(shù)碼管時(shí)鐘
- 1.5個(gè)PNP三極管接在共陽極驅(qū)動(dòng)數(shù)碼管,這個(gè)數(shù)碼管小數(shù)點(diǎn)都有,冒號(hào)是單獨(dú)兩個(gè)LED
- 2.設(shè)置方法:按k1鍵設(shè)置狀態(tài)(小時(shí)位數(shù)碼管閃爍),按K2鍵++,按K3鍵--,長(zhǎng)按連加連減;
- 按K1鍵第二次,分鐘位數(shù)碼管閃爍,按K2鍵++,按K3鍵--,長(zhǎng)按連加連減;
- 按K1鍵第三次,退出設(shè)置狀態(tài),回到正常走時(shí)界面。
- 3. P2.0-P2.4位驅(qū)動(dòng)口,P1口為段驅(qū)動(dòng)口;
- 4. 單片機(jī)=STC8H1K16(LQFP32封裝) @11.0592MHz 時(shí)鐘芯片=DS3231MZ(SOP-8封裝)
- 測(cè)試通過
- 第一次發(fā)的程序按鍵長(zhǎng)按有bug,也改好了。
- #include <STC8H.H>
- #include <intrins.h>
- #include "ds18b20.h"
- //#include "delay.h"
- #define uchar unsigned char
- #define uint unsigned int
- //typedef unsigned char u8;
- //typedef unsigned int u16;
- //typedef unsigned long u32;
- sbit k1=P0^0;// 按鍵1 設(shè)置 +
- sbit k2=P2^7;// 按鍵2 -
- sbit k3=P3^7;//
- sbit k4=P2^5;
- sbit out = P3^2; //輸出端口
- sbit w1 = P2^0; //設(shè)置位驅(qū)動(dòng)口
- sbit w2 = P2^1;
- sbit w3 = P2^2;
- sbit w4 = P2^3;
- sbit w5 = P2^4; //冒號(hào)控制
- sbit BZ = P0^3;//蜂鳴器控制口
- uint count,cont1,cont2,cont3;
- uint fen,fen_temp;
- uchar fen_L,fen_M,miao,num,num2;
- uchar Ledcount;
- uchar num;
- uchar k1_lock,k2_lock,k3_lock;//按鍵鎖
- uchar knum;
- uint shan,shan1;//秒點(diǎn)閃爍 計(jì)時(shí)變量
- uint k1_time_count; //K1消抖計(jì)數(shù)
- uint k2_time_count; //K2消抖計(jì)數(shù)
- uint k3_time_count; //K3消抖計(jì)數(shù)
- bit flag; //計(jì)時(shí)啟動(dòng)標(biāo)志
- bit flag1; //按鍵消抖計(jì)數(shù)標(biāo)志
- bit flag2; //按鍵消抖計(jì)數(shù)標(biāo)志
- bit save_flag;//數(shù)據(jù)保存標(biāo)志
- bit save_flag1;//數(shù)據(jù)保存標(biāo)志
- bit set_flag=0; //設(shè)置標(biāo)志
- bit fm_flag;//蜂鳴器
- bit flag3;
- bit qh_flag,qh_flag1;
- uchar hour,minute,second,year,month,day,date,week;
- uint TH3231;
- bit ack; //應(yīng)答標(biāo)志位
- uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xC6,0xbf,0x8e};//共陽段碼 (0--9、黑屏,C,-,F)0X46 C帶點(diǎn),0xc6C不帶點(diǎn)
- uchar LedBuff[]={0xff,0xff,0xff,0xff};
- // IO口模擬I2C通信
- sbit SCL=P3^5; //串行時(shí)鐘
- sbit SDA=P3^4; //串行數(shù)據(jù)
- ** DS3231常數(shù)定義
- #define DS3231_WriteAddress 0xD0 //器件寫地址
- #define DS3231_ReadAddress 0xD1 //器件讀地址
- #define DS3231_SECOND 0x00 //秒
- #define DS3231_MINUTE 0x01 //分
- #define DS3231_HOUR 0x02 //時(shí)
- #define DS3231_WEEK 0x03 //星期
- #define DS3231_DAY 0x04 //日
- #define DS3231_MONTH 0x05 //月
- #define DS3231_YEAR 0x06 //年
- #define DS3231_TEMPERATUREH 0x11 //溫度寄存器高字節(jié)(8位) 整數(shù)部分
- #define DS3231_TEMPERATUREL 0x12 //溫度寄存器低字節(jié)(低2位) 小數(shù)部分
- #define NACK 1
- #define ACK 0
- //void Delay5US() //@12.000MHz 延時(shí)5us
- // _nop_(); _nop_(); _nop_();_nop_(); _nop_();_nop_();//STC Y6指令 1T單片機(jī)用6個(gè)nop,12T用1個(gè)nop
- void Delay5US() //@11.0592MHz STC Y6指令
- unsigned char i;
- _nop_();
- i = 16;
- while (--i);
- void delay(uint x)
- uint y,z;
- for(y=0; y<x; y--)
- for(z=0; z<1200; z--);
- //IIC Start
- void IIC_Start()
- SCL = 1;
- SDA = 1;
- SDA = 0;
- SCL = 0;
- //IIC Stop
- void IIC_Stop()
- SCL = 0;
- SDA = 0;
- SCL = 1;
- SDA = 1;
- ** 3231
- uchar BCD2HEX(uchar val)//轉(zhuǎn)10進(jìn)制
- return ((val>>4)*10)+(val&0x0f);
- uchar HEX2BCD(uchar val) //轉(zhuǎn)16進(jìn)制
- return (((val%100)/10)<<4)|(val%10);
- void SendByte(uchar c)
- uchar BitCnt;
- for(BitCnt=0;BitCnt<8;BitCnt++) //要傳送的數(shù)據(jù)長(zhǎng)度為8位
- if((c<<BitCnt)&0x80)
- SDA=1; //判斷發(fā)送位
- else
- SDA=0;
- SCL=1; //置時(shí)鐘線為高,通知被控器開始接收數(shù)據(jù)位
- Delay5US(); //保證時(shí)鐘高電平周期大于4μs
- SCL=0;
- SDA=1; //8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位
- SCL=1;
- Delay5US();
- if(SDA==1)
- ack=0;
- else
- ack=1; //判斷是否接收到應(yīng)答信號(hào)
- SCL=0;
- Delay5US();
- uchar RcvByte()
- uchar retc;
- uchar BitCnt;
- retc=0;
- SDA=1; //置數(shù)據(jù)線為輸入方式
- SCL=0; //置時(shí)鐘線為低,準(zhǔn)備接收數(shù)據(jù)位
- Delay5US(); //時(shí)鐘低電平周期大于4.7μs
- SCL=1; //置時(shí)鐘線為高使數(shù)據(jù)線上數(shù)據(jù)有效
- Delay5US();
- retc=retc<<1;
- if(SDA==1)
- retc=retc+1; //讀數(shù)據(jù)位,接收的數(shù)據(jù)位放入retc中
- Delay5US();
- SCL=0;
- return(retc);
- void Ack_I2C(bit a)
- SDA = a;
- SCL=1;
- Delay5US(); //時(shí)鐘低電平周期大于4us
- SCL=0; //清時(shí)鐘線,鉗住I2C總線以便繼續(xù)接收
- Delay5US();
- uchar write_byte(uchar addr, uchar write_data)
- IIC_Start();
- SendByte(DS3231_WriteAddress);
- if (ack == 0)
- return 0;
- SendByte(addr);
- if (ack == 0)
- return 0;
- SendByte(write_data);
- if (ack == 0)
- return 0;
- IIC_Stop();
- Delay5US();
- Delay5US();
- return 1;
- uchar read_current()
- uchar read_data;
- IIC_Start();
- SendByte(DS3231_ReadAddress);
- if(ack==0)
- return(0);
- read_data = RcvByte();
- Ack_I2C(1);
- IIC_Stop();
- return read_data;
- uchar read_random(uchar random_addr)
- uchar Tmp;
- IIC_Start();
- if(ack==0)
- return(0);
- SendByte(random_addr);
- if(ack==0)
- return(0);
- Tmp=read_current();
- if(random_addr==DS3231_HOUR)
- Tmp&=0x3f;
- return(BCD2HEX(Tmp));//都轉(zhuǎn)10進(jìn)制輸出
- uchar read_random1(uchar random_addr) //這個(gè)是讀溫度函數(shù)
- uchar Tmp;
- // write_byte(0x0e,0x20);//0x0e寄存器的CONV位置1開啟溫度轉(zhuǎn)換,要這句,溫度實(shí)時(shí)刷新,這句不要,溫度要64s才刷新1次
- //數(shù)碼管顯示不能要這句,否則溫度值小數(shù)部分亂跳
- IIC_Start();
- if(ack==0)
- return(0);
- if(ack==0)
- return(0);
- return Tmp;
- void ModifyTime(uchar address,uchar num)
- uchar temp=0;
- if(address>6 && address <0) return;
- temp=HEX2BCD(num);
- write_byte(address,temp);
- void IapIdle()
- IAP_CONTR = 0; //關(guān)閉IAP功能
- IAP_CMD = 0; //清除命令寄存器
- IAP_TRIG = 0; //清除觸發(fā)寄存器
- IAP_ADDRH = 0x80; //將地址設(shè)置到非IAP區(qū)域
- IAP_ADDRL = 0;
- char IapRead(int addr)
- char dat;
- IAP_CONTR = 0x80; //使能IAP
- IAP_TPS = 12; //設(shè)置等待參數(shù)12MHz
- IAP_CMD = 1; //設(shè)置IAP讀命令
- IAP_ADDRL = addr; //設(shè)置IAP低地址
- IAP_ADDRH = addr >> 8; //設(shè)置IAP高地址
- IAP_TRIG = 0x5a; //寫觸發(fā)命令(0x5a)
- IAP_TRIG = 0xa5; //寫觸發(fā)命令(0xa5)
- _nop_();
- dat = IAP_DATA; //讀IAP數(shù)據(jù)
- IapIdle(); //關(guān)閉IAP功能
- return dat;
- void IapProgram(int addr, char dat)
- IAP_CMD = 2; //設(shè)置IAP寫命令
- IAP_DATA = dat; //寫IAP數(shù)據(jù)
- _nop_();
- void IapErase(int addr)
- IAP_CMD = 3; //設(shè)置IAP擦除命令
- _nop_(); //
- void Timer0Init(void) //2毫秒@11.0592MHz
- AUXR |= 0x80; //定時(shí)器時(shí)鐘1T模式
- TMOD &= 0xF0; //設(shè)置定時(shí)器模式 16位自動(dòng)重載
- TL0 = 0x9A; //設(shè)置定時(shí)初始值
- TH0 = 0xA9; //設(shè)置定時(shí)初始值
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- EA = 1; //開總中斷
- ET0 = 1; //開T0中斷
- //void Timer0Init(void) //5毫秒@11.0592MHz
- // AUXR |= 0x80; //定時(shí)器時(shí)鐘1T模式
- // TMOD &= 0xF0; //設(shè)置定時(shí)器模式
- // TL0 = 0x00; //設(shè)置定時(shí)初始值
- // TH0 = 0x28; //設(shè)置定時(shí)初始值
- // TF0 = 0; //清除TF0標(biāo)志
- // TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- // EA = 1; //開總中斷
- // ET0 = 1; //開T0中斷
- void keyscan()
- uchar temp;
- hour = read_random(DS3231_HOUR);
- minute = read_random(DS3231_MINUTE) ;
- second = read_random(DS3231_SECOND);
- if(k1) //
- k1_time_count=0;
- k1_lock=0;
- flag1 = 0;
- else if((k1_lock==0))
- flag1 = 1; //按鍵按下 消抖計(jì)時(shí)標(biāo)志置1 開始消抖計(jì)時(shí)
- if((k1_time_count==10)) //20毫秒
- k1_time_count=0;
- k1_lock=1;
- knum++;
- if(knum==3)
- knum=0;
- second=0;
- write_byte(DS3231_SECOND, second); //秒寫0
- if(knum==1) //設(shè)置小時(shí)
- if(k2 ==1) //++
- k2_time_count=0;
- k2_lock=0;
- flag2 = 0;
- else if(k2_lock==0)
- // flag = 0;
- flag2 = 1;
- // save_flag = 1;
- if(k2_time_count==10) //短按
- k2_time_count=0;
- k2_lock=1;
- hour++;
- if(hour>23)
- hour=0;
- temp=HEX2BCD(hour);
- write_byte(DS3231_HOUR, temp);
- else if(k2_time_count>500) //長(zhǎng)按
- // cont1=0; num=0;
- k2_time_count=400;
- hour++;
- if(hour>23)
- hour=0;
- temp=HEX2BCD(hour); //10進(jìn)制轉(zhuǎn)16進(jìn)制
- if(k3 == 1) //--
- k3_time_count=0;
- k3_lock=0;
- flag3 = 0;
- else if(k3_lock==0)
- flag3 = 1;
- // save_flag1 = 1;
- if(k3_time_count==10) //短按
- k3_time_count=0;
- k3_lock=1;
- hour--;
- if(hour==255)
- hour=23;
- else if(k3_time_count>500) //長(zhǎng)按
- k3_time_count=400; //長(zhǎng)按200ms連減
- hour--;
- if(hour==255)
- hour=23;
- if(knum==2) //設(shè)置分鐘
- if(k2 ==1) //++
- k2_time_count=0;
- k2_lock=0;
- flag2 = 0;
- // flag = 0;
- flag2 = 1;
- // save_flag = 1;
- k2_time_count=0;
- k2_lock=1;
- minute++;
- if(minute>59)
- minute=0;
- temp=HEX2BCD(minute);
- write_byte(DS3231_MINUTE, temp);
- minute++;
- if(minute>59)
- minute=0;
- if(k3 == 1) //--
- k3_time_count=0;
- k3_lock=0;
- flag3 = 0;
- flag3 = 1;
- k3_time_count=0;
- k3_lock=1;
- minute--;
- if(minute==255)
- minute=59;
- minute--;
- if(minute==255)
- minute=59;
- void display_sf() //顯示 時(shí)分
- // year = read_random(DS3231_YEAR);
- // month = read_random(DS3231_MONTH);
- // day = read_random(DS3231_DAY);
- // week = read_random(DS3231_WEEK);
- if(knum==0)
- LedBuff[0]= table[hour/10];
- LedBuff[1]= table[hour%10];
- LedBuff[2]= table[minute/10];
- LedBuff[3]= table[minute%10];
- if(shan>250)
- {w5=1; }
- else {w5=0;}
- if(knum==1)
- if(shan1>125)
- else
- LedBuff[0]= table[10];
- LedBuff[1]= table[10];
- if(knum==2)
- if(shan1>125)
- else
- LedBuff[2]= table[10];
- LedBuff[3]= table[10];
- void ds18b20disp(uint Value)
- if(s==0) //顯示正溫度
- if((Value/1000)>0)//大于100度顯示最高位
- LedBuff[0]= table[Value/1000];
- else
- LedBuff[0]=table[10];//小于100度不顯示最高位
- }else {LedBuff[0]=s;}//顯示負(fù)號(hào)
- LedBuff[1]=table[Value%1000/100]; //十位
- LedBuff[2]=table[Value%100/10];//
- LedBuff[3]=table[11];
- void main()
- Timer0Init();
- P0M0 = 0x00; //
- P0M1 = 0x00; //
- P1M0 = 0x00; //
- P1M1 = 0x00;
- P2M0 = 0x1f; //p2.0-p2.4 設(shè)為推挽輸出
- P2M1 = 0x00;
- P3M0 = 0x04; //P3.2設(shè)為推挽輸出才能驅(qū)動(dòng)繼電器
- P3M1 = 0x00;
- P4M0 = 0x00;
- P4M1 = 0x00;
- P5M0 = 0x10;
- P5M1 = 0x00;
- // P2PU=0x10;
- // P2DR=0X00;
- // w5=1;
- while(1)
- keyscan();
- if(qh_flag==0)
- display_sf();
- else
- if(knum==0)
- read_temp(); //DS18B20溫度
- ds18b20disp(tvalue);
- w5=1;
- if(knum!=0)
- qh_flag=0;
- // if(shan>250)
- // {BZ=1;}
- // else {BZ=0;}
- // BZ=0;
- // Delay_us(10);//實(shí)測(cè)11us(延時(shí)函數(shù)里面4個(gè)_nop_();@11.0592MHz)
- // BZ=1;
- // Delay_us(10);
- void timer0() interrupt 1
- static uint i,j;
- if(fm_flag)
- BZ = 0; //蜂鳴器開
- cont3++;
- if(cont3==100)//0.2秒
- cont3=0;
- BZ = 1; //蜂鳴器關(guān)
- fm_flag=0;
- shan++;
- if(shan==500)
- shan=0;
- if(knum != 0)
- shan1++;
- if(shan1==250)
- shan1=0;
- Ledcount++;
- P1=0xff; //消影
- if(Ledcount==4)
- Ledcount=0;
- switch(Ledcount)
- case 0: w2 = 1; w3 = 1; w4 = 1;w1 = 0; P1 = LedBuff[0]; break;
- case 1: w1 = 1; w3 = 1; w4 = 1;w2 = 0; P1 = LedBuff[1]; break;
- case 2: w1 = 1; w2 = 1; w4 = 1;w3 = 0; P1 = LedBuff[2]; break;
- case 3: w1 = 1; w2 = 1; w3 = 1;w4 = 0; P1 = LedBuff[3]; break;
- default: break;
- if(flag1) //按鍵消抖計(jì)時(shí)
- {k1_time_count++;}
- if(flag2) //按鍵消抖計(jì)時(shí)
- {k2_time_count++;}
- if(flag3) //按鍵消抖計(jì)時(shí)
- {k3_time_count++;}
- if(qh_flag1==0 && knum==0)
- i++;
- if(i==500)
- i=0;
- j++;
- if(j==7)
- j=0;
- qh_flag=1;
- qh_flag1=1;
- else
- if(knum==0)
- i++;
- if(i==500)
- i=0;
- j++;
- if(j==3)
- j=0;
- qh_flag=0;
- qh_flag1=0;
- [code]#ifndef __DS18B20_H__
- #define __DS18B20_H__
- /*定義DS18B20數(shù)據(jù)線*/
- sbit DQ = P0^1;
- //sbit DQ = P5^4;
- /*DS18B20驅(qū)動(dòng)程序------------------------------------------------------------*/
- uchar data disdata[5];
- uint tvalue;//溫度值
- uint s;
- void Delay_us(uchar i) //us延時(shí) STC Y6指令 使用STC8系列
- { //@11.0592MHz
- while(i--)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_(); //_nop_();// _nop_(); _nop_();
- /*單總線初始化時(shí)序*/
- bit ds_init()
- bit i;
- DQ = 1;
- _nop_();_nop_();_nop_();_nop_();_nop_();
- DQ = 0;
- Delay_us(250); Delay_us(250);//拉低總線499.45us 掛接在總線上的18B20將會(huì)全部被復(fù)位
- DQ = 1; //釋放總線
- Delay_us(38); //延時(shí)37.95us 等待18B20發(fā)回存在信號(hào)
- i = DQ;
- Delay_us(145); //141.95us
- DQ = 1;
- _nop_();
- return (i);
- /*寫一個(gè)字節(jié)*/
- void write_byte_ds18b20(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- DQ = 0;
- _nop_();//產(chǎn)生些時(shí)序
- DQ = dat & 0x01;
- Delay_us(78);//76.95us
- DQ = 1; //釋放總線準(zhǔn)備下一次數(shù)據(jù)寫入
- _nop_();
- dat >>= 1;
- uchar read_byte()
- uchar i, j, dat;
- for(i=0;i<8;i++)
- DQ = 0;
- _nop_();//產(chǎn)生讀時(shí)序
- DQ = 1;
- _nop_();//釋放總線
- j = DQ;
- DQ = 1;
- _nop_();
- dat = (j<<7)|(dat>>1);
- return (dat);
- read_temp()
- // float tt;
- uchar L,M;
- ds_init();
- write_byte_ds18b20(0xcc);//*跳過讀序列號(hào)*/
- write_byte_ds18b20(0x44);//*啟動(dòng)溫度轉(zhuǎn)換*/
- Delay_us(100);
- ds_init();
- write_byte_ds18b20(0xbe);//*讀取溫度*/
- Delay_us(100);
- L=read_byte();
- M=read_byte();
- tvalue=M;
- tvalue<<=8;
- tvalue=tvalue|L;
- // if(M >= 0x08) //判斷是否為負(fù)數(shù)
- // tvalue = ~tvalue + 1;//負(fù)數(shù)是以補(bǔ)碼的形式存放的需要取反加1
- // s = "-"; //顯示負(fù)數(shù)符號(hào)
- // else s = 0; //為正數(shù)則不顯示負(fù)數(shù)符號(hào)
- tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
- return(tvalue);
- /*溫度值顯示-----------------------------------------------------------------*/
- void ds1820disp()
- disdata[0]=tvalue%1000/100+0x30; //十位數(shù)
- disdata[1]=tvalue%100/10+0x30; //個(gè)位數(shù)
- disdata[2]=tvalue%10+0x30; //小數(shù)位
- if(disdata[0]==0x30) { disdata[0]=0x20; }//如果十位為0,不顯示
- set1616pic(5,4,0,1); //顯示"溫度計(jì)圖標(biāo)"
- write_com(0x30); write_com(0x06);
- write_com(0x9d); //在液晶上顯示溫度起始位置:"28.8°C
- write_data(disdata[0]); //顯示十位
- write_data(disdata[1]); //顯示個(gè)位
- write_data(0x2e); //顯示小數(shù)點(diǎn)
- write_data(disdata[2]); //顯示小數(shù)位
- set1616pic(8,4,0,0); //在第8列第4行不反白的°C圖標(biāo)
- #endif
復(fù)制代碼 |
