查看: 1222|回復(fù): 1
52單片機(jī)密碼鎖設(shè)置
ID:1096616 發(fā)表于 2023-12-24 12:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我想在里面加入一個在第四次錯誤是不可以輸入了,但是為什么在我加入定時器之后不可以使用呢
#include <reg52.h>      //包含52頭文件
#define uint unsigned int //宏定義uint代替unsigned int
#define uchar unsigned char //宏定義uchar代替unsigned char
#define out P0
sbit lcdrs=P2^4;
sbit lcdrw=P2^5;
sbit lcden=P2^6;
sbit buzzer=P2^7;//蜂鳴器
sbit led=P3^1;
void check_busy(void);
void write_cmd(char cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void keyscan();
void verify();
void beep();
void T1_init();
uchar key,num=100,flag,warn,time1,time2;
unsigned char code password[6]={1,4,0,2,0,6};//密碼
uchar dat[]="0123456789abcdf";
uchar DispBuff[6];
uchar code xianshi1[]="  first error!";
uchar code xianshi2[]="  second error!";
uchar code xianshi3[]="  third error!";
uchar code xianshi4[]="  alter fail!!";
uchar code xianshi5[]=" you are thief!";
void delay (uint xms)     //毫秒函數(shù)定義
    uint i,j;
    for(i=0;i<xms;i++)
       for(j=0;j<120;j++);
void  main()                            //主函數(shù)
{    T1_init();
     lcd_init();
          num=0;
          keyscan();
          if(key!=0xff)
           {  uchar i;
           DispBuff[num]=key;
           num++;
           key=0xff;
           write_cmd(0x01);//清除屏幕
           delay(1);
           write_cmd(0x80+0x40);
           for(i=0;i<num;i++)
           {        write_data(dat[DispBuff[i]]); }
           verify();
                if(time2==4)            //門鎖打開后4秒關(guān)閉
                { time2=0;
                   TR1=0;                 //關(guān)閉定時器1
/**********************檢查忙標(biāo)志函數(shù)************************/
    uchar dt;
        out=0xff;
        do
           lcden=0;
           lcdrs=0;
           lcdrw=1;
           lcden=1;
           dt=out;
        }while(dt&0x80);
        lcden=0;
/**************************1602顯示****************************/
void write_cmd(char cmd)  //寫指令函數(shù)
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=0;
        lcdrw=0;//先將RW拉低
        out=cmd;
        lcden=1;
        lcden=0;
void write_data(uchar dat) //寫數(shù)據(jù)函數(shù)
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=1;
        lcdrw=0;//先將RW拉低
        out=dat;
        lcden=1;
        lcden=0;
void write_str(uchar *str)//寫字符串函數(shù)
        while(*str!='\0')
                write_data(*str++);
                delay(5);
/***************************初始化******************************/
void lcd_init()//初始化1602
        write_cmd(0x38);//顯示模式設(shè)置
        write_cmd(0x0c);//顯示開關(guān),光標(biāo)沒有閃爍
        write_cmd(0x06);//顯示光標(biāo)移動設(shè)置
        delay(1);
void keyscan()
    uchar temp,num;
    P1=0xff;       //先向P1寫1
        P1=0xfe;       //選中按鍵第一行
        temp=P1;           //把P1給中間變量
        temp=temp&0xf0;//低四位清零
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xee:key=0; break;
                            case 0xde:key=1; break;
                            case 0xbe:key=2; break;
                            case 0x7e:key=3; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfd;//選中按鍵第二行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xed:key=4; break;
                            case 0xdd:key=5; break;
                            case 0xbd:key=6; break;
                            case 0x7d:key=7; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfb;//選中按鍵第三行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xeb:key=8; break;
                            case 0xdb:key=9; break;
                            case 0xbb:key=10; break;
                            case 0x7b:key=11; break;
                        while(temp!=0xf0)
                            temp=P1;
                            temp=temp&0xf0;
        P1=0xf7;//選中按鍵第四行
        temp=P1;        //把P1給中間變量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xe7:key=12; break;
                            case 0xd7:key=13; break;
                            case 0xb7:key=14; break;
                            case 0x77:key=15; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
   while((num<50)&&(temp!=0xf0))
   {delay(10);
     num++;
    num=0;
void verify()//對輸入密碼進(jìn)行判斷
{  uchar j,Flag,a;
if(num==6)
             {         num=0;
               Flag=1;
                            for(j=0;j<6;j++)
                            Flag=(DispBuff[j]==password[j]);
                        if(Flag)
                                          write_cmd(0x80+0x04);
                             write_str("Right!   ");
                                 warn++;
                                 if(warn==1)
                                 { write_cmd(0x01);                   //清屏
                                  write_cmd(0x80);
                                for(a=0;a<14;a++)           //顯示first error
                                 { write_data(xianshi1[a]);
                                 if(warn==2)
                                  write_cmd(0x80);
                                 { write_data(xianshi2[a]);
                                 if(warn==3)
                                  write_cmd(0x80);
                                 { write_data(xianshi3[a]);
                                 if(warn==4)
                                  write_cmd(0x80);
                                 { write_data(xianshi4[a]);
                                  write_cmd(0xc0);
                                 { write_data(xianshi5[a]);
                                    TR0=1;                  //定時器0啟動
                                    beep();
                                    led=~led;
                                   warn=0;
void beep()
{             buzzer=1;
        delay(200);
        buzzer=0;
        delay(200);
void T1_init()
    TMOD=TMOD|0x20;    //設(shè)置T1為方式2
    TH1=256-200;          //置T1高8位,備用初值
    TL1=256-200;          //置T1低8位,初值
    ET1=1;                //開T1中斷
    EA=1;                      //開總中斷
/**********T1中斷服務(wù)程序*********/
void T1_int() interrupt 3  //200us進(jìn)入中斷
{   TH1=(65536-50000)/256;
    TL1=(65536-50000)%256;
    time1++;
    if(time1==20)//一秒
      time2++;
     time1=0;
ID:883242 發(fā)表于 2024-1-2 11:49 | 只看該作者
跟定時中斷無關(guān),一定是別的地方出問題了,樓主解決了嗎?
主站蜘蛛池模板: 亚洲一级特黄 | 国产精品日韩欧美 | 日本视频一区二区三区 | 亚洲69视频 | av一区二区三区在线观看 | 国产乡下妇女三片 | 午夜国产 | 黄色片网站免费 | 亚洲激情五月 | 长河落日| 91精品国产成人www | 亚洲第一色 | 交换多p群乱高h文 | 中文字幕在线不卡 | 国产精品爽爽爽 | 日韩色网站 | 成人欧美一区二区三区黑人孕妇 | 午夜影院在线免费观看 | 玖玖精品视频 | 午夜精品国产精品大乳美女 | 成av人片一区二区三区久久 | 国产操操操 | 51成人做爰www免费看网站 | 日韩精品视频免费 | 国产伦精品一区二区三区四区免费 | 天天操天天操 | 97精品国产97久久久久久免费 | 国产成人区 | 久久99精品久久久久久水蜜桃 | 九九精品九九 | 久久综合亚洲 | 久久久久久久免费视频 | 五月婷婷在线播放 | 成人免费毛片男人用品 | 欧美成人极品 | 日韩免费毛片 | 国产午夜一区二区 | 在线观看国产一区二区 | 色综合国产 | 久久精品视频一区二区 | 亚洲女优在线 |
