代碼怎么把共陰改成共陽啊,還有這個仿真圖還需要改什么呀,單片機代碼如下:
#include<at89x51.h>
#define uchar unsigned char
#define uint unsigned int
char s;
uchar num=0;
char time=20; //搶答時間
char datitime=30; //答題限時時間
uint tt,t1; //T0,T1定時器定一秒時
bit flag,s_flag=1,b_flag,fall_flag; //標(biāo)志位
bit K_startcountflag,K_timecountflag; //時間調(diào)整標(biāo)志位
sbit K0=P3^0;
sbit beep=P3^7; //蜂鳴器
sbit rled=P3^1; //指示燈
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
sbit K6=P1^5;
sbit K7=P1^6;
sbit K8=P1^7;
sbit K_Time=P3^2; //答題計時鍵
sbit K_startcount=P3^3; //開始搶答時間調(diào)整鍵
sbit K_timecount=P3^4; //答題計時時間調(diào)整鍵
void delay(uchar ms)
uchar y;
for(;ms>0;ms--)
for(y=120;y>0;y--);
uchar code tabledu[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
uchar code tablewe[]={0XFE,0XFD,0XFB,0XF7};
void T0_Init(void)
TMOD=0X01;
TH0=(65536-2000)/256;
TL0=(65536-2000)%256;
TH1=(65536-2000)/256;
TL1=(65536-2000)%256;
ET0=1;
ET1=1;
EA=1;
P0=0;
void Key_Scan(void) //開始鍵掃描
if(K0==0)
delay(10);
if(K0==0)
while(!K0);
TR0=1;
s=time;
tt=0;
flag=1;
s_flag=1;
b_flag=1;
num=0;
beep=1;
rled=1;
fall_flag=0; //清除違規(guī)標(biāo)志位
K_startcountflag=0;
K_timecountflag=0;
void Scan(void) //八路熱鍵掃描(哪個鍵先按下,哪個優(yōu)先級最高)
if(K1==0)
delay(10);
if(K1==0)
while(!K1);
num=1; //數(shù)碼管顯示1號"1"
TR0=0; //關(guān)閉定時器0,時間停止
TR1=1; //打開定時器1,使揚聲器響一聲
s_flag=0; //關(guān)閉開始鍵標(biāo)志位,使再按其他七個鍵不會響應(yīng)
if(K2==0) //下面七個鍵的處理同上
delay(10);
if(K2==0)
while(!K2);
num=2;
TR0=0;
TR1=1;
s_flag=0; //重要
if(K3==0)
delay(10);
if(K3==0)
while(!K3);
num=3;
TR0=0;
TR1=1;
s_flag=0;
if(K4==0)
delay(10);
if(K4==0)
while(!K4);
num=4;
TR0=0;
TR1=1;
s_flag=0;
if(K5==0)
delay(10);
if(K5==0)
while(!K5);
num=5;
TR0=0;
TR1=1;
s_flag=0;
if(K6==0)
delay(10);
if(K6==0)
while(!K6);
num=6;
TR0=0;
TR1=1;
s_flag=0;
if(K7==0)
delay(10);
if(K7==0)
while(!K7);
num=7;
TR0=0;
TR1=1;
s_flag=0;
if(K8==0)
delay(10);
if(K8==0)
while(!K8);
num=8;
TR0=0;
TR1=1;
s_flag=0;
void display(void)
if(flag==1) //開始鍵按下,開始計時搶答
if(num!=0) //如果有人搶答,則顯示相應(yīng)的幾號
P0=tabledu[num]; //顯示幾號搶到了
P2=tablewe[0];
delay(2);
P0=0;
P2=0XFF;
else //否則沒人搶答,則前面不顯示幾號
P0=0;
P2=0XFF;
P0=tabledu[s/10]; //下面為顯示搶答倒計時
P2=tablewe[2];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[s%10];
P2=tablewe[3];
delay(2);
P2=0XFF;
P0=0;
else //如果開始鍵沒有按下,則顯示F FF(若有違規(guī)者,則顯示違規(guī)號碼及 FF)或時間調(diào)整
if(fall_flag==1) //違規(guī)顯示
if(num!=0)
P0=tabledu[num]; //顯示幾號違規(guī)了
P2=tablewe[0];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[15]; //下面顯示 FF,表示違規(guī)了
P2=tablewe[2];
delay(2);
P0=0; //消隱
P2=0XFF;
P0=tabledu[15];
P2=tablewe[3];
delay(2);
P0=0;
P2=0XFF;
P0=0;
P2=0XFF;
else //沒有人違規(guī)才顯示調(diào)整時間
if(K_startcountflag==1)
P0=0X6D; //第一位數(shù)碼管顯示"5(S)"(表示搶答時間調(diào)整)
P2=tablewe[0];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[time/10]; //下面顯示調(diào)整的搶答時間
P2=tablewe[2];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[time%10];
P2=tablewe[3];
delay(2);
P0=0;
P2=0XFF;
else if(K_timecountflag==1)
P0=0X07; //第一位與第二位數(shù)碼管合起來顯示"T",表示答題時間調(diào)整
P2=tablewe[0];
delay(2);
P0=0;
P2=0XFF;
P0=0X31;
P2=tablewe[1];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[datitime/10];
P2=tablewe[2];
delay(2);
P0=0;
P2=0XFF;
P0=tabledu[datitime%10];
P2=tablewe[3];
delay(2);
P0=0;
P2=0XFF;
else //否則顯示F FF
P0=tabledu[15];
P2=tablewe[0];
delay(2);
P0=0;
P0=tabledu[15];
P2=tablewe[2];
delay(2);
P0=0; //消隱
P2=0XFF;
P0=tabledu[15];
P2=tablewe[3];
delay(2);
P0=0;
P2=0XFF;
void Time_Scan(void) //調(diào)整時間鍵掃描
if(K_startcount==0) //搶答時間調(diào)整
delay(10);
if(K_startcount==0)
while(!K_startcount);
time++;
if(time==50)
time=20;
K_startcountflag=1; //將搶答時間標(biāo)志位置1
K_timecountflag=0; //同時關(guān)閉答題時間標(biāo)志位
if(K_timecount==0) //答題時間調(diào)整
delay(10);
if(K_timecount==0)
while(!K_timecount);
datitime++;
if(datitime==60)
datitime=30;
K_timecountflag=1;
K_startcountflag=0;
void main(void)
T0_Init();
Key_Scan(); //開始鍵掃描
if((flag==0)&(s_flag==1)) //當(dāng)開始鍵沒按下及沒有人違規(guī)時才可進行時間調(diào)整
Time_Scan();
if((flag==1)&(s_flag==0)) //當(dāng)開始鍵按下及有人搶答才進行開始回答計時倒計時
if(K_Time==0)
delay(10);
if(K_Time==0)
while(!K_Time);
s=datitime;
TR0=1;
tt=0;
TR1=1;
if((flag==0)&(s_flag==1)) //違規(guī)
Scan();
if(num!=0) //開始鍵沒有按下時,有人按下了搶答器,則置違規(guī)標(biāo)志位
fall_flag=1;
rled=0;
if((flag==1)&(s_flag==1)) //如果開始鍵按下且搶答鍵沒有人按下,則進行八路搶答鍵掃描
Scan();
display(); //顯示到數(shù)碼管上
void timer0(void) interrupt 1
TH0=(65536-2000)/256; //2ms
if(b_flag) //開始(START)鍵按下,嘟一聲(長1秒),表示開始搶答
beep=~beep;
beep=1;
if(s<5) //搶答時間快到報警,隔1秒響一聲且紅燈閃爍,響三聲
if(s%2==0)
b_flag=1;
rled=0;
b_flag=0;
rled=1;
tt++;
if(tt==500) //1秒
tt=0;
s--;
b_flag=0; //關(guān)閉開始鍵按下響一秒的嘟聲
if(s==-1)
s=20;
TR0=0;
flag=0; //顯示F FF
s_flag=1;
num=0;
rled=1;
void timer1(void) interrupt 3 //定時器1處理有人按下?lián)尨鹌鬣揭宦?長1秒)
beep=~beep;
t1++;
if(t1==500)
t1=0;
TR1=0;
