查看: 1387|回復: 4
有沒有大佬知道eeprom寄存器為什么會報錯提示內存空間不足
ID:1107532 發表于 2024-1-11 16:32 | 顯示全部樓層 |閱讀模式
* File:   adcshili.c
* Author: Administrator
* Created on 2024年1月5日, 上午9:24
//#include <stdio.h>
//#include <stdlib.h>
int main(int argc, char** argv) {
    return (EXIT_SUCCESS);
# include <xc.h>
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)INTOSC 振蕩器, RA4、RA5為IO口
#pragma config WDTE = OFF      // Watchdog Timer Enable bit (WDT enabled)看門狗開
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)上電復位開
#pragma config MCLRE = OFF      // RA3/MCLR pin function select (RA3/MCLR pin function is digital I/O, MCLR internally tied to VDD)RA3/MCLR引腳功能為MCLR
#pragma config BOREN = OFF       // Brown-out Detect Enable bit (BOD enabled)欠壓檢測功能關
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)程序存儲器代碼保護被禁用
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)數據代碼保護關
//__ CONFIG(0X31A4);
__EEPROM_DATA(5,50,67,6,5,0,0,0);   //0X00第一位表示定時倍數;0X01第二位表示最低電壓-低;0X02第三位表示最高電壓-高;0X03第四位表示清蟲天數記錄;0X04第五位表示清蟲天數預設;0X05第五位表示為0鉛酸電池(最低不能低于2點幾V)、為1鋰電池(最高不能超過12.6V);0X06空;0X07空
#define uchar unsigned char
#define uint unsigned int
uint count;
uint AN2_val;       //存放AN2通道模擬轉換的值
uint AN4_val;       //存放AN4通道模擬轉換的值
uchar i = 0;
uchar j = 0;
uint yanshi;
uchar AN2_num1;
uchar AN2_num2;
uchar AN2_num3;
uchar AN4_num1;
uchar AN4_num2;
uchar AN4_num3;
uchar AN4_num4;
uchar yukon_num1;
uchar yukon_num2;
uint anjian_num1;
uchar anjian_num2;
uchar n;
uint num;
uchar daochon_num;
uint h;
uchar day;         //0為白天,1為晚上
uchar fuzhai=1;     //負載開啟
uchar chondian;     //0為充電完成,1為充電未完成,繼續充電
uchar taiyangban;   //1為太陽板電壓高于電池,0為太陽板電壓低于電池
uchar ONOFF=1;  //放電到充電一循環,1開啟,0關閉
uchar qingchontianshu;
uchar k;
uchar a=6;
uchar t;
uchar z=0;
uchar m;
void init1()
    TRISA = 0b00110100;     //設置RA輸入輸出端口   RA2,RA4,RA5(AN2、AN3)為輸入,其他輸出
    TRISC = 0b00010011;     //設置RC輸入輸出端口   RC0、RC1、RC4(AN4、AN5)為輸入,其他輸出
    PORTA = 0b00000000;     //設置A端口輸出為低電平
    PORTC = 0b00000000;     //設置C端口輸出為低電平
    ANSEL = 0X14;           //ANS4=1,ANS2=1;AN4和AN2為模擬輸入   二進制00010100
    CM2 = 1;                //CM2:CM0:111 比較器模式位(關閉)
    CM1 = 1;
    CM0 = 1;
    ADCON1 = 0X10;          //ADCS<2:0>:A/D 轉換時鐘源選擇位   0011 =FOSC/8  4MHz頻率   二進制00010000
void ADAN2()         //對RA2(AN2)進行A/D模擬轉換輸入
    for (i=0; i<20; i++)
        ADCON0 = 0X09;  //二進制0000 1001 (bit7:0 左對齊,bit6:0 參考電壓VDD, bit5:0 未用, bit4-bit2:010 通道02(AN2), bit1:0 A/D轉換結束/未進行, bit0:(ADON)1 A/D轉換模塊正在工作)    A/D 控制寄存器
        asm("NOP");  //稍微延時
        asm("NOP");
        asm("NOP");
        asm("NOP");
        GO_DONE = 1;    //1 = A/D 轉換正在進行。該位置 1 將啟動 A/D 轉換。 在轉換結束后該位將被硬件自動清零。      ADCON0 _ A/D 控制寄存器
        while (GO_DONE)   //循環檢測GO_DONE是否為0,為0轉換結束
            continue;
        AN2_val + = ADRESH;   //將左對齊后的20次結果賦值
    AN2_val = AN2_val/20;  //取20次檢測電壓的平均值
    ADON = 0;   //A/D轉換模塊結束
    if (AN2_val < eeprom_read(0X01))   //讀寫寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第二位,電源電壓為10.8v時,電路分壓后測出AN2電壓為:0.98v  (5v是參考電壓,一個數值代表多少電壓:5/1024=0.00448,如果輸入電壓為0.98v,0.98/0.00448=218.75)
        AN2_num1++;
        if(AN2_num1 > 20)     //(超過20次電壓低于10.8v)
            AN2_num1 = 0;   //計數清0
            fuzhai = 0;    //負載未開啟工作
        AN2_num1 = 0;   //清0
    if (AN2_val > eeprom_read(0X02))   //讀寫寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第三位,電源電壓為14.4v時,電路分壓后測出AN2電壓為:1.31v   (如果輸入電壓為1.31v,1.31/0.00448=292.41)
        AN2_num2++;
        if(AN2_num2++ > 20)   //(超過20次電壓高于14.4v)
            AN2_num2 = 0;   //計數清0
            chondian = 0;  //充電完成
        AN2_num3++;  //計數自增
        if (AN2_num3 > 20)   //(超過20次電壓低于14.4v)
            AN2_num3 = 0;   //計數清0
            chondian = 1;   //充電未完成,繼續充電
void ADAN4()         //對RC0(AN4)進行A/D模擬轉換輸入
    for (j=0; j<20; j++)
        ADCON0 = 0X11;  //二進制0000 1001 (bit7:0 左對齊,bit6:0 參考電壓VDD, bit5:0 未用, bit4-bit2:100 通道04(AN4), bit1:0 A/D轉換結束/未進行, bit0:(ADON)1 A/D轉換模塊正在工作)    A/D 控制寄存器
        asm("NOP");  //稍微延時
        asm("NOP");
        asm("NOP");
        asm("NOP");
            continue;
        AN4_val + = ADRESH;   //將左對齊后的20次結果賦值
    AN4_val = AN4_val/20;  //取20次檢測電壓的平均值
    if(AN2_val - AN4_val < 13)   //連續檢測20次太陽板比鉛酸電池或鋰電池低于3V   (晚上)
        AN4_num1++;
        if (AN4_num1 > 20)  //(超過20次太陽板電壓比電源電壓低于3v)
            AN4_num1 = 0;   //計數清0
            day = 1;   //晚上
        AN4_num1 = 0;
    if (AN2_val - AN4_val > 23)  //連續檢測20次太陽板高于5.5V的鉛酸電池或鋰電池   (白天)
        AN4_num2++;
        if (AN4_num2 > 20)   //(超過20次太陽板電壓比電源電壓高于5.5v)
            AN4_num2 = 0;
            day = 0;  //白天
        AN4_num2 = 0;
    if (AN4_val < 0b00000011)  //連續檢測20次太陽板電壓高于電池電壓,開始充電,連續檢測20次太陽板電壓低于電池電壓,不充電
        AN4_num3++;
        if (AN4_num3 > 20)  //連續檢測20次太陽板電壓高于電池電壓
            AN4_num3 = 0;  //計數清零
            taiyangban = 1;  //1為太陽板電壓高于電池
            fuzhai = 1;  //負載工作開啟
            ONOFF=1;  //放電到充電一循環,開啟
        AN4_num4++;
        if (AN4_num4 > 20)  //連續檢測20次太陽板電壓低于電池電壓
            AN4_num4 = 0;  //計數清零
            taiyangban = 0;  //0為太陽板電壓低于電池
void kaijishansuo()   //開機閃爍5次
    if (yanshi > 3906)  //1s溢出
        yanshi = 0;
        if (z == 0)
            z = 1;
            z = 0;
        a--;
void condianshansuo()    //充電連續閃爍
        yanshi = 0;
        if (z == 0)
            z = 1;
            z = 0;
void panduan ()    //轉換后的數據判斷,定義是否需要開燈、充電、雨控等待
    if (fuzhai == 1)   //負載開啟
        if (day == 1)  //晚上
            if (ONOFF==1)  //放電到充電一循環,開啟
                TMR1ON=1;  //中斷TMR1開啟,開始計時
                if (RC1 == 0)  //雨控控制,0為雨控檢測無雨,短接帽斷路
                    yukon_num1++;
                    if (yukon_num1 > 20)  //檢測超過20次沒有雨
                        yukon_num1 = 0;  //計數清0
                        RC2 = 1;  //沒有雨水,繼電器啟動
                else   //雨控控制,0為雨控檢測有雨,短接帽連通,將5v電壓拉到RC1引腳
                    yukon_num2++;
                    if (yukon_num2 > 20)   //檢測超過20次有雨
                        yukon_num2 = 0;  //計數清0
                        RC2 = 0;   //下雨,繼電器關閉
               RC2 = 0;  //未實現放電到充電的循環,繼電器關閉,負載未啟動
            RC2 = 0;  //白天繼電器關閉,負載未啟動
        RC2 = 0;  //繼電器關閉,負載未啟動
    if (chondian == 1)  //1為充電未完成,繼續充電
        if (taiyangban == 1)  //1為太陽板電壓高于電池
            RC1 = 1;  //RC3高電平,電源模塊充電,太陽板給電池充電
            if (num > 0)
                num = 0;  //定時清0
            if (h > 0)
                h = 0;
            condianshansuo();  ////充電藍燈閃爍
            RC3 = 0;  //充電完成,RC3低電平,電源模塊不充電
            if (a < 1)   //藍燈不閃爍
                z = 0;   //RA0=0
        if (a < 1)  //藍燈不閃爍
            z = 0;  //RA0=0
void anxia()
    anjian_num1++;
    if (anjian_num1 > 7200)
        anjian_num1 = 0;
        anjian_num2++;  //增加一小時(定時數據)
        a = 2;   //藍燈閃爍一次
        k = 1;  //有未寫入數據
void sonkai()
    if(k == 1)
        eeprom_write(0x04,anjian_num2);  //把anjian_num2寫到地址0x04
        qingchontianshu = anjian_num2;  //清除定時時間
        k = 0;   //沒有未寫入數據
        anjian_num1 = 0;
        anjian_num2 = 0;  //清除定時數據
    if(t == 1)  //開始讀定時時間
        if (a < 1)  //藍燈不閃爍的時候
            if (anjian_num2 > 0)  //定時時間大于0
                anjian_num1++;
                if (anjian_num1 > 7200)  //延時7200
                    if (anjian_num1%2000 == 0)
                        anjian_num2--;  //減去一次已顯示的
                        a = 2;    //藍燈閃爍一次
                t = 0;    //讀定時時間控制位清除
                anjian_num1;  //延時清零
        if ( anjian_num1>20 &&  anjian_num1<40)  //短按10s-20s之間,可以開始讀定時間t=1
            a = 6;    //開始讀藍燈閃爍5次
            t = 1;    //開始讀定時時間
            anjian_num2 = eeprom_read(0x04);     //從內存讀取定時數據
        anjian_num1 = 0;   //延時清零
void shezhi()  //設置定時時間
    if (RC4 == 0)  //按鍵按下
        anxia();
    else  //按鍵松開
        sonkai();
void  init2 ()
    T0CS = 0;  //Timer0使用內部時鐘             OPTION_REG _ 選擇寄存器
    PSA=1;   //將預分頻器給看門狗WDT           OPTION_REG _ 選擇寄存器
    TMR0=0x00;  //定時器
    T0IF=1;  //Timer0 啟動控制位使能(0關閉)(標志位)    INTCON _ 中斷控制寄存器
    T0IE=1;  //Timer0中斷開啟(使能位)                   INTCON _ 中斷控制寄存器
    TMR1CS = 0;  //Timer1使用內部時鐘           Timer1 控制寄存器
    T1CKPS0=1;  //1:8倍預分頻比                Timer1 控制寄存器      T1CKPS1:T1CKPS0:11=1:8倍預分頻比
    T1CKPS1=1;  //1:8倍預分頻比                Timer1 控制寄存器
    //TMR1H=(65536-(500000/8))/256; //初始化TMR1的高八位初始值   0.5s中斷溢出一次
    //TMR1L=(65536-(500000/8))%256; //初始化TMR1的低八位初始值
    TMR1H=0x0B;  //高八位置初始值
    TMR1L=0xDC;  //低八位置初始值
    TMR1ON=0;  //Timer1 啟動控制位使能(0關閉)       Timer1 控制寄存器
    TMR1IF=0;  //中斷標志位清零                      外設中斷標志寄存器 1
    TMR1IE=1;  //Timer1中斷開啟                      外設中斷使能寄存器 1
    PEIE=1;  //外部中斷開啟                          INTCON ? 中斷控制寄存器
    GIE=1;  //全局中斷開啟                           INTCON ? 中斷控制寄存器
void daochon();  //倒蟲,函數聲明
void interrupt time0()
   if (TMR1IF == 1)
        TMR1IF=0;  //中斷標志溢出清0
        num++;
        if (num == 7200)  //定時計時1一個小時溢出
            h++;  //每小時自增
            num = 0;  //溢出清0
            if (h == 1)
                count = eeprom_read(0x03);   //清蟲天數計數+1天
                eeprom_write(0x03, count + 1);
            if (h == 5)  //等于設定的小時
                h = 0;  //小時清零
                RC2 = 0;  //繼電器/負載關閉
                ONOFF=0;  //放電到充電一循環,時間到置0,關閉
   if (T0IF == 1)  //1 = TMR0 寄存器溢出 (必須在軟件中清除) 0 = TMR0 寄存器沒有溢出
       T0IF = 0; //tmr0溢出清零
       yanshi++;
       TMR0=0x00;
       n++;
       if (n > 200)  //1s/256us=3906.25,1秒溢出
           n = 0;  //溢出清0
           ADAN2();  //讀AD轉化口RA2/AN2
           ADAN4();  //讀AD轉化口RC0/AN4
           panduan ();  //轉換后的數據判斷,定義是否需要開燈、充電、雨控等待
           if (eeprom_read(0x03)>=qingchontianshu && TMR1ON==1)  //讀清蟲設定天數2天的時候  ?????
               daochon();  //倒蟲
       if (a > 0)
           kaijishansuo();   //開機藍燈閃爍5次
       if (z == 1)
           RA0 = 1;  //藍燈閃爍
           RA0 = 0;
       shezhi();  //設置定時時間
void dianchi()  //每次開機判斷所使用的電池,和讀入定時時間
    if (RA4 == 0 )  ////RA4口為低時是用蓄電池
        if (eeprom_read(0x05)==1)   //如果RA4口為蓄電池,控制位為1時,就寫入蓄電池的數據
            eeprom_write(0x01,50);  //最低電壓
            eeprom_write(0x02,67);  //最高電壓
            eeprom_write(0x05,0);  //標記為蓄電池   ????
    else        //RA4口為高時是用鋰電池
         if (eeprom_read(0x05)==0)   //如果RA4口為鋰電池,控制位為0時,就寫入鋰電池的數據
            eeprom_write(0x01,43);  //最低電壓(41)
            eeprom_write(0x02,58);  //最高電壓
            eeprom_write(0x05,1);  //標記為鋰電池   ???
    qingchontianshu = eeprom_read(0x04);    //(預計青蟲天數為5天一次)
    if(eeprom_read(0x03) <= qingchontianshu)   //(判斷清除天數幾天一次)
        eeprom_write(0x03,6);   //(將清蟲天數記錄設為6天一次)
void daochon()  //倒蟲
    if (RC5 == 0)
        RC5 = 1;
    if (RC5 == 1  && RA5 == 0)
        m = 1;           //(步驟控制)
    if (RC5 == 1 && RA5 == 1 && m == 1)
        daochon_num++;  //倒蟲天數增加
        m = 0;
    if (daochon_num >= 2)  //超過兩天清一次蟲
        daochon_num = 0;   //清0
        RC5 = 0;
        eeprom_write(0x03,0);
void main ()
    init1();     //通道初始化
    init2 ();    //定時器初始化
    dianchi();   //電池選擇
    daochon();   //倒蟲
    while (1)    //死循環
以上是我寫的代碼,可是編譯時出現以下報錯
:: warning: (1273) Omniscient Code Generation not available in Free mode
adcshili.c:421: warning: (752) conversion to shorter data type
D:\XC8\sources\common\lwdiv.c:31: error: (1358) no space for _eeprom_read temps (1)
(908) exit status = 1
nbproject/Makefile-default.mk:131: recipe for target 'dist/default/production/ADCshili.X.production.hex' failed
make[2]: Leaving directory 'D:/MPLAB X IDE v4.05��Ŀ/ADCshili.X'
nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
make[1]: Leaving directory 'D:/MPLAB X IDE v4.05��Ŀ/ADCshili.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** [dist/default/production/ADCshili.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
編譯已失敗 (退出值2, 總時間: 1s)
有沒有大佬知道是哪兒的問題啊?
ID:883242 發表于 2024-1-11 20:29 | 顯示全部樓層
沒有為你的單片機指定eeprom地址空間。
ID:1107532 發表于 2024-1-12 08:04 | 顯示全部樓層
Hephaestus 發表于 2024-1-11 20:29
大佬,這條語句不是指定eeprom的地址空間嗎
ID:1057978 發表于 2024-1-12 08:45 | 顯示全部樓層
Omniscient Code Generation的首字母組合起來就是OCG,這是PICC宣傳的一種高效率編譯模式,這個模式只有在收費的PRO版本中才支持,非OCG模式下編譯出來的代碼優化不夠,比較大,編譯器的全知代碼生成在免費版中不可用。僅影響編譯器的優化性能。
no space for _eeprom_read temps:內存不足的問題,提示芯片空間不足,flash夠大,就是需要用到的ram不夠了,導致數據放不到ram中報空間不足。解決辦法:增加RAM分配空間,直到編譯通過
ID:1107532 發表于 2024-1-12 17:06 | 顯示全部樓層
wangxiangtan 發表于 2024-1-12 08:45
Omniscient Code Generation的首字母組合起來就是OCG,這是PICC宣傳的一種高效率編譯模式,這個模式只有在 ...
大佬,代碼可以實現解決這個問題嗎
主站蜘蛛池模板: 清清草视频 | 中文字幕视频在线 | 免费a网站 | 一起操在线 | 三年中文在线观看免费大全中国 | 欧美精品在线观看视频 | 看片地址| 久久成人免费视频 | 午夜久久久久久 | 久久久久久久综合 | 国产一级黄色录像 | 精品免费视频 | 黄色一级小说 | 亚洲欧美日韩一区二区 | 操欧美女人 | 欧美精品福利 | 女同一区二区 | 国产福利在线视频 | 黄色理论片| 国产伦精品一区二区三区视频网站 | 黄色网页免费 | 伊人网视频 | 国产精品久久久久久无人区 | 日韩不卡在线观看 | 一区二区三区在线观看视频 | 成人在线视频免费观看 | 国内自拍偷拍 | 久久一区二区三区四区 | 欧美成人午夜 | 日韩一区二区免费视频 | 毛片一级片 | 中文字幕一区在线观看 | 欧美色综合天天久久综合精品 | 日本中文字幕在线观看 | 亚洲视频一区在线观看 | 欧美激情视频一区二区三区 | 久久久久网 | 精品久久久久久一区二区里番 | 色日韩 | 中文字幕永久免费 | 免费激情网站 |
