查看: 1193|回復: 0
簡易單片機計算器,最基礎的
ID:1109513 發表于 2024-1-17 16:32 | 顯示全部樓層 |閱讀模式
剛學到,求助多功能計算器的設計
代碼:
#include         "reg51.h"
#include         "math.h"
#define         ON                10
#define         ADD                 11
#define         SUB                 12
#define         MUL                 13
#define         DIV         14
#define         EQU        15
#define        BLANK        10
#define        ERROR        11
#define        MINUS        12
sbit         SPEAKER = P3^7;
long Result,VarTmp;
unsigned char code LED[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff,0x86,0xbf};
unsigned char code KeyTable[]={ON,0,EQU,ADD,1,2,3,SUB,4,5,6,MUL,7,8,9,DIV};
unsigned char DisplayNo ,Operate,MS,DisplayBuffer[8];
bit Over,NoError=1,FirstInput=1;
unsigned int BeepTime,DelayTime;
void delayms(unsigned int ms)
{        DelayTime=ms;
        while(DelayTime);
unsigned char Key()
{        unsigned char Row,Col,k;
                P1=0x0f;
                k=P1&0x0f;
                if(k==0x0f)        return -1;
        delayms(20);
                k=P1&0x0f;
                BeepTime=300;
                for(Row=0;Row<4;Row++)
                {        P1=0x7f>>Row;
                        k=P1&0x0f;
                        if(k!=0x0f)
                        {        Col=0;
                                while(k&(1<<Col))        Col++;
                                break;
                while((P1&0x0f)!=0x0f);
                k= Row+Col*4;
                return KeyTable[k];
void ClrDisplayBuffer()
{        unsigned char i;
                for(i=0;i<7;i++)
                        DisplayBuffer[ i]=BLANK;
                DisplayBuffer[7]=0;
void ModifyDisplayBuffer(long num)
{        unsigned char i;
                if(num>9999999||num<-9999999)
                {        ClrDisplayBuffer();
                        DisplayBuffer[0]=ERROR;
                        NoError=0;
                        return;
                ClrDisplayBuffer();
                if(num<0)
                {        num=labs(num);
                            DisplayBuffer[0]=MINUS;
                i=7;
        do
        {        DisplayBuffer[ i]=num%10;
                        num/=10;
                        i--;
                }while(num!=0);
void Calculate()
{        switch(Operate)
                {        case ADD:
                                        Result=Result+VarTmp;
                                 ModifyDisplayBuffer(Result);
                                        break;
                         case SUB:
                                        Result=Result-VarTmp;
                                        break;
                         case MUL:
                                        Result=Result*VarTmp;
                                        break;
                         case DIV:
                                        if(VarTmp!=0)
                                        {        Result=Result/VarTmp;
                                                NoError=0;
                                        break;
void KeyProcess(unsigned char k)
{        if(k==ON)
                {         Result=0,        VarTmp=0,Operate=0,Over=0,NoError=1,FirstInput=1;
                        ClrDisplayBuffer();
                if(!NoError)         return;
                if(k<10)
                {        if(Over)         Over=0,VarTmp=0,Result=0,Operate=0,FirstInput=1;
                        VarTmp=VarTmp*10+k;
                        if(VarTmp>9999999)                VarTmp=VarTmp/10;
                        if(Operate)                FirstInput=0;
                        ModifyDisplayBuffer(VarTmp);
                if(k>10&&k<15)
                {        if(Over)
                        {        Over=0,VarTmp=0,FirstInput=1, Operate=k;
                                return;
                        if(Operate&&FirstInput==0)
                        {        Calculate();
                                VarTmp=0,FirstInput=1;
                        if(Operate==0)
                        {        Result=VarTmp;
                                VarTmp=0;
                        Operate=k;
                if(k==EQU)
                {        if(Operate&&FirstInput==0)
                        {        Calculate();
                                Over=1;
{        unsigned char k;
                TMOD=1;
                TR0=1;
                ET0=1;
                EA=1;
                ClrDisplayBuffer();
                {        k=Key();
                        if(k!=-1)
                                KeyProcess(k);
void Display() interrupt 1
{        TL0=64536%256;
                TH0=64536/256;
        if(DelayTime)DelayTime--;
                if(BeepTime)
                {        BeepTime--;
                        SPEAKER=~SPEAKER;
                P2=0;
        P0=LED[DisplayBuffer[DisplayNo]];
                P2=1<<DisplayNo;
                if(++DisplayNo==8)
                        DisplayNo=0;
Proteus圖
Proteus圖
主站蜘蛛池模板: 一级免费看 | 亚洲乱码国产乱码精品精软件 | 91看片在线| 一级片在线免费观看 | 欧美不卡在线 | 成人羞羞国产免费游戏 | xxxx黄色| 国产精品伦子伦免费视频 | 欧美日韩国产片 | 欧美亚洲激情 | 国产91精品在线观看 | 午夜视频一区 | 福利网站在线观看 | 亚洲国产欧美日韩在线 | 国产高清一区二区 | 亚洲自拍偷拍视频 | 黄色三级av | 欧美日韩亚洲一区二区 | 国产欧美日韩在线 | 亚洲一区免费视频 | 69人人| 国产伊人网 | 国产一区二区欧美 | 黄色一区二区三区 | 波多野结衣亚洲一区 | 99精品成人 | 911看片| 精品成人在线 | 日韩精品一区二区三区四区 | 日日夜夜天天操 | 国产福利一区二区 | 亚洲综合二区 | 国产视频成人 | 免费a在线观看 | 在线播放av网站 | 亚洲精品久久久久avwww潮水 | 午夜精品视频在线 | 国产成人精品视频 | 日韩午夜av | 欧美日韩亚洲国产 | 免费高清av |
