查看: 2229|回復: 7
stc8g1k08a單片機改造方波逆變器
ID:675799 發表于 2024-2-1 16:39 | 顯示全部樓層 |閱讀模式
#include        "STC8.H"  //  用于普通方波 逆變器的改造, 就只要把 原來輸出的TL494的,8,11的腳調起來,分別接入 P33 P55
typedef unsigned int          u16; //45HZ  @30.000MHz
  u16   tt; //1111點計算,為1個周期 22.22ms, ;即是每點20us
typedef unsigned char          u8;
  u16 dg,df;
u16 a;b;c;d;e;f;g;h;
u8  overA;
         void Timer0_Isr(void) interrupt 1
                   if(df<=19) //軟啟信號對,df==19退出軟啟動。
                         dg=190-df*10;
                                          if(tt==1111)
                                        df++;
                                           if(dg<=10)
                                          dg=0;
                 e=45+dg                 ;
              f=510-dg;
                  g=600+dg  ;
             h=1067-dg ;
                 a=e;
                 b=f;
                 c=g;
                 d=h;
                           if(P30==1&&df>18) //電壓過高,比如。>245v
                  {  if(tt==1111)
                  df--;        //電壓下降3---6V
           if(tt==0||(tt>=(a-41)&&tt<=(a-38))||(tt>=(a-33)&&tt<=(a-31))||(tt>=(a-25)&&tt<=(a-24))||(tt>=(a-18)&&tt<=(a-17))||tt==a-10||tt==a-3   )
                   {        P33=0;
                                    // // |0,4-7,12-14,20-21,27-28,35,42
                         P55=0;
if(tt==b+4||tt==b+11||(tt>=(b+18)&&tt<=(b+19))||(tt>=(b+2)&&tt<=(b+26))||(tt>=(b+32)&&tt<=(b+34))||(tt>=(b+39)&&tt<=(b+42)))         //
                   {        P33=0;
                                    //514,521,528-529,535-536,542-544,549-552
                         P55=0;
                                   if( tt==556||(tt>=(c-40)&&tt<=(c-37))||(tt>=(c-32)&&tt<=(c-30)) ||(tt>=(c-24)&&tt<=(c-23))||(tt>=(c-17)&&tt<=(c-16))||tt==c-9||tt==c-2  )
                   {        P33=0;
                         P55=0;         //556 ,560-563,568-570,576-577,583-584,591,598
                           if(tt==d+3||tt==d+10||(tt>=(d+17)&&tt<=(d+18))||(tt>=(d+24)&&tt<=(d+25))||(tt>=(d+31)&&tt<=(d+33))||(tt>=(d+38)&&tt<=(d+41)) )        //
                   {        P33=0;
                                    //1070,1077,1084-1085,1091-1092,1098-1100,1105-1108
                         P55=0;
                        if( (tt>=(a-44)&&tt<=(a-42))||(tt>=(a-37)&&tt<=(a-34))||(tt>=(a-30)&&tt<=(a-26))||(tt>=(a-23)&&tt<=(a-19))||(tt>=(a-16)&&tt<=(a-11))||(tt>=(a-9)&&tt<=(a-4)||(tt>=(a-2)&&tt<=(a-1)))           ////////////////////////////////////////////////////
)        //正半波前斜坡幾個脈沖(1-3,8-11,15-19,22-26,29-34,36-41,43-44)
                P33=0;
                  P55=1;
         if(tt>=a&&tt<=b)                                           //中間為220V         45--600
                 {        P33=0;
                         P55=1;
          if((tt>=(b+1)&&tt<=(b+3))||(tt>=(b+5)&&tt<=(b+10))||(tt>=(b+12)&&tt<=(b+17))||(tt>=(b+20)&&tt<=(b+24))||(tt>=(b+27)&&tt<=(b+31))||(tt>=(b+35)&&tt<=(b+38))||(tt>=(b+43)&&tt<=(b+45)))        //正半后斜坡
           {        P33=0;
                                    //511-513,515-520,522-527,530-534,537-541,545-548,553-555
                  P55=1;
           if(  (tt>=(c-43)&&tt<=(c-41)) ||(tt>=(c-36)&&tt<=(c-33))||(tt>=(c-29)&&tt<=(c-25))||(tt>=(c-22)&&tt<=(c-18))||(tt>=(c-15)&&tt<=(c-10))||(tt>=(c-8)&&tt<=(c-3))||(tt>=(c-1)&&tt<=(c-0))        )         //負半波前斜坡
                   {        P33=1;
                                    //557-559,564-567,571-575,578-582,,585-590,592-597,599-600
                P55= 0;
                 if(tt>=c&&tt<=d)         //中間為220V           600-1067
                 {        P33=1;
                         P55=0;
if( (tt>=(d+1)&&tt<=(d+2))||(tt>=(d+4)&&tt<=(d+9))||(tt>=(d+11)&&tt<=(d+16))||(tt>=(d+19)&&tt<=(d+23))||(tt>=(d+26)&&tt<=(d+30))||(tt>=(d+34)&&tt<=(d+37))||(tt>=(d+42)&&tt<=(d+44)) )//負半后斜坡
         {        P33=1;
                                    //1068-1069,1071-1076,1078-1083,1086-1090,1093-1097,1101-1104,1109-1111
                   P55= 0;
                tt++;
           if(tt==1111) //一個周期完成
                     tt=0;
void Timer0_Init(void)                //20微秒@30.000MHz
        AUXR &= 0x7F;                        //定時器時鐘12T模式
        TMOD &= 0xF0;                        //設置定時器模式
        TMOD |= 0x02;                        //設置定時器模式
        TL0 = 0xCE;                                //設置定時初始值
        TH0 = 0xCE;                                //設置定時重載值
        TF0 = 0;                                //清除TF0標志
        TR0 = 1;                                //定時器0開始計時
        ET0 = 1;                                //使能定時器0中斷
void Delay200ms()                //@30.000MHz
        unsigned char data i, j, k;
        i = 23;
        j = 205;
        k = 120;
        i = 23;
        j = 205;
        k = 120;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void main(void)
{         overA=0;
     P3M0 = (P3M0 & ~0x01) | 0x08; P3M1 = (P3M1 & ~0x08) | 0x01;         //p3.3 推挽輸出
                                           // p3.0 高阻輸入         如果,電壓過高240 則,P30=1;
         //      P3M0 = 0x00; P3M1 = 0x00;  //  準雙向口
          //   P5M0 &= ~0x30; P5M1 &= ~0x30;  //P54, P55,   準雙向口
        //  p3.1 準雙向口, p3.3  p3.0
            //  P5M0 |= 0x30; P5M1 &= ~0x30;   //P54, P55,         推挽輸出
//  P5M0 = (P5M0 & ~0x10) | 0x20; P5M1 &= ~0x30;  // P55推挽輸出,P54準雙向口 用于過流
   P5M0 = (P5M0 & ~0x10) | 0x20; P5M1 = (P5M1 & ~0x20) | 0x10; // P55推挽輸出,P54高阻輸入
                     for(a=0;a<10;a++)
                  {  Delay200ms()        ;         }         //2秒后開始逆變輸出
                        dg=0;
                        df=0;
                        P31=0;
                          P30=0;
                        P33=0;
                          P55=0;
                         tt=0;
         Timer0_Init();
     EA = 1;                //允許全局中斷
  while (1)
           if( P54==1)    //過流關閉中斷。
          {    EA = 0;           //        關定時。
                              ET0 = 0;
                       P33=0;
                         P55=0;
                             tt=0;
                                dg=0;
                            df=0;
                       Delay200ms()        ;
                      Delay200ms()        ;
                             P54=0;
                        if(        ( overA+1)%2==0)  //第二次過流 ,或者 奇數次 過流,為負半波的 tt計數。
                            tt=555        ;  //tt 負半波開始
                          Timer0_Init();        //
                              EA = 1;
                   if(        overA>= 254)  //過流超過254次 ,22ms*250=5.5秒,就不再重新啟動,人工重啟
                {                   //        關定時。
               //        關定時。                 ET0 = 0;
                  //        關定時。                EA = 0;
                 PCON |=0x02 ;//停機模式
                        overA++;
//                  //軟啟動后, 判斷是否電池電壓小于設定值,比如9.5v
        /*        if(P30==1)        //P30 兩個用途,235v 過壓, 和12V電池電壓過低。
                               if(tt==1100)
                              { if(df>=19)
                                      df++; }        //22ms計數增加
                               if(df==700)         //22ms*700=15.4s,連續15.4秒是低電壓,就關閉逆變輸出
                                  EA = 0;           //        關定時。
                                      ET0 = 0;
                            P33=0;
                             P55=0;
                                 tt=0;
                                 dg=0;
                                df=0;
                                        PCON |=0x02 ;//停機模式
                }//        .0
                         df=20; //如果是瞬間 電壓下降,就重新從20計數
                                                //df=20是之前,軟啟動結束值
ID:675799 發表于 2024-2-2 08:47 | 顯示全部樓層
用在 最大500w ,實際300w.的方波逆變器, 可以啟動 電機 ,風扇,沒有明顯大的噪音。
ID:675799 發表于 2024-2-2 08:49 | 顯示全部樓層
可以 驅動 電機,等,沒有明顯噪音。
ID:68189 發表于 2024-2-2 10:00 | 顯示全部樓層
沒有電路原理圖,表示不太懂,只說了P33 P35如何接替原電路TL494,沒有說明P30 P31 P54  P55是何作用,代碼中卻使用了。
ID:1064915 發表于 2024-2-2 11:10 | 顯示全部樓層
改造原理沒有依據
ID:675799 發表于 2024-2-2 11:42 | 顯示全部樓層
電路圖。
ID:675799 發表于 2024-2-2 13:43 | 顯示全部樓層
wpppmlah 發表于 2024-2-2 10:00
沒有電路原理圖,表示不太懂,只說了P33 P35如何接替原電路TL494,沒有說明P30 P31 P54  P55是何作用,代碼 ...
打錯 P35 應該P55, ,p54穩壓用的, 發現方波逆變有了。如果要接。要加三極管。
ID:136083 發表于 2024-11-30 11:05 | 顯示全部樓層
哈哈哈,這個研究非常不錯。看到這個紅色的板子好有感覺。
主站蜘蛛池模板: 成人黄色大片 | 国产一级视频在线观看 | a视频在线观看 | a级片免费在线观看 | 黄色大片免费观看 | 经典三级第一页 | 欧美激情小视频 | 久久这里只有精品6 | 国产深夜福利 | 国产欧美一区二区精品忘忧草 | 日本少妇久久 | 日韩欧美中文在线 | 国产精品美女久久久久久久久 | 日韩国产精品一区二区 | 国产亚洲一区二区三区 | 亚洲资源在线观看 | 日韩精品一区二区在线 | 国产精品免费一区 | 伊人激情网 | 在线看片a| 午夜免费福利视频 | 日本一级一片免费视频 | 99re在线观看视频 | 国产成人精品一区二区 | 欧美激情一区 | 视频一区二区在线 | 国产亚洲欧美日韩高清 | 色哟哟一区二区三区 | www.日韩在线| 中国女人真人一级毛片 | 影音先锋中文字幕在线 | 岛国av免费观看 | 日韩精品在线免费观看 | 91久久久久久久久 | 国产成人精品久久久 | 亚洲性生活片 | 午夜免费毛片 | 欧美日本在线观看 | 免费在线成人网 | 国产精品视频免费在线观看 | 欧美精品亚洲 |
