查看: 2774|回復(fù): 15
大佬們看看,ds18b20單片機(jī)讀出來(lái)溫度總是55.9不變
這是ds18b20.c的:
#include "ds18b20.h"
#include "reg52.h"
sbit DQ=P1^4;
void Delay_OneWire(unsigned int t)
        unsigned char i;
        while(t--){
                for(i=0;i<12;i++);
void Write_DS18B20(unsigned char dat)
        unsigned char i;
        for(i=0;i<8;i++)
                DQ = 0;
                DQ = dat&0x01;
                Delay_OneWire(5);
                DQ = 1;
                dat >>= 1;
        Delay_OneWire(5);
unsigned char Read_DS18B20(void)
        unsigned char i;
        unsigned char dat;
        for(i=0;i<8;i++)
                DQ = 0;
                dat >>= 1;
                DQ = 1;
                if(DQ)
                        dat |= 0x80;
                Delay_OneWire(5);
        return dat;
unsigned char init_ds18b20(void)
          unsigned char initflag = 0;
          DQ = 1;
          Delay_OneWire(12);
          DQ = 0;
          Delay_OneWire(80);
          DQ = 1;
          Delay_OneWire(10);
    initflag = DQ;
          Delay_OneWire(5);
          return initflag;
float read_ds18b20_temp()
        unsigned char ls;
        unsigned int hs;
        init_ds18b20();
        Write_DS18B20(0xcc);
        Write_DS18B20(0x44);
        Delay_OneWire(1000);
        init_ds18b20();
        Write_DS18B20(0xbe);
        ls=Read_DS18B20();
        hs=Read_DS18B20();
  return ((hs<<8)|ls)/16.0;
這是主程序:
#include "reg52.h"
unsigned char smgdata[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf,0x8c};
float temp;
void selecthc573(unsigned char a)
        switch(a)
                case 4: P2=(P2&0x1f)|0x80;break;
                case 5: P2=(P2&0x1f)|0xa0;break;
                case 6: P2=(P2&0x1f)|0xc0;break;
                case 7: P2=(P2&0x1f)|0xe0;break;
void seg_dy(unsigned char wei,duan,point)
        P0=0xff;
        if(point)
                selecthc573(7);
                P0=duan&0x7f;
                P2&=0x1f;
                selecthc573(7);
                P0=duan;
                P2&=0x1f;
        selecthc573(6);
        P0=0x01<<wei;
        P2&=0x1f;
void delay(int s)
        while(s--);
void segdisplay()
        temp=read_ds18b20_temp();
        seg_dy(0,smgdata[((unsigned char)temp/10%10)],0);
        delay(600);
        seg_dy(1,smgdata[((unsigned char)temp%10)],1);
        delay(600);
        seg_dy(2,smgdata[((unsigned int)(temp*10)%10)],0);
        delay(600);
int main()
                segdisplay();
ID:1109793 發(fā)表于 2024-2-6 09:53 | 只看該作者
10多年前研究過(guò),記得時(shí)序要求比較嚴(yán)格。還有加上拉
ID:1058641 發(fā)表于 2024-2-6 12:47 | 只看該作者
xiaobendan001 發(fā)表于 2024-2-6 09:53
我感覺(jué)這也沒(méi)問(wèn)題啊
ID:1058641 發(fā)表于 2024-2-6 14:50 | 只看該作者
有人知道嗎
ID:213173 發(fā)表于 2024-2-6 15:07 | 只看該作者
rtyweq 發(fā)表于 2024-2-6 12:47
ds18b20對(duì)時(shí)序要求很高,數(shù)碼管動(dòng)態(tài)顯示也要求穩(wěn)定掃描,你不掌握兩者時(shí)間的有序協(xié)調(diào),很難成功。
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. sbit DQ=P1^4;
  4. unsigned char code smgdata[]={
  5. 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,
  6. 0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf,0x8c};
  7. unsigned char  data dis_buf[8];
  8. unsigned int temp;
  9. bit flag;
  10. void delay(unsigned int n)
  11. {
  12.         while(n--);
  13. }
  14. unsigned char init_ds18b20()
  15. {
  16.         unsigned char x=0;
  17.         DQ = 1;
  18.         delay(8);
  19.         DQ=0;
  20.         delay(80);
  21.         DQ=1;
  22.         delay(10);
  23.         x=DQ;
  24.         delay(20);
  25.         return x;
  26. }
  27. void Write_DS18B20(unsigned char dat)
  28. {
  29.         unsigned char i;
  30.         for(i=8;i>0;i--)
  31.         {
  32.                 DQ=0;
  33.                 DQ=dat&0x01;
  34.                 delay(5);
  35.                 DQ=1;
  36.                 dat>>=1;
  37.         }
  38.         delay(4);
  39. }
  40. unsigned char Read_DS18B20()
  41. {
  42.         unsigned char i,dat;
  43.         for(i=8;i>0;i--)
  44.         {
  45.                 DQ=0;
  46.                 dat>>=1;
  47.                 DQ=1;
  48.                 if(DQ)
  49.                 dat|=0x80;
  50.                 delay(4);
  51.         }
  52.         return (dat);
  53. }
  54. void read_ds18b20_temp()
  55. {
  56.         static unsigned char ls,hs,i;
  57.         switch(i)
  58.         {
  59.                 case  0: init_ds18b20();        break;
  60.                 case  1: Write_DS18B20(0xcc);   break;
  61.                 case  2: Write_DS18B20(0x44);   break;
  62.                 case 94: init_ds18b20();        break;
  63.                 case 95: Write_DS18B20(0xcc);   break;
  64.                 case 96: Write_DS18B20(0xbe);   break;
  65.                 case 97: ls=Read_DS18B20();     break;
  66.                 case 98: hs=Read_DS18B20();     break;
  67.                 case 99: temp=((hs<<8)|ls)/1.6; break;//保留1位小數(shù)
  68.         }
  69.         i=++i%100;
  70. }
  71. void Timer0_Init(void)                //2毫秒@11.0592MHz
  72. {
  73.         TMOD |= 0x01;                        //設(shè)置定時(shí)器模式
  74.         TL0 = 0xCD;                                //設(shè)置定時(shí)初始值
  75.         TH0 = 0xF8;                                //設(shè)置定時(shí)初始值
  76.         TF0 = 0;                                //清除TF0標(biāo)志
  77.         TR0 = 1;                                //定時(shí)器0開(kāi)始計(jì)時(shí)
  78.         ET0 = 1;                                //使能定時(shí)器0中斷
  79.         EA  = 1;
  80. }
  81. void main()
  82. {
  83.         unsigned char i,j;
  84.         Timer0_Init();
  85.         while (1)
  86.         {
  87.                 if(flag)
  88.                 {
  89.                         flag=0;
  90.                         P0=0xff;       P2=0xe0; P2=0x00;//段消影
  91.                         P0=0x01<<i;    P2=0xd0; P2=0x00;//傳位碼
  92.                         P0=dis_buf[i]; P2=0xe0; P2=0x00;//傳段碼
  93.                         i=++i%4;
  94.                         read_ds18b20_temp();
  95.                         switch(j)
  96.                         {
  97.                                 case 0: dis_buf[0]=smgdata[temp/1000%10]; break;
  98.                                 case 1: dis_buf[1]=smgdata[temp/100%10]; break;
  99.                                 case 2: dis_buf[2]=smgdata[temp/10%10]&0x7f; break;//加小數(shù)點(diǎn)
  100.                                 case 3: dis_buf[3]=smgdata[temp%10]; break;
  101.                         }
  102.                         j=++j%4;
  103.                 }
  104.         }
  105. }
  106. void Timer0_Isr(void) interrupt 1
  107. {
  108.         TL0 = 0xCD;                                //設(shè)置定時(shí)初始值
  109.         TH0 = 0xF8;                                //設(shè)置定時(shí)初始值
  110.         flag=1;
  111. }
ID:1109793 發(fā)表于 2024-2-6 19:04 | 只看該作者
wulin 發(fā)表于 2024-2-6 15:07
真不錯(cuò),學(xué)習(xí)了
ID:1058641 發(fā)表于 2024-2-6 21:29 | 只看該作者
就是對(duì)這里不明白,做這個(gè)延時(shí)就很煩
ID:161164 發(fā)表于 2024-2-6 21:37 | 只看該作者
Delay_OneWire這函數(shù)有問(wèn)題
在11.0592Mhz之下
Delay_OneWire(5)=766us
Delay_OneWire(12)=1814us
Delay_OneWire(80)=1200us
ID:1058641 發(fā)表于 2024-2-6 21:40 | 只看該作者
lkc8210 發(fā)表于 2024-2-6 21:37
在11.0592Mhz之下
是把for循環(huán)去掉嗎?
ID:1058641 發(fā)表于 2024-2-6 22:26 | 只看該作者
在11.0592Mhz之下
好像是多了這個(gè),仿真不是12Mhz。但是為什么那個(gè)顯示出來(lái)的溫度要跳成別的溫度?
ID:161164 發(fā)表于 2024-2-7 09:10 | 只看該作者
本帖最后由 lkc8210 于 2024-2-7 11:09 編輯
rtyweq 發(fā)表于 2024-2-6 22:26
時(shí)序不對(duì)就會(huì)出現(xiàn)莫名奇妙的情況
正好你用的是仿真
可以加個(gè)虛擬邏輯分析儀來(lái)看看信號(hào)電平變化時(shí)序
ID:213173 發(fā)表于 2024-2-7 10:20 | 只看該作者
rtyweq 發(fā)表于 2024-2-6 21:29
軟件都是基于硬件條件編寫的。給你改的代碼是基于你以前的帖子用的藍(lán)橋杯CT107D電路。小延時(shí)可以用阻塞型沒(méi)有問(wèn)題,超過(guò)1ms延時(shí)不宜用阻塞型,要用定時(shí)器。否則無(wú)法滿足各個(gè)子函數(shù)對(duì)時(shí)序的要求。上述程序主函數(shù)有效運(yùn)行周期2ms。也就是數(shù)碼管每2ms顯示1位。8ms完成一輪掃描。讀取溫度DS18B20函數(shù)需要在主函數(shù)中運(yùn)行100次才能完成,實(shí)際有效運(yùn)行只有9次,其它時(shí)間都是在等待確保轉(zhuǎn)換成功。讀/寫DS18B20函數(shù)中的小延時(shí)都是us級(jí)的不會(huì)影響數(shù)碼管動(dòng)態(tài)掃描。
ID:1058641 發(fā)表于 2024-2-7 15:08 | 只看該作者
wulin 發(fā)表于 2024-2-7 10:20
軟件都是基于硬件條件編寫的。給你改的代碼是基于你以前的帖子用的藍(lán)橋杯CT107D電路。小延時(shí)可以用阻塞型 ...
學(xué)到了學(xué)到了
ID:492633 發(fā)表于 2024-11-17 20:49 | 只看該作者
要是測(cè)負(fù)溫度怎么改
ID:1128354 發(fā)表于 2024-11-18 10:03 | 只看該作者
Delay_OneWire這函數(shù)有問(wèn)題好像
ID:1133081 發(fā)表于 2024-11-18 10:22 | 只看該作者
3wjkdhus 發(fā)表于 2024-11-17 20:49
要是測(cè)負(fù)溫度怎么改
讀取到的ds18b20數(shù)據(jù)是16位2進(jìn)制數(shù)。高5位為符號(hào)位,中8位為整數(shù)位,低4位為小數(shù)位。只要識(shí)別到高5位任意一位為1即可判定是負(fù)溫度值。
主站蜘蛛池模板: 日韩www | 亚洲国产网站 | 天堂资源中文在线 | 黄色一级片黄色一级片 | 日韩精品一区二区在线 | 性大毛片视频 | 国产视频成人 | 日韩欧美高清 | aaa级片| 日韩一级在线观看 | 日韩在线视频观看 | 欧美xx孕妇 | 成人性生活片 | www.青青草| 日韩午夜影院 | 久久精品久久久精品美女 | 成人羞羞国产免费游戏 | 天天色影院 | 亚洲天堂一区二区三区 | 自拍偷拍欧美日韩 | 91性高潮久久久久久久久 | 免费网站观看www在线观看 | 欧美日韩国产在线 | 婷婷免费视频 | 亚洲色网址 | 在线免费毛片 | 在线视频a| 黄色片视频网站 | 91亚洲一区 | 国产女人18毛片18精品 | 麻豆精品一区二区 | 国产黄视频在线观看 | 亚洲天堂视频在线 | 超碰免费在线 | 国产精品成人一区二区三区 | 日韩免费观看视频 | 亚洲激情视频 | 国产三级在线免费观看 | 国产一区精品视频 | 久久久久久久91 | 中文字幕无人区二 |
