查看: 1180|回復(fù): 1
STM8單片機(jī)想用按鍵來控制PWM輸出頻率,現(xiàn)在寫好后發(fā)現(xiàn)按鍵無反應(yīng),求大佬
ID:792289 發(fā)表于 2024-2-18 13:58 | 顯示全部樓層 |閱讀模式
#include "STM8S.h"
unsigned char  a=20;
signed long int  pwm_duty;
void delay_ms (int ms) //延時函數(shù)
for (int i=0; i<=ms; i++)
for (int j=0; j<120; j++); // Nop = Fosc/4
void KEY(void)
GPIO_DeInit(GPIOC);//D口默認(rèn)狀態(tài)
GPIO_Init(GPIOC, GPIO_PIN_5, GPIO_MODE_IN_FL_NO_IT);
GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT);
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0)        //加1按鍵有效
            delay_ms(20);
            //延時去抖 一般10-20ms
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0);
                if (a < 41)
                  a = a+1;
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)        //減1按鍵有效
            delay_ms(20);
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)
                if (a > 1)
                 a =a-1;
void PWM(void)
pwm_duty=2000000/a/30;
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//  有些硬件會自動八分頻 導(dǎo)致后面的計算出現(xiàn)錯誤
CLK_HSICmd(ENABLE);    //打開內(nèi)部的時鐘函數(shù)
TIM2_DeInit(); //TIM2回復(fù)默認(rèn)
GPIO_Init(GPIOD,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_FAST);//設(shè)置 Timer2 D4口輸出PWM模式
TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,pwm_duty/2,TIM2_OCPOLARITY_HIGH);
TIM2_TimeBaseInit(TIM2_PRESCALER_8,pwm_duty);//16M晶振
TIM2_OC2PreloadConfig(ENABLE);
TIM2_Cmd(ENABLE);//啟用Timer2定時器
void main(void)
  PWM();
  KEY();
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
代碼如上,百思不得其解!求大佬幫忙看看
ID:69038 發(fā)表于 2024-2-20 12:02 | 顯示全部樓層
流程不對,你按對鍵后a值沒有反饋到PWM控制中去,a值變了還要pwm_duty才行。
好比你要請客,飯菜在灶臺,老是不端上桌子,客人能吃到熱乎的嗎?
主站蜘蛛池模板: 国产网友自拍 | 亚洲精品99 | 91久久久久久久 | 天天干夜夜拍 | 欧美伊人久久 | 精品一区在线 | 精品理论片 | 五月婷婷激情 | 久久久久久伊人 | 国产精品一区av | 亚洲欧美日韩国产精品 | www一区| 黄色一及片 | 国产一级一片免费播放放a 免费国产视频 | 欧美激情久久久 | 日韩欧美国产高清91 | 成人激情综合 | 免费一级大片 | 欧美中文字幕在线观看 | 亚洲免费视频网站 | 国产不卡在线观看 | 日韩精品极品视频在线观看免费 | 欧美一级做性受免费大片免费 | 国产aⅴ爽av久久久久成人 | 色播五月婷婷 | 亚洲激情综合 | 香蕉视频一区二区 | 亚洲欧美日韩综合 | 国内福利视频 | 99re在线观看视频 | 天天干天天草 | 中文字幕网站 | 欧美片网站yy | 日韩欧美小视频 | 亚洲精品国产精品乱码不卡 | 伊人久久网站 | 日本福利在线 | 亚洲一区二区中文字幕 | 91在线观看免费视频 | 久久伊人网站 | 欧美不卡一区二区三区 |
