查看: 2704|回復: 32
大佬們,為什么我這單片機數碼管會亂閃呢?
ID:1058641 發表于 2024-2-23 20:50 | 顯示全部樓層 |閱讀模式
  1. #include "reg52.h"
  2. #include "seg.h"
  3. #include "iic.h"
  4. #include "onewire.h"
  5. #include "key.h"
  6. #include "led.h"
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9.
  10. //led
  11. uchar led_buf[]={0,0,0,0,0,0,0,0};
  12. //°´¼ü
  13. uchar key_sld;
  14. //ÊýÂë¹Ü
  15. uint seg_sld;
  16. uchar seg_pos;
  17. uchar seg_buf[]={10,10,10,10,10,10,10,10};
  18. uchar seg_point[]={0,0,0,0,0,0,0,0};
  19. //½çÃæ
  20. uchar show_mo=0;
  21. bit mode=0;
  22. uint temp;
  23. uchar set_temp=25;
  24. uint out_v;
  25. //º¯Êý
  26. void smg_reset()
  27. {
  28.         uchar i;
  29.         for(i=0;i<8;i++)
  30.         {
  31.                 seg_buf[i]=10;
  32.                 seg_point[i]=0;
  33.         }
  34. }
  35. void init()
  36. {
  37.         P0=0x00;
  38.         P2=P2&0x1f|0xa0;
  39.         P2&=0x1f;
  40.
  41.         P0=0xff;
  42.         P2=P2&0x1f|0x80;
  43.         P2&=0x1f;
  44. }
  45. void key_proc()
  46. {
  47.         static uchar key_val,key_old,key_down,key_up;
  48.         if(key_sld)
  49.                 return;
  50.         key_sld=1;
  51.
  52.         key_val=readkey();
  53.         key_down=key_val&(key_val^key_old);
  54.         key_up=~key_val&(key_val^key_old);
  55.         key_old=key_val;
  56.
  57.         if(key_down==4)
  58.                 show_mo=(++show_mo)%3;
  59.         else if(show_mo==1 && key_down==6)
  60.                 set_temp=(++set_temp>99)?99:set_temp;
  61.         else if(show_mo==1 && key_down==7)
  62.                 set_temp=(--set_temp==0)?0:set_temp;
  63.         else if(key_down==5)
  64.                 mode=~mode;
  65.
  66. }
  67. void seg_proc()
  68. {
  69.         uint temp_temp;
  70.         if(seg_sld)
  71.                 return;
  72.         seg_sld=1;
  73.         temp_temp=(uint)ds18b20_read();
  74.         temp=temp_temp;
  75.
  76.         switch(show_mo)
  77.         {
  78.                 case 0:
  79.                         smg_reset();
  80.                         seg_buf[0]=11;//c
  81.                         seg_buf[4]=temp/1000;
  82.                         seg_buf[5]=temp/100%10;
  83.                         seg_buf[6]=temp/10%10;
  84.                         seg_buf[7]=temp%10;
  85.                         seg_point[5]=1;
  86.                  break;
  87.
  88.                 case 1:
  89.                         smg_reset();
  90.                         seg_buf[0]=12;//p
  91.                         seg_buf[6]=set_temp/10;
  92.                         seg_buf[7]=set_temp%10;
  93.                  break;
  94.
  95.                 case 2:
  96.                         smg_reset();
  97.                         seg_buf[0]=13;//a
  98.                         if(mode)
  99.                         {
  100.                                 if(temp_temp>set_temp)
  101.                                         out_v=500;
  102.                                 else
  103.                                         out_v=0;
  104.                                 seg_buf[5]=out_v/100;
  105.                                 seg_buf[6]=out_v/10%10;
  106.                                 seg_buf[7]=out_v%10;
  107.                                 seg_point[5]=1;
  108.                                 da_write(out_v*16);
  109.                         }
  110.                         else
  111.                         {
  112.                                 if(temp_temp<=20)
  113.                                         out_v=1;
  114.                                 else if(temp_temp>=40)
  115.                                         out_v=4;
  116.                                 else
  117.                                         out_v=temp_temp*3/20;
  118.                                 seg_buf[5]=out_v/100;
  119.                                 seg_buf[6]=out_v/10%10;
  120.                                 seg_buf[7]=out_v%10;
  121.                                 seg_point[5]=1;
  122.                                 da_write(out_v*16);
  123.                         }
  124.                         break;
  125.         }
  126. }
  127. void led_proc()
  128. {
  129.         led_buf[0]=(mode==0);
  130.         led_buf[1]=(show_mo==0);
  131.         led_buf[2]=(show_mo==1);
  132.         led_buf[3]=(show_mo==2);
  133. }
  134. void Timer0Init(void)                //1??@12.000MHz
  135. {
  136.         TMOD &= 0xF0;                //???????
  137.         TL0 = 0x18;                //??????
  138.         TH0 = 0xFC;                //??????
  139.         TF0 = 0;                //??TF0??
  140.         TR0 = 1;                //???0????
  141.         ET0 = 1;
  142.         EA =1;
  143. }
  144. void timer() interrupt 1
  145. {
  146.         if(++key_sld==10)
  147.                 key_sld=0;
  148.         if(++seg_sld==1000)
  149.                 seg_sld=0;
  150.         if(++seg_pos==8)
  151.                 seg_pos=0;
  152.
  153.         segdis(seg_buf[seg_pos],seg_pos,seg_point[seg_pos]);
  154.         led_disp(seg_pos,led_buf[seg_pos]);
  155. }
  156. void main()
  157. {
  158.         Timer0Init();
  159.         init();
  160.         while(1)
  161.         {
  162.                 key_proc();
  163.                 seg_proc();
  164.                 led_proc();
  165.         }
  166. }
ID:1058641 發表于 2024-2-23 21:12 | 顯示全部樓層
就是這種
ID:123289 發表于 2024-2-24 09:53 | 顯示全部樓層
掃描方案不合理。
ID:123289 發表于 2024-2-24 09:57 | 顯示全部樓層
掃屏顯示的切換應當用最少的指令完成,在不多于8個LED的情況下:三條指令即可完成,對于STC的單片機,10us不到就完成了,例:8個LED哪個亮(位選)受P1控制,顯示什么內容(段碼)由P0決定。
要點:技巧如下!!
先將哪個LED需要亮的參數事先準備好,放在:P1_OUT變量中,同樣將這個LED需要顯示的段碼放在P0_OUT中!具@個做法最關鍵,不要直接切換操作P0、P1口,而是通過這兩個變量來操作。原因是,無論你用多長時間對P1_OUT、P0_OUT進行操作,操作期間,顯示不受影響!
切換:
第一條指令:關斷所有顯示:P1=FFH              ;關閉所有顯示
第二條指令:切換LED段碼:P0=P0_OUT         ;這時顯示已關,切換不會有殘留,重影,閃爍了。
第三條指令:更新顯示的LED管:P1=P1_OUT  ;點亮需要顯示的LED,例如:11101111B
【這個做法是最優秀的掃描顯示切換方法,用時最短,最合理,沒有之二。!】
重復一下關鍵點:事先處理準備好變量P1_OUT、P0_OUT的值。
以上供參考,請根據你的接口來操作,這里的P0、P1不一定與你的圖相同。
ID:1110945 發表于 2024-2-24 10:18 | 顯示全部樓層
8個數碼管實際就是64個發光二極管,可是控制它的引線只有16根。
實際上同一時間只能顯示其中的一個數碼管,8個數碼管分時輪流顯
示,只要切換的時間足夠快,人眼就能感覺到8個數碼管在同時顯示
數字了。數碼管有段碼表,還有共陰或共陽的區別。其中任何一個環
節出錯了那么顯示的數字就是亂的。
ID:1109793 發表于 2024-2-24 12:28 | 顯示全部樓層
電路好復雜,這是買的誰家的實驗板嗎?看代碼挺費勁,也沒有注釋,好像沒看到驅動代碼,只是在計算一些BCD碼。先不要計算,只給緩沖區里面固定的數據看,如果還是閃,就是驅動部分了
ID:1058641 發表于 2024-2-24 14:47 | 顯示全部樓層
yzwzfyz 發表于 2024-2-24 09:57
掃屏顯示的切換應當用最少的指令完成,在不多于8個LED的情況下:三條指令即可完成,對于STC的單片機,10us ...
不太明白
ID:1109793 發表于 2024-2-24 16:27 | 顯示全部樓層
閃爍是怎樣的也看不到。代碼也不全。
ID:213173 發表于 2024-2-24 17:30 | 顯示全部樓層
樓主搞了這么長時間數碼管還搞不定,情何以堪。前面的帖子給你的示例認真看了嗎?這是壇友畫的仿真圖,寫個時鐘程序給你試試。
無標題.jpg 仿真.rar (46.5 KB, 下載次數: 1)
  2. #include "intrins.h"
  3. sbit key1=P3^0;
  4. sbit key2=P3^1;
  5. sbit key3=P3^2;
  6. sbit GND =P3^7;
  7. unsigned char code smgdata[]={
  8. 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,
  9. 0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf,0x8c};
  10. unsigned char  data dis_buf[8];
  11. unsigned int temp,Cnt2ms;
  12. char H=12,M=30,S=0;//時分秒
  13. unsigned char KeySec;//鍵值
  14. bit flag;//中斷標志
  15. bit flicker;//閃爍標志
  16. void keyscan()
  17. {
  18.         static char time=0;
  19.         static bit sign=0;
  20.         if(!key1||!key2||!key3)
  21.         {
  22.                 if(++time>=20 && sign==0)//短按消抖
  23.                 {
  24.                         sign=1;
  25.                         if(!key1)KeySec=++KeySec%4;
  26.                         if(!key2 && KeySec!=0)
  27.                         {
  28.                                 switch(KeySec)
  29.                                 {
  30.                                         case 1: if(++H>23)H=0; break;
  31.                                         case 2: if(++M>59)M=0; break;
  32.                                         case 3: if(++S>59)S=0; break;
  33.                                 }
  34.                         }
  35.                         if(!key3 && KeySec!=0)
  36.                         {
  37.                                 switch(KeySec)
  38.                                 {
  39.                                         case 1: if(--H<0)H=23; break;
  40.                                         case 2: if(--M<0)M=59; break;
  41.                                         case 3: if(--S<0)S=59; break;
  42.                                 }
  43.                         }
  44.                         Cnt2ms=0;
  45.                 }
  46.         }
  47.         else {time=0;sign=0;}
  48. }
  49. void Timer0_Init(void)                //2毫秒@11.0592MHz
  50. {
  51.         TMOD |= 0x01;                        //設置定時器模式
  52.         TL0 = 0xCD;                                //設置定時初始值
  53.         TH0 = 0xF8;                                //設置定時初始值
  54.         TF0 = 0;                                //清除TF0標志
  55.         TR0 = 1;                                //定時器0開始計時
  56.         ET0 = 1;                                //使能定時器0中斷
  57.         EA  = 1;
  58. }
  59. void main()
  60. {
  61.         unsigned char i,j;
  62.         GND=0;//模擬地
  63.         Timer0_Init();
  64.         while (1)
  65.         {
  66.                 if(flag)
  67.                 {
  68.                         flag=0;
  69.                         P0=0xff;       P2=0xe0; P2=0x00;//段消影
  70.                         P0=0x01<<i;    P2=0xd0; P2=0x00;//傳位碼
  71.                         P0=dis_buf[i]; P2=0xe0; P2=0x00;//傳段碼
  72.                         keyscan();
  73.                         if(++j==100){j=0;flicker=~flicker;}
  74.                         if(KeySec==0)Cnt2ms++;
  75.                         if(Cnt2ms>=500)//秒
  76.                         {
  77.                                 Cnt2ms=0;
  78.                                 S++;
  79.                                 if(S>=60){S=0;M++;}
  80.                                 if(M>=60){M=0;H++;}
  81.                                 if(H>=24)H=0;
  82.                         }
  83.                         switch(i)
  84.                         {
  85.                                 case 0: dis_buf[0]=smgdata[H/10]; break;
  86.                                 case 1: dis_buf[1]=smgdata[H%10]; break;
  87.                                 case 2: dis_buf[2]=0xbf; break;//"-"
  88.                                 case 3: dis_buf[3]=smgdata[M/10]; break;
  89.                                 case 4: dis_buf[4]=smgdata[M%10]; break;
  90.                                 case 5: dis_buf[5]=0xbf; break;//"-"
  91.                                 case 6: dis_buf[6]=smgdata[S/10]; break;
  92.                                 case 7: dis_buf[7]=smgdata[S%10]; break;
  93.                         }
  94.                         i=++i%8;//循環計數
  95.                         if(KeySec==1 && flicker){dis_buf[0]=dis_buf[1]=0xff;}//時閃爍
  96.                         if(KeySec==2 && flicker){dis_buf[3]=dis_buf[4]=0xff;}//分閃爍
  97.                         if(KeySec==3 && flicker){dis_buf[6]=dis_buf[7]=0xff;}//秒閃爍
  98.                 }
  99.         }
  100. }
  101. void Timer0_Isr(void) interrupt 1
  102. {
  103.         TL0 = 0xCD;                                //設置定時初始值
  104.         TH0 = 0xF8;                                //設置定時初始值
  105.         flag=1;
  106. }
ID:1058641 發表于 2024-2-24 21:50 | 顯示全部樓層
wulin 發表于 2024-2-24 17:30
樓主搞了這么長時間數碼管還搞不定,情何以堪。前面的帖子給你的示例認真看了嗎?這是壇友畫的仿真圖,寫 ...
這是數碼管部分的
unsigned char smgduan[]={
0x80,0x90,0xff,0xc6,0x7c,0x88};
unsigned char segwei[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
void segdis(unsigned char wei,unsigned char duan,unsigned char point)
        P0=0xff;
        P2=P2&0x1f|0xe0;
        P0=segwei[wei];
        P2=P2&0x1f|0xc0;
        P2&=0x1f;
        P0=smgduan[duan];
        if(point)
                P0&=0x7f;
        P2=P2&0x1f|0xe0;
        P2&=0x1f;
ID:213173 發表于 2024-2-25 06:20 | 顯示全部樓層
rtyweq 發表于 2024-2-24 21:50
這是數碼管部分的
P0分時復用通過573驅動數碼管需要分3步:段消影、送位碼、送段碼。以本例硬件條件編寫
  1.         P0=0xff; //P0賦段消影碼
  2.         P2&=0x1f;//清P2高3位
  3.         P2|=0xe0;//傳送消影段碼
  4.         P2&=0x1f;//清P2高3位
  5.         P0=0x01<<i;//P0賦位碼
  6.         P2&=0x1f;//清P2高3位
  7.         P2|=0xd0;//傳送位碼
  8.         P2&=0x1f;//清P2高3位
  9.         P0=dis_buf[i];//P0賦段碼
  10.         P2&=0x1f;//清P2高3位
  11.         P2|=0xe0;//傳送段碼
  12.         P2&=0x1f;//清P2高3位
ID:1058641 發表于 2024-2-25 11:46 | 顯示全部樓層
wulin 發表于 2024-2-25 06:20
        P0=0xff; //P0賦 ...
還是不對勁,我把工程發給你能幫我看看嗎
ID:1058641 發表于 2024-2-25 11:47 | 顯示全部樓層
這是壓縮包
十二.rar
46.38 KB, 下載次數: 9
ID:1109793 發表于 2024-2-25 13:15 | 顯示全部樓層
問一下題外話,我鼠標指針指到文件名上面就出來一個黃顏色提示框,點擊文件名下載,這個框擋住了文件名,點擊也不能下載,是咋回事
ID:1058641 發表于 2024-2-25 14:34 | 顯示全部樓層
球球了,真不知道咋回事了
ID:1058641 發表于 2024-2-25 15:58 | 顯示全部樓層
有沒有哪個大佬能幫我看一下啊
ID:1109793 發表于 2024-2-25 19:47 | 顯示全部樓層
問一下,你這用什么打開?我用keil好像不行啊
ID:1058641 發表于 2024-2-25 20:43 | 顯示全部樓層
就是keil啊keil5
ID:1058641 發表于 2024-2-25 20:44 | 顯示全部樓層
我可以啊
ID:1109793 發表于 2024-2-26 07:23 | 顯示全部樓層
真先進,我剛在這里下載了keil3和proteus,研究了一下,順便問問,proteus能不能導入AD的原理圖?
ID:213173 發表于 2024-2-26 09:45 | 顯示全部樓層
rtyweq 發表于 2024-2-25 11:46
還是不對勁,我把工程發給你能幫我看看嗎
初學階段不要試圖將學習板上的功能模塊在一個工程里都實現。要由簡入深循序漸進。充分掌握各模塊功能后再將各功能模塊組合到一個工程里就是水到渠成的事。
ID:161164 發表于 2024-2-26 09:48 | 顯示全部樓層
還是不對勁,我把工程發給你能幫我看看嗎
如何不對勁?描述一下或錄屏
把仿真檔也上傳
ID:1058641 發表于 2024-2-26 15:14 | 顯示全部樓層
這是proteus的仿真,后面是錄屏
藍橋杯單片機仿真原理圖 (2).rar
39.82 KB, 下載次數: 6
ID:1109793 發表于 2024-2-26 17:44 | 顯示全部樓層
rtyweq 發表于 2024-2-26 15:14
這是proteus的仿真,后面是錄屏
正好我用來學習一下proteus
ID:1109793 發表于 2024-2-26 17:46 | 顯示全部樓層
這是proteus的仿真,后面是錄屏
怎么我在這里下載的proteus還是打不開你的這個文件呢?難道又是版本太低?
ID:1058641 發表于 2024-2-26 19:35 | 顯示全部樓層
xiaobendan001 發表于 2024-2-26 17:46
我是8.10的
ID:1109793 發表于 2024-2-27 08:10 | 顯示全部樓層
我找了一個KEIL5怎么只有ARM的
ID:192020 發表于 2024-2-27 09:52 | 顯示全部樓層
改的小問題,不夠細心
十二_2.rar
52.3 KB, 下載次數: 1
ID:1058641 發表于 2024-2-27 12:25 | 顯示全部樓層
qq475878026 發表于 2024-2-27 09:52
改的小問題,不夠細心
那里的錯唉
ID:1058641 發表于 2024-2-27 21:36 | 顯示全部樓層
改的小問題,不夠細心
那里的問題唉
ID:192020 發表于 2024-2-28 09:07 | 顯示全部樓層
中斷里調用segdis函數的傳參反了
主站蜘蛛池模板: 欧美日韩黄色片 | 亚洲免费在线观看 | 丰满少妇高潮在线观看 | 国产日本在线观看 | 国产成人在线观看免费网站 | 中文字幕三区 | 中文精品一区 | 人人草在线视频 | 日韩成人高清 | 一区视频 | 精品一区av | 精品久久一区二区 | 四虎黄色片 | 欧美综合久久 | 在线播放av网站 | 久久久久国产视频 | 日本精品在线视频 | 女同一区二区三区 | 青青五月天 | 一区二区av | 成人免费视频观看视频 | 亚洲精品在线免费 | 天海翼一区二区 | 久久免费看片 | 黄色大片在线 | www.jiujiu| 成人深夜视频 | www.日本在线 | 国产专区在线播放 | 亚洲天天操 | 在线观看的av网站 | 国产精品一区二区三区四区 | 国内精品一区二区 | 欧美成人三级 | 久久国产一区 | eeuss一区二区三区 | 免费毛片观看 | 欧美精品一区在线 | 国产伦理一区 | 99视频在线精品免费观看2 | 日韩精品免费 |
