查看: 1520|回復: 3
單片機程序(FOSC/1000000)這里的1000000這個數值是哪里來的
ID:849894 發表于 2024-2-27 11:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
        主控MCU:STC15F104W
        開關:INT0(P3.2)                        下降沿觸發
        亮度增加:INT2(P3.4)                下降沿觸發
        亮度減少:INT3(P3.5)                下降沿觸發
        PWM輸出:P3.3
#include <reg51.h>
#include <intrins.h>
//#define FOSC                 24000000L                //晶振頻率
#define FOSC                 6000000L                //晶振頻率
#define MACHINE_CYCLE        (FOSC / 1000000)        //時鐘震蕩6次1μs
#define _1US                1                                //1us
#define _50US                50                                //50us
#define _100US                100                                //100us
#define _150US                150                                //150us
#define _200US                200                                //200us
#define _250US                250                                //250us
sfr INT_CLKO = 0x8f;                //外部中斷與時鐘輸出控制寄存器
sfr AUXR = 0x8e;                    //輔助寄存器
sfr P3M1 = 0xB1;                                        //P3口寄存器
sfr P3M0 = 0xB2;
signed int duty_cycle;                        //占空比,0-10,帶符號
unsigned int init_value;        //定時器初值
unsigned int count;                                //定時器中斷次數
sbit pwm = P3 ^ 3;                                        //PWM輸出口
bit flag;                                                //燈開關狀態
//INT0初始化程序
void init_int0(void)
        INT0 = 1;
        IT0 = 1;                    //設置INT0的中斷類型 (1:僅下降沿 0:上升沿和下降沿)
        EX0 = 1;                    //使能INT0中斷
//INT2初始化程序
void init_int2(void)
        INT_CLKO |= 0x10;               //(EX2 = 1)使能INT2中斷
//INT3初始化程序
void init_int3(void)
        INT_CLKO |= 0x20;               //(EX3 = 1)使能INT3中斷
//初始化計時值
void set_tm0_init_value(unsigned int value) reentrant
        switch(value) {
                case 50:
                        TL0 = (65536 - (_50US * MACHINE_CYCLE)) % 256;
                        TH0 = (65536 - _50US * MACHINE_CYCLE) / 256;
                        break;
                case 100:
                        TL0 = (65536 - _100US * MACHINE_CYCLE) % 256;
                        TH0 = (65536 - _100US * MACHINE_CYCLE) / 256;
                        break;
                case 150:
                        TL0 = (65536 - _150US * MACHINE_CYCLE) % 256;
                        TH0 = (65536 - _150US * MACHINE_CYCLE) / 256;
                        break;
                case 200:
                        TL0 = (65536 - _200US * MACHINE_CYCLE) % 256;
                        TH0 = (65536 - _200US * MACHINE_CYCLE) / 256;
                        break;
                case 250:
                        TL0 = (65536 - _250US * MACHINE_CYCLE) % 256;
                        TH0 = (65536 - _250US * MACHINE_CYCLE) / 256;
                        break;
                default:
                        TL0 = (65536 - value * MACHINE_CYCLE) % 256;
                        TH0 = (65536 - value * MACHINE_CYCLE) / 256;
                        break;
//定時器0初始化程序
        時鐘周期 = 1 / FOSC = 1 / 6 MHz = 1/6us
        機器周期 = 1 * 時鐘周期 = 1/6us        (1T模式)
        定時100us:
        100us = 100 / (1/6) = 600機器周期
void init_timer0(void)
        TMOD = 0x00;                   //設置定時器0為模式0(16位自動重裝載)
        set_tm0_init_value(init_value);
        TR0 = 1;                                //定時器0開始計時
        ET0 = 1;                                //使能定時器0中斷
        頻率 = 1 / 周期
void main(void)
        P3M1 = 0x00;
        P3M0 = 0xFF;
        AUXR |= 0x80;                   //定時器0為1T模式
        duty_cycle = 5;        //初始占空比為50%
        count = 0;
        init_value = 100;        //初始頻率1kHz
        init_int0();
        init_int2();
        init_int3();
        init_timer0();                                        //定時器初始值為0.1ms,初始頻率為 1 / 0.001 = 1000Hz
        flag = 0;
        EA = 1;
        while(1);
//INT0中斷服務程序
void ex_int0() interrupt 0       //INT0中斷入口
        EA = 0;
        flag = !flag;
        if(flag) {                //關燈
                TR0 = 0;
                ET0 = 0;
        } else {
                TR0 = 1;
                ET0 = 1;
        pwm = flag;
        EA = 1;
//INT2中斷服務程序
void ex_int2() interrupt 10       //INT2中斷入口
        EA = 0;
        if(++duty_cycle > 10) {
                duty_cycle = 10;
        INT_CLKO &= 0xEF;           //若需要手動清除中斷標志,可先關閉中斷,此時系統會自動清除內部的中斷標志
        INT_CLKO |= 0x10;           //然后再開中斷即可
        EA = 1;
//INT3中斷服務程序
void ex_int3() interrupt 11       //INT3中斷入口
        EA = 0;
        if(--duty_cycle < 0) {
                duty_cycle = 0;
        INT_CLKO &= 0xDF;               //若需要手動清除中斷標志,可先關閉中斷,此時系統會自動清除內部的中斷標志
        INT_CLKO |= 0x20;               //然后再開中斷即可
        EA = 1;
//定時器0中斷服務程序
void tm0_isr() interrupt 1 using 1
        EA = 0;
        //初始化計時值
        //pwm = !pwm;
        if(++count > 9) {
                count = 0;
        if(count < duty_cycle) {
                pwm = 1;
        } else {
                pwm = 0;
        EA = 1;
ID:1064915 發表于 2024-2-27 16:19 | 只看該作者
1s=1000ms
1ms=1000us
則1s=1000,000us
ID:1110945 發表于 2024-2-27 18:54 | 只看該作者
這兩行定義了時鐘頻率(其數字和實際安裝的晶振頻率對應)和
每微秒的時鐘數,當改換了其它頻率的晶振時,只要改“FOSC”
對應的數字就可以了,而“每微秒的時鐘數”可以自動同時改變,
1秒=1000000微秒,所以要除以這個數。
參與人數 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎勵!
ID:849894 發表于 2024-3-4 20:06 | 只看該作者
謝謝各位的解答。
主站蜘蛛池模板: 国产精品一区在线播放 | 国产福利一区二区 | 久久久中文字幕 | av在线播放网站 | 国产小视频在线观看 | 国产在线一区二区 | 中文字幕2021 | 国产成人免费视频 | 成人黄色大片 | 久久国产成人 | av天天操| 99福利 | 久婷婷 | 久久视频一区二区 | 免费看a级片 | 日韩欧美亚洲 | 日韩视频在线观看免费 | 91久久精品日日躁夜夜躁欧美 | 可以看的毛片 | 一区二区三区中文字幕 | 我要看一级黄色片 | 国产精品网站在线观看 | 久久99精品久久久久久 | 国产免费一级片 | 福利视频免费观看 | 欧美激情国产精品 | 国内精品久久久久久久久 | 欧美在线不卡 | 国产乱码精品一区二区三 | 午夜久久久 | 欧美精品网 | 伊人久久影院 | 国产一级二级 | 日韩在线小视频 | 国产高潮在线观看 | 久久国产99 | 欧美国产精品 | 天天拍天天操 | 日本久久久久久 | 日韩激情一区二区 | 亚洲乱码在线 |
