查看: 1194|回復: 1
51單片機關于EEPROM的讀寫
ID:1111967 發表于 2024-3-2 14:08 | 顯示全部樓層 |閱讀模式
首先我們要知道什么是EEPROM
這里要看自己的單片機EEPROM地址大小和起始地址
主要要用到的寄存器并不多,一個是IAP_CMD(C5H),還有的就是IAP_CONTR(C7H)
然后以下就是通過代碼寫命令到寄存器最后進行數據操作即可
  1. #include "STC15F2kxx.h"
  2. #include "stceeprom.h"
  3. #include <intrins.h>
  4. #include <string.h>
  5. #include  "delay.h"
  6. //關閉IAP功能
  7. void IapIdle()
  8. {
  9.     IAP_CONTR = 0;
  10.     IAP_CMD = 0;
  11.     IAP_TRIG = 0;
  12.     IAP_ADDRH = 0x80;
  13.     IAP_ADDRL = 0;
  14. }
  15. //擦除指定地址的扇區
  16. void IapEraseSector(WORD addr)
  17. {
  18.     IAP_CONTR = ENABLE_IAP;//使能IAP
  19.     IAP_CMD = CMD_ERASE; //擦除命令
  20.     IAP_ADDRL = addr;   //指定地址
  21.     IAP_ADDRH = addr >> 8;
  22.     IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  23.                 _nop_();        //等待
  24.     IAP_TRIG = 0xa5;
  25.     _nop_();
  26.     IapIdle();//關閉IAP功能
  27. }
  28. //往指定地址中寫入一個字節字符數據
  29. void IapWritecChar(WORD addr, BYTE dat)
  30. {
  31.     IAP_CONTR = ENABLE_IAP;  //使能IAP
  32.     IAP_CMD = CMD_PROGRAM;  //寫命令
  33.     IAP_ADDRL = addr;     //指定地址
  34.     IAP_ADDRH = addr >> 8;
  35.     IAP_DATA = dat;
  36.     IAP_TRIG = 0x5a;  //命令觸發器先寫5ah,再寫a5h命令才能生效
  37.           _nop_();
  38.     IAP_TRIG = 0xa5;
  39.     _nop_();
  40.     IapIdle();
  41. }
  42. //往指定地址寫入兩個字節數據
  43. void IapWriteInt(WORD addr,unsigned int dat)
  44. {
  45.         unsigned char i;
  46.         typedef union  //設置共用體,用char分攤2字節
  47.         {
  48.                 unsigned int dat1;
  49.                 char mchar[2];
  50.         }NEW_DATA;
  51.         NEW_DATA data1;
  52.         data1.dat1 = dat;
  53.         IAP_CONTR = ENABLE_IAP; //使能IAP
  54.         IAP_CMD = CMD_PROGRAM;   //寫命令
  55.         for(i = 0; i < 2; i++)
  56.         {
  57.     IAP_ADDRL = addr;    //指定地址
  58.     IAP_ADDRH = addr >> 8;
  59.                 IAP_DATA = data1.mchar[i];
  60.                 IAP_TRIG = 0x5a;  //命令觸發器先寫5ah,再寫a5h命令才能生效
  61.           _nop_();
  62.     IAP_TRIG = 0xa5;
  63.     _nop_();
  64.                 addr++;
  65.         }
  66.          IapIdle();  //關閉IAP功能
  67. }
  68. //往指定地址寫入四個字節數據
  69. void IapWriteI32(WORD addr, unsigned long dat)
  70. {
  71.         unsigned char i;
  72.         typedef union//設置共用體,用char分攤4字節
  73.         {
  74.                 unsigned long dat1;
  75.                 char mchar[4];
  76.         }NEW_DATA;
  77.         NEW_DATA data1;
  78.         data1.dat1 = dat;
  79.
  80.         IAP_CONTR = ENABLE_IAP;  //使能IAP
  81.         IAP_CMD = CMD_PROGRAM;   //寫命令
  82.         for(i = 0; i < 4; i++)
  83.         {
  84.     IAP_ADDRL = addr;   //指定地址
  85.     IAP_ADDRH = addr >> 8;
  86.                 IAP_DATA = data1.mchar[i];
  87.                 IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  88.           _nop_();
  89.     IAP_TRIG = 0xa5;
  90.     _nop_();
  91.                 addr++;
  92.         }
  93.         IapIdle(); //關閉IAP功能
  94. }
  95. /*******************************************************************************
  96. * 函數名  :        Powerlost_data
  97. * 描述    : 斷電中斷數據寫入函數
  98. * 輸入    : addr  地址  dat  寫入數據
  99. * 輸出    : 無
  100. * 返回值  : 無
  101. * 說明    : 為了應對中斷函數與主函數循環使用IapWriteI32函數沖突
  102. *******************************************************************************/
  103. void Powerlost_data(WORD addr ,unsigned long dat)
  104. {
  105.         unsigned char i;
  106.         typedef union//設置共用體,用char分攤4字節
  107.         {
  108.                 unsigned long dat1;
  109.                 char mchar[4];
  110.         }NEW_DATA;
  111.         NEW_DATA data1;
  112.         data1.dat1 = dat;
  113.
  114.         IAP_CONTR = ENABLE_IAP;  //使能IAP
  115.         IAP_CMD = CMD_PROGRAM;   //寫命令
  116.         for(i = 0; i < 4; i++)
  117.         {
  118.     IAP_ADDRL = addr;   //指定地址
  119.     IAP_ADDRH = addr >> 8;
  120.                 IAP_DATA = data1.mchar[i];
  121.                 IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  122.           _nop_();
  123.     IAP_TRIG = 0xa5;
  124.     _nop_();
  125.                 addr++;
  126.         }
  127.         IapIdle(); //關閉IAP功能
  128. }
  129. //往指定起始地址寫入不固定長度的字符串數據
  130. void IapWriteString(WORD addr,BYTE *mString,BYTE n)
  131. {
  132.    unsigned char i;
  133.                 IAP_CONTR = ENABLE_IAP;   //使能IAP
  134.                 IAP_CMD = CMD_PROGRAM;   //寫命令
  135.    for(i=0; i<n ;i++)
  136.          {
  137.                 IAP_ADDRL = addr; //指定地址
  138.                 IAP_ADDRH = addr >> 8;
  139.                 IAP_DATA = mString[i];
  140.                 IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  141.                 _nop_();
  142.                 IAP_TRIG = 0xa5;
  143.                 _nop_();
  144.                 addr++;
  145.           }
  146.          IapIdle();   //關閉IAP功能
  147. }
  148. //向指定地址讀取一個字節的字符數據
  149. char IapReadChar(WORD addr)
  150. {
  151.                 BYTE dat;
  152.     IAP_CONTR = ENABLE_IAP;  //使能IAP
  153.     IAP_CMD = CMD_READ;    //讀命令
  154.     IAP_ADDRL = addr;  //指定地址
  155.     IAP_ADDRH = addr >> 8;
  156.     IAP_TRIG = 0x5a; //命令觸發器先寫5ah,再寫a5h命令才能生效
  157.                 _nop_();
  158.     IAP_TRIG = 0xa5;
  159.     _nop_();
  160.     dat = IAP_DATA;
  161.     IapIdle();  //關閉IAP功能
  162.     return dat;
  163. }
  164. //向指定地址讀取兩個字節的數字數據
  165. unsigned int IapReadInt(WORD addr)
  166. {
  167.         unsigned int dat;
  168.         unsigned char i;
  169.         typedef union        //設置共用體,用char分攤2字節
  170.         {
  171.                 unsigned int dat1;
  172.                 char mchar[2];
  173.         }NEW_DATA;
  174.         NEW_DATA data1;
  175.         IAP_CONTR = ENABLE_IAP;  //使能IAP
  176.         IAP_CMD = CMD_READ;      //讀命令
  177.         for(i = 0; i < 2; i++)
  178.         {
  179.     IAP_ADDRL = (addr + i);  //指定地址
  180.     IAP_ADDRH = ((addr + i) >> 8);
  181.     IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  182.                 _nop_();
  183.     IAP_TRIG = 0xa5;
  184.     _nop_();
  185.     data1.mchar[i]= IAP_DATA;
  186.         }
  187.         IapIdle();   //關閉IAP功能
  188.         dat = data1.dat1;
  189.         return dat;
  190. }
  191. //向指定地址讀取四個字節的數字數據
  192. unsigned long IapReadI32(WORD addr)
  193. {
  194.         unsigned long dat;
  195.         unsigned char i;
  196.         typedef union//設置共用體,用char分攤4字節
  197.         {
  198.                 unsigned long dat1;
  199.                 char mchar[4];
  200.         }NEW_DATA;
  201.         NEW_DATA data1;
  202.         IAP_CONTR = ENABLE_IAP;  //使能IAP
  203.         IAP_CMD = CMD_READ;      //讀命令
  204.
  205.         for(i = 0; i < 4; i++)
  206.         {
  207.     IAP_ADDRL = (addr + i); //指定地址
  208.     IAP_ADDRH = ((addr + i) >> 8);
  209.     IAP_TRIG = 0x5a;  //命令觸發器先寫5ah,再寫a5h命令才能生效
  210.                 _nop_();
  211.     IAP_TRIG = 0xa5;
  212.     _nop_();
  213.     data1.mchar[i] = IAP_DATA;
  214.         }
  215.         IapIdle();//關閉IAP功能
  216.         dat = data1.dat1;
  217.         return dat;
  218. }
  219. //向指定地址讀取不定長度的字符串數據
  220. void IapReadString(WORD addr,BYTE *mString, BYTE n)
  221. {
  222.   unsigned char i;
  223.         memset(mString,0,strlen(mString));
  224.         IAP_CONTR = ENABLE_IAP;   //使能IAP
  225.   IAP_CMD = CMD_READ;      //讀命令
  226.   for(i = 0; i < n; i++)
  227.         {
  228.     IAP_ADDRL = (addr + i);  //指定地址
  229.     IAP_ADDRH = ((addr + i) >> 8);
  230.     IAP_TRIG = 0x5a;   //命令觸發器先寫5ah,再寫a5h命令才能生效
  231.                 _nop_();
  232.     IAP_TRIG = 0xa5;
  233.     _nop_();
  234.     mString[i] = IAP_DATA;
  235.         }
  236.         IapIdle();//關閉IAP功能
  237. }
ID:41656 發表于 2024-3-9 11:49 | 顯示全部樓層
小數據可以這樣寫分開幾個字節幾個字節的寫,不過建議寫數據可以使用一個結構體把數據和校驗數據都寫進去,使用指針,存儲根據結構體數據sizeof結果直接寫入,讀取時通過結構體數據大小一次性讀取并做校驗,我現在數據量小CRC8做校驗,要是數據量大可以考慮CRC16或32
主站蜘蛛池模板: 国产精品aaa | 国产三级在线播放 | 中文字幕在线视频观看 | 黄色激情视频在线观看 | 黄色免费网站视频 | 九色91popny蝌蚪 | 精品国产区一区二 | 欧美大片18 | 欧美精品一级片 | 国产成人黄色 | 色婷婷影院 | 男人的天堂亚洲 | 日本欧美在线 | 4438成人网 | 欧美黑人性猛交 | 四虎色播 | 免费av一区 | 天堂中文av | 国产精品一区二区在线播放 | 黄色一级片免费看 | 国产三级视频在线 | 一边摸一边操 | 亚洲精品一区二三区 | 四虎影库 | 日韩av在线看 | 肉丝美脚视频一区二区 | 亚洲精品视频在线播放 | 美女黄色在线观看 | 久久精品久久久 | 亚洲乱码在线观看 | 色婷婷一区二区三区四区 | 久热久 | 在线免费看黄色 | 精品少妇v888av | 91麻豆精品国产91久久久久久 | 成人黄色免费视频 | 欧美日韩一区在线观看 | 黄色网址在线视频 | 影音先锋在线观看视频 | 国产成人+综合亚洲+天堂 | 日日夜夜干 |
