查看: 1290|回復(fù): 3
單片機直流電機調(diào)速正反轉(zhuǎn)程序如何改為只有正轉(zhuǎn)?
ID:1105344 發(fā)表于 2024-3-3 19:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
哪位大佬可以把里面的正反轉(zhuǎn)改為只有正轉(zhuǎn)啊
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. void displaym();
  5. void displayj();
  6. sbit en=P2^5;                //1602  6管腳
  7. sbit rs=P2^7;         //1602端口        4管腳
  8. sbit rw=P2^6;//lcd1602控制端口 5管腳
  9. sbit num1=P1^0;                                                //占空比加1
  10. sbit num2=P1^1;        //占空比減一
  11. sbit num3=P1^2;        //正傳
  12. sbit num4=P1^3;        //反轉(zhuǎn)
  13. sbit num5=P1^4;                 //開始停止切換
  14. sbit beep=P2^4;
  15. sbit out=P3^4;                                                         //PWM輸出用于正傳
  16. sbit out1=P3^7;                        //PWM輸出用于反轉(zhuǎn)
  17. uint zhuansu,flag,z1,z2,m,flag_1,zheng,fan,kai,j,su,qian,bai,shi,ge;
  18. void delay(uint z)//延時1ms函數(shù)
  19. {
  20. uint x,y;
  21. for(x=0;x<z;x++)
  22.      for(y=0;y<110;y++);
  23. }
  24. void write_com(uchar com)//向1602寫一字節(jié)(控制指令)
  25. {
  26.   rs=0;
  27.   P0=com;
  28.   delay(5);
  29.   en=1;
  30.   delay(10);
  31.   en=0;
  32. }
  33. void write_data(uchar date)//向1602寫一字節(jié)(數(shù)據(jù))
  34. {
  35.   rs=1;
  36.   P0=date;
  37.   delay(5);
  38.   en=1;
  39.   delay(5);
  40.   en=0;
  41. }
  42. void init()//初始化函數(shù)
  43. {
  44.   en=0;
  45.   rw=0;
  46.   write_com(0x38);                                           //5X7顯示
  47.   write_com(0x0c);                         //關(guān)閉光標(biāo)
  48.   write_com(0x01);         //lcd初始化
  49.   TMOD=0x11;               //定時器方式1
  50.   TH0=0xdc;
  51.   TL0=0x00;                //定時器裝入初值
  52.   EA=1;                    //開總中斷
  53.   ET0=1;                   //定時器0開中斷
  54.   TR0=1;
  55.   EX1=1;
  56. IT1=1;                 //定時器啟動
  57. TH1=0xfc;
  58.   TL1=0x66;//定時100us
  59.   ET1=1;                   //定時器1開中斷
  60.   TR1=1;
  61.   write_com(0x80);
  62.   write_data('V');
  63.   write_data(':');
  64.   write_com(0x87);                 //第一行顯示轉(zhuǎn)速
  65. write_data('m');
  66.   write_data('/');
  67.   write_data('m');
  68.         write_data('i');
  69.         write_data('n');
  70.   write_com(0xc0);
  71.   write_data('z');
  72.   write_data('k');
  73.   write_data('b');
  74.   write_data(':');
  75.   displaym();
  76.         write_com(0xc8);
  77.         write_data('s');
  78.         write_data('d');
  79.         write_data(':');
  80.         displayj();
  81. }
  82. void keyscan()  //鍵盤掃描函數(shù)
  83. {
  84.   if(num1==0)
  85.   {
  86.     delay(5);      //消除抖動
  87.          if(num1==0)
  88.          {
  89.                 if(m<=199)
  90.                  m++;
  91.                         displaym();        //設(shè)定占空比加一
  92.      }
  93.   }
  94.   if(num2==0)
  95.   {
  96.     delay(5);
  97.          if(num2==0)
  98.          {
  99.                   if(m>=1)
  100.                 m--;
  101.                         displaym();                                        //設(shè)定占空比減一
  102.
  103.          }
  104.   }
  105.     if(num3==0)
  106.   {
  107.     delay(5);
  108.          if(num3==0)
  109.          {
  110.           j=j+1;
  111.                  displayj();
  112.          }
  113.
  114.   }
  115.       if(num4==0)
  116.   {
  117.     delay(5);
  118.          if(num4==0)
  119.          {
  120.          j=j-1;
  121.                  displayj();
  122.
  123.          }
  124.   }
  125.       if(num5==0)
  126.   {
  127.     delay(5);
  128.          if(num5==0)
  129.          {
  130.          while(num5==0)         ;
  131.           kai=1-kai;
  132.
  133.          }
  134.   }
  135.
  136. }
  137. void display()
  138. {
  139.   write_com(0x82);
  140.   zhuansu=zhuansu*30;          //將兩秒內(nèi)的計數(shù)乘以30得到轉(zhuǎn)每分
  141.
  142.         su=zhuansu*0.01*2*3.14/2;
  143.             qian=(su/1000)%100;
  144.                                                 write_data(qian+0x30);
  145.                                                 bai=(su/100)%10;
  146.                   write_data(bai+0x30);
  147.                                                 shi=(su/10)%10;
  148.                                                 write_data(shi+0x30);
  149.                   write_data('.');
  150.                                                 ge=su%10;
  151.                                                 write_data(ge+0x30);
  152.   write_com(0xd0);
  153. }
  154. void displaym()
  155. {
  156. write_com(0xc4);
  157.    if(m/200%10!=0)
  158.   write_data(m/200%10+0x30);                           //如果占空比百位不為0則顯示百位否則顯示空格
  159.   else
  160.   write_data(' ');
  161.
  162.   if(m/200%10==0&&m/20%10==0)
  163.   write_data(' ');
  164.   else
  165.   write_data(m/20%10+0x30);                                 //如果占空比小于10 十位正常顯示  否則顯示空格
  166.
  167.   write_data(m/2%10+0x30);                                 //顯示個位
  168. }
  169. void displayj()
  170. {
  171. write_com(0xcb);
  172.    if(j/100%10!=0)
  173.   write_data(m/100%10+0x30);
  174.   else
  175.   write_data(' ');
  176.
  177.   if(j/100%10==0&&j/10%10==0)
  178.   write_data(' ');
  179.   else
  180.   write_data(j/10%10+0x30);
  181.
  182.   write_data(j/1%10+0x30);
  183.    write_com(0xd0);
  184. }
  185. void main()
  186. {
  187.     flag_1=0;
  188.         m=100;                                                         //占空比為100
  189.         zhuansu=0;                                           //轉(zhuǎn)速初值0
  190.         flag=0;
  191.         zheng=1;                                  //初始化電機正轉(zhuǎn)動
  192.         fan=0;
  193.     j=67;
  194.     init();              //初始化
  195.         while(1)
  196.         {
  197.         keyscan();                                //鍵盤掃描程序
  198.     if(su>j*10)
  199.                         {
  200.                                 kai=0;
  201.                                 beep=~beep;
  202.                                 delay(500);
  203.                                 kai=1;
  204.                                 m-50;
  205.                         }
  206.
  207.         }
  208. }
  209. void int1()interrupt 2                                //外部中斷1脈沖技術(shù)記錄電機的轉(zhuǎn)速 電機轉(zhuǎn)一圈zhuansu加一
  210. {
  211.   zhuansu++;
  212. }
  213. void int2()interrupt 1                                  //定時器0顯示轉(zhuǎn)速
  214. {
  215.   TH0=0xdc;
  216.   TL0=0x00;//定時10ms
  217.   flag++;
  218.
  219.   if(flag==200)                                   //計時到達(dá)2s
  220.     {
  221.         display();                                        //顯示轉(zhuǎn)速
  222.         zhuansu=0;                                          //轉(zhuǎn)速置0
  223.         flag=0;
  224.         }
  225. }
  226. void int3()interrupt 3                                         //產(chǎn)生PWM
  227. {
  228.
  229.   TH1=0xff;
  230.   TL1=0x00;//定時100us
  231.
  232.           flag_1++;
  233.         if(flag_1>199)
  234.         flag_1=1;
  235.         if(kai==1)                  //如果kai==1電機啟動
  236.         {
  237.         if(zheng==1)                                //電機正轉(zhuǎn)
  238.         {
  239.         if(flag_1<m)                                          //小于占空比m輸出PWM=0輸出電壓為1
  240.      {out=0;
  241.          out1=1;}
  242.          else
  243.          {
  244.            out=1;
  245.            out1=1;
  246.          }
  247.          }
  248.                  if(fan==1)                           //電機反轉(zhuǎn)
  249.         {
  250.         if(flag_1<m)                                //小于占空比m輸出PWM=0輸出電壓為1
  251.           {
  252.             out=1;
  253.                 out1=0;
  254.           }
  255.          else        //大于m輸出PWM=1輸出電壓為0
  256.           {
  257.             out=1;
  258.                 out1=1;
  259.           }
  260.          }
  261.          }
  262.          if(kai==0)                          //kai=0電機停止轉(zhuǎn)動
  263.          {
  264.            out=1;
  265.            out1=1;
  266.
  267.          }
  268.
  269.
  270. }
仿真程序.7z
216.69 KB, 下載次數(shù): 4
ID:453974 發(fā)表于 2024-3-4 11:12 | 只看該作者
兄弟,我看了一下你的仿真,其實最簡單的辦法就是直接把電路上的那個控制反轉(zhuǎn)的那個按鍵干掉
ID:453974 發(fā)表于 2024-3-4 14:17 | 只看該作者
你這程序缺東西吧?管反轉(zhuǎn)的那部分沒有控制變量變化的程序
ID:1105344 發(fā)表于 2024-3-4 15:31 | 只看該作者
累不死的狗 發(fā)表于 2024-3-4 11:12
好像也行
主站蜘蛛池模板: 可以看的毛片 | 欧美日韩亚洲视频 | 亚洲777| 二区三区在线观看 | 国产午夜一区二区三区 | 福利视频网址 | 在线免费av网站 | 亚洲美女一区 | 五月天婷婷影院 | av网站在线免费观看 | 亚洲免费在线观看视频 | 国产一区在线视频 | 国产福利视频在线观看 | 少妇激情视频 | 午夜天堂av | 亚洲一区国产精品 | 亚洲午夜精品一区二区三区 | 国产特黄 | 日韩一区不卡 | 蜜臀久久99精品久久久久宅男 | 成人一区二区在线 | 一级片在线观看视频 | 日产精品久久久一区二区 | 婷婷精品| 日韩欧美视频在线 | 久草网在线 | 日韩大片在线观看 | 欧美性猛交99久久久久99按摩 | 成人福利在线观看 | av网站在线免费观看 | 岛国av在线免费观看 | 欧美在线视频一区二区 | 欧美黄色一区 | 日韩久久综合 | 在线一级片 | 午夜免费毛片 | 97在线观看视频 | 69人人| 亚洲欧美日韩一区 | 欧美成人精品一区二区三区 | 一级片在线观看视频 |
